View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16Z6 problems please help!!
- what is the diameter
- Can't get my Fuel pressure down, HELP!
- Can someone run a carfax report for me? (non-honda)
- b16 tranny or b18 tranny
- Still a work in progress, but here's my hatch w/pics
- just bought an ek need help
- b20 v-tec gasket problem
- Del sols outside door handle was actting wierd now it wont work
- car has a mis after rebuild. (searched)
- Exhaust mani onto head
- I need help car keeps dropping vtec
- I need help with finding what trans I have....
- New to Del Sols, quick question
- Do i have stock brakes or GSR Brakes?
- check engine light
- front upper control arm civic 2000
- p1298 code in 99 lx
- ok so
- Honda Civic O2 Sesnor probloem
- First time civic owner- P0420 with background on car...
- Fog Light Bulb Replacement
- Honda-Tech stickers?
- SUSPENSION/SWAY BARS
- Idle adjustment? proper how to?
- integra cluster swap ~ speedo lag?
- Help/ Question
- eg bigger front disc conversion
- Need Help: Severe rattling after replacing Valve Cover Gasket...
- imort alliance
- jdm del sol gauge for sell
- loose shifter
- Car is running very hot HELP
- i need this part number please!
- Air Intake sludge/slim/boogers/gunk/buildup?
- MPG adjustment over 60mph?
- gsr sway bars on ek
- Metal Flexing sometimes clicking sound after dropping my EK...help
- throw out bearing?
- RMP gauge jumps randomly during driving???
- proportioning valve questionaire
- Some A/C expertise requested...
- B18c1 killing me
- B20 in ek coupe
- First real post for suggestions
- What e-brake lines for DA rear disk swap?
- 94 Civic Ex Question
- Engine Compartment bolts
- NEED HELPPP for something stupid
- Help annoying noise comin from rear window!
- Z6 backfireing after Cranking
- for sale or trade
- b18c1 smoking after high rev's
- Transmission Grinding Into 4th
- Emmisions trouble???
- JDM b18c dizzy wiring.
- jdm B18c fuel pressure
- Stock integra LS injectors work with b16 basemap no start up?
- Questions on a Kswap harness
- 94 GSR front aND rear disc onto ek?
- Loose shifter
- ek needs help.. battery/ alternator/ wiring problem????
- Lowercontrolarm help, please
- most stolen vehicles.. give it up for the civic ...
- removing stock steering wheel
- ek needs help!!! alternator problems
- 92 Civic LX lower alternator bolt
- stock engine no good, what to replace it with
- Do JDM ITR Rear Seats Fit???
- Cylinder head????
- What is wrong with my car? Help PLZ
- intermittent lack of power
- HELP: TIMING BELT SLIPS
- rpms jump around
- gsr ek wire harness help?
- Code 8 TDC sensor + Code 22 Vtec Pressure help
- Better Fitment? VIS or Seibon Rear Wing for EG6?
- OMni power coilovers
- rear disc kits
- Does anybody have a How-to on how to install gauge cluster needles?
- please help me find
- OEM 92-95 Fog lights ___ USDM ???
- Where's Waldo? (O2 Sensor) HELP!!!
- mounting OEM front lip
- Intermittent rev drop and stall while stationary (B16A2)
- AUTO-2-MANUAL TECH HELP!!
- 1996 civic si electrical problem
- Identify Wheels Honda OEM
- FAILED STATE REFEREE
- bigger brake conversion help! =(
- Hi from Italy ;)
- ****will these wheels fit??****
- Question about dash illumination
- springs please help
- B16 TypeR, GSR, Or ITR
- mini me turbo swap!!!! help!!!!
- Fuse for radio?
- LSD TRANNY ON LS MOTOR
- Problem with a bumper
- core support question
- Test Pipe for 99 EM1
- Help need answer soon, 96-00 civic rear bumper fit 98 Acura EL?
- left the honda scene :(
- Brake question
- how to remove the center panel from the dashboard on a 96-2000 civic???
- interior for my si hatch
- Can't put it my b16 tranny in 3rd or 5th
- oil leak on d16z6 -- cam seal, crank seal, or oil pan gasket?
- searched. swap question
- HORSE POWER FOR LESS
- B16 transmission question
- funny noise
- 12v source for electronics
- contemplating
- Help(PLEASE) gsr swapped ek
- chipped p28 in 98 civic ex lsvtec?
- b20b wont crank over
- Do you need to break in a motor if.........
- 99 ek overheating?
- engine beeping noise
- Ball Joint Question Searched already
- check engine code 19???
- header problems
- altenator?????? help!!!
- kinda of weird question -.-"
- Wierd Idle and acceleration
- Wierd Speed Sensor/Speedometer
- alternator/ power
- 94 CIvic EG engine nuts/bolts question
- my car is bogging out
- VSS (Vehicle speed sensor) question
- b20 swap in my ek
- H22a swap into 96 civic ex coupe help
- Aligment problem after rack and pinion and tie rod install
- Need Help badly - Wont start, but its not the main relay or fuel pump
- high output alt. for B16B type R swap
- tryin to keep the stock look HELP!
- problem with fresh rebuild d15b
- civic d16z6 wastegate help!!!!!!!!!!!!!!
- wiring for auto to manual
- auto y8 manifold conversion question
- B16A into a 94 civic ex
- Is my TPS bad???
- LS cluster
- b18b1 worth it?
- 92-95 civic front lca's
- A/C belt shredding apart
- and words of advice?
- Thread Tap Need Help-URGENT
- When checking your blue tach pulse wire for a pulse are you supose to get a 12V reading
- STOCK CIVIC PARTS
- Where does this plug go? **pics**
- Which front lip kit do you prefer?
- Del Sol high speed ?
- Ride height/springs. Del Sol
- civic hatchback w/ type r turbo question!!!
- Buy a new B16A2
- B16 or b18c(gsr) tranny?
- 949 racing wheel
- civic crower camshaft please help
- Possibility to "turn off" CEL?
- GSR brake conversion help
- will a dc four door integra sunroof fit a 92-95 civic coupe?
- AEM alternator pulley
- Light sockets for eg hatch/coupe
- Help:::D15b bu`ild
- passenger window button
- need help on how to read my smock check prit out ...i failed .....
- Clutch Diagnosis
- Why does my car vibrate.. HELP
- NEED HELP WITH MY B16 SWAP IN MY EK
- loosen axle nut ?
- civic 1999 losing power at 5000 revs
- parking break light staying on
- driver side wheel bearing
- Thermal Protector A/c compressor.
- 70mm throttle body sizing
- I was looking into buying the cf intake from passwordjdm...
- Intermitent No Start, VTI Hatch
- ECU problem
- hesitation and VTEC issues
- Help CEL 61 (already searched)
- Rear body drain plug, where is it?
- integra Dash problem
- mystery wire
- Which o2 sensor to use?
- Does a y8 cam work in a y7
- Hello I´m new here!!
- Sidemarker wiring help
- 96 climate control to SI climate control ???s
- 92 Civic A/C problems
- 78 cam work in a y7
- 1997 honda civic GSR swap problem
- 96-00 Civic exhaust modifications
- misfiring+unstable idle. . . pls help
- battery going dead!?
- No throttle response?
- knock off seats
- Water Leak in Hatchback, help
- the parking/ intermediate/ running/ instrument cluster lights relay is where on 1993 civic?
- Diagnosing valve tapping...?
- stock weight of a 92-95 honda civic 4 door
- Head bolts
- just switched out shocks to koni yellows. my car is as high as stock
- Koni's with GC coilovers??...
- B16A 92-95 (SiR-II) swap???
- Newbie here - please help
- Cost to change thermostat and do a coolant flush?
- Asr sub frame with 22mm sway bar question
- Would this be hard to do?
- 90-93 throttle cable
- automatic transmission shift point.
- ff squad crank angle sensor bypass hack
- wheels for sale/trade
- 96 civic ex has some brake issues...
- throttle body
- Help!!! Radiator Problems PLease help!!
- exhaust problem (still) so help please!!!
- Wierd stalling problem
- two different SRS module? 97 civic
- How long's a 99 SI clutch suppose to last?
- Quick Question
- just go a 92 si hatch
- ek ctr door panels in eg
- Why's my 99 SI smell like clutch?
- no CEL jumper plug
- do u put the stock bumpstop onto koni yellows when changing shocks? ASAP
- 99 Civic suspension
- 96 Honda Civic Ex (D16y8) NGK spark plug gap issue
- Overheating car, compression normal, oil normal..
- NEED HELP ASAP ASAP! how do i move the perch up on koni yellows!?!?
- good deal or no?
- Would this prevent me from passing smog?
- how to tell difference from r12 a/c and r134 a/c evaporator
- (( Raw Gas On The Bottom Of My IM, Whats The DEAL ))
- Sitting a while in a garage and black smoke...
- crank sensor plug
- another b16 swap...HELP!!
- dark interior...
- need help on viper 791xv installation
- Speedo trouble on 94 Civic EX
- B18C3 for sale?
- 98 ex civic with 5 lug b20vtec motor
- CEL #43
- BDL fuel rail AN sizes
- home made exhaust systems.
- Low idle and cranks but doesn't start sometimes when car is warm
- shifter questions for my h22 sol
- ls trans won't go
- Paint list
