View Full Version : Honda Civic / Del Sol (1992 - 2000)
- civic LX (d15b7) swap to d16z6 or d16y8 few questions
- Starting hard
- 94 del sol si/B18B swap - what shift linkage do i need????
- f i e/m 15a fuse for main relay keeps blowing! Help! $$$
- Need Help!99 Ex Coupe Miss Fire
- a/c compressor help
- civic ek 98 engine mount recommendations?
- Building a california legal performer
- how do i swap d16y8 to d16z6
- another Y8 Idle issue
- Different D-Tranny's.
- Questions about swapping D16Y7 engine into a 95 Civic
- would the skunk2 mega power rr 3inch exhaust from a integra dc2 fit a 4dr eg?
- p1298, p0135, p0141, p0302, p1399
- p28 ecu...OBD1 or OBD2? How can I tell?
- Total Noob Question. Pictures would help.
- Mil-Spec Connectors male and female?
- '98 Civic is missing, rough idle and backfires
- Worth it to Turbo D16Y8 Automatic?
- P28 vs other ecu's??
- distributor dust cover
- Rpm drop fast Honda civic 95
- Blown Hose's
- Coolant issues - please read.
- Ecu type??
- 92-96 Prelude seat rails into a EG hatch
- Could use a bit of help tuning Crome P30
- Ls vtec starts but dies after a minute help please!!!
- my car wont start
- torque mounts
- does a d16a6 motor bolt to a d15b7 trans?
- Effects of Upgrading the Engine
- b16a2 or ls/v
- B16 - rpms really slowly go up
- d15b manual mount question
- Driver's side speaker out.
- 99 Civic DX with CEL P0131 - time for an o2 sensor i guess?
- 97 Civic brake light problems
- D16z6 Dizzy Keeps Braking!!
- Fenco CV Axles
- Weathertech Mats Don't Fit!
- in need of guidence
- What hold the headlight bulb into the headlight?
- Wiring for cluster.
- z6 smokes really bad upon start up
- d16y7 leaking oil timing belt side.
- d15b to d16y7 swap. what to do with power steering pump bracket
- What rear mount is this?
- Distributer Cap with gasket?
- delsol brakes
- How to rebuild Honda B series book...
- High Beam Indicator Integra Cluster
- 99 Civic Replaced radio, dash lights do not work
- how does one go about getting a car from Japan and licensing it in the U.S.?
- Daily driver turbo project
- What part of the headlight is this?
- mini me oil pan
- 93 civic VX, no crank after heater core replacement?
- D16Z6 head porting
- F20b in Eg driver side mount
- Exhaust System for B18c
- wheres is the egr valve?
- pulsing idle, high temps, bogging???
- Type One Coilover sleeves, shocks, and struts
- K20z3 swap?
- lower control arm help
- traded my car for a 4 door ek shady title need help!!
- y does it take a long time for o/d to kick in?
- car idle, jumping, and clock dimming
- rhd throttle body
- hatchback cx power window conversion
- Manual transmission fluid and old mystery fluid
- GSR Tranny
- key stuck in the ignition
- AEM CAI question
- Shift boot collar
- Stock B20B/B16A build up.
- car stalled then didnt restart.
- d16z6 mini-me vtec into ek?
- Heat in Civic SUCKS
- 96-00 Civic CX vs. DX (EK - Hatchback)
- increase compression ratio?
- Kswap 92 hatch
- eg f22a6 or h23a1 frankenstein
- 75mm to 75.5mm bore?
- Black interior for 92-95 Civic sedan?
- Where is the door open wire 96-00 Civic
- horn location on a 98 hx? plz help
- Racing seat belt harness necessary?
- 96-00 Civic Fog Light Switch (Dark Grey - Type K)
- Automatic b16a5 Wont Rev in Final Gear?
- kn air filter for my 97 civic dx d2
- EG Civic Antenna Replacement How-to (PICS)
- obd2a to obd2b conversion??
- P30 manifold-throttle body port matching
- 2000 civic starts clicking then dies
- 96 ek fuse box
- bleeding cable to hydro conversion
- Valve Cover Stud Part #
- d17 into EG or EK
- Prop valve issues
- EG won't crank
- Late Old 70's Autometer in Civic 1992
- hmm. Name that plug behind my cluster
- 92 civic ecu ? Please help.
- Need Help ASAP!
- single cam people
- Sound like headgasket? Reservoir hose blowing off
- Stainless Russell fuel line kit
- Advice on buying 99 civic SI
- Windage Tray D16Z6!!!!! HELP
- Can i use hondabond on t-stat change??
- vacume line idle trouble
- Iacv question.
- DIY: Re-route D16Y7 throttle cable for better pedal feel
- speedo problems need some help/info
- Radiator Caps from Autozone and parts stores
- need help deactivating factory alarm
- 2000 hatch ITR losing coolant + White Smoke
- Cylinder 4 not reaching tdc. Crank will not rotate by hand????
- Honda Civic License Plate Garnish fit JDM?
- 2000 civic tailights brake lights and license plat light not working neeedd help!
- Video of my EK thanks to BRND'N FILMS
- Are there any cons to all aluminum radiators?
- completely converting obd2 to obd1 on a del sol.
- 94-01 Integra fogs the same as the eg?
- 2000 SI power steering pump question
- eg LS swap help
- Car not sparking (d16z6)
- alignment question
- Y7 coolant inside intake manifold
- is it just me or do the wheels in the front seem wider then the rears
- RADIATOR FAN NOT WORKIN
- Clutch fork question
- Where should I look for a good condition D16Z6?
- D16 Valve Cover Bolts?!?
- damn radiator hoses still
- B20 into EK, Motor sits funny.
- Help!!! Ticking / Knocking noise after engine stops. Help!!
- Alternator output too high (17v) help
- lock
- 92 hatch dash lights very dim
- 92 civic rad hose overpressurized
- NEED HELP 0BD1 HARNESS WITH NO TPS
- 99 civic si o2 senses?
- Bad gas mileage 00 civic ex
- where to get ONE wheel CHEAP!?
- Tire pressure change in regards to tire size and engine swap/weight reduction
- state ref???
- gauge cluster stop working help 2000 civic ex
- Help me on honda engine wont start ..died
- Seeking Help
- EG Electrical problem, headlights work but nothing else does
- lowering springs for del sol..
- engine suddenly stops ? ? ?
- Random misfire on H22a swap civic
- USDM Optional Audio Console Install
- my first engine pull (2000 y8) few questions
- Car won't start or turn over
- LS-V into Acura EL
- Obd1 b1 block with obd2 b1 head
- 2000 honda civic ex side view mirror
- Second Blown Head gasket... :/
- ej2 engine swap dilema
- Port on top left of valve cover
- What is the oem thermostat opening temp rating - 95 civic ex
- Oil Pan 98 Civic EX D16Y8
- 96-00 Civic Coupe Rear Seat Options
- 97 civic BIG PROBLEM
- Transmission leaking
- Stuck starter solenoid
- 92 Civic SI - Fuel pump power ground die! (Help)
- eg ferio rear brake light
- need parts located in germany
- bee*r installation help
- P30 Ecu making my del sol idle irregular
- 96 civic oem exhaust with b18c type r?
- b16a ?s
- Recommended Pistons
- 92-95 Hatch jump
- Give me your opinons
- In need of a vtec head for a d16 single cam
- hey new to the forums looking for a little input/ help on my del sol build
- did prices for everything go up?
- d16y8 all motor build?
- D16Y7 Idles funny after it's warmed. *First Civic*
- please help!! zc swapped del sol.
- Dc dash in eg help
- d15 to d16 turbo mani
- Code P1336 on stock 2000 Civic EX
- TURBO SMOKING! HELP
- Si door swap mess HELP!
- 99-00 civic si squeaks sometimes
- STOLEN: 2000 EX coupe in Portland, Oregon
- 98 Civic knock sensor issues WTF!@!!??&@#@$
- High Performance Radiator? Mishimoto, Koyo, Fluidyne
- Need advice on engine block
- Help wanted: eg hatch overheating issue!
- Just Did Oil Change Nothing on Dipstick
- Purchased b16a with water on spark plugs - need advice
- 93 del sol/dz16z6 swap - CEL code 4/CKP sensor problem after swap
- help what to put on rear poly bushings squeaking
- 92 hatch auto transmission replacement - compatibillity question
- b18b1 in 92 eg rpm fluctuation with steady throttle.
- speedometer problem
- Civic EK Sedan vs Hatchback mudguards
- WEIRD metal scraping noise from wheel area (vids inside)
- Re-ring B18B1 vs. used B18B1 vs. used B16A2
- Eg molding question?
- EK hatch headlight issues
- wheel offset on EJ6
- fitv in 1996 ek?
- TRIM poll--keep or remove
- idle problems need help now
- 96 ek civic cleaned iacv still roaming idle when warm
- 98 civic ignition question
- [HELP] Civic E-Brake Uneven Pull
- How do I rewire crank sensor?
- S2000 push button start in del sol?
- Where can I find a 3" EK cold air intake?
- 93' Civic Wiper Assembly
- VX Partial Throttle Flat Spots.. yes yes again
- 1996 Civic dx free mods
- d15b7 turbo using p28 and injector size?
- What is the Purpose of the Engine Coolant Temp switch (C119) vs C122?
- 92 VX Engine "Died" While Running, and Now Won't Start.
- b18c shut down problem
- Need suggestions; missing on #3 piston
- Motor Health: Exhaust pressure (?)
- 96 Civic Center Console beverage door latch
- 97 hatch jspec brake qustion
- 95 Civic EX Motor Swap
- Valvoline Max-life in AUTO tranny?
- d15b7 timing belt tensioning / cam timing
- No pressure on clutch pedal until engagement, won't reset
- HID Xenon Lights
- (UK) Drag delsol & 200mph project
- Eibach ANTI-ROLL-KIT - thoughts?
- Sputtering problem...98 ex with a 94 B18c
- Check engine light ON, vtec still works
- ecu/harness issue
- Titanium Rsx seats in 94 dx civic
- Fix or put new engine?
- Carbon build up on sparkplugs
- 99 civic Si misfiring.
- Civic - makes noise when cold
- Changed out the VTEC solenoid gasket YUCK
- power window and lock swap into a 92 vx helppp
- removing/installing window
- Alternator kill switch
