View Full Version : Honda Civic / Del Sol (1992 - 2000)
- the rear sags....
- quick question
- diameter of the D16&B16 pipes...
- Mini-me?
- B16A timing belt cover on b18a1
- oil pressure causing vtec CEL?
- 00 bumper
- MAP SENSOR PROBLEM ON 95EX wit JDM B16A
- ex headers
- rear sway bar in 00 sedan
- d16y7 noise problem help any one
- Vss wire order in plug
- Steering problem
- Honda Tech I need your help, something is messed up!
- H22 VIbration
- stock exhaust on h22 swap?
- another transmision question
- sway bar??
- My new motor does the coolest trick. It sprays oil out the back.
- B18B1 swap into 99 EX questions...
- decisions....boost a d or n/a at b series
- Car won't start - wierd situation
- Which one works best with my EK?
- need a rpm tach
- problem when car is cold.
- EK4 Wiring Help? D15B obd2 to obd1 p28 vtec
- went to track.. noticed huge engine mount problem. help!
- Will a 96 LS rear sway bar fit 92-95 eg
- D15B Question
- IS there diffirence in performance?
- d15 won't start
- obd2 to obd1 help!!!!
- car won't start when warm.
- Finally found a civic that i liked...
- Exactly how hard is an H22 swap into a del sol?
- need help with clutch
- Smokey Exhaust
- roof spoiler for eg civic...
- hondata?
- OK IM STUCK NEED SOME OPINIONS GUYS....
- ROchester anyone??
- 01 integra lowering Springs Fit on a 96 del Sol??????
- ok i checked that now what do i do!?!?!?!
- Distributor Questions??
- freshly built b16 question!
- wat is this motor i was told it was out of a 99si but i dont think it is
- Can I throw a EX Gearset in a DX Trans?
- INTEGRA DASH IN EG HELP
- CEL Code
- should i buy a auto
- sensor/vtec problem
- dash lights dont work? help puh leeezzz
- d15B7 + problems with rev limit.
- starter wire
- aftermarket exhaust for 1999 honda civic ex
- pic request 96-00 civic hks exhaust
- B16 swap HELP!!!!!
- should i use trim pait to paint my side mirrors?
- someone help me out!!
- 97 Civic ABS plug??
- Chipped ECU Vs VFAC
- eg pics
- map sensor
- can I bar a jdm b16 in a EG?
- 95 honda ex brakes
- my clock doesnt work in my sol..
- how to get oem fan to kick in earlier ?
- my car
- Replacing the climate control
- oem honda parts
- Will a Full b20 Crv swap (automatic) run perfectly in an automatic civic ek hatch??
- transmission fluid
- driver window off track...how do i?
- 99-00 civic ex/si is there a write up step by step how to install these jdm foglights?
- how to remove this gunk on my car
- OEM DC5 axle back/cat back fitment on eg
- QUESTIONS PLEASE ANSWERE?
- where can i buy door panals!
- vtec controller?
- thermostat housing
- new member :-)
- code 19 on a manual transmission? (a/t lock up solenoid valve)
- Loose Shifter feeling shifter...wierd noise?
- '95 del sol vtec specs...
- jdm cluster
- ITBs
- ***Radiator Questions/Opinions Wanted***
- cruise control going Nuts ???
- Problem with Windshield Wiper/Washer on 1997 Civic - I think
- EK4 idle trouble after setting vavle clearance
- ARGH! What is the part number?!?!
- JDM OBD1 B16 Into 1999 Civic DX Hatch
- I need to read the rules
- D16Y7 INTAKE
- LS head vs Type R
- Erratic Idle after Skunk2 Manifold install in B16
- 92 civic fuel pump relay????????
- VSS trouble code, no problems with speedo..
- bleeding brakes
- Greddy Intelligent Informer Question
- JDM H22a SWAP
- my car used to be automatic now its manual... gotta tech question..about wiring.
- Power lock does not work.
- Need Help Choosing Mirrors...
- 99 00 PWR WINDOW/LOCK/MIRROR CONVERSION
- Fuel Problem please help
- Help with radio
- Need Help w/ Boosting
- GSR dual runner Intake. (Clam Shell) Any good?
- idle air control code , with bad idle and tip in on throtle very jumpy
- how do i change the title of my thread?
- 93 ex with a 00 civic engine i think, idleing problems, please help
- rev limit d15b
- Plugging FITV?
- is this wiring diagram correct?
- cranks sparks but no start
- Where to buy T30 Torx driver or bit?
- help!!! 92 4dr wit a cable tranny, yes i kno i kno i seached!!!
- WhAt To Do??????
- New Build 94 DX Coupe for Road Racing
- b16 swap v-tech problems
- can anyone help me find a hatch for sale
- what is the hole on the intake manifold for?
- bumper plug install, holes too big?
- Buying a swapped EG hatch? Good idea?
- Someone Please Help Me...
- p30 chip
- pricing
- Update on mini-me swap
- need help with installing hondata s100
- Ek cluster question(dont flame plz)
- Good sites to get usdm motors?
- i have a 92 si i dont know should i keep the d16z6 or swap it with b18c1
- rear strut tower brace
- ek coupe weight
- Auto trans Problem, any tips?
- MAP sensor Q
- Swap Questions
- does anyone know how to fix this?
- anyway to run the odometer miles up?
- h2b or h22 or b18c1
- Honda civic speed sensor?
- jdm fog lights
- Will my d15 timing belt work on my d16 head?
- PCV Valve Q
- Need Help On Motor Again
- FET quick release ...
- gauge cluster not working
- Car Won't start 95 civic
- I NEED A WINDOW REGULATOR FOR A 00 CIVIC SI
- Grinding during shifting
- Paint that matches the Type K code?
- HELP PLEASE!!!!!!!!!
- suspension stuck in fender well after puttin camber kit on??? HELP
- hatch parts?
- Looking for a cheap roof-rack
- Will a type R exhaust bolt up to an other wise stock EG coupe? Nope
- Projector Lights?
- 93 vx few questions..... HELP
- OBD-II VSS into stock EG?
- 96 civic tranny help 2nd gear not working PLEASE HELP
- TPS C E L
- OBD1 ECU Questions : PR3 vs P30
- anyone have a chart for torque and horsepower
- Was going D series turbo, but found an awesome deal and have a few questions about H series...
- srs light
- Need help on 95 civic ex
- power window keeps coming off track!
- Bad idle, Tryed a million things
- which would you rather have b20 block with b16 head or b18c5 type R
- Vtec problems, is it related to ECT sensor
- Slight Bogging...
- !!!!!!HELP!!!!!!!!
- apexi afc neo p28 help
- measuring drums
- what is this sensor?
- Need some help with my eg :(
- nobb Q? jdm D15b water pump/timing belt change?
- ITR Brake Booster in an EG/EJ civic?
- Recharging my A/C after a swap how to go about it???
- ls cloth seats into an ek?
- gears popping out
- Fuel Filter
- i have a h22a eg need help
- b20 problem
- need some help finding thise fender flares for an EG
- Car stalling
- 97 honda civic tranny problem
- RSX Muffler w/ Catback?
- Rattling noise and no working AC on 2000 Honda Civic Si
- 96 dx auto hatch high idle problems when car is warm
- ECU HELP!
- car is cutting out
- removed dash?
- trouble w/my power windows and sunroof
- H22 EGH2 motor mounts and Skunk2 intake manifold....will it fit and lets see them if so
- fifth gear poppin out!!!!! help please!
- another one gone....
- How to wire sub and amp to stock unit?
- Check Engine from nowhere ...
- Stalls
- 99-00 Dash wiring question?
- How to install a AEM wideband with bosch 02 sensor...need help guys
- Installing new calpiers...anything i need to know?
- Bent trialing arm on disk swap, can I swap trialing arm with drum setup?
- Suspension on EK?
- How to remove An EG dash
- 97 CIVIC (searched)
- Cleaning the Throttle Body on 2000 Civic LX
- Noob Question: Would lowering a car increase gas mileage?
- PNP and other options?
- header size?
- Overheating problems..
- Use of dielectric grease
- Would EK Sparco seats fit in an EG?
- Searched, ECU ??? JDM v. USDM
- Help? Advice. Broken Valve.
- Smoking Alternator?
- half shaft tranny cap keeps popping out of place. and spilling tranny fluid
- MPG b20 into EG...12MPG>>?WTF
- B18A1
- Would a S2000 Fuel Pump fit my 1999 SI?
- What to build
- Spun rod (need engine swap
- can a z6 flywheel fit on a y8?
- No spark on D15b swap
- dashboard lights don't turn on
- ******Blown Head Gasket******* what to do???????????
- showing my civic
- I need a battery relocation kit for a EK 99 civic
- North ATL -- Woodstock Area
- Slamming my EG on Tein Monoflex + edfc.???
- b18 build
- are v spec coil overs any good???
- bottom end help
- D15b7 Purchase, Help me out!
- eg hatch front on sedan
- tranny/clutch noise
- where to find rhd conversion
- 96/97 OEM Del Sol Fog Lights
- ITB's
- problem with civic taillight
- About my SRS light ( i have searched)
- obd-2 injector & clips on obd-1 car need help?
- b18 gsr cams vs. b16 cams
- Exterior/ Interior Lighting Issues
- No clutch engagement(yes i searched)
- f20b into 97 ex?
- obd2 b16 in a 97 hatch
- pr4 ecu
