View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Motor swap into a 92 Civic VX - 7 wire O2 question ???
- Gsr EG Axle Problem. Pics Posted
- Window popping off track?
- EK dash into an EG
- Engine Conversion Help , I have a 97 ej6 Coupe with D16y7, need help with my B16
- should i trade my ek for an EF?
- CTR Cam specs
- Can a Fuel Pump "Wear Out"?
- Need Help Automatic Swap 93 Hatch I know WHY!! I already have a B18C 5 speed
- i need wiring form b16a2 obd2b to obd1 distributor wiring
- heat wrap on exhaust canister
- will superchager give my b16 lote more hp
- 92 EG H22A jdm swap speedometor inaccuracy.
- car bugging under acceleration
- LS VTEC ITB'S
- Stupid question, Running Automatic D16Y8 Intake Manifold with no IACV
- what year head?
- where can i get EL parts in the u.s.
- axleback
- EP3 Seats in EG hatch *how to bolt up*
- D Series tranny HELP!!!!!!!!!!!!!!!!!!!
- 97 d16y8 into 93 EG [HAVE SEARCHED]
- Same Fuel Pump?
- h22 build setup question
- gsr questions!
- compression on stock b16a2 plz help
- Just got an oil change at Honda.. Did they use the wrong oil?
- where to mount IACV on OBX D16Y8 intake manifold???
- Transmission Problem (auto)
- No Lights!!!
- Questions regarding my JDM EG2.
- HELP:Weak Vtec Crossover H22A
- Which Comptech Ice Box for My '93 Hatch - Pic Request!
- rim size for a 94 ex
- what axle and half shaft need?
- Honda civic weak heat and car will not heat up?
- Mounting 4 point harnesses.
- thermostat resistor switch: useable, cheap 'tune'.. or doesn't work at all?
- suspension height reference?
- ek4 digital climate control?
- d16y8 OEM MAP and y7/y8 throttle cable.
- where is the fuel filter
- 06 si exhayst on 92 SI?
- SRS light!
- Idle Problem
- civic EG9 DX with AC?
- Should I buy a Civic?
- WHAT ENGINE SWAP WOULD BE BEST FOR A 93 CIVIC HATCHBACK
- Is there a way to tell the difference between an RSX type S muffler and a.....
- wat radiator hoses for b16 swap
- EGR valve not opening far enough
- rough / low idle (94' EX, D16Z6)
- rev limit for a 92-95 honda civic cx
- ek w/h22
- D15B Throttle Body Q
- Problem after motor swap - Crank seal leaks heavily!
- SRS light ON... help please. thnx
- what ecu can i step up 2???
- 92-95 eg cluster
- Stock civic rad with B18B?
- B16 Head Studs
- michigan street tuners
- ls vtec/gsr internals or stock gsr???
- Need answere to some questions...
- pictures?
- synchros for $15 each or oem kit for $350
- complete auto to manual swap
- Changing coolant
- need help... what mount to use 98gsr into ek coupe
- New Axles Vibrating
- gsr cold runnig issues
- Cost of painting fenders?
- Em1 Hesistating, MIL Flashed.
- How mucH HP do i got??
- would like to cahnge my auto to manuel
- need torque specs. on b20
- what distributor
- warming up issues?
- check engine light!
- Wheel color??
- looking at used civics - question
- WHAT COLOR!!???
- expletive GM SYNCHROMESH OIL
- throw out or input shaft bearing....
- ~~~how can i tell if my momo is real?~~~
- If I swapped a B16??
- axle back muffler is hitting again chassis
- my civic
- Burning oil
- wanna boost and D16Y8!!
- Which Distributors work for the d16z6 VTEC?
- Probably a Stupid Question
- Mud Guards... *searched*
- install 98 civic 1.5 engine into a 93 civic 1.5
- h22 into a EG? do they make a a/c bracket???????
- MISFIRE. CHANGED ALOT sTILL MISFIREING.
- Need help on finding a new front bumper
- Parts List...
- smoke
- Water-Leak Del Sol
- installing lsd
- Problem with my ek?? trouble code help
- oil coolers
- cant find much information on a b18a1 swap??
- skunk 2 sport shocks/sprins
- b20 swap or greddy turbo kit on d16z6
- 93 dx civic manual rack and pinion cost
- starting issues
- suspension
- Trade? Please Help
- Power steering issue/ h22 type s del sol
- toda timing belt?
- Civic 99-00 Vtec???
- ITB
- Using A Ton Of Oil, Help!
- N/A B18 GSR in an EG.
- Safe boost level on D16Y8
- EG hood latch Help!
- Heater core flush ?
- Engine Bay cleaning
- Low Compression?
- Torque Converter
- car hesitates and stops at around 4 thousand rpms
- Lighting problem.
- Where did you guys get your motors?
- exhaust ?
- Where can I buy the gauge cluster?!?!?!?!
- Greetings from the Oktoberfest City...
- transmission question????? 1992 into a 1998 d16 5 speed ?????????//
- 11" slotted rotors with 4x100?
- Need help high idle but is NOT bouncing
- wiring diagram for a 93si
- Cold Compression Weird #'s ?????
- Found some metal shavings in my oil pan... wondering where there from and what to look for?
- Replacing the Rod in the Tranny?
- apexi noir muffler
- Track car project.
- tranny oil
- i need some center caps for rota slipstreams
- Need sum primer info
- temporary rear disc EG brake swap without 40/40 prop valve...
- cruise control gear switch question
- inner joint for b16a2 - fits from other engine ?
- How to fix scratchs on carbon fiber.
- Need 99-00 CTR Power Folding Mirrors Diagram please!!
- short shifters
- Installing Skunk2 GSR intake manifold (pro series) where do lines go?
- HOW MUCH HP CAN I GET FROM A D16Z6 MOTOR
- The repetitive ctr mirror question.
- got pulled over
- 160 Amp Alternator
- '94 DX Speedometer Problems
- HELP. GSR swapped EG axles. HELP
- taking the steering wheel out without using Gear Puller
- CLUTCH PROBLEMS!!!! HELP!!!
- Can anybody help me find this rims?
- need help finding....
- how to tell what ODB a motor is?
- 1996 Civic Hatch
- what would these two cars be worth
- brake problem
- Stock EM1 rear sway on an EG (DX???)
- B16 Pistons in a D16?
- SPC vs. skunk2
- qustion on z6 and y8 intake mani.
- 92 civic eg car does not start, i need some input
- d16z6 je pistons
- Broken weld on a nut on trailing arm link - cant get to the nut
- havin problem with tie rod stud HELP!
- GSR swap?
- Em1 Wiring help.Speedometer light/radio
- dx master cylinder same as ex master cylinder? no abs
- will this work?
- my bro need help
- loose of power when cruising.
- Need climate control help ASAP!!!!
- which one better for turbo
- lights??
- Cam Gears???
- Sensor Question
- civic axle or integra?
- Speedometer Question
- how do i wire my del sol fogs to stay on constant? high beams parking lghts ext.
- fuel (problem after problem)
- white exhaust valves. are they ok
- injectors size / rc or precision? / gasoline-e85 all for my setup b16a2
- built b16b turbo - many problems, need help
- Sedan wiring (DX vs LX)
- Ordering Clutch, have some questions about otehr things
- identify sensor please......
- Heavy Duty Brakes Option on an EG?
- 99 civic Air Fuel problems when engine hits operating temperature
- MIsfire at idle. not the traditional problem
- need help quick
- where to get honda tools
- Compression Rings won't compress
- "New Build Thread" Project Ls/vtec-T (pics)
- Swapping a d16Y7 into a stock 95 CX
- CEL -Code #9 "Cylinder Sensor"...WTF is that about lol
- H22?
- coilovers?
- what rims should I buy?
- HELP Vtec is on at ALL times. Getting horrible gas mileage
- Side Markers
- need help!
- Hi first honda owner here!
- alex bracket
- Car wont go into gear PLEASE help me!!....baby
- Civic VX Questions
- Question which is better cr-vtec or ls-vtec
- jdm integra type r front brakes
- do d15b vtec engines run interference?
- 2piston calipers
- Rear Brake Line
- Thinkin about sellin so interior parts and a oem cfh anyone interested!!!!!!!
- Buying a 93 Honda ex hatchback with no motor.
- boosted b20
- mah gsr swap
- civic si-R questions
- I need help hiding some wire, from my 12v outlet up to my sun visor - Valentine 1
- D15B and the D16y8
- serious oil burning help!!
- Any write up on installing the ASR brace on the EK?
- d16y8 into dx hatch with d167y7 question
- Proper tension/torqueon e brake nut
- Anyone try EG lca Bushings In EK Lca??
- Column / key hole light install help. Did a search found nothing
- tire Question.
- 97 Prelude stock spoiler fit on a 97 civic? How about seats?
- Clutches interchangeable?
- quick exhaust manifold question
- How many ppl not rockin Innerfenders?
- honda wont crank or turn over
- VTEC spool solenoid valve cel 21
- ek rear lip
- dash piece removal!!!
- need help with LAF sensor!
- HELP! - Civic hatch stolen in San Antonio, TX
- EJ coupe dies out
- idling a bit high?
- Steering Wheel Slipping WTF!!
- finally purchasing my ls motor.. what sort of paperwork should i look for?
- Major D-series troubles
- ITR sway bar on del sol DOHC VTEC?
- HELP instructions for jdm civic window visors
- no power to coil
- h22a in Eg shifter question
- HELP WITH MOUNT CUT FOR H22
- f1spec or hytech replica header?
- E-brake loose
