View Full Version : Honda Civic / Del Sol (1992 - 2000)
- B16 Head studs torque specs?
- civic type r or integra type r carpet
- quick suspension question please help!
- Valve's Rattling
- ITR steering wheel in EK
- What mounts for a b-series swap in to a del sol?
- Cable B Series Tranny
- Want build up a good 12 sec d16z6???
- quick questions y0!!
- I WANT EVERY BODY TO SEE THIS BEFORE DECIDING TO SWAB A B-SERIES
- 99/00 Si Brake Prop valve. 4040, correct? No stampings on the one I picked up.
- headlight problems....
- 2004 accord V6 coupes??????!!!!!
- Front bumper of 96-97 vs. 98-00
- i'm new, but not new
- is it worth it puttin power doors on VX 94 Hatch?
- need Lower control arms for DC2 teggie
- ZEX setup, what flywheel?
- sup people im new
- Need info on High Flow Cat
- tokico HP spring shock combo--stance/rake???
- apexi safc and rsm
- Needed thermostat housing badly....are b and d series the same???? anyone got one
- sohc zex flywheel
- Need new tires
- jdm d15b help
- so i get pulled over :mad:
- need opinion??
- How much to replace wheel studs?
- wired shifter sound
- Got a swap in your EG coupe?
- parking cable uneven
- Need a little help deciding.
- Car shakes
- I need a camber kit
- Rust in my stock exhaust piping?
- b16a sir 2 going in on saturday
- AGX / Tanabe BUMPSTOP ?'s PLZ HELP!!
- Loud exhaust
- EM Racing C-pillar bar on the EG coupe....
- brakes makin a funny noise
- Healight bulbs
- GSR radiator... I have a few questions.
- how do i become a member already
- turn signal lights for 99-00
- HELP !!!! Spark won't fire on a ek(b16)
- Prelude Radiator in EG? Anyone tryed this?
- Overheating....
- What kind of SPRAY to use to coat/protect coilover sleeves
- wierd cooling problem(snoflake eg is lazy as hell)
- D and b series crank pulleys?
- B18B...Which damn mount?!?!
- GSR suspension Swap into 94 civic CX hatch
- How To: Swap FULL GSR suspension?
- EK hatch +sunroof .....???
- Quick Intake Swap Question
- Fuel Needle Problem in 95 civic EX manual tranny
- JDM Brake components
- tokico illumina or kyb agx??
- Shiny Disco balls Song?
- ECU Service Plug
- just bought a 1990 hatchback civic with....
- Whats a quiet 3" exhaust
- Did search need help not your basic "car won't start" thread.
- ITB's
- Post Your Pictures: Del Sol Front bumper kits
- Heater question...did search...
- Carfax Report?
- ECU QUESTION! HELP ME PLEASE! IM YOUNG AND DUMB!!
- Ground control coils question...
- please help! SF area stock parts needed for 95 civic
- 91 B16 into a 96 Coupe?
- Just Installed: Megan Racing LCA's
- Suspension Tech Rear Sway with Lower tie bar? 98 EX
- good suspension setups for drag
- stock bumper's?
- Please Read...Need help!
- Anyone on the east coast have a del sol, and want to switch bodies for a hatch?
- Wheel Bearings? How to remove
- 1st gear grinds
- how do i put 03 si seats in my 96 civic
- Civic type-r front subframe
- Auto-5spd conv. Do i need a lift to remove the tranny?(EK)
- Clean solo's or civic's HB for sale in michigan
- trial user?
- Driver's upper motor mount torn, what are my options?
- Exploded view of tranny
- NEED HELP! Need some Tech advice can't get boosted hatch to start
- Gauge cluster lights in my 98 civic!~need info
- clicking noise from fuel injectors
- What can't I find a dang Del Sol in WI?
- side skirts 92-95 same as 96-00? 2dr 4dr HB same? Painting stock Sideskirts?
- APC Formula 1 Relcining Racing Seats & Rota Slipstream Wheels
- 94 Civic Shuddering
- I cant wait
- integra dash swap... will my EG a/c plug into DC2 wire harness?
- 2000 Si pump in EG?
- H&R Race Springs vs Skunk2 Coilovers.....
- cant figure out whats wrong with my car, revs but won't move forward. auto
- questions about 92 dx
- steering wheel tilt in eg--cx???possible?
- Carbon Fiber Trunk 4 Del Sol !! HELP!!
- Replacement for my stolen Si
- throwin codes
- why is my vtech not working?
- gs-r cluster in ek fuel gauge wont work!!!!!!!!!! i have searched cant get anything on this prob
- TRADE: 2 guages and bezel OR cash for help pulling civic engine
- The Snowball Effect - PART 2
- power to weight ratio
- Fuck h-t, i'm out.. too many ricers.
- Modding a 2001 Civic... Please Help
- oil on bottom of engine - what can it tell me?
- VIN locations on a 92 Hatch?
- JDM folding mirror install
- looking to paint molding but cant find paint anywhere???
- Had some fun at the dyno with some buddies
- Rim/Tire Question
- WHAT DO YOU THINK IS BETTER GSR ECU OR P30 FOR BY 96HB B16 .....ANY SUGGESTIONS.....
- 2000 civic si check engine light...HELP!!!
- where to fill tranny oil?
- make itr reat seat fit in a ek
- whats do you like best about your ek hatches
- Remove Hub from Trailing Arm
- Damn Meinke and timing belt replacement questions
- Mini me on d16y7
- check cam timing??
- Wanna know what numbers after EK mean?
- where can a find a b20 block
- state laws???
- What is the B18c1 redline?????
- b16a or b18 swap
- v-tec - e ???????
- DA(90-90 integra) and eg civic parts interchangeability
- cylinder #1
- Any way to get rid of shock squeak??
- Quick question on why the hell my steering wheel isn't coming off! Plz Help.
- Dash Lights Won't Work!
- Newbie Q: Mixing different oils?
- EG Headlights
- carb to EFI V-tec swap
- koni yellow fittings
- clutch question
- massive steering problem
- In need of Honda Civic Hatch Pictures
- Looking for a good alignment shop in NOVA - thanks
- Koni Yellows
- valve springs
- hasport vs. place racing
- The new Apexi World Sport
- ATTN MN H-T MEMBERS: CAR JUST STOLEN A FEW HOURS AGO!!!
- stock front bumpers over aftermarket.....
- 4 Door 92 Civic question
- Air intake question
- what would i need?
- 92 dx now sold
- RS*R Header?!?
- D16Y8 Swap need help!!!
- 2 questions
- Bought a JDMSh!t lip for my EK...good company to deal with.
- What determines where hood pins are placed on a hood ?
- I need help!!!
- How hard is it to install....
- windshield washer
- Parting out the civic ... sorry mods
- bad mounts?
- car weight
- Question About Maryland Emission......
- pretty simple question... need help!!!!!!!
- making head gasket smaller ?
- Opinions I have a choice between kyb w/ type r springs or tein ss coilovers
- Did tranmission swap and now my exhaust seems to short????
- 95 gsr motor in 98 civic ex... what harness for use with standalone?
- Anypics of evo 2 exhaust?
- bad caster
- 2k si code 14
- ITR catback or dunk??
- swap question
- cable to hydro kit
- Need Help! HX Tranny swap info
- Gotta love vtec, i found this on jdmcivic.com
- 6x9's in my eg coupe?
- anybody want to post a pic of my car
- is a sohc d series worth the time and money?
- possible to get the just the mirror lens from a spoon style side mirror?
- 94 coupe with b18b smokes at high rpmmmmmmm
- forums
- How did you learn how to perform all your own installs/mods?
- CRASH
- might be interested...
- got a no start problem just swapped in a d16y8
- Okay I know who makes good clutches and flywheels but..........................
- Oil Pan Gaskter Question
- Which Clutch for my D?
- What can a stock type r redline?
- for you guys wanting to buy azenis.
- Uneven suspension!?!?!?
- please help-'96auto EK tranny in '91auto EF???
- looking for a car
- Replacing Transmission
- ne wiring trouble expected?
- d16y8 knockin wtf
- AEM OR INJEN
- Manta Ray Motorsports??
- Wheel question with motor swap
- Guys with rear drums. what brakes are you using
- hey is there preset settings on aem cam gears?
- carfax please...i need it bad
- is it hard to replace shifter?
- AC, NOT SO TECHNICAL QUESTION SO SIMPLE?
- UPDATE ON H22A4 EJ AXLE PROBLEM!!!!!!!!! NEED HELPPPPP!!!!
- Rear Trailing.
- wtf does an safc workin in an Si
- Makin a del sol sub box, need ideas...
- pls help: honda-tech.com access problem
- vin #
- D16Y8 with SI fuel pump...
- VAFC 2 - Help me out here...
- Where to buy cross drilled and slotted rotors?
- Quick f series fuel stuff question
- Question about Ek Power Steering
- cruise control light?
- WTB: 00 OEM Stock Spoiler(Silver)
- D16Y8 Timing.... HELP!
- New steering wheel! Well technically not new but who cares!
- 92-95 civic hatchback rear wheel wells?
- Anyone Interested ?
- what do b16's shift at?
- Another Crower cam story!!!!!!
- STOLEN CAR IN MILWAUKEE (Mikahowski) KEEP A LOOK OUT!!!
- Headlight Bulb Info....HELP
- civic VTI emblem???
- Through the traps in 3rd??
- swapping a d16y7 in a eg
- 96-98 DX shifter bushings
- apexi n1 cat back pipe routing????
- How much would you expect to pay for a 92-95 hatch w/no engine/trans?
- Have an EG b16a, do I have a resistor box?
- Hand Brake light comes on when going full throttle!!
- jdm bronze eg6 glass..... how much are they worth.
- my transmission
- need help with d16z6 buildup
- air conditioning weight questions??
- Is a D15B8 good or bad
- 99 SI after market clutch suggestions?!?
- How much is a good price to sell my car?
- replaceing door skin
- DIY/ How To : relocating you deck to lower din in a ek
- fake j's racing intake fitting with strut bar?
- My car idles funny
- GSR TB Question...
