View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Oil Pan Replacement on B16A2
- Is this part the fender bolt?
- NEED HELP NOW!~!! FACTORY B16 transmission fluid change HELP~~
- I need help with b16
- BURN ME IF YOU WANT BUT IM GUNNA STILL ASK
- cant see at night...headlights
- mugen axle hitting swaybar link. bad? are there any kind of sway bars that doesnt stick out like thi
- Can Anyone Help me with this?
- gsr rear sway bar on 96-00 civic. need aftermarket lca?
- EK rear camber kit on an EG?
- would full-race traction bar clear?
- 96 \
- 96 hatch swap questions
- cams
- is mugen twinloop suppose to be louder than the apexi ws2?
- What causes OVERHEATING?
- HELP!!!!!! Lights dimming Crazy on every STart, 97 Civic
- Yet another IDLE + other problems
- srs steering wheel removal? *searched*
- 96-98 CTR climate control help
- Brake job
- 0bd2 civic with obd1 b16 swap problem
- exhaust leaking??
- **Blown Head Gasket or NO**
- Help removing grill
- need VSM fenders!!!
- EVOTION *)()()()()()(* Good or Bad???
- HKS Hi power plus generic header?
- Question about cam gear on ek hatch...
- 99-00 Civic Fogs..Suggestions??
- Problems starting the car.
- What's Causing this Engine Noise???
- gas mileage
- Thumping From Front
- Weird...
- distributor question
- hp rating on jdm sohc vtec zc...??
- CEL code 41. looking for help.
- distributor wiring request
- B16 Head removal
- Bad tie-rod joint, what will it do?
- VALVE SEALS
- CEL with missing link??
- HELP!!!!!!!!!!!!!!!! Axles 95 honda civic ex PLease ASAP
- s2000 steering wheel question
- ball joints and poly bushings, what do you know about them????????????
- Question About Headlights of Delsol
- need quick info about rear shocks
- sh!t!!! stripped bolt on header!!!ahh how do i get off......
- Odd Leak...Odd Location d16z6
- Quick question??
- I Got My Car Back!
- 00siEm1 suspension
- low mpg after oil change?
- Can someone who is good with all the coolant lines/sensors on b series motors help me out a litle bi
- Were to find fat fives?
- which is better..
- TPS Adjustment
- PERFORMANCE HELP
- Rsx cluster in a 92-95 civic hatch
- I HAVE A 95 CIVIC 4DR 1.5 . REPLACED THERMOSTAT, STILL OVERHEATS , ANY IDEAS
- Surging Idle 1999 Civic
- quick couple of questions about warped heads
- What size are these pistons - OVERSIZED OR STOCK? Pictures to show
- ball joint
- HELP..Pager Alarm installation question
- Crank, no start
- Ek stock spoiler??
- Gsr build
- 00 civic ideas
- throttle body help
- Problem After Wire Tuck. Car doesn't start. Solid CEL?
- Need help with placing location of ballasts for PnP Hids?
- i need help with my civic
- Strut Bar Question?
- Lower ball joint question- pressed in or hammered in
- exhaust fitment
- hardware...in socal
- bent tip on spark plug
- loose rearview mirror - fixes?
- e brake question need help quick
- S2K Steering wheel in EG
- Valve clatter when cold a sign of timing belt wear?
- EK Header Question
- Failed NJ emissions help
- 92 dx sedan fix it and DD it?
- CTR headlights VS SIR headlights
- 96 Civic Rear Passenger Door Bent In
- D15B swap
- Hamp filter vs OEM filter vs S2000 filter
- EK M/C upgrade
- Rear disc brake swap identification
- GSR into an EK CHASSIS SWAP LIST
- Do i need an o2 sensor with hondata s100?
- Distributor for d16y7 head
- would this work
- 93 integra seat, 98 civic coupe
- d16
- What kind of harness does 1996 civic hatch dx's use?
- Lack of Power in certain RPM...
- if you havent done it dont reply to this: b16a block b18 crank oem stroker kit?
- Electrical Issue?
- Are none of these plugs to pull CEL? YES, I saw the FAQ
- EK engine swap
- PCT (ctr ecu) vtec engagement...what is it supposed to be???
- Anyone ever heard of Silkroad?
- b16 sirII tunning
- "Wont start"
- my car is pulling!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- upgrades for my motor....
- Is there a difference between JDM and USDM EG tail lights?
- ITB
- 99 SI sturt bar, front/rear lower tie bar will bolt on 99 ex?
- Energy Bushing Confusion
- what compression would this be "pixs inside"
- need help quick TPS remove pics
- 7/94 Production Date, what year?
- estimated power gains...?
- is my tranny dead?
- i am too lazy to post in the classifieds
- turbotenics trubo kit.....
- ctr headlights pics
- oem key
- y Need info on Bar'd Civic Hatchback
- need some help with some insurance issues mileage wise
- help need ifo on ls/vtec swap
- Mugen strut tower bar install.....?
- civic speaker install
- oem lower balljoint no circlip?
- having trouble with gsr swap
- b18 type r head leaking
- Will they fit?
- Steering rack boots
- 92 rear brake confirmation
- How to install aftermarket tach in my ek
- 92 Civic CX Hatch with GSR swap NY
- Brakes help:teg calipers...
- Typical "Car won't start" question.
- Lacking power after plug change
- instaling a radio in honda 96 civic
- hatchback brake question
- searched. squeaking brake
- **QUESTION?! JDM WINDOW VISOR..... VOLK WHEELS... HELP
- Which Intake This Year?
- RHD Clip
- O2 Sensor
- An old Post...
- SI COMPLETE
- hey, HID QUESTION
- WTB..92-95 hb rear trim qt panels..
- need help with type r rears in my eg
- SOMETHING VERY IMPORTANT SNAPPED please help!!!
- quick question....
- What can I do to save gas?
- Good Decent price exhaust setup?
- front tower strut bar
- swap help
- backup light sensor plug??
- civic hatch accelerating problem....please help....
- question
- Secondary o2 Help GSR swap!
- How do I test my Radiator fan & How do I connect a fan switch?
- wtb: a d16y8 vtec solonoid in jacksonville will pay $80
- Honda Challenge roll cage blue print?!?!
- K20Z3 Swap
- help! brake pad flush on rotor
- what kind of sensor is this?
- smal oil leak
- intercooler hiding
- WTF is my Idle doing!??!
- ***Suspension help!
- NEW to the Honda Scene
- 99 civic si window problem
- what are TT rods?
- What is this part of the headlight called???
- any ever remove an altornator from the top?
- need help with vtec
- New tranny, new MTF?
- Do eg power mirrors need a relay
- need help with mini-me
- 99-00 mirror replacement??
- remote oil cooler/filter install question
- quick question on how to drive with messed up synchros
- Smoking issues
- short throw shifter?
- CEL 94 honda civic ex
- are all ex models vtec?
- Better For Looks/Preformance....Tein s tech or h&r sport springs!
- oil capacity quick answer please
- my car stops accelerating while moving HELP ASAP
- How to Fix "Safe Mode" in 92 hatch w/b18b engine, trans, ecu,
- Lagging Turn Signal
- How fast?
- H371 H370 H374 bulb whats the difference???? 168 / 194 city light application
- DA-EG
- sometime my drivers side headlight doesnt turn on
- Injector Question
- HONDA EK4 SWAP DONE BY DOHC GARAGE.
- Facelifting an EK? 96-98 to 98-00 bumpers etc
- GC + Koni Yellow Settings
- valve clearance?
- JUST BOUGHT AN SI!! Now need advice with set up! =]
- b16a1 EF distributor, box and harness to EG stuff.?.?.
- WHAT ENGINE SHOULD I GET
- skunk 2 Intake manifold?
- Identify some cams & head (already searched & looked at pics)
- help with my auto tranny
- b16 ob2 swap problem
- How to install EK Clock
- low RPM knock
- D series ?'s
- Official Ek pics
- 99-00 EBP SI w/ Cali plates in Upsate New York
- My radio doesnt work
- 99 Civic EX Power Window problem
- i need to know voltage power pin of B16a ECU
- new lug nut studs??
- new exhaust
- Why you shouldn't buy cheap wheels
- Eg Rad Support Question
- STOCK B20VTEC MAINTENANCE
- My EM1 runs funny....
- gsr rebuild itr internals
- question about a wire plug coming out of the firewall
- HELP!! 98 EK COUPE AUTO. NEED TO SWAP TO MANUAL!! PLEASE READ
- fuel pressure gauge install?
- Speedometer help
- Engine howling noise question
- b18 eg
- WANTED: Honda Del Sol in Ontario
- performerX IM on a Y7 motor
- Looking for engine builders in the San Diego area
- Strong vibration on driver side
- H22 head on F22 block
- what kind of intake manifold to get????
- Wire harness for b20b swap.....
- Wrecked my civic what should I do?
- Part # Request: 2000 Si 12V Main Relay
- baltimore md STOLEN followed and found
- any ideas?
- USDM OBD2 diagnostic port? Can you add it?
- Looking to buy a 92 - 95 civic.. anything I should look out for?
- Runing d16y7 instead of d16y8?
- i have a request from those that have obd2 injectors on their car. D\B series.
- intake manifold question!
- obd2 plug? hondas from MEXICO??
- Problem With Car
- Y8 HEAD Crower camshaft, new Cam Gear???
- Best place to buy bolts (fender, shifter, exhaust heat shield, etc)?
- Carbon canisters, swaps, and vaccum leaks, oh my!
