View Full Version : Honda Civic / Del Sol (1992 - 2000)
- looking for front lip help if you can
- Are these any good??? (LCA's)
- Cv joint/Half shaft question
- identifying an LS transmission
- where to find
- how much?
- Become a smog ref....
- what engine code is this?
- 2000 si 16a2
- tsunami front lip
- Ball joint/cv axle question
- What are some other civic Forums out there?
- Part list needed for auto to manual conversion in EK
- Quick Question
- Spoilers don't do anything on FWD?
- 99-00 si pedal assembly fit an eg?
- Del Sol Exhaust Clip
- full-race.com *make my wish come true*
- No Respect
- Help: sound is killing me
- d16 question
- car won't start
- People in the Orlando, Fl. area watch for theive's..
- Calling out all Honda know-it-alls!!!
- Integra fuel pump in a Civic????
- PIC request: EK with ITR 4-Lug conversion...
- More new toys! (56Kers you will die!)
- what should i sell for
- lude 4 lug conversion
- For those wondering about 96-98 civic jdm fog lights...
- i cant even sleep anymore
- Chipped Ecu question
- i have a distributor problem
- What motor should i get for my new hatch?
- ITR seats in a 99-00 Si
- Bent Valves or Bad timing?
- hele me with my power lock!...please
- (rapfix) quick-release hub horn hook up to srs
- 96-00 civic cat question!!
- Look what UPS left me!!!!!!!!!!!!!!
- performance shop
- Loosing clutch pressure
- Suspension question: Camber kits?
- wrong Key open my door !!
- Z6 or Y8
- Ek rear strut bar cut-out template
- I want to go fast.
- J's Racing intake on an EK w/ GSR?
- motor question...burnt main bearing..??
- where i get mugen
- need help car is acting up bad (long story)
- heater is leaking
- del sol air bag, NEED TO KNOW QUICKLY
- jdm audio console
- New Car Auto to Manual
- Just Finished Swapping in a JDM D15B into My Delly and Have a few Questions.
- 96-98 folding mirrors
- new guy
- struts
- what should i do fellow h-t'ers
- b18c5@11:1 vs b20z@12:1
- 93 civic si???
- Engine Noise around 3K
- exhaust sticker
- Groupbuy on Mugen and TypeR LIPS
- No spark at the coil
- Want pictures of 92-95 hatchs with eyelids...
- d16z6 specs
- del sol map lights
- 96-00 civic manual, what page ?
- do all stock vtecs engage at about 5000 rpm???
- pr4 dist. work for y8?
- AH! I just found out my brake rotors were never bolted to the hub!
- Reclining Level
- SRS Light Issue in Del
- quick newb question
- WTF? spark and coil and not at plugs HELP
- CTR ecu
- hatchback bumper
- B20VTEC Question....
- head gasket question on d15
- b18b lightened flywheel
- How much...
- well guys the civic is almost gone
- Ek CTR CLUSTER HELP
- sonc vetc builted up
- CAN SOMEONE PELASE RUN THIS VIN THROUGH CARFAX FOR ME?
- hx v-tec e engagement?
- 180 for bolts...HELP ME
- WTT: your APEXi N1 for my APEXi WS rear section off your 92 up civic
- Installing JDM rear sway bar
- how do i put on coiovers
- need EG foglight switch diagram
- COrbeau Seats?
- SALBAJE rocks!
- TECh question: 94 hatch..will a 00' ex exhaust manifold fit?
- help!??! starting problems
- Any 6th Gen Comptech Sport Spring users?
- Mugne lip for EK 96-98 couple of questions?
- what type of lip is this??
- where to buy indiglo gauges...
- STOLEN CAR!!!!! SO-CAL / BURBANK // WHITE GSR HATCH PLZ HELP
- Whats all this worth? :)
- Holes in dash :(
- Did we just mess up these mirrors?
- Removing inner tie rod ball joint from steering gearbox/push rod...how the f*ck?
- ***TOO ALL THE FLAMERS***
- Are the 2000 Civic Si rear sway bar endlinks different?
- question on gas 87 octane and 93 octane
- what do i do
- 96 hatchy exhaust question
- Carfax Please!!
- d16y8.........Y Y Y!?
- Just a stupid question
- cel 20-Electrical load detector ??????
- How do I check ECU code...?
- Keep your civic from being stolen
- strut/tie bar fit q...
- foam from radiator?
- Noises from the dash
- what' the best way to test electrical problems??? READ ON, HELP PLEASE...
- snow tires
- Nankang tires
- Espelir Exhausts.... pics on a Del Sol???
- spark plug wires 00 si...??
- rota group n
- need help with header???
- White smoke from Radiator.
- Will EK Civic seats bolt right into an EG Civic?
- Newbie question
- EG hatch with pimp sag
- Will I run into any problems (besides inside tire wear) if I don't have a camber kit?
- Bleeding Brakes
- do i need cam gears with itr cams ?
- Searched couldn't find it.
- car wont start after rebuild...HELP!!!!
- wondering if this will work?
- leather armrest 'n audio console?
- 5 lug conv question
- 89 and 90 civic sedan differences
- Car Cover recommendations?
- gsr sideskirt on ek coupe???
- Just picked up a nice hatch yesterday! (huge pics, 56k take a break)
- jdm fog lights
- will a 94 CX distributor fit on a 00 EX head ?
- what should i sell my ob0 jdm b16 dizzy for perfect condtion
- b16a2 short block?
- high pitched squealing noise... WTF??!
- exhaust fit?
- Anyone know where I can get this Trunk Lip?
- ECU truble...
- my eg and DA
- is there someone who sells turbo adapter plates and pipes?
- Lenso aka Axis VPD's, 16s..experience?
- Si lips in EG???
- my car died... im home and not my car... tell me wat u think.
- suspension gurus..
- where to pin airfuel on ECU? obd1
- What are the differences between a 95 civic ex(abs) brake system vs an integras?
- Anyone got any teal eg pic's?!@?!!??!
- I need some new rims........
- EG CTR/ITR 5 lug pic request
- Where to get flat black Si Lip?
- does this happen to your hatch too?
- DC Sport Ceramic JDM 4-1 Header?
- How much would you pay
- Will H&R springs give a good drop with 14's?
- squeeky hatch
- good deal or not?
- swap integra rack or keep EX steering rack?
- engine swap
- Where to purchase catalytic converter?
- Dont know if this is a repost, but how hard is it to switch out a tranny? vid inside
- steering wheel question?
- New motor...B18c5
- Mud Civic Revisited
- which do you like better...
- what tools to do alignment
- Wuts the diff between 96-98 Eks and 99-00 Eks?
- IACV control screw on a 97 civic lx d16y7
- Wheels Telll Me if they would look good on a red civic
- dvd sound question.
- ZC SOHC engine??
- places to shop?
- 96-98 Civic couple tailights bolt on to a 99-00 Civic?
- Which Turbo Kit For Built D-Series?
- Importparts.com - We need prototype vehicles to turbocharge!!!
- mugen lip?
- How to make Hyper Blinker
- NorCal Peeps - Post pics of your ride!
- ordered new goodies!! yummy!!
- Will OEM Intake Work From Integra to Del Sol?
- fiberglass
- I need help! dowel pin
- D16Z6 Throttle Body questions
- block guard fitment question
- side marker
- ABS from a ITR
- pics of swapping to vtec.
- Spoon direct air flow pipe
- need help finding quarter panel
- Fatty EX here.....2625lbs!!!
- another suspension q
- 19" Rims on a EG Civic Coupe...
- Noob blown shock question...
- buzz buzzing dash noise every two minutes on the nose...
- I've Got A Leak!! HELP!
- took some pics of my car
- #$%^ HELP!! A/C and BOOST!!! @#$%
- i think my car is possessed
- Pic request... and a few Q's
- b16 Pressure Plate ?
- p28 and p 30
- Stock Tire Size Question
- Does anybody make a GOOD fitting molded carpet? Tried ACC...
- Which steering wheel would you get?
- busted rack? tie rod? HELP!
- interior
- B16 flywheel bolt troque specs
- conversion opinion!
- Rear bumper fitment
- does the 94-95 civic EX coupe come with 4wd??
- what can i do with my '98 hatch?
- b16a messes up in rain and snow
- ecu code #19?
- Any1 put a gsr guage cluster in their 92-95 civic???
- b16a swap question
- Advice on coupe or HB
- trunk leak?
- Any of you EG guys have Bronze/Sport Bronze Rota C10's on your hatch??
- d15b mounts
- Quick question guys - just point me in the right direction
- Budget racing.....b series vs d series
- fuel cut problem
- b16a, what is the best way.....
- Anyone seen this? Broken Pressure plate
- irractic idle and jerking.... on 2 cars ?
- Guage Cluster is TRIPPPIN!!!
- 96 civic front cap on a 94 chassis has anyone ever tried this?
- ek tein flex users: what dampering setting are you guys using?
- Rota circuit 8 rims on my coupe
- jdm crx front and rear brakes
- Did Anyone have there red civic hatch stolen in the NOVA,MD,DC
- a6 pistons in a z6 block???????????
- Will a type r muffler fit an eg hatch?
- Rota Downshift?
- bonnet switch?!?!
- RIMS 16's or 15's???
- Opinions on my possible suspension upgrades?
- Blowin some steam
