View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Dim Headlight problem
- Rack and Pinion?
- 2 quick questions, helppp!
- d16y8 build advice needed
- my 99 civic si has no lights what so ever... need help!
- Need a stock exhaust for 2000 Civic Ex Coupe
- what to do with a hx motor
- No power to the ecu! HELP!
- eg 3469???
- HOW do i remove paint from wheelss?
- 99-00 D16Y8 intake manifold on 96-98 D16Y8 Head (No Air Assist)
- a/c trouble in ej1 (b18c1)
- B7 head shave/mill
- Are these Tokicon shocks good for my lowered civic on coilovers.
- Pass. side axle wont go in for NOTHING
- Solution to Cold Air intake Cons?
- Random Loss of power, blown hg?
- Help Fixing 93 civic ex front end
- gsr wire harness help!
- fuel in the oil?
- Code 10 please help
- h22a swap in 98 civic
- b series swap questions,
- AIR PRESSER ON 16" 205/45/16 TIRES?
- Blower Motor help 92 civic
- Radiator Help AGAIN !
- Main fuel relay OEM or aftermarket?
- what kind of brake pads is good out there ?
- swapped now no power
- eBay suspension kit for daily...Good/Bad?
- DRAINED BATTERY, NEED HELP!
- D Series Head Swap
- Werid Electrical Problems
- D16Y7 clicking from engine bay
- 1992 Honda Civic - Cluster Lights Not Working
- del sol exhaust help!!!
- lapping valves vs cutting. Why is one bad, but the other ok?
- Losing coolant through the radiator cap?
- Low pressure A/C line bracket near condenser fan. What does it connect to.
- another fluctuating idle thread - 95 civic ex
- Moroso Oil Pan Problems!!??
- TDC sensor code 8
- What Color Is This Hatch?
- 95 hatch with 92 dash swap srs light on
- a6 Cam vs a6 Head
- Automatic wavers when switching gears
- 93 del sol weatherstrip
- Need help, Tail lights jus stopped working
- car goes into gear without clutch
- does anybody know the colour of the ek9 hradlamp internals
- bleed valve where the top hose meets the head
- Idle air control valve issues!!
- si harness / and my hx harness obd2
- engine advice opinions experiences
- my 92 civic vx h22 turbo!
- Knocking Issue- 94 Honda Civic ex
- Color of car on registration or title? (State of CA)
- '98 lx headlights don't work
- taking apart my del sol?
- My Coupe build project
- Are Lowering Control Arms Needed to go lowwww?
- 2000 civic ac on a 95 civic?
- o2 sensor problem
- EK Power Folding Mirrors Schematic!!
- 95 cx/97 gsr swap/97 gsr harness -- slightly bogs when fully warmed up
- What transmission is this? *PICS INSIDE*
- map sensor problems?
- Loose fuse in fuse box 2000 Em1
- HELP! clutch fork stuck
- WILL THEY FIT?? 15.7 40MM Offset on my EG???? I hope they will!
- grinding clutch
- are these specs right for a b16b??
- How to install double din in 97 civic hx
- del sol tail lights ?
- instrument cluster help quick
- 2000 si comp test results
- B18B into a 2000 Civic DX: Got everything on hand but anything I should know about???
- might have bought the wrong motor
- Si /rant
- d16 sticking idle problem
- things to look out for when buying a block?
- where to get honda parts
- del sol engine build and swap opinons
- Ex spoiler swap for an SI spoiler
- sway/exhaust ???
- 1999 Civic LX Dying / Stalling
- help: how to change cluster bulbs EK
- anyone with flowmaster 60 series delta..
- 95 dx hatch rear sway bar install
- D16Z6 Oil Light Flickers when Braking?
- Threads MUST Summarize Technical Problem in TITLE and List Car Details in FIRST POST
- Installing an aftermarket muffler - HELP
- mini me swap timing question
- CC Stage 5...... Whats up with the disc?
- honda del sol idler air controller???? HELP
- Clutch doesnt disengage all the way.
- ls v/tec
- Should be easy for you guys? A/C Question?
- Brake pedal is alittle too soft for my blood! car doesn't stop well!
- p30 ecu question
- thinking about swap to d16z6
- 1998 LX Dials acting weird problem
- 95 Civic without cruise control, brake lights don't work.
- spark plugs white! Too much timing???
- Starting Issues (94 Civic)
- apexi neo vafc?
- Idle annoyance
- Full Coilover Combo For EG hatch koni/GC
- issue with vtec?
- GSR swap into 98 dx coupe, mount questions
- WHAT FRONT IS THIS?
- d16y8 help
- Carpet Help Please!
- help bad cat exhaust muffler clogged .
- Skunk2 throttle bodie question
- wheel bearings
- HELP! B16A Automatic Cluster to Manual and Need to find the computer to match engine.
- 95' Honda Civic DX Thermometer Failure or...?
- Fuel line questions
- car steers to the right and shakes during hard acceleration (solved)
- Cel code 1.Is my ecu bad?Can it be repaired?
- Trying to Find & Fix Engine Leaks
- B16 swap in ek sedan
- HELP! GSR tranny
- 92 hatch - how come my ac only works somtimes?
- MY RHD eg6
- 99 Civic DX D16Y7 Seeking for some extra power
- 92 Civic S20 Transmission, bad ISB or not?
- eg/ek seats
- D series Alternator on B series. fits?
- REAL HONDA WHORES PLZ LOOK LEGIT PARTS TRADE ???
- Convert D15B to Vtec
- sk2 tuner 1 or crower stage 2 turbo cams
- A/C going out
- Fan does not come on 1998 civic EX
- SMooTHn'z Battery Relocation on a BUDGET
- 94 civic smoking out every possible hole
- Another EG Gsr swap wont start!!!!!!!!!!
- coilover sleeve help
- help! new wheel bearing already F**** up, 95 honda civic hatch back
- now there are a million and ONE overheating issue threads, please help!
- 93 del sol si b20 has no A/C
- WTB: GSR shift linkage (integra 94-01)
- o2 sensor wire
- Lower ball joint causing vibration on front end.
- Where on online to buy bushing kit?
- coilovers questions
- LS CRANK GSR CRANK THE SAME?
- d15 powered lawnmower
- Need Help With Steering Wheel SRS ( Air Bag )
- h.i.d. 8k problem
- o2 sensor question
- ball joint castle nut HELP
- 1994 b16a3 a/c problem? cant anyone help
- 2000 Honda Civic DX cracked manifold
- help!! code 10 and 13 IAT and BARO press
- How much lower?
- need help with suspension part
- mini me vtec wiring need help
- 92 Civic Cluster not working!
- o2 and vtec question
- ****HELP!!!! obd2 B16B type R swap into a 2000 em1****
- just got firestone alignment but new problems occur?
- h.i.d. 8k problem
- 92 civic overheating problem
- Quick Easy Question: Suspension Coils
- b16a3 into eg mount question
- My daily '99 Civic EX progress..
- Please Help! 92 Del Sol H2b S300 problems!
- JDM B16 AC tensioner?
- passing NYS inspection
- Moonroof and AC Woes
- cluster lights problem
- 96-00 power folding mirrors?
- new i got Eg .. tranny help
- when I turn my wheel I hear a creak
- 94Delsol -- AC squealing; pressure high, discharged, now not cooling!
- Pic Request.. Tein S-techs on EG hatch
- b16a3 in eg mount question
- help with my turbo del sol
- quick ?s
- Problem with my door Locks..
- Hello Honda
- d16 vtec with p30 short case ecu
- 99 harness to an obd1 motor
- best coilovers for the price
- turbo blanket
- Motor Swap Wiring Q - OBD2a SIR-II into 97 EK
- honda civic 98 OBD plug location???
- HELP!!! my del sol wont move!!!
- Apexi World Sport 2 or Skunk2 Megapower RR
- nitrous questions
- EG A/C Question
- FRONT END AXLE BUSHING HELP
- Where To Buy: Honda Access Window Visors (2000 Civic Si Coupe) EM1
- need some help with my hazard lights!!
- B20 Vtec Misfiring :(
- Rebuilt d16z6, spark knock
- 98 Civic Runs hot after head gasket job, wtf?
- 99 civic gsr
- Climate Fuse Blows - Please Help
- ek civic help
- B18c5 Head
- Need help with B16 swap
- d16y7 problem! please help
- Help get my car back to stock!!
- Where to get passenger and drivers side door window trim? and wiper blade arms?
- em1 blinking cel need guidence
- alternator problem, please help!!
- NEED HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!
- d15/16
- GSR or LS tranny????
- hesitation/sputtering issue, HELP!
- dash swap question
- HELP - Bogging while pulling out only.
- EK tranny on EG?
- Dome Light or Open Door signal not working
- 95 coupe dash cluster ?
- Autozone ignition switches, are they any good?
- bumper?
- 98 DX no power
- PLEASE HELP!!!!Passenger brake caliper problem...
- Cutting out/Misfiring.
- Convert 95 ex auto to manual
- Mini me swop questions
- D16Y7 IACV Question
- Front Suspension fork
- serious help D engine
- VIS CF Hood
- 5th gen tranny vs. 6th. Same gear ratio? If not, which is better?
- o2 sensor wiring
- SMOKE AT HIGH RPM ?!?!?!?!?!?! Help
- eg gsr swap axles
- dizzy connectors are different??
- 95 civic ex wiring harness problems
- Motor problem-d15b
- 95 civic ex question
- can your distributor fail and not throw a code?
- GSR swap CEL problems help!!!!
- 99 SI. Difference between TEC and Hitachi Distributors
- Is my TPS bad?
- EK FOGLIGHT PROBLEM
- EJ with EK front end conversion??
- My wheels Si?
- Car jumps in low RPM's...wtf need help diagnosing.
- Need a measurement from an EK Front Upper Control Arm...
- Oil leak problems with '93 I just bought
- advice on ls swap
- 99 Civic - Driver's side speakers dont work?
- turbo~ing my 96 ek. am i missing anything?
