View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Turbo ProJect! d-series!!!! i need parts!!!
- mini me swap // 1.5 liter 92 civic dx
- EDM EG cluster
- b16A intake mani and throttle body question
- ek info about what axles to use and mouting bracket info
- Broke a Rear LCA bolt
- can't build pressure in my clutch hydraulic system.
- Suspension?
- pics request: del sol
- times suck wit these kuhmo tires need opinion
- ::best place to get a B16/B18/B20 swap!!::
- HELP!!! What shift linkage for my del sol?
- EK swaybar problem!
- Honda Certified Warranty
- DC2 AGX's on an EK?
- 94+ integra armrest work in my eg?
- tein type flex and pillow ball mounts
- new ls/vtec swap wont start in 92 eg hatch
- car broken into =(
- DIY: Brake pads on Civic (56k? No way)
- which exhaust system???
- any sites dedicated to 92-95 civic sedans or ferios
- Tryin to fix my SOL i need HELP!!!!
- is this a good deal??
- si cluster question something i cant find though search????
- Difference between Rushed and Uncrushed BOV
- Looking for the best cam and cam gear????
- OEM fog lights
- shorts
- ran into a problem with my hood
- suspension probs
- CTR cams????
- Golden Eagle Ls/Vtec conversion kit...
- JDM gauge pod in 92 civic
- Heater problem in a 95 dx with a B18B
- Another ?
- Spark wires
- 99-00 Civic SI Center Caps
- Draft:how do you adjust headlights on a 99-00 ek?
- 2000 Civic SI 15.1 @91mph.
- I got a new O2 sensor installed but I still can't clear the CEL by disconnecting the battery/fuse!
- slingshot boys
- Battery Dying a lot.
- I'm stupid, someone explain timing to me.
- ABS axles...will they work?
- project question
- Breaking the 14mm driver side motor mount bolts loose.
- new member pics.
- Tom's Motorsport Coilovers
- ek console
- GSR and B16 valve cover
- Springs/ Coilovers/ Help!
- What die size to rethread lowe ball joint?
- power windows-ek ex doors on a hatch. help
- new swap problem iacv and idle d16y8 in 94 eg
- Failed Emission...High NO...any suggestions?
- Burning Clutch
- Help with 96 ls swap into 97 civic dx
- Springs or Coilovers
- Car Just Died. PLease HELP!
- Sohc vtec or Dohc vtec ?
- Cheapest Place To Get OEM Plug Wires?
- d16y7 - 96 DX
- Sprint steering wheel?
- troubleshooters & techies read this!!! 95 b18c1 swap into 92 civic si cuts off!
- Window makes a cracking noise
- d16z6 nitrous???
- Stiff Suspension for Rubbing
- troubleshooters/techies READ THIS! help PLEASE!
- Where to buy rear disc conversion for EK?
- JDM sidemarkers " asked but never answered "
- Shipping an engine???
- Goin From Power windows to Manual
- anyone know what ecu is better? 93 ls or 94 ls
- What is CEL 0?
- Questions on B20Z Build-Up???
- So I just instaled new rotors, pads, and calipers and....
- to synchromesh or not?
- under the d16 head
- CEL
- What Sz Windsheld jet to use for JDMshit c/f hood?
- sohc supercharger help!
- What does my H22 TURBO need, not WANT, need in order to run?
- Question about ECU.
- i want the cheezefrog motor
- DIY: Painted valve cover and heat shield.
- y8 ecu's...which codes are for at and manual?
- guage clusters? will 98 integra gsr fit in 93 civic ex?
- color or pin of the RPM signal?
- Exhuast help for eg hatch.
- rear disc
- EDM eg parts????
- eg steering wheel and srs problems?
- jdm b16a2 swap question
- new track times!!
- gear ratio
- Just got back from the track. Sohc style. Man I stink...
- looking for a wiring harness
- Alternatives to using ITR 5 lug conversion anyone?
- Planning to sell some parts...Need help on pricing
- motor crissis
- 96 Civic LsVtec Fuel Pump... need kit or no?
- Turns over w/ fuel but wont spark to start
- RPM's not right
- Those with EK foglamps...
- D-series LSD tranny -- questions
- Stock brackets and sliders for Tenzo R rally seats?
- no cold air ....
- b18 or b16 first?
- Mini-Me Discussion: Get in on it and give me your knowledge
- b18b rebuld?
- ractive mufflers?
- Alternatives to Using ITR 5 Lug? Prelude Perhaps? ITR Sus is Hard to Find...
- hey tom
- DIY: How to remove Cruise Control *EK*
- ::Car trading and would you take this deal??::NEED ALL OPINIONS
- anyone know where to find this climate control?
- Battery relocation pics
- Hole in AC line, going to order new line and re-charge myself... any advice?
- Phantom Gray touch up paint and spray
- what would you do......
- WHICH PISTONS AND RODS FOR HIGER COMPRESSION IN b16a2
- OBD2 - Any Way to Get Rid of Second o2 and Run a Test Pipe?
- Got a Deal On a Greddy Evo But I Want To Know If It Would Fit?????
- Need to know right now...
- GSR CLUSTER INTO EG HELP PLEASE HELP ASAP
- bigger high impendance injectors
- 96 civic hatcback weight?
- energy suspension motor mount inserts
- jdm cluster
- 195/50/15 on 15x6.5 wheel?
- The hatch NEEDS help!
- Car Dying After It Reaches Nromal Temp. *HELP*
- H&R race spring help...
- hole in oil pan!?!?>! JB weld?
- Pro/Cons of using afermarket Honda OEM Parts....
- Battery/Fuse/Dash Lights Electrical Problem
- Rolling fenders? Already searched
- Rear brake piston question
- Any1 selling any type of lip for a 92 civic hb
- Noob questions, provided by a noob
- A slide on brake caliper bracket is stuck, any help
- sohc motor tuners
- Rear quarter panel
- GSR Swapped EG Intake?
- suspension question, searched but didnt find answer i needed
- Cam Question?
- NEED HELP ON FUEL PUMP WIRE COLOR?
- which brake system are better for my 95 EG coupe???
- Help with 96 GSR Gauge Cluster into 98 Civic. Dimmer Switch not work.
- 02 sensor removal help...
- Jacksonsupercharger help!!!
- 17 in Rims - Camber Issues
- cam gear compatibility
- 14" rims clear 11.1" "ghetto-fab" Hype-R/Prelude VTEC brakes?
- gauge pods
- NOVA people....where to get my flywheel turned?
- Choosing Cam for D16z6
- next of japan(miracle x bar)
- question - 2000 civic Si exhaust
- Turbo
- need help and info on swap
- cv joint or axle
- Correct Size For Sidemarkers?
- need to find wring harness before english town!!!
- CV joints, front end noise
- Slipstreams 15/16???
- Touch Top of Spark wire and its knocking?
- Rear disc help cable lines
- DIY / How-To: Sound Deaden your Door *pics*
- Need help with 92 civic timing
- ca; people how do u pass smog?
- 95 b18c into 92 civic hatch si
- ya another overheating thread
- B20Z or B18A Block for LS VTEC???
- SRS light?
- Odometer Got stuck! help
- B18c or ls vtec or b16a2?
- under the lip
- Tech question please!
- Quick Ques: will 94+ integra springs fit a 2000 civic 2 door
- need eg hatch shell ASAP
- vafc help
- b16 turbo run
- Car won't start HELP!!!!
- IAC code 14 problems...car wont idle
- coupe or hb?
- anti-freeze going some where
- which throttle cable or bracket to use with jdm itr swap?
- best way to fix A/C line leak
- trying to remove EJ1 head lights Damn these things!!! please help me if you ever took your head ligh
- $5600. I will buy a hatch with it. the leftover will be my engine. what to do?
- b16 idle and driving probs
- Has anyone delt with Ryan@ff-squad before
- 95 coupe with b16a2 how much does it weigh?
- Bouncing idle, what can it be?
- emission question
- my alarm system
- gsr hatch not starting need quick tech help. . .
- Want H23 Del Sol
- help motor Problems with y8!!!already searched
- Can i use brake cleaner to clean out the IACV?
- dizzy for EG models
- B16 vs. B18 (Opinions)
- d16y8 head on d16y7
- How do you check CEL?
- Clutch install price
- TPS Removal...
- How do you change the park bulb in a 97'
- auto to manual swap on eg
- Saturday morning disaster....
- Tool suggestion
- VAFC tuning
- help with my eg steering wheel
- hey i'm new here check out my car.
- How to adjust timing?
- Interesting DX motor problems, take a look
- Reasobable price for stock EG in NJ
- anyone know what the adjustable looking screw on the side of an msd box is for?
- Torque on ST sway bar?
- Tech Q' bout fuel accesories to use with mini me and Nawwwz
- Tech Q's about Mini me Ignition...
- Making CIA from an U-bend exhaust pipe?
- A REAL TECH Q' OMG!!! Mini-me wiring on ECU...
- Interior Color Code for EM1 (99-00 SI)
- type one rear section
- KYB install, bump stop help!
- d16y7 d16y8 mini me problems!
- B18A1 or B18B
- D16Z6 Tranny
- conversion harness for Civic Si 99 B16A2 from OBDII - - - -- to OBD!
- Problems with ZC motor????
- Busted for a JDM tranny
- lookin 4 some oem parts for a 96-98 civic.....but a 99-00 conversion would work too.
- speeddomintor question
- stereo wiring
- hid lamp lumens question
- Noob Swap Question
- Del Sol Dual Radiator In EG Coupe?
- fitment issues on b16 crx
- Keep my EK or pay off and buy a swapped EG
- Swap will be done saturday but should b16a3 spark plugs cost 14 dollars a piece?
- My 98 Civic HX Need Help Please
- wheel/slick size for 5 lug conversion
- 92-95 Ferio Owners...ferio door panel question
- 96-96 civic oem foglight instructions
- Brakes need pumping after startup or they dont work!
- Brake caliper problems, help me get back on the road.
- which carsound cat to get to bolt on perfectly on 92 hatchback
