View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Messed up ECT (temp sending unit) wire
- Headin to the junkyard - what steering racks fit my 95 Civic?
- Pleas help!! Tranny issues! :(
- 1994 Civic EX Coupe ABS light code confuses costly dealer estimate
- Speedometer and odometer not working
- ej8 auto to manual problems
- Transimission HELP!!!
- Driver Side Rattle
- blown headgasket 4 days after rebuild d16y7
- Tranny/car Problem!
- D15XX bottom end Question
- 96 Civic Headlight Problems
- 98 civic d16y8 - can someone help? - injectors wont spray
- 。◕ ‿ ◕。What is this called? Needed new parts 。◕ ‿ ◕。
- grinding in neutral 97 ek
- Ground Control Coilovers Help
- eg hatch/b18c swap drag car -- vtec blues
- Failed emissions 1994 Honda Civic SI -1.6 ltr. - HELP!!!!!
- automatic shifter cable
- 94 Dx Quick Fix Swap in a pinch
- 00 civic ex coupe questions.
- 98 Civic sedan rear problem?
- would this engine replace mine?
- turn signal doesn't work with city lights or headlights
- 92-95 Ferio rear wing
- B series interchange with D Series
- How can i recharge my A/C when... [Pics]
- took transmission apart, don't have a 3rd gear?
- A/C Compressor
- HELP!! 95' civic close to overheat.. I did alot of Troubleshoot and no luck
- Jdm d15b vtec obd1 timing set
- 9c civic swapping an h23 frank into it ecu advice
- Help Identifying these Seats
- Idle issue...
- 89 civic shuts down, cooling fan doesnt come on
- engine build help! for supercharger
- CX/VX Shift Light Swap To EX/Si
- halfshaft for ek with ls/vtec
- what do you think? video inside!
- Roof rack question - not for looks, for carrying lumber and stuff
- b18C eg CEL problem.
- MY VTEC KICS IN BUT NO ACCELERATION
- Drain Plug Size? Anyone? JDM B16
- Low Idle / Wants to Die after enguaging Vtec
- how to remove OEM fuel rail fitting ?
- 99 civic rough idle on start up
- 95 Cx z6 p28 - Code 1 and 43
- radiator for b18b1 swap
- 93 vx w/ob2 Y8 swap: running poorly (code 1 o2 sensor)
- HELP!!! car won't start.
- d15b7 running like crap
- overheating ek coup =(
- Hairline crack on radiator? Check video
- OBD2 ENGINE HARNESS in an OBD1 CHASIS...
- d15B7 with a Y7 head?
- 95 Civic DX: Headlight bulb socket -- Name of this part?
- 99 civic hx b16a build
- b18b1 into 98 Hatch
- Crazy B20 Problems
- what size fitting for oil pressure sending unit
- pcv valve, and or running problem
- Help my identify this transmission
- Ordered LMA - need torque specs
- Hood Latch & Cable install?
- what clusters fit 2000 si?
- obd2 or obd1
- troubleshooting thermostat vs headgasket causing overheats?
- NEED HELP ASAP!!!!! SEARCHED, NO LUCK!!
- Walbro model question
- OEM Suspension upgrades for a EG6 Si?
- Error 41 – Please Help
- fender question
- 195 60 15 on eg! hell of a deal
- T bracket for ek with ls.vtec
- which firewall plugs do i order for a 96 Civic HB?
- 1998 Civic DX Stops running
- 95 ej2 tail light question??
- a/c minor issue blowing warm/cool
- j30a4 swap into 95 civic hatch is it possible? ( help )
- Del Sol accelerating issue
- D-series compressor with B-series motor EG
- Need Help with 96 Civic LX - No Start/No crank
- Help 00 SI temp gague goes full hot on startup
- IDLE PROBLEM
- 98 Civic (Hot outside->brake pedal gets hard -> engine revs high
- How do I make my D16Y8 faster?
- d15B head question
- no light in my eg cluster
- d16z6 wont start/wont crank
- Help please! Wiring trouble.
- b16a no power on hills
- What intake do I need to get?
- 94 Civic eh2 - project log
- vss weird reads, trans fluid level?
- Another AC Question??
- Ratta tat tat!!!!! O2 sensor noise
- HELPPP! GSR T/B and TPS Q!
- Help! IAT sensor and powerchamber
- 99 civic front end, most sleeper intercooler?
- 99 Civic DX Spark Issue
- Running a nonchipped p28 with b16a2 eg swap
- 99 Civic EX Weird noise at high rpm
- Squeaking when I shift?
- Sunroof broken
- Best Place to Buy Black Housing Headlights?
- D15B7 dizzy capadable
- Gas Pedal is semi sticking???
- Slow moving power windows
- ITR sway, D bracets... *searched*
- 99 civic battery will not charge
- Yonaka (WS2 Knockoff) exhaust review? (How quiet?)
- Bad gas can cause high afr's
- 93 del sol in need of knowledgeable help - misfire and no-start problems
- R134 leak
- IS Stage 3 6 puck too much for stock b16a????
- problems with my tach not working
- need help with coilover selection
- What CV Axles and Struts to get? 2000 civic si
- Help with tranny noises, 97 dx
- Throws out water from the radiator cap
- r134a boiling with car off
- Low idle sputter on my 97 Civic ex
- dead 95 coupe/LS swap - fuel pump won't run
- gauge cluster and windows wont work
- b16a with a cable tranny issue
- P28 Auto into DX Manual (1995)
- vitara tuning help
- 2000 Civic ex 5spd chugs while accelerating uphill
- WILL IT FIT??? A/C SYSTEM.
- Civic EK hood dampers?!
- 98 Civic EX - stall problem
- Vx/Si EG Final Drive Gear Swap? Possible?
- del sol b pillar bar?
- #10 fuse keeps blowing
- 93 civic si hatch
- need help with t brackets
- Advice on buying a 00 Civic Si?
- Car Dies Randomly
- What exhaust should i get?
- Vitara build question
- help!! misfire at full throttle!
- possible to move evaporator out of way w/o removal for heater core replacement?
- 95 Civic D15b7
- ls/vtec in ek, but... no vtak??!!
- b18b swap in EK ecu issues...
- Clean the Cabin filter in 1995 civic
- b16/b20 timing cover marks
- B series swap. Is it worth it?
- problem with alternator?
- Brakes go to the floor
- Questions on Integra front brake swap: new 40/40 required?
- Suggestions on turbos that let me keep a/c?
- Stock 1996 Civic EX - Buying and Replacing Window Regulator
- Del sol wiring problem!! please help!!
- Lets talk- master bushing kits??
- 97 civic shaking bad
- What do u guys think about this exhaust idea.
- D16y7 to B16a2 conversion wiring?
- Endless bubbles in coolant
- Old Strut test
- brand new bottom end sitting for 6 years
- Bleed the cooling system question
- Painting ABS Plastic (EM1 Grille) Questions
- EK rear LCA on an EG?
- car won't stay running...INJECTOR ISSUE?
- What's the benefit of swapping in a cable trans?
- 95 Civic rear door panel removal
- VTEC NOT WORKING
- Civic D15B 3 stage Vtec hesitant on low rpm.Help..
- Ultimate 92-95 Civic L.E.D. Dome light
- Just converted PW/PL/PM... Issues
- Full built B18c troubles starting
- Civic driver side trailing arm fitment...
- AEM EMS start up HELP!!!
- B16A turbo question
- b20 in Em1
- EG how to know if i have a bad wheel bearing
- HEATER NOT WORKING
- New Member with 2000 Civic Si **Pics**
- 1995 EG needs new exhaust...whats should i get?? help!
- Del sol with idleing problem/slow to start
- timing issues
- 93 civic si main relay
- EG all red tail lamps
- hx rims compared to si rims question
- 92-95 Climate Control Relocation…*possible?
- Noob looking for engine mods.
- 95 Civic A/C Problem
- 1.6EL Outer Tail Light Part #??
- trans nosie???
- How to hook up my power windows?
- Should i be hearing air escaping
- Need advice on engine harness asap..
- 92 Civic CX starting problem - CEL remains on and fuel pump won't prime
- 94 swapped eg hatch new starter still wont start..need help!
- B20 EG GSR Tranny - missing flywheel inspection plate
- broke a stud over torquing my new headers
- wiring killswitches (wire colors?)
- Over heating when I have any thermostat in the car...
- Don't know how to fix my power windows
- What kind of knock am i hearing?
- Engine stalls when stopped at a light
- D16Y8 missing cylinder
- 99 accord cd player in a 98 civic?
- eg ac help
- what is the name of this lip???
- How to clean a sticky throttle cable - d15
- How to remove the roof of a Honda del sol
- straw fell into cluch housing
- how do you tell if aftermarket valvetrain are used or new?
- buying a b18a block?
- 99 Si slight overheating problem.....Fans
- identify the image! help!
- 94 civic cx hatchback - black nuts on back glass
- A/C Not Working Questions
- Inability Brake Bleeding MB6 1.8vti
- Ek hatch?
- EM1 DOHC VTEC and Si Sticker Placement??
- Need help building a honda civic hatcback
- Should i attempt to change my transmission fluid??
- 97 Honda Civic with Weird Starting Issue
- Emissions question need help 99 civic si...
- motor swap help
- my first h-t project. ls-vtec build!
- axles?
- b series axels ?
- Need Help. Engine, Oil, Battery Lights keep Flickering
- What ecu chip to run?
- dumb ? Can you use a auto engine harness on a manual engine?
- cluster issue(tach)
- A slightly unusual obd1-obd2 conversion question(Please help, have searched)
- Vtec solenoid blocked off.....??
- New Del Sol Owner Question
- 00 Civic EX stolen in Hawaii -- My poor baby :(
- First post. 97 civic cx burning hella oil w/ hella low miles
- 96 civic EX - wont start - no power to fuel pump
- no cel light and diagnosis plug wont read
- Automatic d16z6 oil leak
- EG hatch door warning light help!
- 1994 Civic Del Sol BAD MPG
- D15B8 Misfiring, Im stumped
- jdm b18b, usdm EG Si, many questions!
- WA state emission inspections
- first post. tech with d16y8 issues...
- Hi guys, new here. CEL code 9
- help b18c/b16 leaking a little oil were block meets tranny casing
- New to forum Crank pulley problems
- 94 civic ex wont go past 5400 rpm
- Failed Emissions HELP!!!
- Del Sol Picture thread?
