View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ACT clutch vs Exedy, for d16?
- WTB: DelSol
- are jdm ITR 4-1 and CTR 4-2-1 headers same length??
- Spoon N1
- b16 AEBS IM just came in !
- Need help identifying wheels (by description)
- ***Exhaust help***
- EG power door wiring help
- d16z6 intake on d15b vtec worth it?
- 2001-2004 civics d-series?
- I have a rattle coming from short shifter, help!
- Camber Kit
- SELLING MY JDM INTEGRA CHAMP WHITE BAY AREA interested?
- B16 trans on B18b?? (tried searching)
- what tranny for a b20z???
- i need a new radiator...copper and brass??
- Looking for a average price.
- Is there a website i can go to 2 see what parts my honda dealer has in stock?
- Question about h22 jdm tranny
- suspension question......can this work??
- Getting CEL PO301
- Squeaky Noise...PLEASE HELP!
- d16 Clutch proplem
- Better How-To for Del Sol Aux. Lights Re-Wire
- j-SPEC b16 SiR2 engine civic picks
- engine swap!!
- Is this Pressure Plate Still good?? HELP!!!
- race steelies
- damn i fucked up my dash wiring.. i think..
- INFO
- Wheel aligment 4 or 2 wheels
- stupid intake question
- retreiving trouble codes
- cable tranny in a hydro tranny car
- I'm new.... tryin to lower my car....
- help?, have any suggestions on a good clutch for my turbo d16?
- calculate displacement....
- Fix car or Boost?
- quick question guys.
- pcm up grade for ek
- painted oem style foglights...
- ground control sleeves
- What ECU is best?
- GAS?
- Paint My Sideskirts or No ???
- Need help w/ e-brake
- parts list
- will 92-95 ls cams do anything on my b20
- anyone know where to buy an IACV plug?
- thermostat location???
- del sol lip
- A/C and Heat reversed?
- Compatible Engine Swaps
- Left and Right B-series axles interchangable???
- ? about Vtec Setting
- Climate control clip
- Car idles way too fast when cold, need help
- quick 2k1 civic question? size of steelies?
- How-To --> S2000 steering wheel into 96-00 Civic fully functional w/cruise controls 56k I think n
- Front lower tie bar
- What is this???
- Certi fit
- where do you sell air bags?
- Help on my rear disc conversion!
- camber kits, are they worth it
- Windsheild wipers won't turn off
- where can i buy springs for ground controls
- EK and EG axle-back
- Ugh another question about my stupid car.....
- wtf is this front bumper from?
- crazy trans whine?
- new here. 4-door eg
- motor smoking
- Redline and Rev limiter
- S2000 seats in a Del sol
- zex setup
- looking for a B16
- please help.....
- new guy question
- redoing interior trim question
- ac coolant
- 3rd gear sux!!!
- MIR time slips... How can I get some better times?
- POS 2000 SI
- problem installing 5zigen exuast on my nissian 240sx help!!!
- OMG NISSAN-TECH.COM ????!??!!??!?!?!
- possible swaps?
- 92 civic hatch headlight housing...NEED HELP
- Resetting ECU with a backup battery?
- piston rings!?
- h22a civic
- Bought some Ground controls....problem~!
- nissan-tech? who's leaving with me?
- NISSAN-TECH.com?????
- How will my exhaust sound? magnaflow oval and resonated piping.
- DX tranny/ And turbo?
- GooGone...
- Rear hubs for discs and drums the same?
- SELLOUTS
- looking for a bar
- Will prelude 6x9's fit in my back speakers in my DX?
- Cheaper Turbo
- help finding spoon replica lip and konig mozart muffler
- Mini-Me
- exhasut question
- need an answer quick if possible --> SRS system 96-00 civics
- i think i found my stolen b16
- Piston Install.
- D16a1
- ctr front end
- JUN Lip on 00 sedan?
- replys
- Who has an Apex'i N1 on their car?
- New Tie Rods!??
- Spark Plugs for High Compresson SOHC ? (mini-me)
- MAP Sensor plug problem, please help!!!
- racing seats
- My RSR GTII exhuast review
- Site Changing Questions
- Items that I will put into my Civic...
- DC sports rear lower tie bar
- Honda Civic Newbie
- B16 long block....what else am I going to need??
- Oil life information...
- GSR swaybar on EK/EJ: Will GSR endlinks work?
- those with airbag blockoff trays...
- Tranny Advise Needed Here
- Engine dying after modifications done to Civic
- Door locks
- mini me help needed
- dashboard
- help with power windows
- FPR question
- loud exhaust
- CARBON FIBER DASH.. where
- Head gasket kit??
- any diffrence between a z6 znd y8 tranny?
- CEL code 14
- spongy clutch?
- How do we get rid of those UNSIGHTLY NICKS on the bumperss!!??
- My suspension plan... give me your thoughts.
- for the EK peeps vid
- how much does 5zigen's N1R becketts worth?
- b18c gsr head?
- AWD
- failed smog ref...will this work?
- need advise about fuel system
- Bad clutch?
- Anyone done this.
- Spoon Sports.
- Those with a TypeR rear lip what exhaust you using?
- Intake Manifold Install
- White Smoke :/
- 95 integra exhaust off of a 95 integra fit a 98 civic si?
- HELP: Civic and Teg catalitic Converters
- need good engine builder in MD/VA/PA
- Hiding engine harness on a eg6?
- why do you have to jump the service connector when moving the dizzy?
- EG Interior Thread. Post your interiors (dash, center consoles, etc) NO RICE PLEASE
- I paid $988.33 for a complete B18B longblock. Did I end up ok?
- Ground Control question....different spring lengths?
- Trunk Cover on EG
- attn....HT members! What is the suggested SPARK PLUGS..???
- Front LCA Pivot Bolt torque spec.
- will EG front bumper from 4door fit hatch??
- ECU WIRING DIAGRAM FOR D-16Z6
- K-Sport Coilovers?
- Question????
- LS swap priceing i need alittel help.
- Is it possible to use various discs with the ACT heavy duty press. plate?
- time line of THE RIDE.
- 300whp del sol
- Vtec Controller??
- usdm p30 ecu - was there an automatic version?
- Has anyone colored changed there dash with vinyl spray paint?
- Highest OEM piston for my d16z6?
- need insights on installing a changer
- anybody in here a CS major?
- Facts on D16?
- 96-00 ek9?
- Clutch adjustment
- Self made headlights
- Yeah yeah, I shoulda used the search function...but
- D-Series Exhaust Question
- Cold Start Problem
- *Decent Civic Shocks*
- Will Teg mirrors fit...
- Cant get trailing arms off my POS.... any suggestions?
- Did a Compression test on the B16*Woot Wott*
- Tranny Question
- DOHC junkies have finally gotten to me!
- WIre Prob I think Help?
- Question about what distributor to use????
- How to DIY amber clock?
- window keeps popping out of place when i close my driver door
- 4dr integra seats in a 92-95 coupe, question?
- what distributor will fit on my b20
- n00b question--EG jacking points
- d16y8 manual tranny into auto d16y7
- LS in Civic HB
- need vacuum diagram for 96-00 civic
- B20A5 VTEC???
- help with swap having problems
- SI Fuel pump
- zex nitrous jets!
- SCAMMED!! (If you work for Telus, PLEASE READ!)
- 93 HB T1R onto an EH9?
- V-TEC swap question. PLEASE HELP!!!!!!!
- 195/55/15 or 205/50/15??
- DIY traction bars???
- any one have the hondata heatshield ??
- ex,dx gaskets the same??
- 92-95 mirror...
- just got back (dyno)!!!!!!!!!!!!!!
- Prothane or Energy Suspension Inserts(upper) after JimFab(lower)
- Upgrading suspension Compare to Integra*already Searched*
- Bult B16, Doesnt Like my Ecu
- 93 Civic LX Fuel Injectors not Fuel injecting
- MSD er what??
- Help w/converting a 2000 ex coupe to auto from manual......
- Battle of the Imports
- clutch or tranny problem i dont know.
- installing injectors
- auto to manual IACV issue (random thought)
- who wants a turbo b16a crx????
- doing a b16 swap in a 1997 got a dx harness not ex what provisions do i need
- motor swap shops in nj
- How much would this cost.
- Seats and Wiper
- d15b2 Turbo (check this out team703)
- Fumes inside me car help!
- ATTN All EG OEM FOG OWNERS who installed them there selves I got a Q... HELP PLZ!!
- Side markers... various questions
- 92-95 civic S-tech springs on 96-00 civic?
- AGAIN FUCKING THEVES
- NEED ECU codes pretty fast.
- quick rotor question
- spark plug wires not fitting???
- Hondata?
- This has been covered a thousands times but i cant find the answers i need ........ 99-00 conversion
- Will a 99-00 front bumper fit a 93 CX Hatch?
- 1992-1995 Civic HATCH-Specific Car Cover...
- tell me is this timing belt loose or good to go on a mini me
- what bulbs in JDM headlights?
- Need any engine pic of any civic 96-00 with power steering
- auto to manual
- NEED A/C..
- not an asshole or anything but...
- New to this
- o2sensor problem
