View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ek fender??
- EG6 Rear Interior HELP!!!
- Ready to swap but have one more question.
- jdm b16 vs. b18 head on a b20b??
- where is the SRS Main Harness and SRS Unit 18P connector
- is this ricey?
- New tranny an clutch..
- selling a car
- 95 VX - Rev Limiter is off, coming on too early
- 98 HONDA CIVIC CX HATCHBACK IDLE PROBLEMS Y8 INTAKE MANIFOLD
- D15B7 (OBD0) in an EG, idle issues
- cx motor into 93 dx throwing code 4 but cant find a plug to plug it up
- 92-95 3dr hatchback. Rear window question.
- Manual rack swap question
- Pass. Side Axle in a Ek
- distributer trouble
- Clutch pedal feel in a 2000 Civic (Hatch)
- Alternator problems for a obd I b16a
- lsvtec or turbo SOHC
- Problems with intermediate shaft
- Can the Check Engine Light be caused by the maintenaince required indicator???
- Changing Headlight Bulbs
- i need the car wiring diagram for a 95 del sol si
- HELP HELP car wont start HELP HELP
- Do 96-98 civic headlights fit 99-00 civic?
- DEL SOL DOHC VTEC YEARS
- 99 dx shifting points?
- H22a swap in an ek
- Injectors
- oil seal crankshaft pulley
- HAS ANYONE MADE A INTAKE WITH A EM1 SI STOCK PIPING????
- I hope I'm posting in the right forum.. *new to civic forum*
- archive doesnt show my car's ECU?
- Is there still a market for Civic HX wheels?
- wire hepl?
- RTA bushing? OEM = Mugen?
- Quick valve lash question!
- Why are used Civic so expensive????
- Can these 96+ parts work on 92-95
- Fastbrake upgrade ?s
- Crazy swap problem, engine is blowing out the intake and sucking in the exhaust.
- what is the best place to buy replica spoon mirrors?
- Can i use K&N filter
- motor mount bracket question
- Help with Speed Sensor 94 Civic 5spd
- EK Sidemarker QUESTION =X
- soft gas pedal....adjusted throttle cable..what else?
- Alternator Wire O-ring breaking off
- New Parts Ordered
- Bearing or bushings short shifter
- best cam to put it stock 94 civic hatch.
- d15b7 pistons
- difference between 96-97 b18c5 and 98+ b18c5?
- EK9 Brakes, Probelms?
- 02 sensor?
- Wheel Lock Key
- 00 ex electrical prob.
- tach going crazy!
- cruise cntrol questions 96 hatch
- i no i no .. sway bar installation .. not what u think
- Engine starts and dies
- Help! obd2a to obd2b (searched)
- 99-00 si grill question
- Oil filter relocation kit?
- Tie bars, C pillar push in or out?
- Average cost of auto to manual swap in Del Sol?
- f20c in eg95?
- Need Help!!!- Trouble Code 0= ECU. . . how to know if its 0
- Removed tar, car won't start!!!
- big brake kit review.
- zc (dohc) swap
- Clutch Pressure plate dead?
- Gas mileage for Si owners.
- obd2 swap questions into a 93 eg
- Sway Bars 99-00 SI???
- aem pulley question
- cant get into reverse
- "Car Rate"
- Burnout!!
- Cable or Hydro...preferences??
- not sure where this goes but "floor flooded due to thunderstorm las night"
- HAHA this is great
- spark plug wire popped off from dizzy?
- DX EX LX?
- b18 is this true
- What engine???
- clunking noise when i brake
- which suspension?
- Need help cant find it....96 JDM Integra R 4 lug tutorial
- radio harness wiring diagram
- d16z6 or b18a1
- GSR swap
- car idling high
- need some help
- Anyone have Blox Type B Cams (B18C1)? If so, read on...
- hatch- LS/VTEC
- auto to manual wiring
- PITTSBURGHS strictfab
- Best Bet For A D15B7
- rear disc caliper upgrade ????
- GSR STATE REF!!!!!!!!!
- wow suspension help please
- weak idle
- d16z6 head with d16y8 camshaft?
- ECU for my b16a3
- 94 eg gsr
- ONLY half my cluster lights up ??? tach not working.
- 94 civic 4 door
- looking for delsol
- Injen Intake cold air
- ecu question-very easy
- GSR.....
- Slave cyl about to fall off!!!!
- valve adjustment on b16a2 question
- Telling if car has original engine
- B18C5.
- WTF... anti freeze is leaking
- jdm b16a2
- Telling if these parts are oem or not
- electric superchargers? =/
- How to remove outer CV joint from axel
- HELP... transmission makes a clicking sound?
- aem v2 intake question
- What's wrong? B16 mildly modded with 40 miles on it smoking BAD.
- Gage Pod, will this fit a del sol? Searched!!!
- NEED OEM OPTIONAL SIDESKIRTS FOR EG!!
- ASR 32mm swaybar/brace combo
- type r or b16 (p30) on b18b1 block
- startup is messed up
- EK rear seat removal (searched)
- What to look for when buying eg/ek
- Will Stock Civic wheels fit over GSR front/rear brakes?
- 93 ex interior
- IT STARTED!!! First build - *VIDEO* Wont Idle, Sounds Rough. Diagnose me
- Passing smog in CA with a B16b....?
- how to get rid of ricer gauges
- tranny trouble
- need help!! my girl is pregnant only car
- DIY Oil Changes?
- USDM B16A2 into 96 DX Speedo and Tach wiring!
- what do you guys think? yey or nay?
- Block to tranny bolt (long one)
- 89 prelude seats/ 93 civic coupe
- 93 Si Dizzy/ECU questions
- rear seat options?
- Build quote
- Timing light gives two different readings
- What do b18c's .....
- 92 Si Gauge cluster into 95 CX :HELP:
- Anyone use this: NRG m3 Shift Boot?!
- check this out
- 92-95 VSS fits 96-00 ? SOHC
- 5th Gen Measurement Images
- temperature??? help?
- best way to increase 1/4 times
- 99'SI wont start, battery not dead, Maybe a short?? Just asking for a place to start!!
- d series tanny help
- REAR LCA's...SWITCHED UP? SEE PICS INSIDE...56K OK
- Apex'i N1 exhaust vs HKS Hi Power exhaust...
- what suspension for h22 swapped eg?
- intercooler with no turbo?
- HELP: car is choking
- Good to see the EG forum is still the same.
- 1993 civic sunroof relay location? where is it lol
- crushed header
- valve spring tool
- 96 Civic sohc?
- Who Sells Vitara Pistons in here???
- Rear quarter SECTION 96-00
- Power 00 si windows on 00 Dx
- Where to get ES shifter bushings?
- quality shock/struts(aftermarket)???
- 96 DX 5sp
- MY 1998 HONDA CIVIC SI FOR SALE
- abs eg8 civic
- Hey, I need a power window switch wiring schematic for a 92-95 lx 4 door
- 99 si sway bar endlinks question
- help
- Lower suspension crown nut removal
- WHAT IS THE LOUDEST EXHAUST SYSTEM?
- EG Center Console Problems
- NA IS BEST!! Stickers.
- Megan Headers what do u guys think
- Need some help on terminology!
- edelbrock turbo kit problem
- anyone here got a boosted ctr ek9
- Garrett GT ride of the month
- LS/Vtec
- Extra Cranking to start?!?!?!?
- Civic Si/GSR Cluster into EG? Wiring? Does anyone sell a harness?
- F22 ecu . on 93 civic ex?
- what should i do first?
- ITR airbox vs AEM SRI on EM1
- need help car stolen
- intakes?...whats good, what do you have? comments.
- Lower Rear Control Arm
- 1993 honda civic LX A/C not coming on
- IACV block off plate?
- Just bought a 93 Del Sol for $400 :) Can I use some parts for my EJ8?
- Window moves forward when rolled up????
- 96 Civic Ignition Module question?
- Plans for the EG
- EG with B16 - Integra or Civic springs ???
- A LIL' HELP PLEASE?
- don't hear fuel pump when key is "ON" position, won't start.
- did the del sol front end ever change
- Quick question about making a 98 Civic into a 99-00 Civic Si front!! PLEASE HELP!!!
- quick question about cel
- Compression ratio of SPOON SPORTS PISTONS!!!
- Right Hand Drive EG-DC2
- want to swap my d16z6 for a b18c
- does any got a pic of LSwebs on a eg6
- dont know what it is!!!
- anyone install TYC Projectors 1-piece headlamps w/H.I.D built in?
- Noobie rear strut bar question???
- Injetor Size
- Max HP on a AUTO Tranny?
- stumbling idle and temp spikes!!!
- Safe PSI D16
- all wheel drive crx?
- power window conversion
- Spoon N1
- ex brake calipers on cx?
- DEcent single cam V-tec for EK
- will eg floormats fit ek ?
- Whats up with my A/C?
- HELP! trans problem
- hydrolocked??
- GSR brakes?
- getting turbo and keeping it legal to pass TX emmisions? 99si
- who's done it?? ek carpet in eg
- Check engine light readings
- Need Vacuum diagram or picture for B18b1
- need help ITR or CTR pistons
- Do i have a OEM JDM CTR 92-95 rear lip???????
- Integra shocks on an EK?? quick question yo!
- ANy difference between ABS and NON-ABS brake master cylinder
- Horn messed up..hear relay clicking?!?!?
- IAB Drama
- Buying new suspension for my EK
- Skunk2 Manifold vs Jdm B16 Manifold
- need help on ICU..
- b18b1 random misfire, please help
- Pricing on Machining in Bay area and installs???
- need help with my 93 hb!
- 2000 honda civic ex injector size
- how do u change headlight bulbs on 99 ex coupe?
- Someone please help me!!!!
- batfa.com- anyone dealt with
- wheelie bar
