View Full Version : Honda Civic / Del Sol (1992 - 2000)
- OBD2 VAFC OR OBD1 CHIPPED ECU?
- civic 99 ex battery or alternator
- CarFax Request
- looky what i got
- obd2 rumor true??
- program keyless entry remote
- Kumho Ecsta 712 vs. Yokohama AVS ES100
- 92-95 Amber light help?
- Are all rear lower trailing arms interchangable?
- clutchmasters lightened flywheel with ACT 6 puck clutch ??
- vtec question
- EG civic question
- got another honda
- billet lca
- damn oil drain plug
- INFO>....
- Megan Racing Hi Flow cat
- Change Color--> GAUGE CLUSTER <-- *bulbs sizing problem for DX*
- front lower control arms
- o2 sensor
- i got a rattling noise toward the front end of my civic is that the heat sheild and how could i fix
- pulled out my motor last nite need HELP dropping in my d16y8
- has any one ever heard of a camshaft breaking?
- Where can I buy a turbo kit for a D16Z6 for cheap?
- New clutch
- Help 94 civic dx!!!! need motor!!!
- *Huge Pic Update of the Sol* WARNING 56K*
- is it possible to make ur own custom turbo?
- been looking forever
- Anyone Ever...
- where's the best place to buy rim & wheel package
- Titanium valve springs and retainers..louder??
- owning a shop
- Spark plugs revisited...pics for you to diagnose with me!
- ctr sideskirts vs. usdm ek sideskirts?
- Yet another idle problem. Searched already and nothing
- check out this DX---pics
- what would i need to make this a complete swap?
- motor mount inserts
- Cams, intake & ignition
- To Remove or Not To Remove Factor Reflector infront of bulb with HIDS???
- Steering wheel help
- question about Tanabe Racing Med Exhuast
- what do u think??
- Replaced spark plugs... still runs like crap!!!
- question about Osaka Jdm motors???
- EG Help please
- 99-00 oem fog surrounds colour question.........
- upgrade 9.5 to 10.3 inch brakes on del sol si?
- I HATE RAIN!
- Thinking of new rotors, whats out there, what to get??
- questions about apexi N1 muffler!
- b18c1 passed smog, next stop state ref
- Pop Pop Exhaust
- k20 in EG anyone know what clocks down a 1/4 mile?
- BEWARE of Sport Compact / Racer X sponsorship!!!
- Skunk 2 valves?
- building my tranny need opinions...
- greddy evo question!
- Progress of my hatch
- Is this normal for a tranny?? (pics inside)
- Trunk floor board?
- B16A2 PCV
- eg k20
- HELP...Nitrous problem
- eg k20 swap
- i have a problem
- Cooling problem?
- GSR brake set up..
- EG Headlight question....like EK?
- 99-00 Si gauge cluster in my EK sedan. Help!
- SOHC d16y8 turbo
- JDM B16A into 95 Civic EX
- Do all 96-00 civic ex's have vtec?
- help with b-18 install
- Painting my rims any help?
- B16 head
- I added 5 HP today!
- Looking to paint my car in SOCAL
- Radiator support for Delsol
- JDM Civic Type R Power Folding Mirror Switch
- headlight difference between 99-00 EX and SI
- Help a dsm guy w/ questions about hondas (not a hater)
- civic dx header??
- just got a tune up...and gosh it feels good..
- Car fax Please
- HOW DO YOU LOGOUT AND LGIN AS DIFFERENT USER?
- HELP!! GSR/EG swap wiring
- 88-91 B16a1 is a 00 Civic Will it work??????????
- 92-95 coupe front bumper and rear bumper support fit hatch???
- cant find the RWD H22 DEL SOL
- Tire Wear (Toe,Caster)
- High Flow Cat QUESTION
- Clunky Idle. Need Help
- civic type r spoiler
- EG coupe front bumper....???
- Think I bent a valve?????
- any clue where to buy bumpstops?
- HELP HID HOOK UP PLEASE HELP!!!
- K20 into an em2
- In Fu@&ed, how much time left B4 engine completely gone??
- o2 sensor?
- Will EK Hatch 5Zigen Exhaust fit my car?
- stock b18c1 w/ p28(mugen) pros and cons?
- Help! Stock Type R muffler Bolt up to a Del Sol?
- looking for an h22 swap
- Intercooler w/ OEM fogs?
- Idle going crazy, help please
- Please help me out major suspension problem
- crazy timing problems with my z6 zex 59300 cam in my y8 head! *continued*
- need a little feedback please
- lookin to trade my black sparco seat with sliders for two front seats
- Can the mugen muffler....
- Hey, RIGHT ON "Certified Honda Technician"
- EG & EK interchangable seat brackets?
- Does anybody have a pic of a 99-00 Civic SI Prop. Valve?
- speaker size
- I need a d16z6 crank please help
- what does everybody think about the srr sway bar kit is it worth it
- need some bolts...SoCal
- Eibach Pro-kit on my 1999 ex
- '94 del sol VTEC + ITR shocks + spoon springs =
- What is you ideal size wheel
- More JDM B16 in 92 Si questions.
- Water Vs. D16z6: Uh oh....
- Help...No tailights or corner lights
- Car Running Rich After Sitting.....
- Broken Engine Bolt
- knock sensor question...
- pin out
- Anybody seen this civic or know where I can find the owner?
- help me decide
- ek coupe rear lip fit ej1?
- quick question about 92-95 suspension
- passenger airbag alternatives
- Quick Master cylinder/Brake booster question
- fiber images hood wont close...
- will worn shifter linkage bushings cause grinds?
- Del Sol B18 auto question
- 15's or 17
- EDM 96-98 EK Amber Clock Interest?
- b16 headers
- 99si swap into 94 ex
- what size tap do i increase to.. from M10
- why does my EG grind when i start it?
- CARFAX please.
- Hi Guys.New Here and I need help? 1:03 AM 2/7/2004 Reply Edit
- H22 is Here!!
- GSR suspension -> 98 Civic EX question
- Car broken into. Need new ignition. Which part to buy?
- itr springs?
- what kind are these cams?
- Helms book?
- look what i baked~!!
- how do i post pics?
- a B16B of B18C5
- carfax help needed real quick
- All motor or turbo?
- B20 long block for $450? Need your opinion
- Swapping Civic upper control arms to integra...
- Tokico Illumina or KYB AGX shocks?
- speedometer reads 0 mph while doing 20mph. then reads 90 mph while doing 60mph.
- does 94-01 teg carpet fit 92-95 hatches?
- TACH GONE CRAZY?! PLEASE HELP!!!!
- offset question...
- need help with speedometer... it is totally off.
- Any difference between a 1992-1995 Civic DX/EX timing belt?
- Where to get Wiseco piston rings......?????
- Spoon N1 installation
- hks turbo timer install
- New Exhuast
- teg tie rod on a eg
- Anymore suggestion for my current suspension?
- compression test
- Apex N1 installation
- how much is 4-lug worth?
- D15bvtec?
- Need pics of a EK 4-door with door molding shaved, but groves still there
- Help me determine why i keep throwing a cell please
- Need help with overheating (yes I searched)
- question about civic header and exhaust!
- Ground Zero at Portland Auto show
- f22
- broke my tps on my 2k si throttle body would an ls one fit?
- OT: Pictures from Japan
- what suspension
- Quick question about my exhaust
- Steering wheel + brake pedal shake when I brake,rotors?
- mounts for b16 swap
- heater gets cold at idle
- civic revving noises
- these tires fit?
- I need information about this engine
- helms manual, which one should i get?
- Installing new spark plugs??
- Civic HX alloys?
- Ground Wires
- red/clear tails "best"
- 92 Civic w/ b18c. What cold air intake should I get for it?
- ??? About a seller ???
- I searched but i couldnt find it "How to paint mirrors with spray paint"
- Help! Need pics of a SuperSonic blue Honda! :)
- does anyone have any pictures of a 96-98 oem front lip?
- Heres a couple more (vid video)
- Why can't I access my Avatar?
- lowest sitting oem seat
- Y7 whit stuff question!!????
- Code 1 & 23
- Removing Power-everything
- Group Buy
- ARP headstuds: z6 block/y8 head Which studs?
- shaving emblems?
- For all the SOHC monster makers... look at this head?
- Auto tranny starter vs. Manual tranny starter...
- $450 for power windows/locks/mirrors & all parts + installation?
- 03 CIVIC SI
- Wht does the number after EG signify..ie EG6 EG8 etc...
- my hatches
- Why does my car keep dying on me?? HELP ASAP PLZ!
- can i use the same injectors?
- Rods for d15's
- NEED HELP QUICK
- just install new header but something is wrong!! pic inside
- 92 Si needs new head gasket...mod suggestions while it's "open?"
- Removing ABS in my 94 hatch
- K20 anyone? ;)
- Oil leak, help find where its from!
- Turbo d15?
- D16Z6 Distributor Filling up with Oil? 2nd one
- Phantom Grip LSD
- Cheap bulbs for everyone
- Replaced Steering Rack: ALignment?
- WTB: 92-95 civic hatch si in SoCal
- 92-95 Civic hatch with CRV drivetrain and 5 speed man Tranny????
- Camber Help
- piping
- WTD:92-95 civic ex door
- better steering
- Can't remove crankshaft pulley - PLEASE HELP!!!
- how does a real carsound cat look like?
- Reverse 'Glow' Gauges -=in Kilometers?!?=-
- Headers for a 96 uk civic 1.5L
- EG retrofit completed
- BUSHING FOR EG
- 97 lude brake swap into 92dx possible?
- just did swap having backfire probleM
- the clutch that looks like a fan?
- right hand drive EG!!!
- b16 swap question???
