View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Coupe Rocker Panels
- Ricer-In-Progress: 99 EJ6 Hatch Mini-me and fix up (build?) thread
- dash lights ramdomly turn off while driving
- No crank no start del sol again
- 1998 Civic Dome Light Assembly Test - How to?
- 2006 civic hybrid to 96-00? anything interchange?
- low speed letting off throttle feels like brakes are on. TQ Converter not unlocking?
- Fluorescent dye causes check engine light????
- 93 dx swap from auto to 5spd
- 1998 Civic EX Maintenance / Service ?'s
- 1993 civic del sol s burns oil randomly at idle and revved
- Will 17 inch wheels rub?
- LED turn signal probs?
- TPS Sensor doesnt do anything
- B18b1 bucking problem
- trans fill?
- Building b16
- Advice/Help on my new EM1
- Del sol steering wheel
- Tall guys in small cars.
- EG Si - knuckle and power steering questions
- EJ8 Swap cluster from EM2
- Overheating issue
- Changing Timing Belt
- Obd2a->obd1 conv+3 wire to 2 wire IACV
- Civic 97' UK Window Problem
- radiator tank question
- HONDA CIVIC WONT START!! STARTER CLICKS. NEED HELP ASAP!!
- 97 Civic blue smoke coming from exhaust ?
- How bright are these HIDs [pics]
- A.c help b20b swap
- 96 civic dx hatchback starts then stalls?
- 96-00 civic hatch most popular color. gauge cluster problems common?
- New Engine Wire Harness-solid CEL Code 0
- EM1 engine installation tranny mounted
- D15B VTEC-E. Dual VTEC solenoid switched with single.
- Burnt valves causing low compression?
- Ebc or powerstop brake upgrade?.
- AC Question 2000 Si
- Z6 swap in to an EG6 hatchback problem
- Weird Spark Plug Wire Issue
- 99 Civic 1,5 Vtec lSi (EK3) (Croatia) - Where is the service connector?
- need a paint shop recommend in Socal
- B16a S80 Transmission problem
- 99 civic ex, finding an oil leak
- 1998 Civic over heating?
- auto to 5 spd b18 swap hard shifting
- 92 civic dx cluster swap
- VSS metal housing broken - part number?
- 1.5l burns oil after head swap???
- Axel question. B16a axle in a 97 HX
- swapping d16y7 into obd1 car
- Got a 92 hatch with OBD1??Help!!
- 1994 CIVIC EX Hesitation Stumble !Keeps Going Through Spark Plugs!
- Timing belt tensioner bolt!
- JDM D15 Non vtec - Valve seals replacement - Which do I buy??
- Suspension popping noise
- d16y7 spark and fuel but no start
- integra springs on 96 civic what will happen with height?
- 95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
- Speedometer issues....
- 00 ex idle problem
- 00 civic - power windows, doors and mirrors and also power port don't work
- Auto to manual conversion questions (d15z1 civic)
- 94 Civic EX Oil Leak?
- heater box / dash
- EG engine mount windshield sealant fill in??? driver side mount bottom a/c bracket.
- Warm running issues after clearing CEL codes
- 1998 Honda civic EX smog problems
- 96 to 00 Front End Conversion Question
- 94 Civic lx - Driver Window Won't roll up/down
- Fog light wiring question
- 1999 Civic Losing Motor Oil
- Odd knocking noise.... Any ideas appreciated..
- fuel rail problem
- Setting up Viper Alarm and Power Locks at the Same Time?
- 98 Civic EX/P28 ECU with D16Y8 base map - Evap system questions
- head lights
- need help making my carbureted 94 Civic faster
- (HELP) LICENSE PLATE LIGHT
- 94 Civic - CEL stays on and engine won't start
- What other Honda steering wheels fit the 96-00 civic?
- need help y5 block d16z6 head !!!
- Blink code 43 92 civic
- Aftermarket Window Regulator
- 92 Civic - pump wont activate
- Timing belt issue
- Trouble Starting/SRS Light is on. 96 d16y8
- Requesting suggestions for starting issue
- b18 and b16 injector interchangeability question
- 99 Civic O2 Sensor - P0141 CEL
- eg6 corner question
- oil pan problems - bolt holes in block stripped
- Turn Signals inop but hazards work
- d16Y7 intake manifold on d15b7
- 97 Civic - wont pass inspection because it does not have a cat
- 94 ex, left lights on, car wont start even with new battery
- Random throttle issues wtf? Help
- 96 Civic Ball joints and tie rods.
- 95 civic front end noise
- 92 EG: Blower Motor Problems
- Radiator fan won't run!!! Works when switch connector is jumped
- Wont start, cant figure out why!
- after putting silicone lube on OEM jack, now its hard to turn ?
- y8 fpr on b16a2?
- transmission problem. Help !
- surging idle 93 civic si
- replaced head gasket for d15b7, no compression in any cylinders.
- 1999 Honda Civic Si Temp Sensor Problem
- HELP! Heater Motor Relay Missing
- Ex exhaust into 98 Civic Lx question
- Bigger trip w/ leaking heater core? Help me please!
- PCV Valve Broke
- 97 civic sedan measurement
- OBD II d15b non-vtec sensor question.
- Big hp civic skates all over road
- 99 Y7 to Y8 swap
- Fuel Line Issue...
- 1998 Honda Civic DX - overheats
- How-To: Alternator Tensioner - D16y's Finally!
- Installed Integra Interior into 94 Coupe.
- Oooops...forgot to mark RTA bushing orientation. Help please
- Camber and Caster Issue
- Civic Clutch Pedal Sensors
- Transmission Downshifting Jerking
- 94 Civic dx coupe. Motor swapping. .
- d16a6 manifold on y8 head (minime)
- 98 civic dx idle problem
- Rough start and wont rev past 3k
- Rack and Pinion- EJ1 1995 honda civic
- Engine code and VIN relationship?
- help me put a value on this car
- Has my timing belt jumped?
- D16Y7 Water Leak Issue
- Correct transmission oil for D15B Multimatic
- Civic shuts off at a stop help me
- Seat Foam / Covers
- Need verification on a code please
- Dented rocker
- 97 Civic blowing #44 fuse
- 96 civic ex - need advice on b16a1 vtec swap
- How much was your swap?
- P06 or P32 on my mini me?
- how do i know where to set rear lcas before torquing??!!! urgent please help!!
- left side speakers not working? need advice?
- Had to saw my lower ball joint off, '97 LX Sedan
- Problem with D16Y7 cam into D16Z6 head
- New distributor/timing issue, HELP!
- A/C Compressor Not Engaging
- Camshaft letters
- What is this part and do I need it? - Leaking coolant
- OBD1 Code 43 - Fuel Supply System after fiddling with O2 sensor?
- ex exhaust on a dx?
- tps help
- 93 Del Sol and center exhaust possible?
- EG hatch - go over small bumps and front suspension has little rattles
- How Many Miles Per Tank
- Remove chipped ECU
- Wheel size/width/offset help for EG
- More Idle issues
- Flashing D4 light HOnda Civic EX
- EIPT on fuel rail?
- How to tell if my timing belt is original?
- JDM D16Y5 into 97 Civic HX
- subwoofers in del sol
- Swap d16 non vtec head with d16 vtec head?
- eg hatch - mouthing depth of front door and rear panel speakers?
- 92 Hatch wont start
- Proper Timing Belt Tension for D15B?
- 2000 dx o2 sensor cel
- Will 2009 si civic seats fit in my 1994 civic ex?
- 98 civic hatch whats available?
- S40 (p4a - a000) Transmission Questions
- Possible ground or battery issue?
- MY White 96 hatch WAS STOLEN!!! Fullerton CA area
- 03 ex cluster swap into 96 ex (started)
- 2 parter or so
- cel on after 00 b16a2 swap into 98 hatch - code reader not recognized
- EG6 HEATED MIRROR HELP! How to swap OEM PFHM into a JDM EG6?
- Ej1
- 92 civic eg SI with JDM H22 swap high rpm issue
- Ignition coil repeatedly failing / should I swap?
- 93 civic si HB Tailights/dash problem
- Cannot get my boosted civic out of limp mode. Someone help.
- A mechanic saying, civic overheating needs engine overhaul?
- d15b7 starter in to d16z6??
- Del Sol Exhaust
- D16Y7 timing belt cover
- testing a map sensor without a vacume pump??
- Did anybody resurfaced engine head at NAPA?
- d16z6 head d16y7 block
- Password JDM doesn't sell window visors anymore?
- I only had her out for one day.... ;(
- quick question
- ECU won't scan, no connection to computer FIX
- Rear Honda Emblems
- question about the weird noise from suspension/coilover
- Squeaking noise when turning steering wheel. Click noice when accel
- Y8 head y7 bottom blocc
- White Smoke... oil on undercarriage
- 1998 Civic DX cutting out
- 2000 Honda Civic Coupe DX (whatever the lowest model is) Automatic
- 98 heater question
- 95 DX D15B7 Head Replacement / Timing Belt
- HELP! car won't start work in the morning
- 98 Civic LX - CEL code P0113
- SI vs EX
- Slimfan.com
- 99 civic manual conversion help
- Help SMOG! High NO levels and trying to fix heating problems.
- Just bought 95 Civic Dx. Need some help?
- 98 Civic Accessory Socket Problem
- 98 Civic door lock problem
- Idle Air flow valve hates me...
- S2K rear diff plausible in AWD B series civic
- 92 Civic Hatch looses brake pressure
- 95 del sol high emision gases
- help building a zc sohc vtech
- Low fuel light not working
- civic b18 oil gone
- distributor holes wont line up correctly
- spoon mono block
- 2 civics same start up problems
- Starting up after head gasket replacement
- 2000 civic si rear camber jam nut help
- Front speakers - not working
- Possible bad Clutch Master Cylinder on EM1..??
- Proper way to vent/cap off EVAP hard fuel line?
- Fuel issue
- How to replace roof molding clips?
- ckf bypass help
- replacing front oem endlinks with ES polyurethane
- 97 civic lx d16y7 starting troubles
- Car Bogs Under 1500 RPM? Backfires too.
- help!!! 2000 honda civic d16y7 tranny blinking d4!
- LED light bulbs
- 97 ex civic rev limit 5000
- question bout overheating
- Carsteering.com? Del sol steering rack...
- Y8 TRANNY QUESTIONS FOR INSTALLING
- Stumbling when reving
- Honda vx commuter - need new radiator - recommendations
- 98 Civic/D16Z6 swap - Can't read codes with scan tool
- Aftermarket Cam help
- Weird Combination of CEL #'s + Dead Speedometer?
- Getting power doors from a friend
- 98 CX quiet cat back suggestions.
- Please help me understand my frankenstein car.
- Do I need valve clearance adjustment?
- Simple question regarding basic maintenance with brakes
