- '95 EX with; what kind of motor is this? B16? B18?!
- 93 Honda Civic hatchback won't start. Please help.
- 95 EX coupe with d16y8 swap - Inspection issues?
- 00 civic Hatchback dx - metal to metal sound
- motor running rich
- TEST PIPE doesnt sound right...?
- 3 Stage D15B Block w/D16Z6 Head Timing Issues
- JDM B18c Type R into EG ?
- looking for bolts
- EM1 Red Line
- Issue with Rear Drum - 93 Civic CX
- 92-95 VX Exhaust Questions
- Intermittent stumbling/hesitation when A/C is on
- 98 Honda Civic Won't Engage into Drive- Need Help and Direction
- switching 1995 honda civic dx door lock.
- Check engine light needs to be fixed?
- 2000 Civic HX P0135 P0141
- Help, car got broken into
- High Idle and misfire codes.
- secondary o2 sensor
- JDM ITR 96 Spec Swapped 98 civic hatchback exhaust help
- 2000 Canadian Si Alarm Question
- What is needed to fit EK4 Auto Climate Control
- 97 Civic HX passenger door lock problem!
- Compression readings - need advice
- 92 civic dx hatch - brakes upgrade question
- 1993 del sol engine swap advice
- Trans. growling noise
- EM1 Brakes fail ONLY when turning left?
- Power options from OBD2b 99 si into OBD2a 97 ek with OBD2b b20 swap
- EK rear disk conversion question
- Ek9 fender
- How did your y7 act when your exhaust manifold cracked ?
- Civic EG steering column holder bar bolts?
- 98 civic lx wont turn sometimes (solved)
- Compression Ratio and Boost
- 1996 Honda Civic EX Crank No Start
- 95 Civic/00 engine swap - Best distributor?
- '00 Civic CX misfire.
- Black specks in coolant
- Honda EPC (Parts Catalog) online
- OBD1 JDM B16A IN 00 EM1 QUESTION...
- Ball joint safety question
- '98 Honda Civic. New Project!
- oversized valve length???!!?!
- 93 del Sol mod.
- what is the correct idle for 97 civic
- Ek coupe cant stop overheating!please help
- B16 motor / DC2 JDM B18C Type R 5spd LSD 98+ Trans
- Civic EK4 Dimmer Switch Question
- Help me identify this wheel lock
- 99 Civic RPM
- 94 civic won't start.
- Rough spots when turning rear wheel by hand
- 99 civic IACV
- Are EDM Del sol Headlights all glass?
- 98 civic dx - Possible ignition
- my E3 plugs after 3000 miles
- new flywheel binding with starter?
- 7th gen and 6th gen same bolt pattern rims?
- 99 Civic Si/GSR swap - New Distributor - Car won't start
- 3 Occuring Problems! :(
- What bearings for z6 crank in a y8 block?
- Mystery: AM/FM Radio doesn't work when I charge phone
- Does anybody know what kind of shocks these are?
- Intermittent Windshield Wipers - 95 VX
- What is an EG?
- Seatbelt chime, airbag question 95 civic
- td42u dizzy with an unchipped P06
- 1999 civic d16y8 p0505 ideas
- 96 ballade - suspension drop and engine swap questions
- Civic engine rattling when accelerating and during throttle blip
- Knocking/Banging sound in passenger wheel well.
- Want more power in a d16z6 what should i do?
- Z6 Edelbrock Intake Manifold On Y8?
- 95 civic question about cluster/speedo
- Lower Control Arm Help
- Help-gas needle doesn't work
- Exhaust Pipe
- Throttle Body Help
- Manual rack conversion and upgrade questions.
- 96'-00' Civic subframe vs. Integra subframe weight
- Help - Timing belt rubbing
- 99 civic intake fail
- Clutch pedal drops to floor
- Camshaft has play
- Coupe or Hatchback Fuel Tank
- D16a8 help
- No crank no power battery good.
- Manifold Gasket
- 1992 1.5L EGR
- Please help - 97 Civic wont start
- 97 Civic lx with b16a2 with ECT problem.
- eg coupe doors will fit on an eg hatch?
- Failed CA Smog - 1992 CX - High 25 NOX
- 1995 Honda Civic Hatchback VX Gas Mileage Question
- koni/gc oem dust cover
- Should I tear up my car to get to floor harness to fix window? (Nubie)
- Transmission bolt question
- Help needed asap drum brake issue
- EJ fuel vent
- Hood Release Cable Stuck - 96 Civic
- D16z6 smoke piston rings?
- 2000 Civic Head Specifications
- 97 cx misfire help
- Can't remove spark plug wires, stuck on head.
- Checking ATF Level
- Engine
- 92 Civic (Will not downshift into 2nd gear)
- 95 del sol timing belt job
- 1995 Honda Civic EX with Engine swapped out
- Bleeding after ABS pump/modulator replacement - 1994 civic SI
- need p28 chipped for stock d16Y8 manual....
- 1994 Civic cooling system issues
- Remove Stock Alarm?
- D4 Wire Needs Ground Out
- What would you do?
- 99 civic ex intermittent starting problem
- d16y7 swap problems please help
- Prop Valve and Brake Line HELP
- HELP 98 ex codes 138 and 136
- d15b timing belt skipped!!!!! 😖
- intake/exhaust manifold decision
- D16Y7 and P2P ECU problem
- Battery Light Stays on When Car Off & Closed
- OBD2B swap in OBD2A car
- Starter will not disengage after starting
- bogging down low rpms
- d16b?
- OBD2B to OBD2A IACV
- 93 ex interior lights
- no combustion in cylinder 3
- EJ6 power windows and locks
- Quick Release Horn Set up [DEL SOL]
- 2000 EM1 Ignition Issues
- 2000 civic ex
- 99 Civic Si Brake Problem?
- EM1 exhaust problem
- need help asap :(
- fuel pump doesnt prime
- 97 EJ LsVtec with GsR automatic trans
- Speedometer working sporatically? (Now not at all)(Solved)
- crank no start main relay clicking
- matching sway bars with spring rates?
- STAR Smogging my Bseries EJ Hatch
- Hissing Sound when Brakes are applied
- Ok I give up- 2000 Civic Si no start... wtf?!
- B20b swap , throttle body port question
- Help! Sputtering randomly on acceleration
- Civic is randomly cutting off
- D16Y7 to a 94 del Sol
- !!Start of a New Build!! 96 Hatch
- EM1 headliner
- someone please help d16y8 issue!
- 93 Honda Civic hatch intermittent shut off
- Ignition control module: need aftermarket suggestions
- honda civic ej9 2000 not starting injectors not firing
- Anybody ever done rsx type s cluster into 00 Civic,!?!?
- honda civic 1998 back bumper damage
- Y7 into 93 civic body mount help!!
- 00 Civic d16y7 turbo build advice?
- 93 Del Sol - Can power window control module be tested?
- 2000 civic ex not starting
- jdm ek9 parkpole wire it up ?
- D16y8 benefit from chipped tune?
- 1995 Honda Civic Fog lights
- D16y7 swap into 93 civic
- What parts can I use from a 98 civic Ex on a 93 DX hatch.
- Noob advice for recently purchased Del sol?
- Low idle car won't warm up.
- My brakes make a noise while driving what could it be?
- Cable bonnet
- Honda Del Sol Interior
- Help Finding suspension noise.
- 95 civic cruise control issue
- Voltage Surge (18V!!!) when Engine bay is hot and A/C is on
- 98 civic sedan with zc sohc swap
- Need a 99-00 civic SI em1 engine harness diagram. Yes I searched /googled can't find
- ABS Modulator is leaking - Civic Hacthback VTi 95 (similar to SiR II)
- transmission fun times
- Rear Disc Brake Caliper Bracket Help!
- Idle speed dips and then catches up...
- 95 Civic Del Sol motor mount
- 99 EM1 Si Questions
- Fusebox electrical question
- Air System Installation / DelSol
- Vehicle Repair Kit for Long Road Trips - Most Common Items to Fail
- CV Axle Throwing Grease without Ripped Boot?
- 1999 Civic Si Header?
- 1999 Civic Si Stalling (kinda) Problem
- 1996 Civic EX oil leak
- Oil pressure help
- B18C or B16? LS-V?
- B-16 swap into EG ( question on cable and hydro clutch cables?????
- Question on rear brakes
- Need to know what honda model bearing being installed in my Honda PH16 ESI block
- d16y8 issue
- 97 civic hard steering after ball joint replacement
- Help! Keyless entry and dome light.
- Will Integra door speaker shrouds fit in a civic?
- Starting from scratch!
- skunk2 dual bend shifter + energy suspension shifter bushings issue
- 94 civic ex - high idle problem
- Which cold air intake?
- d16z6 o2 sensor.
- D16Z6 BUILD HELP
- Need Help Crank No Start
- D16y8 to Y7 downgrade problems.
- 96 civic no start limited tools
- 92-95 3 Door Si - Door Lock(s) information request.
- New civic steady flashing CEL.
- JDM B16 automatic in 2000 Civic
- Did a search - Cylinder #1 at TDC - Distributor pointed at #4
- 1999 Honda Civic Lx (Mini me swap)
- Rear JDM emblem fitment
- Del Sol Hood adjustment
- 93 LX D15B7 Civic -- Throttle/Trans linkage/low power
- Civic model - A foreign owner challenge!?
- Power windows/sunroof/windshield Wipers stopped working 95 civic coupe
- front end rattle
- 1992 honda civic, trying to turn off airbag light
- 2000 Civic EX overheating
- Exhuast/O2 Sensor Issuse 2000 Civic EX
- OBD port fuse?
- 2000 Honda Civic DX Sedan question
- 2000 Civic D16y8 ECU
- b20 swap crank pulley question
- 2000 Honda Civic clutch won't engage
- b18c swapped ek hard to start!?!?
- What Should I Use On This Steering Wheel?
- Honda Civic circa 2003 5 speed transmission HELP
- Civic 98 Continous undetectable knocking sound while braking from rear brake shoes
- D16z6 Alternator Belt
- Gsr swap in to eg hatch
- Need quick answer bypassing heater core on B20b EG!
- b20 swap cant what iacv for ls intake
- Intake manifold Fitment
- Right hand drive civic, needing a few parts
- Crank pulley came loose..
- catalytic converter on 2000 civic
- Decat and O2 sensor?
- The never ending Low Idle Issue
- 96 Honda Civic EX speaker issues.
- Eg rearquarter panel weird gap
- Speedometer issues
- my car cannot start civic 1992
- 1997 honda civic coupe EX (EJ8) alarm issues
- My Honda got stolen, then recovered
- 94 civic stolen in Tacoma
- Really loud muffler kit for 92 cx?
