View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 97 Civic coupe/00 Civic front end - What wheels will fit?
- B18c1 into 2000 ej8
- H22 EK Build Thread - Keeping it Clean for New England
- tech
- does my 95 del sol have a lsd trans
- Thinking of getting a 2000 EX /w bad motor, what motor?
- Weird Clutch & Vtec Problem :(
- Shifter bushing question
- b16a bogging at 6k rpm
- turbo b18c1 oil catch can issues
- 97 civic ripper vids
- 96 civic trunk hydraulics
- Help with color code
- Shift Linkage Q. Not the stupid one either. Please Read.
- EK/D16Y7 Front Mount Bolt Size??
- GSR TPS question
- EG DX sedan, hamster wheel noise.
- 94 Civic d16 vtec - bogging and misfiring
- 99 civic EX-Weak Spark/Wet Plugs
- 92 hatchback rattle
- recommended clutch release bearing
- oem or aftermarket carpet
- Corner light wire harness
- GSR EG Hatch Build
- 1998 civic running problem
- Want to install power window locks and mirrror in 99 Civic CX?
- Bad temperature sender unit?
- EG Potential Mods
- battery draining
- 98 civic ex having problem with my a/c
- S40 tranny in 95 hatchback d16zc
- b20 head on ls block
- intake cold air/short ram
- Need help on replacing Rear Trailing Arm
- 95 Civic EG: leaking coolant by dizzy
- Car stalls even after replacing ICM. Help!
- will the following front LCA fit on my 94 CX eg hatch?
- 99 civic dx with 97 b16b swap harness advice
- starting trouble - ton of sparks when plug in wire from starter to battery
- Need help ASAP fuel pump relay single v 95 dx coupe
- civic suspension?
- 96 ek sedan lx, headlight dim, flicker while hitting the brake.
- Lost Motion Assembly Bad/Worn. GSR
- my engine revs high and bog badly, and suggestions?!!!
- overheating..tried evrything :O
- stock b16a with gt35r
- 94 Del Sol Windows wont roll up...clicking sound
- fog lights
- 92 civic wont maintain camber
- 96 civic with 91 crx hf stock engine -- mixing alternator to ecu wires
- sway bar help
- ABS kunckle/spindles on non-ABS car
- H4 Bulbs in Mercedes ?
- Where can I buy a D15B oil control jet?
- Starting issue. Pleaaase help :)
- GSR in an EG - low idle and running Rich.
- 98 civic crank no start (no spark?)
- URGENT HELP! slave clutch cylinder
- wire tuck, with head light problems...
- Seats that would fit a 95 civic...
- k20 swap in 97 ek
- D15B engine with Twin Carby has idle issue - Where is my EACV and throttle body?
- Best choice of fuel injectors for b-series ITR and LS vtec?
- building a type-r
- Tachometer flutters and can BARELY accelerate without sputtering
- broken ac compressor??
- 95 Civic struggles to stay running and has smoke coming out of the intake
- 99 hatch - Srs light stays on and comes back after a reset
- Where is Honda Civic 1993 - EACV, Idle Adjusting Screw and Fast Idle Valve?
- 99 si front brake conversion question
- Slide pins replacement
- HELP! GSR tranny grinding
- em1 steering wheel vibration, searched now desperate
- b16A2 into an ek hatch questions
- alternator good but drains my battery wtf ?? helpp ??
- 96 Honda Civic. No power at all. Help?
- gsr in 98 civic over heating
- Ek hatch cargo cover - strap installation question
- eBay Replica EK9 Type-R Carpet?
- Mini-me in EJ8
- A/C problem, please advice!!!
- HELP Del Sol wont start
- losing control??
- 93 eg8 with a y7/y8 mini me -- low idle issue
- **HELP: GSR brake conv. Now it feels like brakes are engaged**
- Timing question
- test alternator - are my numbers good?
- 94 Civic - b16 has VTEC bog
- IACV question
- 92 Civic Si Speedometer not working for the speed but …
- hp to whp conversion
- 1998 Civic: Temp/Fuel Gauges not working properly
- Uneven 92 Civic Si after changing springs
- Jshmotors.com ??? help
- E46 m3 rear lip spoiler.
- cylinder head swap
- b16 swap
- oil sludge under distributor?
- 98 civic rack and pinion in a 95 lx????
- B16A OIL PREASURE
- Help with a JRSC 94 Del sol V-tec
- does anyone have a pics of the driver headlight
- Help . eg overheating when drive long distances
- Failed Emissions, NJ Inspectio
- Question about EG side moldings
- Overheat, no signs of head gasket problems - suggestions?
- 1994 Honda Civic difficult to start when rains
- VERY minor head gasket leak...would you even bother?
- Steering wheel adjustment -> Alignment issues?
- PLEASE HELP! I need wheel spec help
- 92 eg si build
- Starter problem Civic LX 97 all D series starters compatible?
- what fog lights are these??
- battery fuse
- HELP! Turn Signals wo't work
- What alternate Heads fit on my 94 Del Sol
- 92 Si Hatch no left headlight and not turning over
- Car is stuttering/bogged down.
- no clutch pressure...
- MAJOR ELECTRICAL PROBLEMS PLEASE HELP!
- EK Hatch area water leak.
- 95 civic eg: Camber kit issues. NOOB
- 94 civic overheated and now starter won't catch the flywheel
- Identify This Plug
- OEM d16y8 cam specs
- d15b8 trouble running.
- My 1992 Civic CX Build Full Skunk2 Build
- usdm righthand drive honda with a 2.6 v6 in it?
- 97 ex coupe crossmember same as 99 si?
- Valve Cover Question
- B16 sparkplug problem?
- can i bolt up a y8 transmission on my d15?
- b18b swap final details
- Intermittent Hot Start Problem!!
- STARTER PROBLEM..
- CEL code 91 Question
- OBD2a D16y7 A/T Engine Harness
- B16 wont start.
- IAT wiring question 93 EJ1
- CEL and Other issue
- VTEC wheel Bearings?
- VTEC...
- are b series ac bracket PULLEY the same?
- EM1 engine over heating problem!!
- Boosting my lsv
- Rebuit b18c1 hesitates at low rpm
- B18C: High idle @ cold startup
- engine sputtering!
- rear disk conversion
- O2 Question
- JDM LS motor in EG trying to Diag dizzy
- DEMON speedo needle
- new to me bone stock 1993 eg hatch!!
- 93 civic help
- d16y7 got 5 grand what to do??
- Need quick advice! 94 civic si f/r swaybar on CX
- Weird mini me question....
- 97 4dr Vent Visor Issues
- best time to do rust repair??
- 98 civic power window
- New battery time?
- 97 LX Strange Startup Behavior (Video Included)
- My little white hatch build
- Difference between b16 and b20 knock sensor?
- Stock d16z6..just won't go!!!
- Brake Caliper Problem
- AT to 4speed MT
- About to do CFK-Bypass Trick....
- b18c type r knocking vtec like sound between 4-5 rpm
- Idle problem. any ideas??
- The never ending EK build, thoughts please
- questions about honda civic dx
- Buddy Club Racing Spec Cam Shaft B16/18 Spec III Plus or spec IV
- Sub-500 mile engine, oil in all cylinders..but only 3 exhaust ports? So lost..
- Rear Foglight switch wire diagram
- Integra Type R Rear sway on a 96 Vtec (b16) del sol
- stuck with p72 immobilizer
- What would you do if your atf plug looked like this?
- Speedometer Going Crazy
- manual door to power? 93 civic coupe
- skunk2 throttle body, throttle sticking... annoying as hell...
- MAP Reading 122 KPa?
- 00 Civic EX - heatingand A/C not working properly
- DIY: Single cam red wrinkle paint
- CKP CYP CEL LIGHTS NEED HELP.
- Roaming Idle...I've tried everything...everything
- What type of head do i have? N00B with a wrench.... HA
- 94 del sol front engine rwd ideas
- 95 Civic EX Speedometer/Odometer/Trip Odometer Stopped
- What is avg normal time for A/C comp. cycle?
- Gauges messing up while driving
- delsol MID SWAP?
- Help identifying this AEM fuel rail and Injectors?
- 93 civec help
- Keep Blowing Battery Fuses. PLEASE HELP!
- 92 hatch no brake lights
- is there a difference in civic 99 ebp and 00 ebp?
- First molding front lip spoiler
- Headgasket info request
- Buying an EK civic... have some questions on space
- D series crank question?
- 99' Civic, Speedometer or VSS problem?
- Help me find out what is coming out of my middle vents!?!?!
- jdm b18c on civic si- cel on
- car wont start, solenoid clicks.
- ZC engine in 98 civic
- Clunking/Knocking noise after B swap?
- seat rail question
- OBD1 and OBD2
- How do I take apart my Y8 head?
- B16 vtec not pulling after installing resonator
- Where can i get the pins to wire vtec?
- brake issue
- D16Y7 - do the pistons hit the valves?
- Will an integra ac compressor work in my eg?
- ????....i have a couple question about swaping my 95 civic couple with b16a2
- B18 idle air control valve compatible with b16a
- obd2 read error???
- h22 civic wiring harness question
- D15B7 - Swap in Z6 or Y8?
- 1997 civic si spoiler bad?
- could a bad pcv valve on my del sol cause bad idle and mpg
- D16Y8 sensor in water neck...
- Cleaning upholstery without altering interior's smell
- D16z6 into a 97 ek hatch
- Spoon dampers non-adjustable type - will they lower car on spoon springs?
- automatic transmission cooler lines
- sqeaking noise
- 97 Civic EX Overheating...
- blower does not work well
- camber, YES IVE READ THE THREADS.
- 1992 crx vti
- 1997 civic hx vtec motor help
- morbius18's Del Sol build
- adding power windows 95dx
- Need help, cant get cv shaft to fully go in on B16 tranny, right side.
- Need picture of driver window plug.
- 2000 Si intake manifold on d16y7 problems
- Brake light problem which leads to car not starting...its my DD
- Cluster light malfunction
- Quick Question From d15b7 to D16z6...
- Will 2001-2005 Civic seats fit in a 98?
- Questions on supplies needed and how to run VTEC wires from cabin side connector to E
- rear disc conversion
- LS/Vtec question
- 1994 with a D16Y7 engine
- just steam cleaned engine, my experience
- 1997 Civic Hx center Caps help
- spoon b16b stroker kit
