View Full Version : Honda Civic / Del Sol (1992 - 2000)
- swaybars
- Which site to get custom piping for del sol? i tried searching but its difficult to find.
- Could lack of ELD screw up my emissions?
- Neuspeed Race
- gsr swap, knock sensor broken?
- noise coming from head.
- pictures from u.s. 19 october race
- Stripping tint off the rear window
- Passengerside airbag. Will it deploy if i...
- Brake booster will it fit?
- my carbon fiber "Mugen"spoiler is fading? what the hell
- Winter Tires = A must!
- GETTING 99 Civic SI....OPINION
- 92 hatch! best catback, cams, etc.? opinions needed . .
- How to wire bosch universal o2 sensor?
- help with code 1 or 10
- Horrible alternator whine!!!!!!! Help
- I have a Oil Leak =(
- changing bulbs to AMBER on my cluster "HELP"
- best quality carbon front lip
- DX Vtec Wiring...
- some new stuff I got
- Anoyying Idol
- sard website
- Finally gave up...civic goin to shop
- Which quaife do I need?
- can't find model name Si 2003
- camber correction kit
- Head light disassembly
- EDFC placement ideas??
- why is my hose sucked in?
- 99 Si front stut tower bar on EG?
- push button starter problems
- BSQ or Breaks kit?
- ? EXHAUST ON EK COUPE ?
- Best/cheapest place to get y8 headgasket
- just some pics
- My 1 Picture Post: A Timeline of my 92 VX Hybrid Hatch (56k, 53 pics, so I doubt it)
- help me at the track please....
- Which one Skunk2 or Ingalls camber kit?
- Swap effect VIN#?
- How do you check CEL codes for 2001 + civics?
- Has anyone seen a CF rear window spoiler for EK Coupes?
- Check engine light codes
- D16Y7 with a d16y8 intake manifold (need help please)
- what year on the D16's did they put Vtec on valve cover?
- Help -Wiring Harness...
- usdm type r header
- Need a little input on EK exhaust setup?
- Best radiator
- Theives should die
- Crank pulley removal help!
- Fixing camber? HELP!!!
- how to get cold air to a short ram intake on a 98 civic?
- VAFC Wiring
- AEM V1 vs. V2 -- any real world thoughts?
- best coilvers for 1200
- powersteering pump swap question
- I need a muffler! Cheapest place for a universal N1 style?
- PEOPLE ARE SO FARTING STUPID!!!
- jdm gsr/eg swap story...long
- LS gauge cluster in a EK????
- replica spoon mirror replacements?
- What a mess - ideas?
- Looking for Azenis in So. Cal
- After changing the timing belt..........
- compression for y8 minime
- pos ecu fuse
- HELP! what kind of bulbs??
- RSR exmag for '00 Si
- flywheel question
- cat-back magnaflow vs apexi ws
- 5 - lug
- Civic DX ECU with an EX tranny?
- Vtec kicking in or Not
- Signal light runners that should come on with headlights... only one comes on!
- JDM Civic Type R frontend
- Head gasket info?
- d16y8 intake manifold
- dx vs. ex. vs. lx
- i sold out
- ?'s on rear shocks of hatch
- Another Driveshaft Question
- Swap..serious serious millions of problems.
- secret compartment
- da sway bars on eg?
- b18 direct fit into cx??
- Painting my civic
- Ok what is going on? cluth/transmission won't go into gear?
- Need help in finding part
- NEED HELP!! Motor knocking!!
- 2003 Civic LX, what to do next????????
- what the best oil for your tranny?
- Will my hx wheels fit on a 94 ex coupe??
- have cx. want better
- Greddy evo for my 00 civic with b18c5 swap??????
- wonder how much i should sell my car for, TURBO!!
- Help with D-series eg............................
- will a 96 rear integra gsr lca work
- offset question for EK
- ITR rear lower control arms
- Re-Powder Coat Wheels?
- best suspension for 94 civic ex coupe
- does anyone have pic with TOKICO HP SHOCKS their EK, or EG
- My new ride, 1997 Civic Ex
- Pics of my 00 Si with a face lift... (5 Pics)
- what should i swap for a 96 civic ex coupe
- URGENT knock sensor wiring
- type R strut tower bar??
- grease all over
- Seatbelts jammed??
- ABS or not??? 2000 Civic Si. How do you know if it has ABS?
- Running a 70mm TB?
- White RSx-S with Black or Grey Interior
- Got into a wreck today *Pics* 56k warning
- how do i wire the evap soleniod? help
- WTB D-series axles
- d16y8 throttle bracket
- 93' DX Power Steering
- Finally my time for theft (usual da*n thieves comment here)
- New pics of my EG (56K watch out!)
- d16y6?
- whick shocks?
- where to hook up a temp guage.
- White smoke downing it into third gear
- del sol seats
- goodies came in for the EG6
- Stolen/chopped 94 Hatch laid to rest at the bottom of my Driveway...
- idle problem
- Draining coolant from the block of a B16a3
- error code on 98 EX...help please
- B20B Swap Problems Throttle
- D16 tranny on D15 block....
- hood pins
- JDM del Sol Q's...i need help!
- Thinking about doing b18c5 swap in my 00 civic
- B16A swap or should i keep my Zc and turbo it?
- What do I need to change the Front LCAs?
- H&R race for integra, versus H&R race for civic on 92 hatch
- 94-2001 gsr seats?
- Has Apexi redesigned the N1?
- Ba8b or B16a in a del sol
- what killed my car?!
- GUYS I NEED YOUR HELP !!!
- Timing belt?? Does this look like it needs to be changed?
- Annoying Driving Noise!
- How to take off baked spark plug grommet???
- removing door skins
- Dropzone Suspension?
- How to lean out the mixture with a VAFC??
- Does the D16Z6 and D16Y8 use the same water pump and/or timing belt?
- Progress sway bar experience anyone?
- muffler question
- Car Idling Weird....can you help me?
- worried over here!
- Recaro SRD seats
- LOOKING FOR 99/00 SI //S. CALI
- Denji "blue" projectors
- WHO HAS THE BEST EG?
- HELP CAR WONT START!!
- EG civic Ignition wiring needed for IGNITED PUSH START BUTTON
- attn: B20b/z EK owners!!
- what to buy first? springs or shocks?
- Best mods for 94 civic si
- Can't decide on suspension package...
- Shed some light on ECU code #20
- AC question?
- My 1/4 times are...stock LS hatch.
- sedan spring rates?
- REQ: Pics of Gathers rear speaker grills
- Carfax Record Reqeusted
- HELLPP PLEASE
- VANDALS!! KILL THEM ALL!! 56K beware.
- 2dr and 4dr....
- HELP...GSR dash in EG
- shift lite wire
- side marks on buddy club body kit for del sol? where!?
- [FAQ] EG CIVIC HEADLIGHT WARNING BUZZER
- rpm nyc
- will a gsr work?
- whats the lightest race seat?
- Quick n00by question...?
- Starter Problems on my B16.
- sway bars for a dx
- will i rub?
- help on taking off EG dash apart
- WILL A DASH OFF A DEL SOL FIT INTO A CRX
- EG / DelSol FAQs Updated!
- Help Quick!! EX cluster problem
- how to take off srs light
- winshield washer hose help...
- Engine Swap for a Civic
- I finally uploaded some pics. Here ya go, MY SNATCHBACK
- Hybrid Automotive.com Anyone used them before?
- Heat does not work in my car
- those with 99-00 Si's...
- sorry for the noob question in here
- throttle cable question!!
- SI/SIR rear struts
- which spark plugs for a 1st gen B16A
- POST The known factory fuel pump differences for civic years in LPH and models
- 99 Si
- D16Y8 100k mile tune up
- So Fl body shops????
- Hondata Tuning????
- Edelbrock Turbo Kit for The d16y8 opinions
- HCP Driver Side Mount VS. Place Racing Driver Side Mount For Ek Civic
- I smell a scam
- loud clicking noise from the dashboard -- HELP :(
- How many years old are the Mugen MR-5 wheels
- time for a new car maybe
- Skunk 2 stage 3's.... CAMS B-SERIES GUESS WHAT????
- Springs for 1998 Honda civic ex
- have a d16y8? Post your setup here. am looking for a good setup for my 00 d16y8 ex!! Turbo or All-Mo
- What are you guys running in the 1/4 with b18a1 hatches?
- Tires
- 2k DX starting problem.
- what injectors should i use?????????
- Si Rims
- MAP sensor on 89 crx mini me swap
- Door handles?
- ITR rear susp with stock civic front susp... bad idea?
- 94+ int. mounts in 92 hb?
- Brake Help
- Production Date
- Do Prelude Seats fit into an Ek Hatch?
- Spoon Sports VTEC controller
- Upgraded calipers & rotors?
- What do you guys think about this steering wheel?
- 15" wheels vs. 16" wheels, for eg civic?
- Center Console Swap
- Fuel consumption
- how much does a hid bulb cost?
- 92 SI Hatch rear window
- So im going to the drag strip tommorrow.
- What wheels are these?
- ht members in glendale/burbank/pasadena
- anyone run one of these front lower bars?
- D16z6..turbo vs. Supercharge
- eg and sol vids????
- Honda centercaps that will fit Slips?
- 92-95 Cx motor to 92 DX?
- b16a2 with nitrous
- worst luck ever!
- how much did u spend TOTAL on your GS-R swap
- getting my cam gear tunned, few questions?
- 99 ex 4dr exhaust questions
- JG cams, valve springs, and retainers?
- LOoking for a Ek cluster in EG
- Clutch problem, help!!
