View Full Version : Honda Civic / Del Sol (1992 - 2000)
- A question about my DX
- Integra Brakes
- Pictures needed of y8 mani swap onto y7
- this a good price for full car paint job + body kit added?
- what do u guys think of velox vx8 rims?
- what should i do to my civic HX
- HELP, PLEASE!!
- 2000 Civic Ex "Turbo It or Not?"
- Cluster swap question.
- Required addition swap parts
- Will 2000 Civic EX front LCA's work for swaybar in 99 hatch...
- inatake manifold ?
- blow off sound
- odd.. timing??
- EG Cluster swap question....
- HELP! Cleaned engine bay now my car is dead
- stolen car verification. need carfax or similar
- Trailing arm question.
- help!!! SORRY WRONG FORUM
- EG hatch rear seat removal
- zex cam 59300...i need help!
- WTB CRX, or EG Hatch, or early 90's integra. Please help.
- B16A2 SWAP DIFFICULTIES PLEASE HELP!!!!
- gsr motor in 99 civic ex wont start
- wiring for led side mirrors
- pwd door lock/unlock wires in 95 del sol
- Will type-r throttle cable and bracket fit civic si?
- 93 DX sedan Oil Light on and Rod Knock Question.
- my whole day project
- which b16 tranny is this?
- Need help, something up with my steering/suspension?
- EH2 exhaust question
- thermoswitch same? d and b series?
- car keeps dying w/ ac on?
- ac belts measurment?
- radar detectors
- space between the axle/trans = knocking sound HELP PLZ
- motor swap; whats legal, whats not?!
- Online parts stores
- what is wrong
- OT: JDM Spec email is down
- B18B1 swap into EG Hatch
- Whats the largest Oval Style muffler you can fit on a 99 civic coupe?
- Door panel question (did search)
- ITR seats in EK?
- KMS parts???
- e-brak lines for civic hatch
- Prop valve purchase - 99 Civic
- question on broken wheel studs for the eg
- clutch break in?
- fuel line question
- Question for u guys w/ the d16....??
- B18C1 ECU model years...
- h22 swap
- ITR mc/booster fit in EK????????????
- LSVTEC tubro vs all motor??
- Aggressive Brake Master Cylinder ?
- Those with an icebox on an eg
- New vid we all will love...*vid 56k go die....
- phoenix yellow del sol question...
- ek disc swap brake booster/mc q's help me please
- oem part numbers
- car fax please for this integra
- need opinions on corners...
- i got ac backet but now there is a gap please help
- WTF!!! engine out, timing belt prb....
- Hood
- What to do? keep my HB? or buy a new car?
- Action 1MD Clutch
- Does anyone remember the link to the Autozone radiator?
- anyone remember that super quick 500hp civic?
- Civic Turbo?
- Pic's of my Si hatch
- A good trade??? need advice
- d16z6 tuning needed(advice)
- JDM VS USDM
- Ever use Hyperduck Tuning?
- Original OEM d16 head bolts...OK to reuse?
- Need real info, from actual users... Skunk2 vs. Ingalls camber arms
- went to track with d16y8 93 cx hatch for first time
- climate control isnt going off
- B16A2 THROTTLE BODY ON Z6????
- What wheel size?
- Quick Question...
- went to track today (92 hatchcrap)
- help racing seat question
- doing a slight rebuild on an LS. need advise.
- who uses the POWER ENTERPRISE timing belts??
- post pics of your Rear Tower Bar
- clicking when i release clutch
- aftermarket fenders
- 96 civic for $3000 bucks? *WTF*????
- JDM D Series?
- seat swap question?
- fender sticking out... wtF?
- AC Setup for B20 EG
- Went to the track for the first time with my D16 del Sol...
- RNB String (15" black with red lip)
- More from "ghetto tech"
- d16 Zex cam
- 99 Civic DX w/ Si Foglight install Questions
- What are some qtr mile times/weight/horsepower or some of the heavier hondas our there :)
- change my dash lights to orange....
- camber kit question
- Removing Spoiler, How do I cover the holes???
- factory honda lsd for gsr tranny?
- 4dr front lip question
- Pics of one of my hatchbacks *56k DO IT!*
- brake upgrade, rotor quesiton
- stupid question...
- New Members Ride...Flame or Fame? *Lotsa pics* B20 Turbo build
- purplexed by this ecu problem, any tips?
- b18b good swap?
- Question about water getting into the motor
- peeps w/EK hatch & SI tower bar...
- Help needed: suspension
- Axle Problem!!!! HELP!!
- should i get this clutch kit?
- which engine would give me the best results in my hatch
- center caps?
- EG door to a cr-x
- Camber Help Needed!!!
- Which would you prefer usdm itr motor or build gsr
- leaky main seal
- SiR lip?
- which rods
- S-Tech's?
- did swap need help
- question about tire and rim fitment
- quick ? what ecu is this? 7k rev limit, p75
- AC Compressor, D-series all the same?
- DIRECTIONS for installing a skunk2 mani onto a b18c1.
- were can i buy a b16a2 for a good price
- AEM air intake
- What is EG or EK......
- Coilover/Shock question from Newbie
- Ok PROBLEMS with GSR swap in 92 VX please!!!!!!!
- S2 - D16A-Z IM
- SKunk2 SOHC Intake Manifold- yes you SOHC Fans!
- question about mounts, tranny stuff
- all motor b16 block
- Would this fit?
- *ATTENTION* Calling all 99-00 Em1's ( 1/4 track times plz with any mods )
- Electrical Oil Pressure Gauge
- Newbie Questions....
- compression problems
- Where would it say the year of the motor??
- Just got a b16 but it had been outside for a long time
- will these seats fit in an eg?
- 97 Dx and EX coupe front sway bars the same?
- proportioning valve for ABS or not?
- oil pan compatibility???
- Think I am getting scammed...anyone know h00kup?
- ALL MOTOR CLASS IN BANDIMERE (READ)
- itr tranny in a si?
- 94-01 GSR or LS gauge cluster in 92-95 civic?
- what are the best cams for my si.
- !!!!CARFAX NEEDED PLEASE!!!!
- i need help with volt gauge!!!
- b16a2 intake no holes for sensors
- Overheated d16..have head machined or just buy a remanufatured head?
- Comp Cams
- Rear Quarter Panel Differences?
- 5gCiv ex Engine decisions
- D15 block and head
- H MOTORS ONLINE = BAD
- can someone name all the engines starting w/ d16z6
- B16A or H22 in my EK?
- Dashboard swapping?
- B20B w/ JDM ITR tranny???
- 98 Civic Ex-Remote door locks won't work
- B18c1 supercharged vs. my D16y8 superchared
- K20 swap
- Finally , the time has come. wo0t!
- Bouncy ride . . .
- Gold Line Springs . . . ?
- Running a SOHC ECU on a B16A2
- want camber
- which steel braided brakes lines to get?
- Which clutch should i buy?
- 75k on a gsr motor? too much miles??
- EK vs. Jeep "Sahara Ed"
- car fax please!!!
- I know..I know..
- engine harness on swap?
- A/C install; who's gone through it?
- EG9 cluster help!
- Clutch install and High temp. grease
- Clutch question
- I have to sale my 93 hatch with 97k
- 99-00 Civic Owners - Wiring Harness Q's..
- b16a swap idle problem
- Cam Tuning Location in NOVA
- B16B or B18C1
- Has anyone ever delt wit this company before?
- How to take off moldings???
- factory lug seat?
- LCA wont bolt up
- Koni Yellow Install Problem - URGENT
- Tyre advice
- Stock Si Springs. Which are the front and which are the rear?
- Rear disk brakes (function or form)
- Need help deciding on wheels for a 98 EK Coupe
- 5 lug swap question
- Pics Of A 95 EX Lip Spoiler?
- need help making choices..
- how to lock shock assembly on rear AGX's?
- got about 10k need a fast car that gets good gas mileage any suggestions on what to do?
- ex front lip install q's...
- Sell my car?
- Turbo LS Civic runs perfect but randomly shuts off
- Need help on Sensor
- pictures of my car (no this isn't a joke)
- what would you do?
- Will 96-00 civic ex rear license plate holder fit a 98 civic hatch?
- GSR cluster into a ek.. a couple quick questions..
- h22 EK swap
- Ever add the back seat release to Sol Seat ?
- what trans for a 92 civ h22a swap?
- anybody running a gsr radiator in a eg hatch?
- wheel color for a red eg hatch?
- Wow whered all the smoke come from
- Failed emissions question: What would cause a high NOx reading?
- aftermarket bulb info.
- Civic EX D16Y8
- stock itr exhaust on eg?
- EBC Green stuff
- Camber??
- how do i know if transmission has lsd
- What do you think about this!! need some oppinions
- Can someone help me: What am I looking at?
- manual vtec engaguement?
- might sell the Si, if the price is right..
- Transmissions and Clutches
- Need help taking cd player out!
- how do i mount my gauges where the climate controls go
- DX engine build
- D16Z6 or ZC swap
- oil pressure and water temp install help needed
- 1st gen B16a swap questions?
- AEM CAI w/ no bypass
- magnetic oil drain plug?
- Whats your favorite bucket seat?
- Tampa florida hatch meet this sat!!!!
- Need help on a ZC.....
- new shop in midwest...
- which clutch for daily driving?
- Will i need a steering wheel puller for a EG... putting new steering wheel
- Recommendations for a shop in Phoenix
- D16y8 oil pan q
