View Full Version : Honda Civic / Del Sol (1992 - 2000)
- PIC REQUEST: RED USDM ITR front seats in a 96-00 coupe/hb?
- Where is the IAT?
- would a DX tranny be better on a turbo'd d16z6 ??
- im painting my EG headlights today.
- b16a3 question
- H22 Civic, VSS question?
- is it worth taking out sound dedning?
- Wrecked my DA Got an EG NEed help
- How do you remove EK centre console?
- Rear Disk to Drum question?
- What dashes bolt into a 93 civic lx???
- How do you take off this dash piece on 5th gen civics? pic inside...
- 98 civic dx to ZC88-91
- bigger TB and intake
- B18C into EG
- one-piece fiberglass front end; daily driving?
- Civic D16y7 ECU pin diagram??
- will the DX o2 sensor work on a d16z6...?
- oil change dip stick question!!!
- Need Help.. who makes it/sells it/how much etc...
- VX- moldings optional? ? wtf
- D series Cam shift question...
- jdm motor passing state ref
- rev up to 9k on a B16
- Ls internals in a GSR block
- HELP! anybody put JDM seats in their EK 4dr?
- 95 EX Coupe, Starting Problem?????
- 99-00SI lip on an EG
- tonight i was trying to remove the PS pump...
- axle came out? broke?
- ok damnit...done searches, scoured the internet - where to find a motor!?!?
- How is a B20 block preped for a b16 head
- mounting seat belt harnesses?
- replacing front passenger window?
- Axis...
- header for 95 del sol
- Need Help w/ Swap!!!!
- installing fog lights...
- Field SFC VTEC Controller...HELP!!!
- Question on running testpipe with JDM DC 4-1
- help, where is it?
- ne one sellin a dohc zc??
- Best fitting / looking Carbon Fiber lip for 99-00 civic SI, post pics if you can.
- need help: which knob to get now:P
- anyone with a helms for 99-00 civic ex
- suspension setup on my hatch?
- haltech install on del sol vtec
- msd distributor cap and seperate ignition coil
- CKF sensor.....HELP!!!!!!!!!!!!!
- What is wrong with my new suspension setup???
- Question should I buy this?
- 5 speed conversion questions........
- what car does the p30 ecu come from
- What are my mirror options for my eg????
- how do i get that annoying ding to stop when keys are in the ignition?
- EK Airbag block off tray on ebay
- Amber or Black?
- Head code
- Do 99-00 Civic Si seats feel any different from stock civic seats?
- attn: 2000 civic si stolen
- Sold my car :(
- pillar bar
- wtb: civicsigrill
- pinout for 99-00 civic ex
- Where is the power window control unit? >;(
- Best place for head work on a sohc d16y7
- What are some good coilovers?
- Odometer Roll Back....#####
- My new jack.
- B16 swap del sol got some questions.......
- VSS/Alternator/Speed sensor fuse keeps blowing
- power steering to manual
- dynoed my sharged 4door
- ***Miracle strut Crossbar??***
- 94 Integra Rack&Pinion into 95 Civic???
- Need some opinions please.
- Toggle will it hold the power of the fuel pump???
- ATTN Tri-State area concerning Hondata tuning at NRG Tech!!!!
- HELP on Installing skunk2 camber kit?
- Air Intake Temperature Sensor?
- obd2 memory wire help
- Canadian parts???
- Oxygen Senser for 93 sohc del sol
- LCA bolt size????????
- HomeMade CTR Door panels
- best ecu to run with ls plus boost! OBD2
- apc carbon fiber hood any good?
- wire on the map sensor is cut?
- photoshop pictures
- Fastest E/T possible?
- Replacing antenna on 94 hatchback....
- bigger wheels and innacurate speedometer readings!---HELP!!!
- Anyone know where to get the super strong timing belt?
- EK Side Moldings !!!!????!!!!????!!!!????
- moving to Glendale, Arizona.
- can i put a p30 ecu in a d16y8
- CA Residents!! What kind of fine for no Catalytic converter?
- How to adjust the clutch
- what ignition can i get that i can control my timing
- click noise from AGX shock
- replaced vss, swapped out gauge cluster, what could be the problem?(used search)
- swapping out the d series vtec solenoid for the b series solenoid
- Got into an accident today! (56k nah)
- 92-95 ex dash in del sol?
- del sol w/ a b18c swap
- Need Help Spending Money on del sol
- Garage cleaning...b20 wanted
- First Motor swap
- Type One Racing Converter................
- oddometer roll back?
- Knocking sound when I turn?
- Final Drive on EK '99 Si
- zex cam and nitrous?
- b18b --> EG rear mount question
- Need to know all miscellaneous parts needed for B-series swap(I already searched).
- Anyone interested in aftermarket D series axles?
- car broken into......=(
- when to change timing belt
- Nice 'n' clean EK hatch on eBay...
- radio removal
- Coilover Problems
- Product review: Ground Control Upper mounts.
- Del Sol Fuse issue
- Tanabe super racing medallion vs. Apexi N1
- Who lives in NJ?
- name any possible spots coolant can leak from...
- STUMPED: wtf is this ticking noise? 5th gen d16z6
- how do i turn off this check engine light of mine??
- ***quick question or help***** fuse blown
- They tried stealing my car again last night...
- sway bar questions
- B18b guys.........OBD1 LS throttle body question!!
- Problems with brakes squeaking? Whats the noise from or for?
- Those little front license plate covers?!?!
- ***Where can I buy this!?!?!***
- Putting Integra RS side skirts onto an EG
- OEM lip for EG
- Anyone with an EK with a H22.. Any problems? (Yes i did search and only Egs came up)
- Day 1...b18 to b20
- Advantage(s) of Manual steering rack...
- motor mounts for b18b
- bolting ECU to the car?
- Eg Hatch Swap?
- del Sol exhaust alignment
- B16a w/ Jun stage 2 intake cam
- tip or no tip on my es oval??
- Stainless Steel Header Question!!!!
- Civic hard to start after sitting for a week.
- '99 Civic Seat help....
- A Pillar gauges.....HELP!!
- Anyone know how to install clock on 93 civic dash
- ZC Instead of D16Z6?
- Just got a Phantom grey 93 hatchy for 2k....url to pics inside :)
- how do u get rid of the srs light in a 97 civic
- San Diego Meeting - 3/08/03 at 3 pm
- Tein HA owners, read here please!! All others are welcome too!
- just wondering??
- strange whistling noise coming out of my vents...
- choosin a deck
- headlights get brighter out of no where......
- Check engine light
- cheap and or cool performance for eg civic
- Need measurementsand other info on EK skirts, 4dr and 2dr
- what vss do i need for a b18c5 in a 5th gen coupe?(used search)
- Mr. Plow Vs. Downpipe
- carbon fiber exterior help?
- where can you find this spoiler
- hybrid civic b16a1 speedometer not working
- Post you pics and favorite carbon hoods POLL
- What block should I buy?
- GSR in an EG HB
- some insight would be nice*
- So yeah ..i blew the LS ..so moved onto the next temp motor :) *pics*
- coil overs for 02 civic
- engine hoist - cherry picker
- 10A Fuse keeps blowing
- Need help.
- type one test pipe
- need help dropping 03 civic
- Attn:Del Sols Owners!!
- big brake problem please help
- Hesitation on initial acceleration/'91 Civic 1500cc Hatchback Help!
- I need help with reverse glow gauge wiring*
- Thieves Strike Again
- Bumber problems
- 94 canadian cx...
- Question...Buying a 95 CX Hatch
- sidemarker install on EK
- I NEED HELP FROM ALL OF YOU, mu car got tow away
- Del Sol Non-ABS Brake Problems, Need help pleeeze
- HELP With Making Windshield Washer Nozzles Fit...
- eibach with stock shocks?
- steering knuckle?
- post what you think about your b18c1
- 99 si climate control in a 97 civic hb....HELP!!!
- Would it be worth to get my injectors cleaned?
- Probs with GSR rear sway bar..
- D16y8 n/a biuldup.
- I think my rings kinda worn. Bottom end rebuild time...
- Door problems
- is that a good deal?
- Going to be a salesperson need to know were is the best places to open acocunts with....
- ek's what intake are u running for your b18c1 swap?
- Steering column question
- 90 si hatch springs for 93 si?
- Question about installing rear suspension (need pics)
- Best suspension upgrade for ride quality/pure street driving?
- y0. I need some help trouble shooting my problem.
- Integra mirrors?
- Coilover weight rate
- Mod suggestions needed for D16Z6 Civic Si
- z6 head on a y7??
- gear ratios
- Magnaflow part numbers###?
- anybody have a....
- 97 ex clear turn signal bulb
- My car from Canada??? Is this better or normal?
- help with EG rear speaker mounts
- Identifying a d16y8 intake manifold
- air bag block off tray results
- p72 question
- cant find that thread: how to install ek side skirts on an eg
- aftermarket springs/shocks for integra on a civic
- Will '97+ prelude side skirts fit on a 2000 civic coupe?
- lx v-tech?
- Racing Seat Brackets
- Which direction does coolant flow?
- factory head gasket
- ground wires
- Extending wires in the wiring harness
- Blew 2 motors this month =( and need help to build my next one!!!!!
- Take a Look at my ride
- cluster removal in an EG...large black cover?? Please helpnow!
- ATTN: civics with eibach sportline springs!!!
- Those who did the rear disc conversion, what SS brake lines to use??
- 95 Civic EX ECU Jumper
- Apexi N1 exhaust rubbing against fuel tank.
- Rear Lip Kits....
- More pics of the spraypainted EG...come see for yourself.
- Please help!! What mounts and Harness to use???
- B-Series Engine Mounts
- HIN philly meet up
- EK cluster in a EG
- B18C5-EH2
- Is it worth it?
- prices on paint jobs
- FRONT disc conversion?
- Type One Header: anyone heard of it?
- Question about jdm recaros
- does anyone know if gsr interior(seats door panel etc.) can fit in an eg
