View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Where can i find an axle?
- looking for salvage yards in D.C. area
- Question about custom exhaust??
- y7 motor w/ z6 head
- Question about cat placement and sound reduction.
- 96 DX hatch weight?
- Help!! 5 lug Conversion kit for my 98 civic ex
- which tires to use in front and back?
- posting in classifieds section?
- CEL Code 92 - HELP
- I need Help, tranny question
- B16 Setup
- ECU Code: P0420, How do you fix it? Help Please.
- Will a b16 pan work on a b18b?
- Missing Piece?
- f22a1 to h23
- mini me HELP! d15b8 / Z6 cam question
- SRR or other control arms for my EG6??? Help me out???
- Tranny code?
- blower motor ? help!!
- tires...
- What does everyone think about putting a f20b motor in a 1997 civic 4dr
- Stock Shifter/Short Shifter bearings the same?
- What size bolts hold on the front a/c engine mount. 2000 GSR/92vx hatch
- secondary butterflys help wiring
- Question about headlihghts???
- Brake light problem
- what is the stock timing on a 2000 EX D16Y8
- Just finished Stripping Sound Deadening from my Hatch, but what could i use to get rid of the tar?
- Brake problem
- Anyone know where this plug is for?
- clutch input needed please help!
- coolant leak d14
- motor swap
- pics of my finished, shaved 94 DEL SOL
- Ignition timing
- rear disc
- speedometer clip question...
- quick mini me question
- Hatch Weight Question?
- HELP time is running out
- driver window molding
- track whore's dont whait until it dry out. video
- need carfax report, help out a brotheR
- A/C conensor help
- Crank seal or oil pump seal leak??
- would different tire sizes be ok for a short distance?
- soft brake tubes, clutch.. any soft hose that won't expand ?
- Weird tranny noise
- JDM Gen 2 b16a Motor With LS Tranny, Bad?
- rpm tac in 92dx
- I need bore size info.any body got a 93 haynes manuel?
- Parts for sale
- GM Syncro mesh transmission fluid
- [HELP] Removing rear strut and spring.
- front clip swap for an eg
- What year is my motor??????
- Sidemarker Help
- new to EG
- help pls.
- Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed?
- lowering
- Si/Ex tranny
- Throttle body swap question
- need help
- How do i REMOVE the REAR SEATS in my CIVIC HATCHBACK?
- EK Civic that I need the Dealer to make me a key for...
- d15b7 distributor interchangeable with all obd-1 d series?
- Urgent!: Code 14 IACV after turbo install. rough idle
- CR-V K24 into eg hatch
- PLEASE HELP. EK rear suspention.
- ATTN: ILLINOIS looking for my 94 civic hatch w/GSR
- ITR 5-lug on a 99 ex, axle size?
- Confused about swap
- f20b in an bubble back civic can it b done???
- Bouncy Idle
- HELP. swapped jdm single cam into 92 hatch.. step on the gas car dies
- Just need to confirm.. # of quarts of oil in B16A
- Would EK rear lower control arms fit into EF?
- Rear Strut/LCA bolt stuck, it's gonna break....
- question about paint job
- header on a ls/vtec
- Introducton Thread?
- FOR SALE 96-98 CIVIC type-R LIP
- 96-98 fogs on 99-00 Civic
- ok, please just answer
- Ek side skirts on Eg hatch?
- my friends has a bone stock h22a swap in his eg hatch and he thinks hes on top of the world
- Vandalized Again!
- OBDII to OBDI jumper
- wat do you guys do with an engine after a swap?
- GUTTED DEL SOL?
- I AM LOOKING FOR MY FIRST CAR
- Aerospeed vs. Skunk2
- Firing Problem
- obd2 emission
- My baby is gone!!!!!!!!!
- heavy vibration ? PLEASE HELP !
- Question about exhaust piping???
- Honda motor guru's, I NEED YOUR HELP!
- ek exhaust
- Help! engine/cluster problems
- loose tie rod..alignment question
- Foglight cover dimensions.
- Valve Sizes
- City Light/Side marker bulb question?
- what numbers do you think ?
- Will a 99 SI muffler fit my 95 EX ???FAST???
- pics of a ek civic
- spark plug gap ?
- Got a leak help with fix?
- D-series axles
- JDM d15b n aftermarket d1b7
- how to install oil temperture gauge??
- How long before destruction?
- Strange TPS voltage reading..
- battery relocation
- legal swap?
- Tokico Spring Rates
- PLEASE HELP! coil over sleeve ?
- HELP!!! Car doesn't run right
- Removing the part stamped SR3-R on inside of door handle
- what series of motor is in a stock 99 civic ex
- How do I remove my AC?
- Wrong size wheel bolt pattern- what to do?
- Intake install question
- urethane bodykits-delsol
- Another leak... when will it end?!?!? How to fix this one? Check it out...
- i broke 2 bolt on my b16 head on header side help
- How does THAT work?
- coil over o-ring help?
- Anyone thats knows about swaps in sOcal come. Help
- civic ecu auto in 5 spd
- HELP!!! How do i check my engine code?
- will lca's from 2000 gsr fit ek?
- need recomands for clutches.
- How often should I replace timing belt in 1997 Civic?
- strangest wiper problem, and im out of ideas
- help.... want to know how does the oil travel to the vtec selenoid. ?
- JDM b16a themostat and temp sending unit??
- Search around..but no answer.....What are the symptons of a cracked lowering spring?
- power antenna question..please help
- eg hatch trunk light
- pressure plate tourque specs?
- Can not drop 3rd..
- Help coil overs.?
- mass air flow sensor causing CEL on, how do i fix?
- Fast Idle thermo valve on d16's
- HELP
- bov flange
- 94 HB window problem
- ECL Throwing codes 7 & 22.. please help!
- engine starting problem?
- How much for O.E.M. fog lights (92-95 civic)
- Civic prices
- o2 help b18c in a eg vx...code 1 real sluggish
- ]]]92-95 gas tanks....possible others?[[[
- car wont start
- Bad gas mileage on my EG hatch..
- Checking Relay in Fuse box
- My PS resivoir has rabies or something!! WTF, it's foaming!!
- Spoon Parts?!?!
- Post your EJ1/EJ2 1/4 mile times with B18C and incl. setup.
- EK SWAPS INFO...???
- where did the tread go on painting dash bulbs
- going turbo for my d15b v-tec need help
- Which cluster is better? Ek4 or CTR
- B16 swap no tach or speed....
- is that my alternator?
- ruff idle.
- which way do side markers go>?
- Tenzo-R Seats
- over heat problem...help!!
- Clutch suggestions...all inputs appreciated
- is this a good deal?
- Would A SOHC Vtec be worthwhile upgrade?
- new
- i installed some oem fog lights
- Skunk2 stage 1's w/ stock cam gears??
- Help COde 36 Problem
- 2 questions... car shaking.. security system?
- Need a good Honda Shop in the Seabrook,Tx area (southwest houston)
- SOHC Compression Calculator
- need help!!!
- 2000 Civic Si Help
- how would power be with 2.5 in. exhaust?
- need help badly
- Air Intake Filter Oil
- front end shake
- VTEC Solenoid Wiring
- 97 Civic DX MAP Sensor Problem
- easy motor swaps for my EK b16a2?? obd2 ls??? what to do, i need it quick
- i need to know if ek shift linkage will fit a eg hatch with sohc
- car keeps dieing
- ATTN: EVERYONE with a b16a2 in a 96-98 CIVIC i need some help!!!
- **Hond/Acura meet Nj/Ny/Pa**
- Need help!!! my car wont start...
- Another engine temperature gauge problem.
- New discovery to my problems starting. All who can help please help!
- need a wiring diagram of a JDM D15B auto
- OBD1 SOHC Distributors all the same? SI, DX, EX
- PLEASE HELP ME? i'm having problems w/ my swap
- can you please help me? problems on a eg hatch
- head gasket problem on a turbo 93delsol si
- B16 Hydro tranny problem.
- eg oem window visors cheeeeeeeeeeese
- remove a side marker
- Help me! Fast~
- EG greddy exhaust manifold fit issues
- Stock steelies size question
- Do EK owners need to cut the frame with a turbo manifold?
- 98 civic dx need help with stud size for civic ?
- P07 Ecu
- tie thingys with motor mounts?
- Is there such a thing as a 1999 JDM b18c gsr motor?
- Is a CTR wing not legal?
- i neeeeeeeeeeeeeeed to know
- Where to get a COMPTECH MUFFLER
- what rear seat's fit in 95 dx coupe
- changing springs in an EK?
- how does my flywheel look?
- Alternator pivot bolt wont come out.....
- I need help 5 lug on a 2000 ek???
- CX Catalytic Converter..???
- Is there a way to make vtec work and everything that goes with while using obd0
- intake manifold ?
- aside from the performance value
- taking out the brake light.
- parkign light wires
- where is my IACV
- Knock sensor??
- rims for an ek
- what rubber parts need to be renewd ??
- d16z6 oil pan bolts (pita?)
- Tax Money Exhaust..
- lookin for a b18c1(who's the best to get one from?)
- d15 non-vtec I'm having trouble finding the speed signal wire on ecu, for turbo timer
- coilovers fit on my EK?
- CHICAGO honda/acuras
- d and b series flywheel bolts
- will this intake manifold fit??
- Help shift linkage problem 99 civic si
- Tach jumping and car is jerking! HELP!
- Short shifter 95 del Sol Si
- Valve Ajustment.....bad idle now...
- Am i going to tell the difference between 15x6.5 and 15x7 on EK?
- Will an EG coupe power windows work with the EG sedan? Searched, but no answer
- EK si grill....... will it fit on to 96-98 civic ?
- HELP! front suspension
- valve cover bolt Question...with pics
