View Full Version : Honda Civic / Del Sol (1992 - 2000)
- stolen car in atl.
- d16y7 to y8 swap
- Just did a compression test today? What you guys think
- 92 clock question?????help!!!!!!!!!
- Rsx seats in a ek
- Del Sol Engine Swap - Pulling codes 8 and 12
- battery relocation?
- OBD2 B20b --> 92-95 Civic starting woes
- searching but all i get is the same answer!!
- Quick question-Castle nut size for front UCA
- Just a few swap questions
- Fabric Protector?
- Help putting on AC kit for 96 hatch
- OK to run with no 02 sensor for a minute?
- OBD 1 harness in my OBD2a car problems
- is a big 16g too big for stock d15b?
- Which Throttle Cable to use
- CEL - ECU swap needed?
- 95 coupe project
- bi-xenon wiring/retrofit question
- Fuel Filter Replacement Problem
- exhaust problem
- 1997 & 1999 Honda Civic Headlight Alignment
- sorry if this is in the wrong area to post... ITS BOUT GETING A TITLE
- IACV problems please help
- Intake Question
- car cranking but not starting.
- hood?
- b16 swap into a 93 eg problems
- conv harness, IAC valve code
- What radiator hose sensor adapter do I need?
- RSX seat in a civic?...
- aebs???
- 99-00 2DR OEM STANLEY smoked tailights???
- how can i prep my bumper ready for a body shop to paint?
- ECU compatability....HELP
- I Got a TICKET in Cali... help me!!!!!
- Would These Items Be a Fix-IT Ticket?
- Crank shaft
- pics: EK with rota subzeros
- ricers should be nicer
- Water in driver's side footwell
- Skunk 2 Cams or CTR or ITR cams
- skid plates / front lip protection
- New battery. Car still won't start!
- possible stupied question. flam away
- rear disks list
- *** I need some help ***
- 1997 Vtec Head, 1995 Vtec block... which dissy?
- Replacing the Radiator support
- induvidual carbs***for sale***
- what kind of HP gain can I expect with a simple adj. cam gear?
- stripped clutch ??
- transmission swap
- Hesitation under light acceleration...
- Power to manual window conversion?
- gsr ecu on a b18b1
- I Really Need Help
- NEW SOL OWNER
- Question Bout After A Drive
- paint the sideskirts
- Start-up question.....
- goodridge lines
- Using OEM lugnuts on Drag DR16's???
- shift knob fit to shirt shifter?
- LOWEST DROP
- Help me figure out what this is...
- ej8 stock cassett player
- cant find bulb covers for 74 bulb in my dash!??
- ACT 6 puck question
- HELP asap! clutch wont disengage
- chipped p28 ecu throwing a code 6 (engine coolant temp. sensor)
- axle problem!!!!!this is aggrivating
- EK Swap Question
- need a hood for my del sol
- Buying Civic Hatch. Need Help!
- how do i take out my ac controls? brake swap?
- H22a1 93 hatch selling PRICE?
- Buying Civic hatchback 93-00
- new 2 eg's...cuple of questions..
- How do I Remove Dash on 1996 Honda Civic DX Coupe.. ??
- check engine light still on
- need second opinion
- exhaust manifold bolt
- does a 2000 civic ex coupe have a fuel tank pressure sensor or not??
- sound deadening removal problems....
- Complete engine rebuild...
- new to upgrading 1.6 SOHC VTEC...
- Loppy start up in cold.........
- pulsing idle(already searched)
- D vs B
- rod length on pm7 pistons?
- which would be better??
- del sol door won't open from outside.
- in the middle of power windopw conversion using ex floor harness couple questions
- engine light
- Uncontrollable Vibrations
- quick mount question
- obd1 and obd2 parts
- help me kthnx
- mufler
- Which Koni Rear will work in my Civic?
- No one can figure this out
- del sol rear caliper bracket same as integra?
- WTB p30 or p28 obd1 ecu!?! anyone got one cheap!?
- weksos rear lip???
- Affordable Traction Bars?
- del sol type-r urethane front lip
- stupid question i i need to locate it
- eg: k20 or b16 or 18 on nitrous????
- Car runs 10x better with cel on. WHY?
- Help figure out what is wrong? please.
- catback exhaust question
- catback exaust question
- del sol questions
- I NEED HELP WITH MY AIR CONDITIONER
- New Civic owner needs some help
- Front Brakes...
- what gear do you dyno in
- Washington JDM Enthusiasts
- carbon fiber rear hatch(eg6)
- zex dry and TPS 00 si
- EG sunroof
- new spark plugs engine light
- HELP!!! Car revs/idles around 8,000 rpm at start up!!!
- B20Vtec
- How to hook up horn without SRS on EG hatch backback? Whats needed?
- CLUTCH PROBLEMS!!
- momo hub question diff between eg and ek
- engine shaking
- ***is this normal ?
- Anyone ran Greddy Bolt-on Turbo Kit with Intercooler and 3" piping with no Internal Upgrades??!?!?
- ECU
- tutorial on aftermarket h/u install for 96-98 hatch!!
- Throttle Body Vacum Leak?
- Civic Exhaust setups?
- Can You Put a D16z6 head On a D15 non vtec block?
- good site for exhaust?
- "Mini Me" (TYPE-R)?????
- CRV 97-01 rear sway bar on civic
- obd2 ls swap into 94 civic eg obd1
- --------ANTI FREEZE LEAD AFTER SWAP HELP?!?
- Got a ticket tonight.. What to do ? California.
- Clutch question
- b18c1 vtec question
- how much to ask for my rhd eg h/b? (ALOT to read. hope you're bored :)
- not sure which size to use for hose sleeving for my 97 civic ex
- 97 front bumper for my del sol
- civic engine swaps!!!
- Honda Accord Power Dip at low RPM
- valvetrain chattering? (h22a)
- so now i will post about the swap
- turbo or motor swap
- wheel stripping?
- tokico hp-blues
- CRX downpipe on Civic ?
- Sorry Does the DA rear LCA work on the EJ1's
- what to i torque my rear motor mount to???
- putting d15z1 into 92 cx using the vx harness
- sorry wrong forum..but..
- B20 MisFire Fuel....Injectors?? help
- Whats up
- I need to replace this part.
- Header Gasket Leak causing my SP2 to be TOO quiet?
- sohc -dohc o2 sensor
- Wheel hub picture 96-98 civic ex
- Why a B20?
- Civic/Integra owners in St.Louis, MO area?
- New to HT
- CF upkeep
- Tach removed, car won't start anymore.
- DRILLED SLOTTED ROTORS
- no tach! need advice.
- ABS & TCS (Traction Control System) on EG6
- why are hondas so reliable
- ignition timing
- cel code 4 help
- messed up tranny?
- d16 help quick!!!
- EG foglights
- hesitant in 1st gear
- REV?
- 3 wire to 2 wire IACV
- External Fuel Pump
- Help, shift linkage woes...!!!
- i have a request from the somone that have a 99+ climet control....
- part number for cargo cover
- Looking to buy a 93 Civic GSR Swap
- FUEL INJECTORS..? QUESTION
- b20 block?
- adding vtec to a non vetc harness
- Integra RS Master cyl question
- Same process for Blox intake mani as Ex mani swap?
- Alarm Problem
- car wont start when hot
- CRX Eibach Pro-Kit springs in EK3?
- SMOG PROBLEM...HIGH NOX
- Running too rich...please help.
- swapping the best idea?
- H22 Manifold
- Leak in trunk...check almost everywhere...out of ideas?
- Oil In Spark Plug Cylinders
- chatter from left front wheel area... 93cx
- Need to replace Headgasket. Any How-Tos?
- Did i mess up my engine?
- 1992 eg hatch w/b18b
- Cant find source of p1457
- Very very intresting !!!! JDM D15 ECU.. and USDA P28 ECU!!!
- harness on del sol seats
- Problems Installing Power Windows into a DX
- Coilover O-Rings (tried searching)
- When doing a compression test...
- Help! engine running cold and heater is blowing cold air.
- Healights shorting out! HELP!
- My EK feels different after ASR Subframe and CTR Sway install ?
- 94 Honda Civic Si - Engine Rebuild - now with Idle Problems
- I HATE SNOW To Fix or To Swap?
- lug locks?????
- New at building engines.. need a little help or direction..
- NEED HELP: Im civic retarded
- Questions
- ***D16Y8 Skunk2 stg. 1 Cam*** NEED HELP PLZ!!
- How & what to modify to get deeper dished wheels to fit.
- Will D16Z6 final drive fit in CRX D15B trans?
- itr subframe into an eg
- 99-00 Si exhaust questions...
- searched but didnt find my cable to hydro question
- tokiko lowering spring
- detachable wheel / keeping cruise ??
- putting disc breaks on rear of 00 civic
- B16B Engine Swap
- wat do u think/estimate my hp to the flywheel
- tachometer
- Gas Milage
- wat prducts wud u not buy from ebay
- LIGHTS questions, plz help
- RHD EK hatch engine wire harness 96-98 VTI / SIR / CTR
- Something wrong with the dyno or I'm just a good BOLT ONs person....
- what to do???
- Another "My car got broken into" thread.... but with a TWIST!
- Mechanic?
- is a eg 4dr bumber the same as a 2dr??
- painting guage cluster bulbs???
- need opinions ASAP
- d16y8 with port and polish, cam, msd, and i/h/e worth it? high 14's?
- no cat....
- Intercooler w/o a turbo?
- '97 D16Y7 Adjustable Cam Gear Question
- Battery keeps dieing
- d16 ported cam msd i/h/e!?!?!?!?!?!? how fast how much hp
