View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ignition coil?
- other civic forums
- ***HELP*** Idle Surge!
- HOW TO REPLACE THE FRONT DOOR SPEAKERS?
- Front Lip
- State Ref Cali Question
- VTEC pressure valve ecu code
- IAC valve
- body help:scared: helphelp!!!
- got fog with picture
- Someone Please Answer ASAP
- Shift Linkage Problem - 2000 Civic EX
- Injector Resistor Box Install 1996 to 2000 civic ek body
- S2000 exhaust on a 94 coupe
- WHAT IS THE BEST D-SERIES GEARING THAT I CAN GET?!?!
- cams for lsvtec?
- engine vibration issue
- what is the difference between USDM headlights and JDM headlights in terms of beam pattern?
- 97 si throwin 3 codes! help would be nice!! :)
- B16 head on b17 block?
- '93 EG with B16A, Which Samco Hose kit?
- torn boot
- b16a2 in 95 civic hoses
- Will I get a CEL if I..
- Transmission keeps revving even in Neutral. WTF.
- Looking to Buy an EJ8 or EM1
- vx block with d16z6 head. timing belt help
- b16a2 swap into a 92 civic lx
- Whats the diff btw HiFlow Cat and Test pipe
- SI HARNESS
- GSR ECU ?
- What is this notched semi-circle I found in my d16z6 bottom end
- How do you know if your AC compressor clutch is engaging?
- spark plug question
- Where is this located!!!
- z6 or a6
- vibration in gear shift after rear main seal work?
- Who the heck has ek9 thin side moldings in stock????
- 00 Civic Si, P2T ECU - What's the extra green plug?
- Power lock conversion question!
- difference between obd0 and obd2 throttle body's?
- head bolts sequence
- Need some input on SR*S Catback (ebay exhaust)
- Cali Bar Question!
- Spark, Fuel, Compression NO START! H22 swap
- Help - Speedometer Stuck on 15 mph
- jdm b16 obd1
- I NEED HELP!!!!!!!!!!!!!!!!!!!!
- 2000 civic ex 1.6 automatic transmission oil leak
- mugen front lip
- running an a6/y8 on an obd1 e'x
- Anyone ever used cruise control switch for fogs?
- Need help on pricing
- Speed Sensor Questions
- Can i pressure wash engine and engine bay?
- Civic LX Compressor Problems
- check engine light on code 7 tps
- shift linkage
- CEL with VTEC
- integra seats in a civic coupe
- will t3 turbo be too big for sohc turbo?
- sensor question
- lowering the car but keeping stock springs, any ideas?
- prelude radiator in ek?
- help my sedan
- itr lca's on del sol (eg)
- How to spot real or fake Vision corner lights!!!!
- burning oil. advice?
- Projector Headlights
- Need help with JDM Fog Lights!!!!
- calling all EG/Seibon owners!!!
- Are d16z6 and d15z1 came gears interchangeable
- EACV: 92 civic vx
- trans problem AGAIN!.
- NEED SOME HELP WITH VTEC SOMEONE PLEASE HELP??????
- test pipe/cat questions
- ITR wheels
- H22 in eg
- audio console question
- 96 civic question
- where can i find these seats?
- 2002 wrx seats
- new clutch question ??
- need help.....sohc vtec...
- Quick Question
- How to Remove Rear Bumper
- gc top hats
- CTR Wheel With Cruise Control
- d16z6
- do i have to recalibrate the tps if i switch throttle body's?
- iacv and ive searched
- where can i find an oem lip kit for my 99 si
- just bought a 99 si.
- 93 hatch d16y8 cold start problem
- well.....
- 99-00 jdm b20b block with P8R head questions...
- Autometer shiftlight wire in with factory tachometer?
- nOOb... asking for tips?
- o2 sensor? can it make ur car stagger
- 2000 Civic EX 1.6 Sohc Vtec **Code14 ** Tested no go.
- srs q....
- 5 lug conversion?
- Is this a real BOMEX ek wing?
- Need help new intake and no plugin 4 hose to valvecover!
- Location of ignition switch ground wire
- Have You Seen
- d16z6 speedsensor problem?
- autotechnic gauges
- Interior lights come on AFTER key is put in ignition.
- Clock issue in my 92 hatch
- Tranny noise
- what is a good compression ratio for a turbo lsvtec
- Tranny lubrication Syncromesh
- 3rd gear
- h22 swapped civic axle problems, any info
- B16a2 4.4 gears specs needed,help....
- Motor runs with no ecu fuse whyy?
- sedan trunk swap
- Problem with skunk2 intake manifold!
- engine mount
- A b16b reff question
- do 92-92 coupes and 4 doors use the same headlights?
- Car boging down between 2 and 3K after engine warms up
- Electrical Question on 2000 SI / type r motor help plz!
- really odd question?
- i have serious vtec problems... =/
- Brake problems help!
- Ls swap
- what steps should be taken to buy a swapped engine car?
- eg6 Interior question PLEASE HELP!!!
- NEW TO SITE..a Few questions about my d15vtec..
- Losing Faith? (WI)
- 92 civic won't start....
- head gasket?
- ls rebuild.
- h22a4 in 96 del sol
- quick stupid question
- How to bypass o2 sensor
- a few pics
- new to the scene...
- Brake issues HELP =)
- (HONDATA S100) Can't pull CEL code.
- Interior trim piece removal
- EG8 Trunk Dampers on EJ2?
- integra dash in ek
- badges for ek
- Turbo
- cluster lights no worky
- windows jacked and 3 cut wires
- EK hatch sway bars
- carfax please.....
- HELP!!!
- 95 Cx B16 swap.... fitment issues?
- Coupe exhaust on hatch
- need help ???????/
- 96 - 99 Civic Hatch Shell Wanted or 93 - 95 Hatch Shell....
- what would you buy this car for?
- 92-95 civic coupe trunk lock
- would a 1999 ek...
- help with code!
- EM1 weird idle
- need parts help please!!!
- will this work? Help!
- Brake/Clutch Line Question *Searched*
- New to the Scene Tell me what you think
- Different size rear hub bearings?
- do i need a new distributor?
- DIY: Help Wire Tuck
- CTR Exhaust too LONG?
- reverse light
- bellhousing bolts
- no0b,first honda tell me what u think
- What would be good price for my car?
- Skunk2 Pro-C
- temp. gauge
- D15Z1 92 VX
- dynomat
- b16a2 em1 charcoal canister removal??? help..
- Lowered civic but want to raise it up 1 inch.
- PG6B Pistons???
- completely confused with all these different types of mounts, please help
- 96 hatch guage light flickering
- Hello all Need some help on my d15b1
- how do i bleed my clutch line?
- BOV selection, need input/opinions?
- Are the Knucke assemblies from Civic and Integra the same?
- DEL SOL SPECIAL MODS
- Ignition/steering lock interchangability between manual and automatic ???
- Bumper replacment on 96 Civic EX
- Check engine on...no codes
- Weird Sound From Rear End
- EM1 rear sway bar
- test pipe on em1
- 95 civic
- Help car is being weird after Valve Job
- Differences between d16y8 manifold, and z6 manifold.
- Transmission noise under decel
- Need some advice on a new project car...
- Fuel gauge question?
- Help: Fuel flter replacement
- eg h22 wiring
- CAR WONT STARTT!!
- HELP, is my tranny going?
- White SMOKE!!!
- Where to get antenna and wiper delete?
- Quick ? bout a clutch!
- Do eg 4dr civic hoods and bumpers work on eg hatches
- new to h-t... well kind of
- Cat Converter
- Available exhaust's and whats the story with comptech?
- si cluster problems
- 92-95 civic cowl hood
- Front Passenger Side Lug Studs
- b7 firing order
- Exhaust help!!!
- rear lower sway bar
- start up prob
- steering wheel
- FOR SALE!!!! RARE 1995 HONDA DEL SOL SI.... BUILT B-SERIES
- All 4 cylinders Misfire. New timing belt.
- BOOST CUT LIKE SYMPTOM...HELP!!!!!
- 92 civic running rich, smoking from exhaust
- FVCK THEIVES!
- B16 Hick-up
- JDM SRS Momo steering wheel - will it deploy in an accident
- rear window visor/wing???????????????
- "NEED HELP" why does my battery fuse(80A) keep blowing
- prop valve question
- d16z6 clutch squeak
- P2T ECU instead of a P72.
- EP seats fit in EG?
- what kind of cluster is this?
- help me figure this out!
- I'm trying to figure out what would make the most sense (engine swapping/modding)
- EK skirts...
- need help with b20 swap into 96 civic.
- code 3?
- New to EG
- Anybody familiar with vtec-e d15b JDM? basically d15z1?
- Will Evo 8 Recaro Rear Seats fit into an EG coupe???
- Plug's on B18c1
- vtec controller
- Where is IAB solenoid located at on gsr manifold???
- need help on speed sensor
- 97 EK hatch CX with B16A2
- what center caps fit hx wheels
- can't pull codes
- new guy here
- 99-00 conversion questions
- Important question!
