View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How are coilovers adjusted properly and fitted?
- installed d15b into cx and the car bogs?
- Adding ac to my b series eg
- Is it my TPS or my ECU?
- dh-racing heads
- bad headgasket?
- K20A motor in a del sol or civic?
- P30 ecu pin locations
- can a S2000 motor fit a del sol or civic??
- Distributor Picture Requested...Questions Also
- Soft Break problem
- CYLINDER HEAD GASKET SET please help
- Power windows in a vx hb
- HELP....i need a 97dx wiring harness
- Help.. valve cover screw broke..How do I get it out.....?
- weight diff from 5 lug and 4 lug
- who here rebuilds trannys
- silver h22 turbo hatch.....
- Wireing a b16a3 into a 92 civic si
- CV joint halfshaft replacement queston
- N.Y. emission laws??
- whats wrong with my si cluster
- What BHP shud i be aiming for? how about 130bhp at wheels?
- 96-00 rear seat reinforcement bar? (just look)
- would an intake manifold off a 95 civic dx give me more power on 99 dx coupe
- fading brakes?
- ls catback for hb fit sohc header?
- H&R springs
- just got my junkyard hf manifold
- Not uplugging battery during steering wheel swap?
- Replacing a Steering wheel on a 6th Gen Civic
- wiring vtec in a dx hatch
- AC Compressor question! Please Help!!!!!already searched
- h4 or h3?
- weird creakin noice from rear..
- ROTORS (looking for 4x100 with diameter of itr/legends)
- Just got my jdm d15b today. Few questions.
- # of ground wires/locs on a 92-95?
- tranny problem
- EX OEM power windows install to 93 hatch?
- B16A3 Hatch wiring?????
- help routing ducting from the front bumper to the short ram filter, anyone have custom pics?
- Can anyone tell me
- How to remove 96-00 Ek hatch rear bumper?
- how much torque on the headers?
- 98 integra cd player in a 92 hatch?
- how do i turn on my fan
- *** IAT on a 96 civic Fuse ***
- ignition switch?
- climate control doesn't light up!
- del sol:pros-cons
- which size tires?
- gsr m/c and booster replacement now problem.. (searched already) HELP!
- my a/c's making an annoying, high pitched noise...
- Punctured Radiator Help!!!
- anyone no where 2 find J's racing lip for eg hatch
- need help installing tach
- Cutting Carbon Fiber? anyone tried?
- Cold Air Whistles, Need help, annoying.
- where to fill tranny fluid.
- PR3 Pistons
- GSR or Civic Type R motors???
- Changing the oil on a manual transmission
- How to install indiglo gauges without them interferring with your needles
- pick this up for a bomba$$ deal...
- Does this radio have an alarm in it?
- How To Recalibrate the Speedometer
- thump noise from passenger rear strut
- Something I've noticed about Spring rates.
- is it ok to run 205-50-15's on a 15x6 wheel?
- How long do "Energy Suspension Bushings" last?
- B series Coolant diagram
- D16 head? Repair or replace.
- Bosche o2 sensor wires? What goes where?
- Misfiring on Cylinder #1
- turbo and front mount install HELP...thanx!!
- '95 Civic EX, Do I have ABS???
- Help: Car won't start right away when is Warm.
- My timing belt broke after only 5,000 miles?
- suspension/which springs?
- purge solenoid question
- Sir II swap into 1996 civic HX.
- differences between civic and del sol
- valve cover noob help
- Need help/advice on dropping oil pan
- Tokico illuminas and H&R sports
- how do you adjust toe?
- Windsheild Wiper Problem...
- ATTENTION: Ricey McRicerton and BauleyCivic are your NEW MODERATORS
- hi i need to know what clutch i should buy
- Life Expectance of SOHC VTEC engine
- help my car wont go into first!!!!
- disc vs drum.. pros and cons?
- For the People who want the 99-00 Front and Rear conversions and Motor Part places
- OEM civic EX brake pad and disk #s
- blown struts?
- tell me what i should do in your opinion
- Engine Whine at low rpm
- Valve Cover Gasket and Bolts
- Weight
- how to pull 92 civic dash
- 99 Si Power Window Problem...
- start-up problems
- B16a2 engine running problem after fitting type R camshafts please help.
- I have $600 to spend, What should I buy??
- Battery: Dry Cell
- *already searched* Ebay/Generic CAI, what are extra metal brakets for?
- Alternator/Power Steering pump Pictures
- where the fill plug
- Busted EK mount...buy new or upgrade.
- New Here, just saying HI
- 96-00 hatch spoilers with 3rd brake light?
- Distributor & Harness questions
- SILVERS engine dampner
- dash peice on 92 civic
- What mods to beat Accord V6
- Question about engine whine
- Need Help With valve cover ASAP!!
- Hondaautomotiveparts.com Picture help
- Question about Cat.Converters: Glowing red?
- Altezza lights
- Swap and dashboard - question?
- Pillowball uppermounts
- is this the right forum??
- Tach Doesnt work after swap, heres why...
- Cylinder Head Gasket or Cylinder Head Gasket Set?
- Went BACK to the track again...(d16y8 sol)
- Sway Bar***
- RACK AND PINION?
- misc backfire on 02 si?
- anyone texas that can chip my p13
- Ac on or off?
- New IACV for B18C1, what part number???
- mud guard fitment: interchangable hatch<>4door?
- How to take the clear cover off my EX cluster??
- Del Sol Weight Redux
- 92 h22 civic si needs brakes!
- h22 civic clutch and flywheel
- just wondering b18c5 bottm h22 head?
- Overheating problem i cant figure out.
- Y8 manifold and check engine light BIG PROBLEM PLEASE HELP!!!!
- Help, 94 Ex Coupe Sohc Failed MD Emissions (mostly stock)...
- Registration and BAR CERT.
- smoke at high revs
- O2 sensor position causing this?
- Stock Shocks and Skunk Coilovers
- Problem with climate controls
- does this price sound right?
- Spring Rates
- front clips and right hand drive conversions?
- Where 2 find Swaps?
- help removing climate control panel...
- Exhaust manifold gasket help...
- Those w/ CTR carpet
- LSD d-series question
- code 41.... *HELP NEEDED*
- Rebuilding my $1 Z6
- YOKO'S CAR CHECK THIS BABY OUT!
- GSR DASH--Simple question
- Automatic tranny noises, need help!
- Integra GSR seats into EG tech question. (already searched)
- anyone got there ac to work with H22 Eg cx.
- New User asking Experts! PLEASE READ AND RESPOND! tHaNkS guys
- installing short ram intake. do I need to remove resonator?
- Going to Ref Station in San Diego. Need tips.
- opinions on aem Tru-power pulleys
- Jdm sohc zc intake manifold
- jdm or usdm
- Should I upgrade to bigger fuse after new horn install?
- Cronic Misfire HELP
- Best Coilover setup for under $600 for an egcvc??
- tps sensor install help....b18c1
- B18C1 swap into EG
- STUPID QUESTION: REMOVING GAS FILTER 00 CIVIC LX
- [FAQ] How to: Identifying B series transmissions.
- starter interchangabilty??
- Soft Brake
- hey everyone, jus need a quick response no time for searches..
- Fans still wont turn on
- Ecu help quick !!!
- P73 ECU on a B16A2
- Fuel pump
- SCE Copper Head Gaskets ???
- stock diameter of Dserires radiator hose?
- Hood Release
- Need pictures of reverse light plug on a d16z6 tranny...
- JDM ITR header on a b16
- lsd for h22 tranny
- Any socal guys want to lend me their stock '96-00 Civic hatchback muffler???
- Final Drive
- 99 civic cx power steering
- City light wiring... to come on without corners...
- TPS pinout on ecu, help me out
- Gear Ratios: Civic DX d157
- idle caused by additives?
- front wheel bearings and brakes????
- Who makes Carbon Fiber Lips that Arent Mugen? Like OEM style for 99-00???
- Looking For : Auto To Manual Conversion Service, looking for : AUTO to MANUAL conversion
- 2000 civic si gauge cluster
- Which Flywheel with this clutch?
- Zc swap belt help
- water leaking in the trunk,96 ex
- Ebay Strut bars
- I Broke My B&m Fpr...
- Got some new tires today
- ek9 seat rail part numbers
- problems with autometer wire installation on 1994 civic cx. did search already
- Blow off valve!
- d16y8 having trouble coming alive
- Just installed d16a, having code 10 issues
- midpipe?
- ITR 99 EK: 'maintenance required' on cluster turned "RED"
- Armrest & Cup Holder Console not properly aligned in 96-98 Civic
- b18b in Civic.... help me w/ new tranny... LSD worth it? And a couple questions... Thanks
- Ticking Noise
- B16 B18 1/4 times what are you running??? (mods, times, car)
- Any difference between Si shocks and non-Si shocks?
- (New to Forum) need instructions to change headl. . bulb in my 96 Civic
- what is my car worth?
- What caueses the altenator to go bad???
- Looking for 2000 Civic SI full gauges
- Installation complete: S/T Swaybar installation on 92-95 Civic HB w/o oem bars
- clutch break in, maybe clutch is glazed?
- d16y8
- Spoon carbon fiber lip...
- mugen lip from jdmsh!t.......
- Suggestions for properly replacing cracked A/C line?
- Track Times for a D15B7 w/ Junkyard Turbo?
- unknown problem PLEASE HELP!!!!!
- What`s the name of this?
- bumper side stiffener question
- engine replacement
- willwood caliper with stock rotor?
- Car just got stolen in Socal....
- Car wont idle at all....
- just got used dc header for $75
- WTF PIN ON SKUNK2 SOHC CAM GEAR?
- will a GSR dask fit a 92 civic?
- gas needle on 93VX hatch changes constantly
- exhaust questions
- Ehite EG Hatch In Redmond WA
- CAM specs for d15b 3stage vtec
- IACV Question i did search.
- welder question....
- Civic spring rates and Integra spring rates
- All EG owners with Recaros please read!!!!
- d16z6 turbo vs b16/18
- HID bulb exploded pic inside
- gap between headlights and bumper
- heater cable re-installation help
