eg hatch/LS swap - just revs up when in gear
so after a ls was swapped into my eg hatch..its been runnin kinda weird...i cant seem to figure out what it is...it runs fine in the morning and in the evenings when there is low light and still cool outside..when i get off work and its warm with the sun out, the car just revs up when in gear..i have a new clutch and the tranny shifts fine..no grinds or pop outs...when this occurs i smell clutch fluid and some smoke comes from where the clutch slave cylinder bolts on to..NEED HELP!!!!!!
O.G. triple O.G.
Re: eg hatch/LS swap - just revs up when in gear
Prepare for a 4-5hr job to remove the transmission out by yourself if your are mechanically inclined.Next time around, make sure not to leave grease or grime on the clutch disc. It's the same as a brake rotor. Contaminants will cause issues....hence the outcome being his thread.
O.G. triple O.G.
Bleeding the clutch won't do a thing for your problem. Roll up your sleeves and get your hands dirty. Whoever did the swap (from your comments, we all know you didn't) did a SHITTY job with the clutch install. Cleanliness and thoroughness are always a top priorites when you are wrenching on cars.
