View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 13" steelies on a 95 EX? Yes? No?
- i smell gas when i turn on my heat....
- Eibach pro kit drop pics?
- how to clear the signal taillight
- Installed my AEM CAI on my 2002 Si!
- How to remove headliner on 96-2000 CX/DX?
- jdm gsr camshaft vs ctr camshaft
- trying to find any EK civics with charcol paint job... post pics pls!~?
- I need some help with this code super fast.
- Custom turbo questions
- b20 questions
- Can't find whats wrong with my car... can anyone help?
- Pin Stripe Removal
- does this abs/lsd sticker come stock on eg civics?
- how to remove bars from underside of trunk door?
- Clutch swap
- The only way to increase tq is turbo?
- Any one order from Jdmhondaparts
- ITR sway bar on a civic
- strut bar question
- 3" exhuast piping..will i lose some typpe of performance?
- Going To Japan!!!
- Does anybody know where i can get Si rear mounts?
- which would win ???
- What A/C system to use for EG hybrid
- so I`m kinda stoked...
- 96 civic wont start**in desperate need of help**
- newbie needs help with overheating civic
- EG2 @ Thunderhill pix
- got banned from CSI!!! LOL,..for my sig..
- first annaul swift BBQ in CT
- ECU pinout Help
- Do I have to run premium?
- question about CTR cams
- Earls Stainless Brake lines question?? for coupe with rear discs!!!!
- how to disengage fuel pump?
- Photochoppers: I want to see what my rims would look like before I do it.
- problems with my idle control valve
- B18B Stock specs
- Helms scanned & posted HERE! 30k service help!! 56k unfriendly!
- Head swap/head work
- I have a ?
- what the hell is this hum
- HELP! I need the part number or location of chin spolier.....
- New here
- Need to buy stock parts from honda need good website.
- For a b16a2, which would be the best upgrade? ITR cams and gears? Or ITR pistons?
- 215/45 17's in pothole city Chicago??? Is that a bright ideal???
- redrilling holes in rims..
- need 1rim...Where to look....
- So Cali Meet & Drive June 2nd
- Recommendation on lips please.
- What is the best for b16a sir II motor? Toda cam spec b? a? or Spoon cam? or anything?
- Need to put this guy in his place- Civic automatic tranny's-6th gen...
- need website address to godspeed
- SI exhaust on my EG?
- Should I trade my car in tomarrow opinions needed
- D16y7 to D16y8 swap..
- Getting there......in a SOHC VTEC!
- MOBWORKS hangout/meet
- Do all 99 Si's come with the rear bumper lip?
- Want recommedation on the strut bar
- Cleanest lookin Sideskirts?
- JDM engines i donno the mileage!?
- your recommendations....
- Horn difficulties
- JDM SIRII = b16a??
- next suspension mod on ej coupe?
- GSR Brake Swap, what parts are needed??
- The ES oval muffler alternative
- what is the diffrence between a 99 dx hatch and a cx hatch???
- help with sidemarkers
- Exedy clutch and flywheel are installed!!! (1st impression)
- battery light on but battery holding charge??
- Pics of the DONE B18C5 Silver CX - Dial-Up BEWARE!
- ATTN: All Solers look here!
- anyone have pics of ssr comps, on a 96-00 civic, preferably 15's?
- Oil Change
- Apex'i turbo on 95 Civic stock motor, MAX boost?
- timing belt for 97 del sol si
- JV look here i got a question!
- o2 sensor 1 wire or 4 wire..already did a search
- Can a car without axles harm the wheel bearings???
- new pics of coupe, and my new project hatch
- Power pulleys.....are they worth it?
- some new toys for the hatchies(pics)
- What shocks last longest on lowered car?
- Where can i get kit for compression!?
- front lips anyone?
- is low 15's in an auto possible?
- H22a1 and a fluidyne with a felxalite fan
- Dyno Days? What ever happened to them?
- Does anyone have the 909 area code post?
- looking for CF LIP?
- T-25 Garret
- Venom Intake manifold!! What do I do about the sensors????????
- shiftlinkage has fallin after racing
- MSD Ignition-Does it really do anything?
- its hottt in the desert
- new guy: O2 sensors 4 wiring diagram
- need wiring diagram for ecu
- compression numbers for civic ex?
- CarFax this VIN please....
- 99-00 Si VS. 02 Si
- Fluidyne Radiator cap.....what size?
- Opinions......B18C1 swap in my coupe or just get a GSR
- Import accessories?
- 99-00 chin spoilers and side skirts
- new car
- New to this
- Update on Spoon Replica Mirrors
- what the hell happened to this civic??!!
- wuts the best setup to get into 14.5?
- problems with my car
- will a 00' si ecu work for a mini-me?
- i need some floormats...you got 'em?
- Carfax please!!!
- Anyone else have this problem with there windows???
- help which tires for 17"
- How do u unlock a thred?
- VX ONLY rear deflector part number / price
- ot? i need a seat belt buckle from a 92-95 civic for sparco install into an integra.
- CALIFORNIA EK sucks!!!!!!
- Does anyone have the Apexi V-AFC in there 99 or 2000 SI
- Installing B18C1
- DOHC non-vtec Civic faster or SOHC vtec civic faster ?
- DOHC non-vtec civic faster or SOHC vtec civic faster ?
- Any Turbo Suggestions anyone?
- What engine is this?
- Frankenstein Project
- vouch for jdmb18c
- reliable forced induction on 2000 civic si
- how do u tell which is which with cams
- ek exhaust question
- I just cannot take this JDM=rice shit anymore
- Should I have my synchros replaced?
- EK Side Skirts
- The drop
- U think its worth it?? 93 Civic Si
- Turbo Question For b18c1 Hatch
- anyone?
- 92 civic Si swap
- autometer air fuel gauge
- clarifying...on a del sol
- si cluster
- Mirror question
- tein suspension. is it good?
- engine help?
- ex armrest in cx?
- DMV & Engine Swap
- Southern CAli meet this weekend?
- 7th gen Civics (2k1-up) Type-R body kit
- 92 Civic Wiring Diagram ?
- jdm b18c swap
- Engine Shudder
- ??"Red" suspension
- HX model
- Drive wheel question
- How Much Boost?
- Going to DYNO, setting suggestions??
- Speedpeople.com
- Help with suspension! messed up!!
- Oil leak....help
- Stubborn Axle
- EK buddy club rear...
- I want the fastest "Si" in town...
- Check engine light from test pipe
- Is an H22A in a civic still classified as JDM ?
- Need pic--
- Is this the LAW? Friend got pulled over for NITROUS!!
- eg seats in a CRX hatch
- B18c or B20BVtec
- hh
- hhh
- Widest wheels and tires possible on a 92-95 hatch????
- what to use for a d16 turbo setup...
- ****Civic in the Czech Republic***
- b20 swap stock 1/4 mile
- IMPORT SHOOT OUt!! carlsbad raceway....whos going
- WTB: 16" Kosei K1 Anthracite Wheels
- Last Try...Anyone in South Bay/So Cal Help Removing V-AFC?
- Do I need apapters to use Koni yellows w/ current Ground Controls?
- OIL coming out of my exhaust!!!
- poll: good idea/ price or no ? ls vtec turbo
- Southern California Salvage Yards
- Secondary butterflies in B18C1 intake manifold ??
- Si Front Lip on a 96-98?
- need a stock CX exhaust in MD area
- thoughts on SOHC cams?
- air walker body kit
- si cluster
- What do you think would look and sound better on an 99 Si?
- Slotted brakes
- skunk2 coilovers vs. H&R race springs
- plans for my hatch
- Who has the best deals on stock clusters with tachs???? JDM or USDM ..i dont care!!
- anyone squeezing on a D15Y7?
- Where are my H22 Guys..................
- TICKET for Reverse indiglo?
- pully kit
- Differences Between 97/98 & 99/00 Hatches
- Chassis noise
- B18C in hatch... is this right?
- WHERE can I find a new front end?...(dilemma inside)
- got a new sponsor!..now what do i do?
- ITR Exhaust on a D15B
- 87 Civic SI
- can anyone refer me to a shop that does a good paint job in socal?
- Motor problems... need help..
- Need some info
- what would...
- how do u protect race seats from fading ?
- Cheapest way to go fast in a EG?
- '99 civic headlights fit '98 civic?
- exaust?
- Rear view mirror placement on EH2 aka "EG"...
- si boost?
- Exhaust Fitment Question
- Tire Exploded on freeway coming home.
- couple newbie questions
- lo jack worth it??
- Is this a good deal?
- is this an ok price?
- RS*R Catback Sound Impressions
- tail lights
- f/s 96-98 chrome clear headlights
- Need photochoppers' help
- FS:Legit Usdm 01-Type R Swap 15,229 miles-Suspension+Wheels with pics
- I DROVE My Car Tonight!!!
- Test pipe or cat?
- Curb weight, FR, R weight, wtf? 96+ civics!!! what are they?
- Del sol seats
- Question about B16A SiR1 First Generation
- old engines and misc parts.
- help identify
- Got my new brakes today
- some serious quetions about doing a ls swap
- Tranny grinds when pushing the car
- Fuel pump with swap?
- exhaust
- Why does DX ECU work on B16A2?
- Hx and ex ecu
- japanese civic side moldings are diferent than US version
- one down
- Wheel Locknut Problem
- help!!! plzz hurry
- Eg's with H22's
- Wreck my ek
- Clutch problems..
- Who Lives in Orang County? post where ya live and what car
