View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I need help.
- steering rack question
- CLICKING NOISE WHEN SLOWING DOWN AND NOT PRESSING THE BRAKE
- HELP!!! Civic=No Start
- INFO ON BAR W/REF FOR A 92 CIVIC HB JDM B18C MOTOR
- Engine Rattling
- H22A into a 95 Del Sol
- hard to turn steering wheel
- which model steering wheel fits on EK model??
- EK wiring question please help
- civic Eg si
- Adding AC to a '97 DX
- i pray to god its the BATTERY
- Help: Putting a 97 GSR complete motor into 97' EK civic/What you guys do for exhaust? Using DC sport
- witch n1 style muffler 3" muffler to buy?
- So I did a search all over honda tech... CEL code #1 Bad 02 sensor
- has anyone bought these Tail lights
- Trying to BAR a 92 HB w/jdm b18c
- del sol power locks
- anybody know what camshaft is this???
- OEM Muffler Question
- Any difference exterior difference between EK EX & CX coupe body shell
- OBX High Flow Cat - Just bought one, how loud are they with stock exhaust?
- just baught my first honda.. Need help
- when do i smog my car(cali)
- Value? EK JDM SIR NAVIGATION SYSTEME WITH REMOTE
- JDM 96 ITR 114.3 x 4 with 92-95 prelude VTEC calipers?
- 94-01 integra/95 Civic hatch rear seat swap
- Curb Weight of EK..... can't find LINK to thread
- EG Squad President?
- help with shiftlight???
- I have a Momo Hub and wheel...But
- Really need advice on parts!
- should i do it ?
- dynamic dampener on driver axle question
- STOLEN 92 EG in San Diego
- Desperate for answers or input!
- Does the EK CX have a power mirror harness pre-wired into the car?
- will a 93 si harness run a JDM SiR-II (B16A2)?
- will itr springs fit?
- Spark Plugs for GSR MOTOR
- hood release HELP
- Need Help ! ! ! ! 92 civic/gsr motor
- Costs of an H22 swap
- Help Please!!!!
- GSR seats fit into a 00 Civic Coupe?
- Type-r Gauge Cluster - MPH
- Power windows and locks conversion?
- anyone ever put valve springs in upside down?
- what to do ?
- o2 sensor compatability
- CB Radio Mounting Location Ideas?
- can anyone help me on finding out the year of this transmission??
- Gsr Seats in A Del Sol?
- INSANE Clicking sound....valve job??
- engine still run even with key removed?!
- Any civics with white Motegi MR7's
- HELP!!! headgasket problem????
- any thoughts on my friends civic??
- Need HELP Choosing a soldering iron
- HAS THIS HAPPEND BEFORE???
- D17 in a EK
- Couple questions about a JDM EG4 VTI
- Need a little help please
- 300,154 miles RIP
- mid pipe compatibility
- Considering buying..
- GSR BB and MC install?
- Any FTA guys out there have some fresh KEYS
- brake conversion
- Thermostat Question?
- Vtec not working
- Short shifter
- Tranny question(b18c1)...
- Rear mount needed for ls into eg?
- engine probs
- Ticket for exhaust in Orange County??????
- HVAC control diagram, EG Civic with JDM HVAC unit
- Backfiring
- quick timing belt question???? d16z6...
- *HELP* Power steering removal! *HELP*
- Wicked Tuning Header?
- JDM s20, is it a cable tranny?
- Where to get some touch up paint?
- b18c?
- central locking !!!
- lower octane gives lower emission levels?
- shiftlinkage
- ECU Pinout & Knock Sensor Questions...
- bolt that holds rear strut in on an EJ1
- What type of paint/enamel to use on the inside of an oilpan?
- omni sport slip over coil overs
- ebay header???'s
- help me with wheel clearance
- Brake booster leaking?
- What did you guys pay for you eg si's?
- timing belt question
- Intake manifold support bracket
- B16a swap
- Fuel Pressure problems!!!!
- Civic Rolling Chassis 1992-2000
- vafc or uberdata on mini me??
- rpm/speed ratio 2002 civic ex
- 70mm BBK Thottlebody?
- City-Speed.com Review
- Thread on repainting mirrors and sides.
- WIll there be a diffeence in ride height from D15b to b18c?
- SIR guage clusters
- Is there a specific type of Ground Control you have to buy for Koni yellows?
- car meet june 18th at oxanrd state beach??
- mini-me turbo?
- Where to buy my new engine???
- how to reduce weight?
- omni power setup
- b16a2 spark plug suggestion
- QUICK QEASTION WHAT DO YOU THINK
- sticky temperature control switch
- mini me question
- Vtec solenoid???
- EG Fogs DIY?
- Need some help with electrical problem.
- Del Sol Wierd Suspension Problem
- Body work
- How to bleed the clutch fluid????
- ITR wing vs. SI wing...
- b16 stumbling...
- 96-98 civic interior swap?
- What Honda engine is given the tag as most durable?
- anti roll bar compatability on EG w/ITR LCA?
- Throttle Body
- Help w/ CEL #41
- IM on an EM1
- Can an 02 Sensor be bad with no Cell code????
- HONDA 90's TIMING BELTS
- 05 civic si question
- TODA Camshafts Lift and Duration
- where to find a rear oem bumber for cheap
- Engine problems with my bone stock d15b
- my first EK.
- What can i do to my 91 jdm??
- where to buy 60mm s/s piping?
- Timing Belt Question
- help with airbagssss
- car just won't start
- speedometer!
- car wont shut off
- Part identify EK HELP
- help bm FPR/
- Change only when it throws a code?
- my new $1,000 car
- engine mounts
- aftermarket D15b intake manifold
- condensation in trunk
- anyone from the pittsburgh, pa/steubenville, oh area??
- H3 or H4 for EG headlights?
- Steering ratio: How do I make my steering wheel more responsive?
- Bored 64 mm TB giving me wierd idles
- SO CALI: One day paint and body.
- Power Steering problems/issues
- D18
- Newbie need advice
- What shift knob is this? Can't figure it out
- Differences on GSR rear shock and Si or CX? (Used Search but answer.)
- SERIOUS PROBLEM - GAS PEDAL STICK
- car wont redline
- is it worth it?
- horsepower gains
- Another question about wiring vtec
- dash has a dent :(
- Removing sound deading ish?
- help questions about law in massachusetts
- proform shift light
- Problem with power window switches
- LS head
- $1500 too expensive for an engine with installation???
- Need Seats!!
- question about b16 manifold and b18c5
- fly wheel fitment
- whats the ECU looking thing in the trunk?
- quick ? need quick answer
- dizzy help!
- Omni Power slipover coilover
- Anybody know if 90-93 parking brake cables work on 96-00 Civic Coupes?
- pinging/tapping sound? uh-oh?
- b16 obd2 into a 5g......ecu/wiring help
- do all swaps do that?
- better oil?
- shutter at take off??????
- SRS check light is on..
- what site or mag should i look at if i need some performance parts?
- Brake lines integra/civic are they the same need help asap
- My rebuilt motor will just not start.
- frakin sunroof, searched.
- B16A good or bad?
- "Gas Gauge Doesn't Work" needle stays above F
- will usdm type r rear seats fit an ek hatch?
- brake booster and master cylinder question
- y8 head swap on a z6 couple of questions??
- Question about HKS HI-POWER EXHAUST???
- info on a b18 swap
- 3g teg fuel tank into EG hatch??????????
- Question
- bent shifter fork? pops out of 2nd gear
- h23a boosted specs and parts used, stories
- will a ek coupe rear bolt on work on a ek hatch?
- VX and EX/SI harness Are they interchangable?
- Best CF Hood
- coolant amount for ls into eg hatch??
- obd2 head into a obd1 car
- Running Lean!!!!
- mini me electical questions vtec solenoid
- Speedo question. Lights up MPH but shows KMH during the day
- Sound deadening removal-- nothing needed!
- sup guys
- My EG Sidemarkers. A few questions.
- Best Block for my D16Z6 head ??
- H22 Turbo in an EG
- who knows what this plug is called??
- What happend to my Z6? (Nitrous)
- Edelbrock Intake Manifold Questions...
- Quick wheel bearing question
- is this a good price for a d15b VTEC?
- Did obd2-obd2 conversion HELP!
- EK Center console and armrest into EG?
- valve spring thread
- black housing one piece headlights for del sols
- My EM1 *pics*
- 02 sensor voltage range a/f reading?
- short steering hub adapter.
- Removal of Rear Side EG Windows??
- d15b7 and d15b8 difference???
- o2 sensors
- d16a6 intake manifold on d16y7?
- whats the B20 stock ingnition timing
- Grinding Third
- Need help, Car acting strange.
- My gauges are just toying with me now...
- How do u know if u wrecked your diff
- Throwing CEL Code 41
- Changing Climate Control
- replacing halogens q's
- em1 owners
- Is this the correct part?
- d16z6 cam in a y8 head? Yes i searched
- Advance Auto giving me wrong pads>>
- Lugnut Thread Pitch
- whats this plug for
- need parts ?
- white EK's with bronze rims: post pics
