View Full Version : Honda Civic / Del Sol (1992 - 2000)
- rear fog/brake light installation problems?
- 99-00 Ctr headlight wiring the city light?
- K20 swap in ek can i do ac ? if so whats needed
- 98 trim Civic Type R Foglight Install Instructions Directions
- D16 wont start.. good spark, 40psi pressure at fuel filter IM STUMPED HELP!
- GSR ABS Axle work with non-abs?
- 225/45/17 too big for a 95 CX?
- EK9 Pedals.
- EG Coilover Install
- P72
- yay another seafoam thread!
- hasport auto to manual pics
- obd0 long block in an obd1 car???
- rev limit on b20vtec
- would the 99-00 civic front bumper fit on a 96-98 civic
- Si cluster made my HX faster?! WTF.
- idle problems
- d16z6 engine build
- Quality of Blox Products?
- New To Honda-Tech
- any ever instaleld ksports in an eg???
- Stupid Highway trash
- vtec?
- need help w/ my motor
- Car dies at stoplight....film at 11
- Ebay intake question
- 92-95 transmission in 96-00
- seafoam question
- my vtec isnt working
- dizzy rotor wont' come off! Quick help please..
- MTF rec.
- quick throw out bearing question
- True/False: u need 99-00 rad support to add the SI front to a 97?
- where to buy
- Need to double check!
- Power Window Troubles. 94 EX Civic
- Proper way to align a door?
- ABS problem , code 4 and 8
- 98 CIVIC LX o2 sensor wires? which is which??? PRIMARY
- '93 sol si roof ?s
- Strictly for H-Tech(Technicians ONLY) question....
- Skunk2... How much power??
- help!! Question for EG
- D16Y7 Help
- Trick for rear motor mount
- boostin and squeezin at the same time
- another shift linkage question
- Manual Steering rack bushings?
- Ek engine
- Swapping my d16y7 Engine into ????
- TUNING INFO ...
- ****EK PIC THREAD****
- OBX a good brand? and a question about my engine.
- Eg Hatch..
- [FAQ] The Official How To Install Power Windows Into any 92-95 Civic Hatchback
- HELP!
- sidemarker stress
- How can you test INNER cv joints
- D-series swap
- Need some answers (EG related)
- how much airflow improvement does aftermarket valves allow.
- broken, and stuck bolts/screws....
- Upgrading B16
- how to: free lsd
- certified JDM b18c motor in cali?
- JDM Sidemarker light plugs/sockets? in need.
- What Year Is My Bumper?
- piston to deck clarence?
- wtb 92+ hatch with any b18 vtech motor NJ
- MUD flaps not fitting
- vibration on right side of car when under power
- Engine Bay
- Oil light blinking replace oil pump still no Vtec and light still comes on?
- will a stock gsr muffler fit a 92 civic hatch??
- 95 CX hatch speaker
- Aftermarket power mirrors on '95 Civic coupe ex. HELP.
- need alittle help
- ***Help!-Is the vacuum setup the same for All b16's?***
- electrical problems with a b18a1 into a 92 cx
- cluster swap
- auto to manual conversion
- soft brake pedal? also pad recommendation.
- 92 Civic with a GSR motor that uses oil but has good compression??? Need help!
- prepareng for turbo
- 92-95 EG Full on cable clutch conversion.
- 98 Civic Wheel Studs
- is this a rare part, or what?
- Type-r trans ????
- Yet another stolen car thread this one from hamilton nj 99 black R motor equiped hatch many jdm part
- Integra speak into CX hatch
- 1996 Civic LX 1.6 only 30 MPG in town ??
- suspension for a sohc turbo
- 96-98 fog light interchangable with 99-00?
- header
- FOR THE EG GURU'S: QUICK QUESTION
- Whats your opinion?
- EG civic
- O2 sensor question...
- ls running rich on nitrous
- Which engine should I put in my 94 Civic?
- b18b info what you think?
- Pressure Plate & Starter Clearance Issue...
- ek rear disc conversion
- B16B forged rods...?
- 96 Civic DX - Radiator Fan NOT Working...
- LS VTEC TURBO OR LS TURBO
- del sol axles
- does anyone know where i could a window regulator
- z6 vs zc
- PAG or Ester oil?? A/c
- 93 civic clutch install question..
- LS VTEC TURBO OR LS TURBO?
- fuse problem
- EK climate control swap
- Help! P0132 code shot out after new o2 sensor was put in
- 92 Hatch questions... tell me if there's another topic for these. (new here)
- exhaust question
- what engine seals would cause my motor to burn oil
- Wiper and blinker switch question
- Bad response
- A/C Couplers defective?
- USDM GSR or H22 jspec/usdm ???
- EJ1 Power Windows are slow
- i want my b16a tuned right
- 4-1 header with cat ?
- Car troubles Maybe someone can help??? Tach Jumps Won't run well under boost
- Need Install Guide Link please...
- idle problem please help
- cf spoon lip HELP
- how should i biuld my engine?
- I want a b16...but questions...
- Cooling Fan Circuit Issues
- B16A Turbo Tuning Q's
- trouble identifying 1993 model (S vs. Si)
- hey
- SELLING Volks Ce-28s Replica!!!
- gauge cluster went out.HELP!!!
- code 9?
- What is my engine and transmission code?
- big crack in the frame near suspension
- D-series tech resource?
- Searching for Spoon EG6 Pics (for a scale model)
- Del Sol Gauge Cluster
- 3 quick questions!
- '92-00 Civic/Del Sol Pics
- I need some Type-r help.
- poor mileage post swap
- How much for a paint job
- 2000 Si Cruise control Problem
- HELP with stock EX intake
- cluster swap into a cx?
- What engine should I put in a '99 DX Hatchback?
- Koni yellows have to be modified with Ground Control coilovers? 92-95 Civic
- EK dash conversion??
- damn grinding
- GSR's Compression
- PS...easy to remove???
- Difference between a P28 and P2T ECU?
- camber kits
- b16 exhaust question
- SFWD Car wont start.
- Civic HB exhaust
- WA State Emissions
- HELP: VTEC not working, CODE 21 VTEC Solenoid
- what did i do wrong?
- B series swapped. AC bracket pulley question.
- ivac sensor?
- Double Clutching?
- Will a 98 Civic Engine fit into a 95 Civic EX?
- SCHAMETIC DIAGRAM
- intercooler coupler question...
- Ideas of what to do to 98 LX 4D Auto Civic?
- B20 with B16 tranny shift linkage question
- rear disc parts swap question......searched....QUICK!!!
- Thread on Engine Designations
- b16 exhaust
- Info on H23 swap.
- ex/si stock intake question...
- altenator HELP!!!
- problem with idle,.....
- 94 LX sendan exhaust dilema
- A/C compressor
- K20 install prices..Need help.. already searched
- Knowledge of honda electrical systems
- swap help
- excedy stage 2 clutch?
- shift linkage pin question
- need info: vx motor into dx hatch
- Loud squeak when car starts. Please help
- will a '00 stock Si exhaust fit a '95 EX cpe?
- Suspension rattle...yes i searched
- Sweeeky sound from under car,
- sulfur smell from battery
- vtec wont turn on
- What are the causes of loss oil?
- B18c1 obd1 in 99 ex
- http://repo.jackmoves.com/album106
- Motor won't start help!
- Cleaning Red Valve Cover
- 2000 civic si vtec problem?
- New 2.25 Exhaust setup. With dump tip.
- AIR CONDITION PROBLEMS
- Can't get axel into spindel
- swap ecu auto in a 5 speed
- Vanity mirror fell off of Windshield, how to put back.
- Need radio code for serial #.... please help
- wiseco pistons
- Question about GC Spring Rates..
- will d16y7 injectors cause any problems with a b16a2?
- 92 dx how to???
- weekend project.
- anyone else had trouble installing icebox/intake combo?
- quick auto to manuel conversion with cable tranny
- stuck cv joint
- car vibrates only when im picking up speed
- single cam turbo question
- tyc headlights
- Radiator fan?
- im throwing codes... please help
- common problems with '93 del sol SIs
- POWER WINDOWS AND DOOR LOCKS (DEAD THREAD)
- IAC valve on B16a
- aftermarket d15 rods??
- Tuners?
- mini me swap question
- Integra brake onto Eg Hatch
- clutch not good/ please help
- h22 ek - motor is weak, compression results
- '96-'98 Climate control ??????
- Shift linkage/shifter bolt size
- jdm i need help
- 2006 SI seats in 93 SI hatch?
- pic requested: need pic of EG vaccum hoses (please help)
- LOOKING FOR A DECENT EK PLEASE MESSAGE
- rear strut bar
- Any Canadian SIR owners here?
- trim removal
- jdm p30 ecu on GSR
- B20 crank pulley onto D16Y8
- Help! Which Way Do They Go??
- Quick Question: Password JDM Power Chamber Intake
- Rims... no power steering
- TONS OF WHITE SMOKE, NO COOLANT, PLUGS ALL SOAKED W/COOLANT?, WON'T START...
- pulled dash off now it want crank
- header ? on EG
- 94 CX Electrical Problems.
- i want my exhaust quiet.
- 99 civic Si cel
- D15B VTEC into 92 VX---Searched
- Charcoal container on rear firewall..
