View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Please clear up this pinout info conflict for me...
- Jdm Parts
- Help!! Hatch Studders in high rpm!! Dist. I think...
- Does 2001+ sohc final drive bolt into crx Si l3 diff?
- Holy cow 850 for SI rims
- Decent quality intake for 99 CX - Where to buy it from?
- Where do i find a rear wiper plug for an Ek..
- I got some new toys yesterday
- NGK Plugs....
- wheels and tires?
- D16Z6 A/C?
- Will 205/50R14 tires fit OEM Honda 14" Steelies???
- Juicy. Will dem stock steelies hold some slickz y0?
- Some Civic Questions
- Mini Me swap
- 5 wire O2 to 4 wire O2
- Need help installing the factory foglights on 99 Si.....
- How to read codes from 93 civic
- 03 rsx type s to a 02 civic frame
- Useless info
- For People with Autometer gauges
- Steel brake lines?
- ls in my ex?
- 98 civic ex o2 sensor location?
- Sohc Build in So Cal (I Cant put topic anywhere else sorry)
- ECU Pin layout for 96+EX civic (P2P)
- Installing upper control arms.
- projectors
- lower control arms
- Please help me-- Oil pan question
- "DIY" Custom Door Panels
- GSR exhaust on an eg hatch
- which model?????
- headlights dim?
- Someone wanted to steal my hatch.... socal beware: they had an 18 wheeler truck
- Mmm Baked headlights DIY (56K go to hell)
- żżżjdm steering wheel dont match.... should i wrap it in cow....???
- built z6 guestimates!
- What do ya think she's worth?
- Anybody read the Tech article in Honda Tuning???
- Can someone tell me more about this b17 cracnk in a b16???
- distributor question
- Shift Knob Wont Stay Tight
- Mugen Twin Loop muffler on my 99 SI??? Will it be quiet?
- are these any good?
- Question about vaulve cover???
- steering wheel shakes when i brake
- For my brothas with a carfax acct.
- ivicneed turbo info
- Mini-me swap question
- On throttle body for d-15
- Did it drop right?
- Questions about buying a 93 civic hatch cx
- 97 Civic E-brake Help
- does honda rate HP to the wheels or over all?
- wes d im interested in swappin yor a2 into my civic..
- help..ctr rear seats in back
- Engine Swap b series,h22a,or ls vtec
- UPDATE: Del Sol rebuild
- b18, b20, h22 turbo
- College Station Folks!!
- Mini-me Dyno sheet or 1/4?
- intake filter cleaning??
- md/dc/va question
- ecu code 22
- How long would you guess it to take the machine shop
- SRR Sway Bar/Tie Bar Combo?
- looking for shop/website...
- Putting a Cd player in the bottom din of your 96-98 hb
- I need some help?
- EF shocks/springs fit EG's?
- Could cluster be bad?
- can i use a b18c5 header on a 98 b18b1?
- Falken Azenis?
- starting to switch engine harness
- well i was bored and one thing led to another...
- zc engine
- koni yellow and neuspeed sp3 series koni
- swap costs
- Who makes the most quiet exhaust for Del sol with D series
- just got the rotas in have a question
- '99 Si Transmission: Binding main shaft?
- R Manifold on a 99 Si??????
- question about ingalls front camber kit 93 civic
- Anybody had to Bake their corner lights ?
- [KYB AGX/H&R Race springs] how can I tell if my shocks are blown?
- hx wheels
- will 99-00 civic si exhaust fit on 92-95 hatch.
- drum into rotor conversion
- 1992 si question
- What exhaust perform best on EK hybrids ?
- My new swap is throwing 4 ecu codes: 3,7,10,14 Please help me out.
- My Profile/My Control Panel
- Excel Wheels any good?
- stolen lsvtec!
- Looking to buy a good set front headlights. Suggestions?
- Here is a tech horror story for you
- Other online sites to buy EG EK hybrid?
- Rear Lip, or Body Kit?
- 2000 'EBP Civic SI'
- torque wrenches
- jdm b16a2 redline?
- Backyard clutch install!! =P
- check engine code 67 on 99 civic si
- exhaust manifold and header the same thing?
- running exhaust piping under gas tank...hmmm?
- Skunk2 shifter...dual or single bend for '99 Civic Si??
- which option makes more sense???
- B7 abd A6 heads interchangable??
- Anyone Into Auto Meter guages??
- D15b7 ...power at the wheels????
- B16A1
- Time to get new springs::==>POLL INSIDE<==::
- just wanted to say hi.....and i have some questions
- 2003 Civic...trying to find side marker lights
- Where the topic on all the brake conversion possibilities???????
- what u guys think of this?
- To Beat B20V-tec
- how much gas does the 92 cx tank hold???
- Royal Purple ?
- resonators?
- Zeal B2's
- Konig Traffik Rims?
- my eg at the track (b18b1)
- EG6 Instruction manuals
- JDM EG6 rear LCA's. What struts do I buy?
- windshield wiper fluid pumps in a 96-00 civic hatch?
- si logo on floor mats
- HELP--Can someone check a VIN?
- another pic of the hatch with misc pics...u like junior mints?
- went to the track last night again in etown
- fuel relay located?
- problem with brake booster....
- raising compression on a d16y8
- bouoght my new car last night :)
- Sizzling noise coiming from exhaust???
- vtec head
- best cam gear for SOHC?
- Civic Type R
- Has anyone ordered from Jaydm.com??
- Do Axxis Metal Master Brake Pads come with shims?
- Heater control illumination
- Do they make LED rear lights?
- Anyone make a Honda automatic shift kit?
- IACV CEL still, surging idle, sputtering until 3/4 throttle, help..
- Did Recaro make the Del Sol seats?
- Carbon Fiber Hood Question
- What's the easiest way to remove side moldings and rear license plate piece?
- Please can anybody tell me what Si stands for... "according to Honda"
- 99-00 civic foglight amber bulbs
- vtec kick in?
- Civic Type R Turbo
- Problems removing cat on 2000 civic ex
- anyone have pics of a thermal exhaust on an eg?
- I rounded a nut, how do I take it off?
- Engines Online?
- Anyone ever made their own Front air diffuser?
- Car Advice
- Canada Vs. USA
- here is my car
- B20 in a civic?
- I just lived your dream! Caught a guy in the act of stealing my car, nearly shot him.
- a little something from Canada ... lil' group pic.
- pixs
- Finally able to get my pix's up. Feel free to comment, pos or neg
- advice, wanting to build quick, reliable eg/ek daily driver
- How would you build your EH2
- What suspension and exhaust for my 01 EX?
- testing , sorry if its not working
- JDM ITR Wiring into 1992-1995 Civic.
- Coilover install questions...
- Pics of my car!
- 99-00 Si blue paint problems
- how do i post pix's ??? i think my EG needz some appreciation as well haha
- My Hatch With Gunmetal Blade Rims
- my cars story(pic)
- Can you fit an H22 in a..........
- Which cam should i get!!!!!
- 96 Civic EX Rim
- Interior Color?
- 93 hb with 00 H22 sh or 00 ITR swap
- heres my ride...98 ex hybrid
- help help can i swap a f23a1 sohc vtec accord head to a civic d16z6 head ?
- Kamikaze Headers??
- what should i get ?
- D Series Engine Codes
- archive searching disabled???????
- Thinking about getting an EG HELP!!!
- does any one have any track time on b16 in a ek hatchback
- Coolent Leak
- Roll Bar Brands?
- Anyone put SIR/SIR/EX power windows and Locks in their CD/DX hatches? (EK chassis)
- Tein Super Street Damper
- Will they settle?
- Questions about B18 swap into my CX
- EK/EG Radiator Question
- 2003 civic makeover party.
- tran. fluid
- help with exhaust install
- Bushings: What a PITA (pics included)
- Noobie doing an EG disc conversion, what springs?
- 97 CX tranny gear ratio?
- cargo covers?
- N1
- differences in the s80 tranny
- JDM GSR Hatch Owners!
- DOHC cars??
- H22 into a civic HB
- rear bumper question
- roll cage and rims
- few questions about cable and hydro clutches
- h22a: turning
- STD rear lower control arms??
- Spoon Lip
- What Strut Brace is this???
- Overheating problem!
- HELP!!!!
- D16Z6 and D16Y8 Blocks the same?
- 96 hatch wiper removal. looking for plug. part #?
- Q about airbags and harnesses (seats)
- need help ! car over heat after radiator fluid change
- Spoon Magnetic Drain Plugs
- Best rod/piston/crank combo for LSvtec aftermaket or stock???
- Would 225/50/15 tires fit on 15x6 or 15x6.5 wheels?
- Oil leak in EG..please help!
- B18C5
- Short Shifter painting
- I need VIN# check if anyone can help me out
- what kind of mesh do you use for a Mesh Grill ?
- tokiko illumina users...
- Anyone know how to adjust koni reds for a 96-00 civic?
- Rim : what do you think of this one from kosai ?!
- D16Z6 SOHC owners!!
- Engine Swap Options
- Steps to My Suspension Upgrade. I need help.
- b18c1 swap into 92 cx ?'s
- oil fowled plugs can mean ......
- post pics of 96-98 replica mugen front lip ON THE CAR
- Help with changing tranny's
- help help can i saw a f23a1 sohc vtec accord head to a civic d16z6 head ?
- White Rims?
- suspension
- auto to manual swap , IACV issues.....
- Fuse Box Diagrams?!?
- buying a LS motor
- EG Carpet
- cali question....
- stock aluminum wheels
- Radar Detectors
- If you were going to start over
