View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Anyone in Sacramento area, help me do a leak down test?
- 96-98 civic dx cluster??
- Looking for an engine braking post (fuel economy)
- stock springs
- Tower brace bar
- what axels will fit my swap
- Would a 96 honda dx look right?
- The best setup for all motor b16a1?
- d15/zc swap question
- d16 vtech motor question
- What is the thread pitch of the tranny bolts on a 97 EX Auto?
- ecu code
- any guides on how to install a car battery?
- i have a problem
- Wanted Honda part# for rear wiper plug 95 hatch
- Rotor/Brakes sizes between civic and integra models plz
- running with no muffler
- Funny question...transporting a motor with the EG?
- Is it really that bad??
- rebiult distributor,now no run?!?!?!?!WTF?!
- CF Hood
- auto ek puttin in manual h22 swap
- was wondering how much shot can go with
- SRS Light
- new to honda tech
- 99 vti coupe seat subframe (ukdm vti = usdm si
- Battery
- Crank pulley concern
- errrrr help me decide
- 00 SI CD player in a 96 EK HB help!!!!
- 96 HB with a sohc ZC
- need help making desicisions
- How to install camshaft and cam gear on d16z6
- ? for mod
- should i...tokiko blues with suspension techniques springs
- New to the Boards
- does the dizzy realy matter?
- remove head.
- car cranks awhile before starting...what's wrong?
- EJ1 suspension into a EK??????
- some quick help...
- obdI to obdII wiring harness where can I get one ??????
- i want to swap a b18 ls from a 93 teg into my ej8 need advice
- Tanabe Exhaust Question
- 2000 Civic
- WHAT HEAD CAN I USE FOR MINI ME SWAP?
- larger TB on stock manifold
- Need a quick answer...JG Edelbrock Intake Mani
- CYP CODE 9, Honda told me this will fix it .. Is it true??
- Name that plug! If you got the brains give it a try!
- F22
- 96-98 EK D-series tranny mount different from a 99-00 EK D-series?
- Will this difference be a problem?
- best lowering springs for a 95 honda civic cx hatchback???? what would you go with????
- STOLEN: Black 92 Civic DX H/B - B16 swap and lowered - Tacoma, WA
- v-tec help
- Auto to manual swap questions
- No pressure in my brakes?!
- flywheelllll..
- question on priceing with sunroof install
- Recharging my r12 a/c - help!
- VTEC pressure valve
- How do i put this shit back on?
- tire question...
- My ACT clutch squeaks
- little question i got
- brakes...
- Anyone had Code 65 and Code 9... can you help me..
- Fuel injector
- del sol seats
- FS: ROTA GROUP N
- lean at idle and wot ?
- :fuel cutting off way before redline??? please help!!:
- Wheres the jumper plug in 99 SI to check codes!!!?????????? help
- Why My Coolant All Gunky Picture Inside!
- what linkage and mounts
- where to get 97 civic crank pulley?
- light bulb problem
- Quick question
- ecu help needed
- 95 ej1 swap question?????
- Coilover instruction help
- PBR ultimates same as Axis Ultimates?
- b16a3 into 92 cx
- Front Lip on my SI
- SOCAL trade my h22 for a GSR swap 714 951
- Weird idle problem..not your typical surgin..read
- GSR barke conversion
- b20vtec what u guys think?
- b16b, what obd1 ECU
- Currently sitting at Frank Anconna Honda. Car being fixed
- Searched! Tranny question!
- y7 block / z6 head which timing belt to use??
- Auto to manual conversion: Completed, just small problem bitching at me now
- Need help changing wheel stud
- help! eg Si wont start
- Where to get bolts to mount D16Y8 to the engine stand
- over heat/oil problems
- cel cant get code??
- Removing Fron Disk Brakes
- USDM 2001 type r
- Yes, another GM Synchromesh thread
- pistons
- Door Handle Snapped Off
- SOHC timing belt teeth????
- 4-2-1 headers better than 4-1 for the street? (topic searched)
- a/c compressor not coming on
- z6 & Y8 Oil pan: THe same?
- B18C5 vtec engagment
- S40 dx tranny rebuild question
- Interior fan only blows hot air...
- Oil pressure drops in VTEC?
- Air conditioner question. Test for leaks? how much r12, which port
- will 92 integra seat fit in eg?
- b16a bearing installation?
- is it worth it?
- help with d16z6
- Swap or Turbo
- What size wrenches
- Factory Civic Window Tint Question
- any got answers?
- Staying Obd1 With Type R SWAP
- sohc NON vtec head swap
- 97 civic power windows wont work!!!
- obd1 dist to Obd2 Harness *seached plenty
- Annoying and extremely loud SQUEAK from front passenger side...
- no keyless remote, does it have it?
- Jumpers
- check engine light
- Running Very Rich, HELP!
- quick curious qusestion about steeringwheel
- side marker question(blinker sync)
- 93,000 2000 si maintenance
- airbags
- Major Bogging-Vibration
- where would i go about gettin a car shell
- clutch questions. OEM vs STAGE
- Newbie 5th gen or 6th gen
- engine temp is higher
- need some axles
- sputtering missing..????
- B series or Dseries turbo
- p28 hlp
- springs from a eg hatch into eg 4dr????
- what should my stock 97 civic ex run??
- just wondering
- When you are low on gas
- kind of a n00by question
- advancing timing?
- drained battery ??
- Battery? Alternator? Something else?
- 91 Octane ??
- B16A Smog Test
- ej8 radio messed up help
- Half Shaft question
- Quick Release Steering wheels
- pic request... s.techs
- Sunroof Install
- AUTO MIRRORS N SWITCHES! HOW DO YOU
- B16 Tranny question?
- will a 89-91 crx tokico blue shocks and coilovers fit a 92-95 4door?
- What should my fuel pressure be?
- i need axles
- trans conversion anyone?
- Tired Of Crappy Tie Rods
- What ecu for me
- 93 Civic Del Sol frame repair? What can be done?? Just bought it.
- yay!! I put my h&r's in!!!!
- Del Sol D16Z6 Distributor HELP! CAR WILL NOT START!
- Might be moving up from my EF
- resistor box help
- Sunroof Mod?
- ZC/Y8 Mini Me with Boost
- ENGINE CACULATOR
- Leak in the back hatch???
- Shifting trouble...
- 99-00 Honda Civic A/C Controller Console
- clutch
- distributor ?
- i need a pic of the rear mount
- New Clutch?diy turbo
- Where to buy individual CTR headlights? (Searched...)
- Need new clutch: can i just replace the disc?
- Del sol seats into EK and vice versa.
- hydro to cable conversion Problem driverside mount stipping out HELP!!!
- cv axels -- when to fix
- S1 Tranny? How much do they go for?
- b16-b18 interchangible crankshaft??
- need help plans to swap head put a d15b7 (dx) head on a d15b8 (cx) motor
- gas gauge and speedometer
- Looking for this shifter for my ej1.
- help????
- Loud Thumps Over Bumps
- idle surge - think i found the problem?
- Bogging, Misfire, Odd Idle and ECU Code 43
- A Little Clutch Problem
- tranny problem...what is it?
- *jdm mirrors
- Broke clips on wiring harness for my motor
- opinions....
- rebuilt d16z6 break-in with stock p28 ecu
- What ECU
- 98 CIVIC HEADer questIOn...
- 92 ex headers fit 96 ex??
- how do you completely disable an airbag
- 2-1 downpipe
- OBD1 GSR Tranny in an OBD2 Car?
- Clutch pedal grabbing really low to floor
- labor cost on replacing springs and shocks on a 96-98 civic coupe?? How much were u charged?
- What else to replace when installing new tranny & axles?
- anyone has a thread for the whole process changing headgasket on 94dx d15b7 head
- h22 ecu del sol?
- firts auto to manual full swap, some questions???
- My shocks Blew, Help me out. "Ksport Vs D2"
- '94 Civic DX Coupe problem ... won't start!!
- Removing the a/c junk in dash, need a little help
- Odd Transmission Problem
- hydro car to cable tranny?
- blocking the iacv holes with a non functioning iacv???
- car idels up and down
- IAT picture please
- Does changing to a larger tire size effect the odometer?
- Awful rattle at 3500rpm in B18C1 EG
- INSTALLING A JDM CLIMATE CONTROLL IN 92 EG CX
- how can i make my ebrake handle lower?
- suspension question- itr, or si front lower control arms and front lower sway bar???
- Adjusting Tokicos
- Cylinder 3 not firing...
- Plug n play XM Satellite Radio install w/pics on an EM1
- help with vafc 2
- d15b rpm is to low
- b16a to b16b
- Tachometer going crazy, please help
- ecu question
- Clutch problems
- L3 Gears Mixed-Up
- d16z6 into a 1.3 dx what do i need?
- auto tranny install questions....any different from manual install??
- WTB: Manual Steering Rack civic 92-95 Mint
- fuel pressure in b16a2???
- New Belt Squeals
- I need help, GAS problem.
- Loud ticking on acceleration. Fuel injectors?
- Climate Control Fuse
- Eg hatch: Core Support replacement?
- b18c or h22a?
- Tranny/Fluid
- Ebay Hatch headlights?
- y7 to y8 interchangeability
- Block stamp Q?
