View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Problems starting
- bought a hatch! yay!
- first time at the drag strip
- Other cars that share the same Brakes Pads and Rotors as a 97 DelSol Si
- HID eg
- i know a noob question !
- how du u clean headlights???
- ep3 seats in eg.....
- B16 Swap Problems
- strut fork swapping madness.
- ecu
- 92 EX Guage Cluster in an EJ 94 DX
- 2000 civic hatchback spring for 2000 civic coupe?
- Bumper Question
- help, driver side headlight and high beams dont work? whats wrong
- k20 head on a b20 block?
- D series REMOVAL
- N00b help....yes i searched..
- Steering wheel sticks..
- Help! car problem...!!!
- Center console fitment question
- FS:MINT!!!!! 99-00 civic si wheels
- Torn between K and B...
- will p30 run lsvtec temp?
- 2005 EL dash into a Ek??
- Fuel gauge prob
- door help...
- Transmission Help....need answers ASAP
- Trunk leak (not from taillight gasket)
- I swapped a GSR into my hatch and the car struggles to reach 8k rpm's, throwing code 3 map sensor
- will cable tranny work?
- OEM fog lights-blowing fuse.
- d16z6 ticking question
- 99 hatch power window?
- tranny install giving me a headache
- connector for hose
- OEM dc2r exhaust fit eh2??
- ever herd of.....
- LINKAGE need Info
- broke a lug off trying to change my brakes. ARG!
- day time running light problem
- Lsd differenciel viscous
- no intake
- i need some help please.. i did search....
- where to weld o2 sensor bung onto header?
- Megan header Badging
- super street project civic si??
- Engine hits firewall when i accelerate/decelerate fast.
- quick question about tranny mount...
- how hard is it to swap a b16 and tranny into a 96-00 hatch
- What kind of short shifter should i get?
- Help on installing POWER Spoon replica mirrors
- taillights, dash, shifter lights
- keep it or upgrade????
- power mirror switch and climate controls stopped working
- I'm looking for a motor for my 92 honda civic
- turbo exhaust manifold, will it fit? d series
- d16y8 oil pressure sensor location
- JDM P75 Equivalent?
- need alittle help with an air/fuel ratio guage
- supercharge d16?
- EK conversion..
- harness help
- D15B Upgrades?
- acura rdx turbo engine into civics?
- N/A B18 Build
- d16y7 into eg
- 99 civic hatchback for sale or willing to trade
- got a question tried everything and arleady searched
- Going from LS/Vtec to LS/Non-Vtec questions.
- Fuel pump in del sol?
- head studs on d16z6
- Fluctuating Idle
- Just bought 93Del sol
- New Headlight bulbs
- quick question
- I'M TIRED OF MESSING AROUND....IF YOU HAD $1,500 HOW WOULD YOU SPEND!
- transmission squeal when down shifting
- code 505
- RHD eg cabin harness in LHD eg
- KAMAKAZE HEADER.....PLEASE REVIEW
- Swap info... and copule of engine que's?
- knock sensor CEL is on, replace ecu replace knock sensor and the CEL is still lighted up!!!!!!!!!!!!
- vafc help!!!
- Shif Linkage Removal
- just did the swap. few ?s and it is running rough
- rsx seats in eg???
- need quick help....stock rails from ej1 fit on 99 si front seats
- gauge lights actin funny..
- 93 SI keeps overheating
- LSD question
- Clutch alignment??? Tool question...
- Corbeau the cheapest?
- Water leak help.
- what are the symtoms of a clutch m/c?
- Did 97 civic hatch ever came with Power Steering?
- Where to buy 2 96 JDM ITR Rims
- Air-conditioning problem
- help with oil
- Gear Question
- QUESTION? 92-95 CIVIC TOW HOOKS?
- 2000 Si EM1 Rear Seats into 1996 Civic Coupe
- autopartswarehouse.com do not buy
- gsr delsol CEL???
- Integra fuel filter onto EG
- Steering wheel twitches violentley :(
- 98 Civic Hatch ECU....
- quick Q what brake lines for EK w/integra fronts
- What do I need to fill the ls block..?
- Ecu has Rev limit set to 6700-6800 Around there, but below 7000
- passing bar question
- 94 Civic Si Driveshaft
- Can't Feel VTEC
- h22 HotSHot header for hybrid swap.
- radiator questions
- Map Sensor
- OEM power lock actuator for 98-00 EK hatch lock?
- Where can I find a civic grill without any stupid mesh or billet?
- Is my Exhaust too loud?
- Megan racing drift spec exhuast on a EG hatch
- Check Engine Light is on 99 CX, how to check it????
- Aftermarket Radiator Mishimoto & hoses
- how many teeth?????????
- whats cause your a/c to not be cold
- shift linkage
- CARJACKED...........i fought back and won
- Short shifter
- Oil Smell Coming from Car
- zc block z6 head
- battery keeps dieing'
- door sill
- quick question
- itr seats and steering wheel in del sol
- Power window problems on a 00 hatch
- k20 swap in del sol
- EG auto-5spd tranny mount different?
- jdm transmission question
- NEED BEAKS SRK INSTRUCTIONS
- Startproblem when hot (HONDA CIVIC 1500 EG435NP -92)
- Power window+locks conversion for an EK
- obd-2 ecu or obd-1 ecu for my engine
- What is everyones opinion on the D16z6 engine?
- type R seats
- Stock Exhaust Price?
- DX SI catback fit CX?
- electrical problem....HELP!!
- How Much could i sell a complete A.C system for..
- water injection
- help what is manufacturer code p1337? off a 98 dx hatch with d15 swap.
- Where in Dallas......
- c.v. boots torn?
- where to buy breather hose/plastic piece?
- EG 4DR to 2/3DR Front End Swap
- will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
- Stiff motor mounts.
- TIRES
- i need sum help with my honda
- sohc v tec head needed for 93 del sol
- sohc v tec needed for 93 del sol
- EGR valve
- exhaust fitment
- Can someone tell me in which vehicle did the JDM ZC DOHC come in????
- need help with boost controller
- Del Sol axle back OEM muffler closely fit 99 hatch?
- Which engine swap is best to beat LS1 engines?
- Manual tranmission fluid
- ecu
- what ecu to run?
- VTEC not engaging?
- WTB: Jdm Recaro's
- recharge a/c, how many cans of r134?
- Clutch? is this clutch right??
- EG Hatch canister
- no VTEC, help please!!
- Question on Jdm type R rims.
- Question: rev limit low, CEL , car feels sluggish sometimes, serious help please
- New Custom Exhaust?
- frozen bolt help (suspension fork upper bolt)
- which Integra Shift linkage
- tryning to get my 96 civic ex to 16 flats help pleasee.....
- GSR muffler..
- B18b1 into EG Hatch ECU
- dx egine harness
- battery voltage
- JDM SOHC SWAP QUES
- I NEEEED SOME TIMING HELP ASAP!
- A/C Stops working when car is in motion?
- shift from 1 to 2 --> jerk
- A/C Dead
- K20 refd.....
- what is the sensor that installs into the upper portion of the air intake??????
- White Smoke fun...
- 94 civ ex been sitting for 6 months - been troubleshooting but need help.
- help with posting pics of my hatch
- BUY A B SERIES MOTOR OR JUST GO TURBO ON MY D16?
- Identifying an LSD
- blown b series?
- i need jdm parts
- Bra for 96-98 civic with lip
- Swapping drum to disk brakes in a 93 Honda civic Ex 1.6
- will msd wires help
- 94 civic hatch mud flaps
- 92 civic won't restart when warm. Like your help.
- Really soft clutch pedal after clutch & slave cylinder change
- 3rd brake light (safety inspection)
- driver side wheel play when jacked up...
- a/c blower help/
- beep?
- Air Conditioning does not work when idling, hot in SOCal Help
- Engine Torque Damper
- Will a supercharger for a 99 Civic Ex fit on a 98 Civic LX?
- Painting Steelies
- 99 cvic cx hatchback for sale savage needs body work
- JDM engine swap in civic
- Head plug cause Head Gasket failure???!?!?!....
- Willem EPROM Programmer
- Will someone with a 95 civic DX get me a pic of their fuse block? HELP!!!
- weird squeaky noise
- vss problem [already searched]
- quick question on wiring up a 4 wire o2 sensor in a 92 cx
- Realtime feedback via laptop possible?
- NEED HELP WITH DISTRIBUTOR QUESTION. PLEASE!
- D16 build-need advise on best parts to use!
- Where do i get a front license plate relocator?
- How Long Before your ISB Went out??
- Car won't go in reverse ?
- NEWB QUESTION.....What cat. would i use if i did a 2.5 collector mod.
- Please HELP! VTEC wire issues
- where to get carbon fiber targa for delsol
- Cynlinder 1 misfiring!!!
- GOOD SS HEADER 4-1 FOR UNDER $350
- Crank pulley off
- Trying to read codes
- AZ: parts for sale,gauges, sway bar, bodykit....
- Can i use a 2002 civic cd player in my 93 civic????
- b16, d-series compressor, crv bracket, which tensioner?
- B18b1 into EG Hatch, fast answer please
- 95 civic headlight Help!
- Need a question answered. please help!
- maby a dum qustion
- Honda Tech Marketplace ERROR
- Is it ok to plug/loop these holes up?
- b18 swap turbo, doesnt make sense
- gauge recomendations
- gsr block with b16 head with buddy club stage 3 cams.. what would be good competition for this engin
- How long am I a trial user????????????????
- D16Y8 intake manifold looks like Z6 IM??!
- Help a newb
- my "FU!! CAR PROBLEMS" list
- Corvette Owner stereotype
