View Full Version : Honda Civic / Del Sol (1992 - 2000)
- E brake stuck on, can't take rear drum off
- Manual Swapping D16Y7
- Fuel Pump intermittent no Prime
- Check engine light overnight
- EJ9 (D14Z1) steering rack compatibility
- D16y7 n d16y8
- Check engine light won’t turn off
- Starting problem!!?!? Please help!
- Turn Signal Differences
- Ac on and off
- 92-95 civic ignition switch compatible with 96-00
- H22 euro r into civic eg 92 hatch
- engine light is on
- what do you check when it's NOT the Main Relay ?
- low beam is not working but high beam is working
- security alarm system in your hatch?
- 6-pin, 5-wire fuel sender in an EK?!?
- 1997 civic lx d16y7
- P28 conversion question
- Ek b16a into eg carby
- A6 intake swap. Worth the trouble?
- D16y7 good for circle track???
- Civic ej1 ej2 rear quarter glass molding help!!
- Throttle body cleaning advice?
- 93 coupe pulling out swap b18a1 putting in b18b1
- Del Sol non-VTEC header fitment issue
- B18C GSR into 95 Civic
- EG OR EK
- car is not level when jacked off the ground
- 2000 civic auto with 01' b18b1 auto swap trans issues
- Crank no start
- HELPP!! 2000 Civic Auto to Manual Swap Problem
- 500hp D16z6 transmission?
- 1998 Honda Civic Oil Pan Bolts
- Weird question about a 1997 Del Sol build date
- 1995 Civic Blower Motor won't turn off
- 97 D16Y6 civc sedan vtec
- Is it worth it to buy 150k miles B18c1 engine?
- What throttle cable for H series
- Identify my subframe?
- 99 civic shifting please help
- Del Sol Replacment Quarter Panels
- My 94civ is giving me nightmares!!! please help!!
- d15b choking and fluttering at 4900rpm until I power through
- Idle temp 203F, Highway temp 223F???
- Belt Tension
- To Do or Not to Do
- Running an s2000 clutch master on a 2000 civic EJ6
- EG hatch steering wheel.
- What's the best B-series transmission with a turbo as a daily?
- Transmission Problems and Questions. Need some advice. 98 civic
- Coolant leak!!!!
- b20 swap HELPPPPP
- 1996/1997 Ctr Build...
- Bad Input Shaft Bearing?
- Can it be done
- DIY civic eg EX hatch restoration
- No power to distrbutor HELPPPP
- Hard start b16b
- camshaft/rocker part D16z6
- B20b to b18c1 or b18c5
- Troubleshooting: JDM B16 is possessed. Idle and drives fine, but crazy under VTEC.
- D15b7 acting like it has Vtec
- 1993 LED Flasher Relay ?
- Still can't get 95 Del Sol started . .
- EG Subframe in EM1
- First time B18A1 engine swapping seeking help! ( '94 del sol )
- First time ever engine swapping seeking help! ( 2000 Honda Civic Ex Coupe)
- Smoke inside cabin
- Need to replace fuel tank straps, need help identifying what size bolt needed.
- 1156 5000K LED recommendations?
- 1998 civic no spark-pin 20 problem?
- Please respond
- 96 lx b20 power steering questions
- B16a2 dies when starting, hunts idle, and sputters randomly
- Car won’t start no spark after coil urgent*
- Undetected vacuum leak
- Please help
- Help identifying vtec head part
- Clutch petal have NO RESISTANCE. HELP!
- 4k rev limit using P3F crv ecu 99 EX civic b20z2
- code 21
- Huge heavy bar behind front seats ?
- D16y7 to B20B
- Newbie here I need help with my 98 civic
- 97 dx help not running right
- A/C Oddities
- Ebay door pin and bushing kits?
- Troubleshooting: 97 Civic does not remain. running without full throttle
- Help with understanding power door lock diagram
- prevent over heating?
- P0706 code, help with honda part numbers!
- 92 CIVIC DX Engine Help!
- 97 civic with d15y7 mini me swap
- how much did it cost you to repaint your EG hatch?
- Will 92-95 dx intake manifold fit on cx head?
- Intermittent starter failure
- EM1/B16a2 Head/Heater Hose Question
- lock cylinder
- Unknown part from swap or original motor
- b16a civic ek help
- 2000 civic ej6 tach issue
- 7pin ek civic distributor pinout
- Check engine light D4 blinking.
- Where to buy door side moldings?
- Blown head gasket?
- Newbie lookin for insight
- No start when hot
- battery leaking
- 96-00 Dash harness compatibility
- 2000 Civic,Cranking but not starting..HELP 😭
- LSD / Final Drive for racecar advise please
- what transmission did I just buy?!
- Questing about rebuilding a d16y8?
- strut brace?
- Stock 95 Civic Running hot
- Bought it swapped with an auto trans!!
- My swap won’t stay on
- B16 swap Loom and Ecu setup
- Issues with a GSR swapped EM1.
- Proportioning valve issues
- what ecu? help
- 6th Gen Civic, Power but no Ignition Power, no Start (ignition switch?) Lots Info
- exhaust resonator (center pipe) independent of CA vs. Fed emissions?
- My H22a EK Build
- Head Swap
- 2000 Civic Dx - Battery OK but No Electrical Power
- unusual no start
- need better suspension for ek!
- How to connect VTEC Solenoid wires(Green/Yellow & Red) to the ECU pin-outs
- Should i be worried?
- Sparco Shift Knob in '92 Civic???
- 1995 Del Sol Solid CEL/ fuel pump won’t turn on when wet out or humid
- Best way to clean old seats in a hatchback?
- Light weight conversion hatch
- 94 cx hatch gauge cluster rpm signal wire
- My swap won’t start
- ac compressor for d15b with vtec
- is the ignition distribitur the same for 1.6 civic models?
- I/M Gasket Leak, P0505
- Civic EVAP valve hot after car is off?
- y7 harness y5 motor
- 2000 honda civic ek engine hesitaion
- Need purchasing advice for a Civic I want to drag race.
- 95 civic rocker panel
- How do I distinguish which transmission I have
- 1995 Civic, Bogs & Dies at low RPM, Idle surging.
- Honda civic lxi 1998// engine check lights on after cleaning the throttle body
- Ek Civic Engine Harness
- Help needed
- Building My 98 Civic
- engine problem after valve clearance adj.
- Best mounts for daily driver b20 in 94 ej?
- '00 Civic TPS
- PLEASE HELP! Surging Idle Issue
- Hit and run
- Rear bumper
- Vtec spool valve leak
- Help with ECU
- H22a ek axle issues
- I need help swapped my 2000 civic dx with a 97 dx and manual trans now it wont stary
- B16B NOT PASSING NYS INSPECTION HELP
- Strange code 0 CEL
- HyDru's First Engine Tear Down | D16z6
- Need some opinions
- fuel issue?
- y7 to y8 questions
- Depin fusebox connectors?
- 1996 Honda Civic DX - Sunroof Replacement
- Hi I’m new here I have a question?
- Help!!! iacv will not turn off
- No Vtec on B16 swapped EK
- Forgot where this goes help plZ? Mount like piece
- D15z1 to d16y8
- Can a jdm obd1 p72 ecu runs on USDM B18c1 GSR motor?
- Camber in a 95 coupe
- Brakes
- D16y7 block cracked?
- 99 Civic Ex...Bad Tranny?
- D14a3 to D16z6 full swap
- Rounded shifter bolts
- Brake system adaptation
- Boosted del sol
- 99-00 coupe trunk fit 99-00 sedan
- 2000 honda civic dx 1.6ltr you sedan no spark
- Idle Air Control Valve
- trans swap for taller overdrive 2000 Civic Si
- 92 civic blinker problems fix
- 95 civic overheating issue
- 92 cx sway bar
- Honda engine noise or just being paranoid?
- Low power at higher RPM after timing belt replacement.
- type 2 coolant on a 2000 Civic?
- Anyone recognize this?
- Code 9, H22 swap.
- 99 Civic Si - Engine cuts off while driving
- 95 Civic DX H22A swap.
- 1995 Del Sol . . fuel pump/relay issue
- 94 del sol F20b swap
- EM1 SI B16a2 torque dip?
- Can't go over 50 mph
- Fog light
- 97 CIVIC B18B CRANK BUT NO START
- Can you put d2 suspension tops on the top of racelands coils?
- jumper/rewire to turn off headlights with key?
- 1997 Del Sol Si project, opinions/advice please
- Unknown wires under 93 Del Sol dash
- Ls/vtec engine question?
- 2000 Civic Front end out of alignment
- Speedometer/Odometer problems
- Screws for Del Sol ignition switch
- '96 LX sedan B18b no crank
- Sanding valve cover
- 99 Civic, LS/VTEC engine, VTEC intermittent issue
- Stockish budget build
- 2000 civic Si radiator info
- Please help. My Del Sol crank but won't start
- random buck/surge between 20-40mph
- ECU not plugged in, car still runs
- IAC / Idle Issue after Installing New Injectors
- HUGE HELP!!
- Oxygen Sensor 1 issues repeatedly throws slow response CEL with new aftermarket part
- 98 civic ac not working
- Building EG sedan into Exo Kart any suggestions on build
- Vtec not working ! Please help starting to loose hope
- Clutch Fork Replacement
- Blown hose!
- B16 motor swapped into a 99 civic Ex OBD2 wires and connector removal
- 96 Gsr integra alternator in a 96 civic.
- Seats are too high
- Honda Civic Ek Brake Upgrades
- PLEASE HELP***How to tell if you head is plugged from ls vtec while heads on motor
- Plug in old LS VTEC head need to be removed?
- Having idle issues
- Budget build on a eg with a b18c block with a p72-1 head
- 93 Si CRVTEC Fuel Pressure Leakdown, Wideband Issues, Lost tune IDLE LEAN...Help?
- Ect sensor wiring ... and other isues
- 2000 Honda Civic wire harness
- help! 1998 civic ex
- Airbag and SRS replace
- 00 DX track build.
- Does swapping a 97 Honda cluster with a 96-00 LX cluster somehow short the ecu?
- tuned 1996 civic vti EK4 starting problems
- Exhaust for 95 del sol
- Steering Column Replacement Help
- Pakistani Civic 2000 (D15Z6) Issues
- 98 civic VTec or non VTec
- 92 civic fuel pump issues
- Help ek si electricals stopped working
- pulled engine - now cel - don't know what to do
