View Full Version : Honda Civic / Del Sol (1992 - 2000)
- A/C - Radio dash trim removal?
- Honda Motors for Dummies
- ????????????????B18B, B20, or H22??????????????
- add a cd changer into my stock radio?
- Help! Rear Coilovers on eg sedan
- Figured I'd introduce myself
- Alternator belt gets shredded - JRSC setup
- help with 00 si
- HID Lights issue.
- Blox lca's bushings shot
- Coolant and idling problem (HELP PLEASE)
- need si lines for the a/c
- Problems on '92 CX after b18b1 swap.
- em1 muffler
- d16y8 fast idle control valve help
- NEwb Help right now Please Cant get Distributor rotor off
- Turn back speedometer??
- b16 swap question
- where to buy CF Roof Cap for EG?
- Should IAC valve close fully?
- Need Suggestions On Motor Mounts
- un even suspension
- car making noise, related to dizzy? please help!!
- 98 Honda civic cooling and lubrication illustration!!!
- 95 Ex rear disc brake swap!
- cel problemmmm
- need car alarm ASAP!!!!!!!>>>>>>
- 99 Civic Oxygen Sensor Question
- car dying at stop
- painted the engine bay on my ek let me know what u think
- Harness question regarding LS into EG
- Transmission noise
- EK Picture Thread
- Where to find REAL JDM and Mugen Parts?
- swapping stock dx for a d15z1 to save gas :) QUESTIONS?!?!??!
- Sensor in d16y7 air box?
- b20 in ek d/s bracket
- Y8 or z6 manifold????
- Benen radiator stay (searched)
- d15b block with zc pistons
- SOHC Wire Tuck How-To?
- 96-00 civic muffler question.
- wierd sound????
- LSD Install in hydro gsr tranny...
- EK w/obd2 GSR.... need some help with wiring
- Axle questions?
- Bettery keep dieing---- why?
- 93 del sol, gunna lower it and smoke tails
- Hytech Twin Loop muffler fit ek?
- 1999 civic door locks and front speakers not working ?
- Burning Oil - B16
- O2 sensor wiring (need help)
- Low compression, what is causing it?
- Interchangeable Parts
- 00' Civic EX running rich.. after muffler install.
- white smoke
- help: car wont start
- Still getting IAC valve code.
- lots of things not working..all happened at once
- del sol rear lower control arm info
- Braker boosters (yea I searched)
- lean under 1500 rpm
- help... i need a radio code
- Headlight Problem
- Are their any 4dr eg's with sunroof
- timing belt problem.
- OBD2 code reader
- B16A compressor into B18C1 motor
- 97 trunk leaking
- N/A WHP numbers on a D16
- Argentinian Honda civic. Rear caliper piston corroded
- 1994 Civic DX misfires at idle! HELP!
- which part of the starter do I hit with a hammer to hopefully " fix it"
- b18a in eg 93 hatch problem
- EK into EG ??'s
- Bucket Seat Installation ?????
- Rear hatch door shocks
- Distributor question
- d16 y7 tranny on a b16a
- Integra Dash COnversion HELP !!
- Smoke Issue
- my d15b is weeeeeeeeeaaaaaak helpppppppp!!
- ICM aka ignitor ... what fits what (swapable??)
- Don't laugh, but I bought another Civic....
- looking for 93 Civic Diagram of fuel filter assembly
- Windows fogging in rain.
- compression question
- Parts and need suggestions
- p20 trans vs s20 trans
- stock cat-back fitment
- What stock airbox in 92 vx with B16
- Distributor/Vtec Problem?
- EG Wiring (Ls/Vtec)
- NEED FENDERS FOR 92-95 CIVIC 4 DOOR
- Rebuilding My Civic *Some advice please* Cash! Trade!
- 96 civic loose axle nut?
- 92-95 Civic Hatchback Spoiler/wing
- Im back in the Game with my EG b18cR from Australia
- Stock d series fuel presure???
- so i raced a passat...
- Trans Mount Bolt Help.
- is there a write up on piston ring install?
- RSR EXMAG EXHAUST....is it finally done?
- 92-92 prelude seats in 1996-2000 civic?
- How to make my car look "JDM"
- car feels like going to stall on cold start
- Motor Swapped ... Cant go anywhere tho lol ..
- Crank pulley ?
- EG ABS Removal......Need Help
- Show me your EG8's!!!
- Y8 onto my Y6 block question
- d16y8 intake manifold
- How do you avoid being tagged as a "ricer"
- stalled
- How to wire side marker for jdm fender?? help
- 93 del sol auto to manual swap
- Please help.GSR no vtec
- best front bumper for em1
- b20 vtec
- eg headlights
- will this dizzy fit my swap
- check engine light woes
- PIC REQUEST: tan 6th gen coupes
- windshield container thing
- vacuum diagram?
- Aem Fuel Rail
- eg (multiple problems) HELP!
- Engine Mounting: B-Series + EK and the need for lower tranny mount
- distributor conversion?
- Alignment Setup
- No Keys?
- Service Connector?
- do you think that Del Sol's will ever come back as a new model..?
- Is my gas gauge or fuel pump bad?
- trans fluid Q.....
- new guy to H-T
- which is a good setup jdm b16 or a b18c1
- PLEASE HELP!
- is there a difference
- mini me c0nversion help
- obd0 zc into a obd1 eg dx
- Is My car Vtech
- doing rear disc brake conversion on 92 civic HB - use integra ebrake line?
- Dont know what to do with del sol si?
- need help replacing alternator
- help with mount
- 97 DelSol high hydrocarbon at idle
- sick deal
- looking into buying a HB opnions
- swap
- 99 civic dx 5-speed questions
- best bumper for blue em1
- So, uh, not sure what this is...
- Valves sound like a typewriter.
- 93 civic h22 hatch
- i need help wiring my vtec to a switch!!!!!!!!!!!!!
- obd1 d15b into 97 cx
- b16 motor swap, wont start, need help
- some insight on how to prevent a lip from getting stolen
- OIL LEAK
- Can an Gsr rear seats fit in a 96hatch? Urgent help!
- Build the D and boost or buy a B Series?
- Cam Gear Key Shreading????
- Need opinions or experiances!!! Skunk2 Pro C or Pro S?
- gas4free
- b16a2 Ecu info?
- EG coupe door jam
- aftermarket cam
- JDM Imported engines - why they only say -ENGINE INTERNALS WARRANTY-
- tranny problems
- show your h22 ek's
- Looking for BYS Backyard Special Replica spoiler and lip
- AVID H22 question
- Problem diagnosis help!!!
- eg9 sedan ferio spoiler please help
- What Hyperflex bushings kit to get ?
- Go go or No go? Part Deuce(2)
- Clutch and gas pedal
- Looking for d16y8 - having trouble locating, list of vehicles with this engine in it?
- suspension ? with GSR swap
- b20b with a b16a2 head
- 11" rotor?
- needed-fuse diagram for a 96-98
- Cruise control swap ?
- gsr intake butterfly system
- I'm SO stumped please help :)
- reason for engine pulling shifter out of bushing?
- Single Cam timing question
- threw a code 14, turned it off to look around and wouldnt start again...
- civic headlights?
- CTR seats into civic EJ6 coupe
- Difference between Honda HX CVT and 3 stage D15B SOHC MMT?
- bad clutch? or something else?
- puting a/c and power steering back in...
- what kinda rear disc setup on my 97 civic??
- 93 civic problems
- low position rails with stock seats?
- please help..tach. problem
- cold air intakes
- Stripped bolt!!!!--help--
- b18a1 swap in my eg..now cant rev passed 3k while driving
- Honda Civic Stock Tachometer Problem
- Shift knob
- cylinder head question
- Seat Sliders
- 96 EK Fuel pump question PLEASE HELP!!!
- H22 civic wont start
- motor swap question please help!!
- Clutch
- car cranks but wont start. have no spark.
- ecu search
- do 96-98 coupe civic doors fit?
- Antifreeze reservoir
- Huge Spark Issue? Motor Swap Wont Start Please Help
- So confused, d15b vtec-e in my '93 EX... p28 vtec?
- speedometer
- help.
- dragging disc brake?
- What ECU/Header for a eg with a b16a
- will these bearings fit a gsr!!!
- Workshop Manual
- 96-98 to 99-00 front end conversion need info
- Clutch Problems
- header installed....CHECK ENGINE LIGHT?!?
- PeakBoost Cable's GT42 EG
- WOW! running a D16Y7 with a P72
- water problem!!!
- EM1 Rear Trailing Arm Question
- ***pic request em1/ek with white 16 5 lug 98spec DC2 wheels please***
- Beefing up suspension in '99 Civic Coupe for more weight...
- help, wrong brakes?
- jdm headlights
- EG Sedan Rear Seats
- where can i get a cheap set of b series grommets and screws?
- Need help URGENT
- replacing outer rail on gsr seat with 00 civic rail *pic*
- Cops Took My Sh!!!!t....Please help
- dash lights
- looking for power
- SEATS for EM1
- should i get this coupe?
- When installing rear trailing arm - tighten bolts first or after
- where is the oil leaking from?
- Quick timing belt question
- anyone got a jdm single din cupholder in a EG?
- Head gasket question
- I keep blowing my fuse
- smoke from under hood
- skunk2 coilover
