- eg9 Ferio Spoiler Help
- problem with engine light
- Best bolt-on upgrade under $300
- 1998 HX exhaust question.
- D16 build??? Darton or Golden Eagle Sleeves???
- d16b any one know what the spec for it?
- B18B into 96 EK hatch?
- B20 head/ b16 bottom?
- altenater ?
- secondary 02 sensor
- Buying A Hatch 92-95. What model is best!!?? CX, DX, VX, SI ??
- Has anyone put the EDFC on a 99 Si?
- spanked s2k
- baddest del sol ive ever seen
- itr muffler install on 92-95 civic hatch???
- 99-00 Si bumper on 96-98 coupe?
- EP3 brakes on EK write up, were did it go?
- D15b7 swaped to D16z6.
- Mini me help....
- DAMN YOU CAR THEIFS!!!
- AEM Cold air v2 from 96-00MT fit EG6 w/ GSR Swap
- d16eg6 vs. stock 94 ls integ
- best setup for 11s
- Anyone bought a complete head from jdm sh!t?
- Tranny Fluid Change -1 question after reading several posts-
- quick tie bar question.
- exuast ?
- DYNO DAY Showdown
- 5 lug coversion question
- Are all B series axles compatible ?
- Suspension question - opinions
- 02 sensors... how many?
- How about a Clutch and flywheel !
- Civic Tranny
- Stupid problem w/ my brake lights...
- What shall I do.....
- civic cat length question
- Do ignition upgrades make a difference?
- I G fuse?
- Plug wires?
- p2t or 2000 si fuel cutoff? largest injectors for p2t? already searched
- Where can I get a Clutch Alignment tool?
- VAFC II install help on a del Sol
- vtec isnt working!!!1
- Are ignitions interchangle b/t 92-95 civics? Help
- Spring Rates for EG Ferio?
- Need Help with Lights...Pronto!!!!
- RELOCATING MY CD PLAYER IN 99-00 CIVIC I NEED HELP!!!
- Is this still cool?
- 97 civic rear brake conv. ques.
- O2 wiring help on B18C SIR-G
- Cams and cam gears.
- What gasket is this??
- VTEC solonoid tech question.
- do avid mounts make your car shake?
- rotating crankshaft
- 95 Civic DX 4 door !! I NEED HELP!! PLEASE
- water temp goes up when i come to a stop
- KYB AGX adjustments 4 or 8 way??????
- Washer trick bolt sizes/specs (correct your camber with washers)
- EG Hatch Gathers 4 Speaker system!?
- o'rileys or oem honda
- Just bought new tailight and wont fit
- AEM CDI INSTALL HELP ????
- what size wheel spacer and where to get?
- I did a search and couldnt find anything. Spoon/Vision Mirrors question
- 1992-1995 Civic CX HB header
- OBD1 -> OBD2 conversion (obd1 h22 in a 97 EK hatch)
- Help out a wanna-be honda driver
- trade?
- i have 15,000 what should i get for my honda civic hx
- HOW TO: Make your own axles for K20a /k20a2 /k24a hybrids eg/ek/dc2
- valve adjustment chart (cheetsheet)
- Xenon Bulbs Rock
- Built Ls with Cams, Rods, Etc Or B16
- OBD2 to OBD1 Distributor rewiring
- Any insight on cleaning up engine bay wiring?
- Help me please some belt came off
- anyone with a 2.5 oval muffler on an EK??
- What in your mind???
- SOHC VTEC Camshaft... Zex 59300 or Crower Stage 2
- Cheap Greddy!!!
- Help! Starter Problems
- Bay Area junkyards?
- Distributor?
- Opinions on 4.785 final drive install. Should I?
- D16z6 Intaking manifold on a D16y7?
- Mixing and matching clutches and fly wheels
- best ignition wires n spark plug combo??
- Going 5 spd have few questions
- Where to buy Replacement clutch line?
- How much for compression and leakdown test?
- Would This Mess Up My Air Flow???
- need help
- exhaust question
- Benen Industries Products...
- Spring squeak/ too much bounce?
- swap tech help
- Secondary butterflies
- E-Brake Cable (HELP PLEASE!!!)
- 1st Car is Honda EX 1996 or 1997 *short throw kit & gauges*
- Ground control question
- MN Del Sol??
- rear mount and bracket
- where can I check for what year the motor is
- Help - How to install ignition system?
- What do you think?
- Where can i get some OEM civic floormats?
- 3rd DOOR HATCH WING/SPOILER 4 EK9
- Hurry help need to finish clutch!!!!
- EG2 Del Sol.....exact curb weight and weight distribution????
- Gsr Tranny Vin# locations???
- Low vacuum reading at idle...
- Help w/ JDM EG6 Amber Clock
- oil around head gasket
- weird noise. need help and/or advice.
- Exhaust Measurements
- Paint Job???
- Will these still work?
- How much can I sell my car for?
- Does anyone know if the Mugen air intake for a ITR will fit a 99 SI????
- dohc zc in an ek?
- 95 DX brake upgrade?
- Installed new tires
- Taking Away ABS Need Information
- Removing crankshaft bolt
- Differance between EK civic DX and CX
- help
- Something wrong with my...........
- help
- removing the cat
- da best engine??????
- Rockers going bad?
- Looking For Octane/R34 Poly Kit
- should i trade?
- warranty info
- Park pin broke? NEED HELP ASAP
- Throttle Sticking on the 92
- k24 vs. turbo s2k
- oem 96-98 civic rear lip
- 6 1/2 Speaker Installation (EJ8)
- side skirt websites
- my cv boot is almost gone.
- anyone know if d16y8 fuel infjectors will work on my 88-91 multipoint setup
- How to advance timing on a D16Y7????
- Which direction for cross drilled rotors?
- honda cant cut a blank for me...
- code 43..? fuel pump sounds like sucking but still hvae 40psi
- 99-00 si cd player in an eg
- Difference in 96-98 and 99-00 Civic front end
- kteller exhaust question
- My stolen car was found.
- Omni suspension on H22/CIVIC
- Rust Proofing
- Tires for my eg hatch....what???!!!
- Front axle boots and joints are bad !! What should I do ?
- Location of fuel pump in 94 hatch?
- Smogged and failed!!! HELP!!!
- Help me with my TRANNY PROBLEM....
- Need help with speedometer!
- Help on Conversion PLEASE
- ek jdm moldings
- Fake Brides
- 94 del sol
- MSD modified cap
- weird thing happens at 1500 rpm
- EG fog Retro... Just for 1 member special price.. Bauley approved.
- HEAD BOLT TORQUE SPECS ON D15B7
- what do jdm tail lights look like?
- 99-00 Si gauge cluster
- Trunk lid install questions??????
- d15b starting problems
- help.. fan doesnt work in EK
- Comp Cams 59300 and Springs P/N 912-16 need titanium retainers or no?
- best trans swap "searched"
- FREAKING HELPP PLZZZZ
- need some info!!!!
- comprehensive insurance inspection??
- quick question
- Thoughts on Airmass Catbacks
- need help with 89 civic
- Fuel Pump
- Do you guys had any experince with 16 INCH KUMHO 712 TIRES
- Right turn signal has ADD
- type r wing for an ek
- 92 Hatch taking on water!
- I'm Dumb...How To Get Through Passenger Side Firewall To Wire Vtec??
- Strut Tower Bars/Braces same on all civics?
- GSR SEATS
- shifter sits up too close? HELP
- d16z6 automatic swap.
- Civic Lights Question
- Painting Valve Cover_ PCV valve question
- swap or stock turbo??????
- Integra sway and LCAs on EG hatch
- help h23 vtec
- Installing cams...
- 92 hatch electrical?
- delsol front end on eg civic...?
- Which exhaust to use?
- How many volts should be at fuel pump?
- Fuel Pressure Gauge/AEM Rail
- Del sol wheel locks?
- boost vs boost
- All of a sudden throwing 2 codes. Code 20 Electrical Load Detection and Code 21 vtec spool solenoid
- does a 95 EX have holes on the LCA for a swaybar end link?
- Hondata Question
- O2 Sensor going bad...
- jackson racing springs????
- Gah... Wiring question... HELP NEEDED!
- J's Racing Intake
- Quick power steering pump question
- bleed again?
- :i need to ship a EJ8 hood!!??!!: PLEASE HELP!!
- b16a2 wiring
- VSS for sale
- 94 ej1 steering whines when turning?
- Cheapest route to rear disc conversion on ek hatch?
- If you live in NOVA read this!
- 99 cx hatch + 00 itr 5 lug = which ss lines????
- 90-93 Integra MC/BB For EG Rear Disk Conversion
- obd2 to obd1= code 21
- Headgasket problem?
- what D swap should i get?
- Hid tech question
- Skunk2 manifold gsr question
- what exhaust for an ek coupe wit a b16????????
- CTR Vs ITR
- Take a look!!!
- Help! My car is Overheating!!
- Anyone ever do this? (Searched).
- right way to remove the obd1 charcoal canister?
- stripping my bay. what can i remove off the intake manifold?
- need a clutch and helpabout my clutch
- Tranny decision for allmotor b20 (possible vtec head conversion later)
- My Cuzin got owned in his Si by a dumbass on the phone
- d15b swap into vx civic dizzy question.
- Quick Question About A Swap!!!!
- help civic turbo burning oil
- Vtec controller with check engine light
- dc or eg
- 1997 Civic Gauge cluster cant get needles out.
- are JDM/EDM headlamps better than USDM???
- mini me problems....help!!!
- WASTE GATE TUBE LENGTH
- No Check Engine Light
- check engins: air temp sensor
- Spoon or CTR Wing on 98 EK
- should i change the charcol canister
- apexi ws exhaust fitment
