View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help car smokes after it's warm
- Knock Sensor on D16Y7
- need help
- EM1 question
- Integra cluster swap in civic
- Turbo with a/c question
- Reinforcement Bar Removal
- EM1 5 Lug Conversion........Now NO E-BRAKE
- clusters
- charcoal box and throttle body water line
- HID need relay or not???
- toggle switch and fuel pump? headlight wires?
- clutch problem....
- IACV Fix help
- car wont rev after warmed up
- Retaining Power Steering and A/c after swap?
- SIR II intermediate shaft question
- What distributor do I need?
- 96-98 engine harness diagram
- 99 Civic Hatchback tail lights
- overheating of civic
- factory keyless entry
- Wiring schematics
- Omni power
- what type of engine?
- D15B7 Revving high?!?
- D15b8 into vx O2 sensor CEL issue
- plexi windoes for ek hatch
- distributor fits?
- new project 1994 shell civic cx
- Cylinder leak
- 5 spd single tranny id help
- DelSol Rear fog light where to get it
- Over heating 95 honda civic dx
- low idle when stopped
- What color is this switch?
- Searching for a reputable shop in WNC
- Are all B16 flywheels the same?
- Anyway to fit an integra arm rest into a eg?
- Any way to fit an integra arm rest into a eg?
- WTB H2b Header
- My honda is a p.o.s. alright
- JDM D15B7 swap sucking on gas mileage...
- Horn wire?
- Im a new guy. (pics added)
- high flow cat question
- One mount, or whole set?
- motor makes a winding noise
- heater core -del sol
- A/C Compressor question
- cant get my mini my to start
- Adjusting the Cams?
- How to install Tokico Shocks ok EK?
- Headlight issue
- si brakes on ek...(cx)
- EG rear hatch won't open!
- Are my bearings toast?
- Safc install on ek 96
- what turbo manifold with a/c ? ek civic
- y8 b7 mini swap, do i need si/ex injectors?
- oil leak from filter
- Motor Swap
- b7 to z6 swap, MAP sensor/wiring questions
- rebuilt/built JDM B16A del sol
- B16a2 97ek catalytic converter help???
- power doors control unit
- need 00 civic door panel
- tranny oil leak
- Rough Gas Pedal
- cylinder boring and honing?
- Anyone else waiting for the QSD h2b kits?
- non-vtec D16y7 convert to vtec????
- D16A6 vs D16z6 and y8 ??
- how to convert my p2e ecu auto to manual ?
- Misfiring? Flooded?
- jdm type r intake manifold or skunk2?
- Head gasket difference ??
- wont start help
- civic low idle
- Do you think its the harness or what?
- ctr side mirrors
- Fuel rail help!
- Code 43, possible oxygen sensor..??
- installed a new cluster..now nothing works
- Crankshaft problems
- Cam Gears And Fuel Rail Will They Fit?
- spark plug cover question will metal interfer
- Mini Me Head Help??
- dyno tuning, VTEC not working
- Exhaut/Tranny Rattle...
- Clutch write-up?
- how do u get pin for shifter lever out?
- Need help with 2000 ek power window/lock/ mirror conversion
- Clutch?!? LS/Vtec supercharged del sol ??
- suspension
- wireing harness i think
- code 22, what do i do?
- 98 swap b18c1
- Vtec not working, any help appreciated.
- 1994 civic dx coupe power increase?
- auto to manual
- new/first honda...
- D16y8 vs skunk2 intake manifold
- What kind of trans fluid???
- Intake!!
- Doin rear discs on my 00 EX, master cyl and prop valve questions?
- How many quarts?
- sqweeky noise while driving my em1
- civic question.
- Code 41 o2 sensor heater.
- B16a/B18b/B18c into a Eg Coupe
- Horsepower question?
- Odd engine trouble
- Rear Disc Conversion on 5th Gen Coupe
- What headers and full exhaust?
- sohc vtec ZC, trying to restore some power
- lack of power
- need help removing drive shafts
- re-wiring a hacked dizzy
- wiring vtec selinoid to ls harness
- Rear Seat Belts?
- Quick question on EK/CR-V gauge compatibility
- h22 help
- Keys left in ignition beeping - How to fix my problem?
- Any difference between OEM Type R and 00 Si Pressure Plate
- my new project!
- How to buy a new instrument cluster plastic cover
- Are these suppose to be B's?
- 2 clutch cylinders?
- busted ass glove box
- my 94 hatch b18c build thread... lots of pics
- How can i get stripped lugnuts off?? Help ASAP
- diagrams
- D15z1 Vx Hatchback
- timing ? on d16z6
- 99 b16 swap to a 95 Eg LAGGING major power from mid range to high RPM
- RHD Help!
- clutch always engaged
- d16a6 compatible w/ a y8 tranny?
- Mugen vs Spoon vs TODA headgasket
- OEM Mats
- b16a1 into 95 hatch
- manual tranny
- seat bracket DOSN"T FIT!!
- injectors dumping
- Question on Bolts
- Automatic shifting problem
- Timing belt "play"
- removing and replacing headliner fabric?
- What's this part called?
- OEM 96-00 window visor
- Chasing down a short
- Cam qustioned
- Header inquiry 99 hx w b16a
- y8 b7 mini my swap what dizzy do i use?
- Where To Buy a legal California Cat. Converter
- PUTTING/FINDING ls 5th gear~b16a stock tranny
- holy wind noise batman!
- best way to turn cam?
- Ek keeps cutting off and dying out
- Skunk2 Intake Will It Fit??
- 99-00 Civic Sedan Hood
- D16z6 head internals into JDM D15B?
- Ls swap into ek NEED HELP
- what is the best ecu for b20 vtec
- Stalling/surging issue may be diz, alt or tps? details inside
- o2 Sensor Question
- Advice onSkunk2 Pro S Coilovers Part no.541-05-5720-002 for a Del Sol
- d16z6?
- White smoke WTF! Plz help.
- coupe bumper on a 4 door? (eg style)
- Interior brake light wont go off
- 98 cx drums to disc......
- will a dc header for LS fit gsr and b20?
- Guage cluster / Climate Control wont light up
- how to put a obd2 b20 vtec in a 95 obd1 coupe?
- fluctuating idle problem
- Code 9 CYP- cylinder sensor???
- OVERHEATED for 30-40 seconds ?? BLOWN ENGINE? RINGS ?? HELP
- hey idk if anyone can help here..
- injectors/fuel pump running constantly! any ideas?
- LOTS of preasure in cooling system from crankcase ? PLEASE HERLP me out !
- b20 vtec or jdm gsr??
- Finally finished EG project car
- Clutch and transmission questions...
- any sites to download electrical manual?
- where do ppl meet up in D.C.
- idles way to low and stalls
- Throttle body help
- DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch
- Replaced Plugs & Wires, Now something isn't right.
- PIC REQUEST: Red Rota GT3 on EK <--------------
- Civic motor swap b16
- Will any B series header work with a b17 gsr?
- swapped civic needs to be barred
- b20vtecy
- i need to replace my fuel tank and i have ?'s
- mini me problems in lake elsinore
- stereo relocation?
- need help!
- Tail gate shocks for a hatch.
- radio
- Car wont start without me giving it gas/reving it
- Tell me if this makes any sense, fuel issue
- hasport motor mounts
- is this a vacum leak?
- getting ready to supercharge my d
- Quick header question
- Car won't start--details inside
- eg6 control arms
- My ek with gsr overheating...
- b16 intake manifold
- Need Camber Kits Now!
- h22a swap
- Idle help (please help asap)
- crank pulley nut
- trouble with balljoints and tie rod ends
- my car got keyed should i report to insurance???
- help with auto to manual swap thread
- GSR wiring in a 95 EX coupe
- The DEFINITIVE 92-95 Civic Power Folding HEATED Mirrors / Locks / Windows DIY Guide
- radiator core support swap (t bar) swap
- Broken trunk latch need help!
- How To Do a Wire Tuck
- Chipped ECUs for D16y8?
- Big bang! With turbo install.....
- Please help me!!!
- Location of 97 civc Primary O2 sensor!
- 92 si stereo wireing diagram
- D16 Valve cover interchangibility
- installing ws2 on ej6
- need help adjusting coilovers please!!!!!
- help asap need nos refill places in Los Angeles
- manual help please
- cleaning throttle body and iacv
- need input in what i can do
- Limp mode? help please
- Vtec leak
- Would 96-00 civic shocks/springs fit a 92-95 honda civic?
- Wondering how much 1994 Si
- '00 Civic EX w/ B18C: Power Steering Install??
- Visor Repair
- need torque spec on b16 motor mount bolts
- Gold Civic Introduction
- Do i need to add vtec wiring on type r
- itr oem: header, exhaust, intake manifold, cams on b16
- Stolen Civic
- h22 or ls/vtec swap in ej1
- Suspension question
- Is there an easier way to change springs?
