- CRV A/C Bracket not Fitting with ITR Motor In EK
- 00 EX, driver's side door won't lock
- 99 si map sensor goin crazy
- Aftermarket Header problem with b16a swap
- Steering Question
- question about fuel filter mount?
- does your car run with a blown head gasket?
- buying a 1999 si
- d16y8 manifold on d16y7
- sedan rear roof spoiler?
- How to tell between real and fake wheels...
- Speedo going crazy on d16y7
- Making a conversion harness
- Cold air intake
- low mileage JDM engines
- **speaker wiring diagram for 98 civic ex** trouble installing aftermarket speakers
- best control arms...
- Short Ram Intake installation help
- Spring Pin Help
- just bought a civic.
- Single bend Vs Dual bend short shifter questions!
- Help with Removing Interior Door Panel
- where can i buy a drag wing?
- Water pump making weird sounds?
- Wiring 4-wire O2 Sensor or CX harness
- Speedometer
- starter location
- Oil Starvation After Head Gasket
- Bad shake/wobble on interstate
- D15b not going into vtec, no engine codes.....
- question about my engine?
- D16Y8 Intake Manifold Question. Searched.
- D15b Vtec
- Honda Access Visor Install
- planning to tune
- HELP!
- Exhaust Question
- shift linkage question
- obd2 iac in a obd1 (searched)
- Will a 98 spec type r MC and booster bolt right in my 95 eg?
- code 54
- i have an extra 7 inch monitor.....
- Civic check engine light??
- Help
- p30 computer
- LED Gauge Cluster and Climate Control Swap.
- Si cross member
- C&R rad fitting question on ek4
- stock manifold badge question
- 98 d16y7 swap into a 93 del sol
- Noob question on stubborn power window
- Ebay Exhaust?
- i baked my head lights =]
- tein s-tech or h&r sports?
- Megan 4-1 design wont bolt on to my b16a engine because ..
- Delayed Start
- went to the track last night with my b18b in my hatch.
- how to get in del sol trunk when locked out?
- Car won't Start
- Civic Hatch Question
- clutch torque specs
- indentify b16 head?
- What's the best 205/50/15 all season tire?
- 92 hatch roof?
- I Need Your Opinions Please!
- A few CTR headlight questions
- Turbo size?
- Buddy club exhaust
- when i push my clutch down I hear a springy noise
- F+F suspension from JHPUSA, still didnt recieve
- can anyone tell me what spoiler this is?
- Harness Bar!!! please
- Sensor Question
- Where does this hose go?
- b18 swap question
- never ending cel
- lowering springs
- Shift linkage question
- HELP with timing belt
- Burning oil, need opinions.
- 195/50/15 for 99-00 si rims??
- D16z6 parts
- hondata w/program on stock gsr ok?
- b16 ???????????????
- ls/vtec compression test results, need help analyzing
- JDM D16y7
- Was this ever answered?
- whats the difference on chipping an ecu and chipping and dyno tuning ????????
- Trouble installing a deck
- Help Fuel Lines
- coolant leak... dont know from where....
- j's racing 60rs
- What do you guys think i should upgrade next?
- Tach/Speedo problem
- 2000 Civic dx questions (non tech noob here)
- e brake
- New news for ref'ing a 99-00 civic with an h22a
- wiring vtec (B16a) into a 92 hatch
- Anyone making good power on viatara pistons
- EG Headlights
- Quick Q? Would a 96-00 EK Rear Lower Tie Bar fit 92-95 EG??
- Olive Green EG?
- Transmission Oil?
- 06 si vs 99 si
- Curved bolts for the gastank?
- Exhaust Quickie: WS2 or Exmag or SP2
- O light next to seatbelt
- intrest in X-bar for EG
- compression test results
- 91 crx si aem cold air intake
- Where do you buy your stuff?
- CEL help please
- quick hood question
- Exhaust system help!
- quick question integra seats into 92-95 coupe
- 01 ls into 93 del sol help
- 99 hond civic ex d16y8 engine swaping in a 98+ spec ITR engine
- Pic request
- D16Z6 w/Y8 head configuration
- Del Sol Projector Lights
- b16 help
- throwing code 68 which I can not find on any check engine code list
- I Need a mod to talk to
- radiator???
- AEM EMS please HELP!!!
- HELP!! LOOKING FOR CARBON FIBER ROOF
- Foglights Q.
- For Sale
- website authenticity
- h23 eg swap
- Dash recovering - Removing passenger airbag?
- primary oxygen sensor (d16Y5)
- J's racing/Chargespeed and Airwalker/Backyard special question
- wiring help please
- EK hatch mixing parts with 94 GSR
- SS Brake lines swap
- Changing the prop. valve and the lines!
- A/C compressor
- Parking and instrument lights
- adjust the clutch pedal
- Name brand SS header has better air flow than stock cast header ?
- swap question
- need some help trouble shooting !!!
- bushings question please give some feedback if you have time
- new to ht and want to know how to keep my corners and my sidemarkers on
- Civic Died
- PASSWORDJDM.COM IS JUNK
- which spring you prefer
- Help me remove the ignition lock cylinder.
- b18c5 tranny
- Need help matching cat to header/exhaust
- Window trim ?
- Si vs. Prelude
- Y8 CAM
- Steering column slipping out when tightening bolt at bottom near firewall (92-95) Help!!
- heat wrap?
- I need help with choosing which part i need...
- 94 hatch dx....GSR hood clearance?? Motor leans toward the drivers side....
- d16y8
- LS EG
- Which transmission do I want?
- oem fog lights
- HELP HELP FAILED SMOG!
- EK Swap Info
- Help!!! b18a into 93 civic ex
- roll cage question?
- Introduction new to h-t
- Failed smog need help
- Custom Civic & Del Sol Gauges Made Easy???
- Some one plz help me ... cant get bolt out!
- ebay fog lights seller
- ls swap into a 93 vx
- Mugen Side Skirts?????
- NEW SHIFTER CABLES 2IN LONGER??? THEY DONT FIT?
- need help! (somthing with the timing belt)
- Just got an addition to my 93 Si and 95 Ex coupe
- Please help me get my car running right!!!!
- need help here
- idle problem help?
- DAP Paint Problem?
- mini me head info
- B16 swap?
- which motor?
- HELP with mounting EK4 SiR lip on an EK.
- B16b engine swap
- please help, wierd problem with my 94 civic
- RPM? Cluster?
- Possible Bad Master Cylinder?
- clutch job?
- 96-98 Civic Ex Wiring Harness
- AC Compressor from boneyard
- evap canister removal
- 1999 civic hatchback with 93 si motor
- VSS Problems
- ls swap problems
- Cyl. #1 MISFIRE...CANT FIGURE IT OUT. PLEASE HELP!!!
- Legal Performance Exhaust
- b16a2 to b18c1 swap for my 00 Si. been searching. no answers
- CAR CUTIN OFF
- Thinking of buying a megan SS header
- clutch pedal got super stiff all the sudden
- its hard to explain...
- car truble
- tires and top speed
- need help on figuring out my wiring for engine swap?
- 92-95 civic engine harness wiring diagram (EG with B16a)
- USDM B16a2 head on JDM B18C GSR block help
- How to change your conneting bearings.?
- gsr ecu wont start the car.
- Crank Angle Sensor with problems
- fuel problem
- Gas Mileage?????
- Which Intake Manifold Gasket To Use?
- Will the Integra Type R rear seats fit in 96-00 civic hatch?
- how do you relocate fuse box into passenger cabin? (EG guys)
- 92 SI gastank? looks?
- ecu modding for 25shot of nitrous?
- Sway bar question
- Idle---1500
- What the f....?
- Mixing D parts onto a D16a
- '93 Civic 1.6L rough at idle and low revs
- thowing codes 22 and now 21.
- d16z6 swap into EK. can i use y8 distributor?
- vtec not engaging..
- D16Z6 mini Me Swap. What kind of Plugs/Wires?
- 94 Honda Del Sol - Brake Lights stuck on
- JDM DEl sol
- ecu?
- another smsp cat question
- Is Coupe Exhaust Piping same as 4 Door?
- Cleaning engine - temperature precautions?
- front itr endlink 90 degree question
- Anyone know?
- ITR - Civic
- stripped oil pan
- 95 civic ecu
- need a new throttle body for vtec conversion??
- Components needed for EK/EJ 4 disc conversion
- cold air intake in the winter
- How difficult is it?
- Possible to press the bearings out of a Skunk2 Short shifteR?
- Crankshaft pulley removal
- 91 coilovers on a 92?
- Someone help please?
- Code 3, jdm B18cR in EK hatch
- help comon problm ? ecu? distributor? throttle body .what problems?
- Cat converter restricts the air flow,right ?
- h22 jdm civic coupe
- b20b/v turbo
