- question
- Possible causes for the SRS light to turn on?
- Rusted Bolts [please help]
- common problems: 93 EX
- Spoon gauge cluster for EG
- bore out
- RHD Civic SiR Insurance
- mr. clean auto dry car wash
- I AM A FELLOW HONDA OWNER I NEED HELP LOCATING A B16/A-A1 MOTOR FOR A STEAL PRICE SHIPPED HAS TO BE
- ek amber clock installation ???
- stern aguzze s07
- Rear brake adjustment
- URGENT HELP NEEDED! car rpm going up and down
- BRAKE HELP on delsol please
- Reinstalling Rocker assembly on d16z6?
- whats up wit dat
- EK Swap question
- B20 CRV Clip
- Where to buy Arias piston rings?
- Help with AC Bracket
- H22A or B18C5?
- best way to remove rust
- searched...question..help
- Which would u choose????? help please
- Car question 92eg or 99ek
- Type r in a 92 civic hatch
- air to fuel ratio wiring
- Clutch smell in 4th gear....
- Got a weird VAFC question for ya...
- EG d15b
- Torque- b20 vs. h23
- problems with 5g b16a
- attn: Koni Red users
- AC/heater air direction wont switch
- How do you PRONOUNCE "AZENIS"?
- NOS
- What Turbo kit?
- 99 Civic EX Front sway bar
- Engine managment
- Well this just blows!
- 93 Civic LX idle question
- leather gsr seats into 00' 4dr civic?
- headunit ?
- San Diego Machine Shops
- Brake pedal question
- Gauge pod for top-center vent on EG civic?
- Will 5-speed DX tranny from a 00 civic fit my 94 ex auto???
- Turbo kit
- Engine name
- friends car throws code 41 after thermal exhaust install.
- what ek hatch exhausts do they make????
- what is the location of the guage cluster fuse.
- weird idle??
- when people work on the short block and paint them .................
- Going into limp mode-Not sure why
- Pic Request: Red Hatches with rotas
- Shifer had serious play while in gear.....not anymore!
- 99-00 headlights question? Removed Reflector infront of bulb???
- Best online engine sellers?
- Has anyone swapped Integra Front LCA's into thier 99-00 SI?
- Ignition Problems
- car
- lp: hit manhole cover that was laying on street!
- Have anyone install a GSR front sway on an EK?
- 93 Integra bushings in a 92 civic hatch?
- JDM CR-X del Sol sticker
- Rear wiper on my EJ11
- OHIO SHOPS???????
- Help info needed: Please help.
- ls w/ gsr tranny
- JDM "Ek" rearview mirrors
- Question about Headlights
- Tab under code.
- How do I tell what type of engine I have??
- what kind of cage should i put in?
- OT: Who's going to the Canton, OH swap meet this Saturday?
- 4 lug ctr wheels
- Honda touch up paint?
- Pic Request 5zigen inperio
- New Jersey Shops?
- Hey yakitori
- Need info....
- can v-afc be used as a tachometer?
- What do you think of my ride? (opinions wanted)
- Installed JDM DC 4-1 header and SMSP test pipe. Some pics of comparison..LOTS of PICS! 56k go away
- crank sensor problem 00 b16a2 with 96-98 wiring help
- Best All Motor Cams for Gsr ? STreetable
- no gauge cluster lights?
- looking to purchase 92-95 Si hatch
- ENGYNEproduktions video
- water temp gauge
- 96 DX Front brakes...
- Are these cheap projectors or retrofitted OEM headlights?
- Need pics of GREEN 96-00 coupes...JDM style plz
- Bent Valves?
- lower tie bars....
- easiest and best swap
- 94-01 Integra Brakes on a EG Coupe...
- ** Suspension Question **
- HELP! steering problem/alignment
- ITR Pistons and Rods in LS Block
- What can i do to get a lower E.T. ??
- STOLEN 2ooo SI - Im in da club
- Does this sound right? socal Peeps keep your eyes open
- SIRII swap problems... IAC valve
- what to do first???
- will 92-95 tein SS coilovers fit on 96-00?
- need advice, search didnt help, About ITR steering wheel
- JDM power folding mirrors on dx/cx??? how to? help!
- what 2 gauges necessary for turbo?
- DIY / How-To Install an A-Pillar Gauge Pod *w/ Pics*
- D1 GP 2004
- LS Vtec Question
- blue book value
- valve cover painting help....doing this right now
- ITR JDM transmission
- largest width on Wheels and tires?
- Need Help On Integ Dash I have searched
- VTEC
- SKUNK 2 CONVERSION HARNESS OBD2B TO OBD1
- Are 40/40's necessary?
- car keeps blowing coils?? WTF
- d16y8 cat/exhaust manifold interchangeable with d16y7 cat/exhaust manifold
- Need advise from someone who has done the y8 intake manifold swap onto a y7!
- Engine Swap Questions... simple.
- need help picking some slicks
- Is this good or bad ???
- jdm front bumper
- Need Specs on ZC motors
- how much whp can you get out of a ls\vtec swap?
- CLEANING UP
- 91 integra ls engine in a 95 del sol?
- re-install stock e-brake handle?
- trying to fit ITR front sway bar on EK hatch...please help!
- Identify this on my intake manifold please
- i need a d15b
- ***Question about CTR air bag tray.***
- Carbon fiber hatch?
- anyone know the best FPR settings for d16y8?
- k20 swap
- OT: Thanks to Tom (B18C5-EH2) & Acura-Honda Specialist
- GSR sway pics needed
- Del Sol wiring?
- B16 SiR II Engine Swap In my EG next week!
- question
- need some assistance with my EG
- Do del sol seats bolt right up in a ek???
- my b20ek hatch 1/4 mile time
- i need d16z6
- anyone know where to get an obd1 integra xsi fuel line?
- power windows into my DX coupe please help with parts list...
- Window out of track
- Need ideas on how to modify my will-be new car...
- hid retrofit gone wrong!
- Help!!! oil in 4th cylinder
- HID's cleaning please help
- where could i buy an ES oval muffler
- 4 wire o2 Wire colors: Go out to your car and check please!!
- Need Help with D16z6 with y8 manifold w/b18 TB
- can someone CARFAX me asap?
- not getting fuel??
- Question about OBDII to OBDI
- cel, wtf!!!
- Help me search or provide please: Vtec Wiring and 4wire o2 wiring. NEeded asap
- broken dipstick
- custom reciever install in 99 civic
- HELP:92-dx head taller than the a6 head?
- Ebay warning
- Si?
- How Much Boost You Runnin?
- Cracked or Bent Rim?
- Bumper fitment
- where to put tranmission fluid in 93 civic ex sedan
- Spark Plugs: What causes them to go bad super fast????
- How many o2 sensors on a 94 civic ex header?
- SOHC Vtec head question...
- Help 911 , 92 honda civic ELECTRICAL LIGHT PROBLEM!
- Radio Code help
- Mistery Injectors
- ANOTHER STOLEN HATCH!!!!!!!!!!!!!!!!!!!!!!
- Head gasket? first start up. ITR in an EK
- STEERING COLUMN?
- EK-EK4-EK9?
- What do i need to outperform a stang gt?
- i need some help
- Trunk wire?
- car wash, now surging. wtf?
- Help me find a spoiler please!
- Question about Drum Brakes- Basic Maintenace
- HOW TO: MATCH MILES ON YOUR NEW JDM CLUSTER 99-00 CIVICS
- 88 knuckle different than 95?
- just installed koni yellow need help!
- what to do...
- Quick Battery Question.
- d15 d16 differences
- I need to take my ac out but I let my friend borrow my Helms.......
- bearing questions for a d
- does anyone have any pics of a carbon fiber gauge pod in there car?
- EM Weight Reduction (Idea's/Suggestions):
- getting painted soon what to buy...
- clutch pedal vibrations
- catalytic was plugged ...
- Which is better a b16a2 or a d16 turbo?
- stereo install
- Anyone know were I can get a B-pipe.
- which racing seats in 95 coupe
- clutch problem...
- Thieves & the trouble the leave - Window internals subject
- front x member ? about my setup
- disc brake conversion
- Which intake to purchase?
- tranny wont go into reverse
- What turbo kit to get?
- Magnaflow cat-back...yes or no?
- LSD tranny or no?
- prelude steering wheel on a 2000 civic
- integra shifter on civic
- HELP!!!!!!!!!!!!!!
- bolt and washer trick?
- Thermostat Problem - ONE QUICK QUESTION
- looking for a good suspension upgrade??
- 90-93 integra proportioning valve fit EG????
- Do ALL Honda/Acura shift knobs share the the same thread pattern???
- valve adjustments
- my engine bay. sleeper?
- Please Post Pics of your Audio Console w/ Monitors...
- check out my new baby
- -----has anyone dealt with " www.naganojapanese.com "
- Riching and leaning
- can a ls swapped del sol be ref'd? in california.
- i cant take this anymore
- wtf does my 93 dx hatch have an extra map sensor plug?
- Emissions test. how far in advance??
- Looking for a d16z6 motor...
- spoon motor
- wt:door panels
- Del Sol with 2000 conversion
- bone stock ek w/es oval exhuast....pass smog?
- Mini-Me Distributor
- Fly by video with my new exhaust
- motor
- you just have a day for studying?
- What do i need when i change my valve cover?
- Turbonetics or Drag Gen 3 turbo kit?
- Breaking Problem Warped Rotors or something else?
- trying to post pic of car for sale on imagestation...testing
- tcs computer
- Anyone running Competition Clutch?
- what cams did i get for free? (pic)
- who was doing thoes free carfax reports on here?
