View Full Version : Honda Civic / Del Sol (1992 - 2000)
- valves coming out of adjustment
- please help!! axle nuts wont budge
- What auto transmission fits the B16?
- What could be my problem?
- Crank shaft sensor replacement - How?
- jdm d15b qestion
- Acura 1.6 EL stock catback fit onto EK Hatch w/ Bseries???
- 94 ex coupe with 95 c1swap A/C LINES WHICH ONES ??
- hood latch problem
- i need a wirign diagram for a 96 civic dx badly!!
- Need help bad, searched but need more specific.
- quick release steering wheel
- What size rims????
- more power out my b16a3
- Drove thru a flooded road...
- 93 Z6 Crank Position Sensor?
- Rear Suspension Squeaks and Creeks (EJ6)
- trouble getting a proper driver side cv shaft for h22 in my civic
- Help fuel cutting out
- Gauge pods
- 99 SI engine swap
- car problems
- integra type-r or gsr? swap
- shift linkage question
- Help: My EG is making whinning noise when accelerate
- tire size for 15 slips
- bolt on stock muffler
- Suspension opinion
- quick timing belt ?
- B18c swap 93 Del Sol
- Does anyone know where I can find 100 octane in So. Cal.?
- GRRR.. rear brakes calipers
- how to fill in side molding holes?
- D16B7 VTEC engine
- Will an Apexi WS2 catback clear the Comptech rear sway bar?
- Want to hire some to tune ITB's
- Engine wouldn't start after jumping.
- what piston is this?!?!?!? help ASAP!!
- Swap HELP
- Passenger door dent...help
- b16 gauge cluster
- Need pics of the brackets which hold the wiring harness, both sides of the engine bay
- I am looking to replace an injector on my B16 engine but I have a question?
- civic turbo questions
- Can anyone run a carfax report on this car for me?
- b18b with blox and handata gasket
- buyyyyyy
- better brakes...Si or GSR?
- VAFC Problems
- LCA
- stock gsr sway bar, fit ej1?
- ok guysobd2 gsr in a 99 ex
- low voltage reading
- car is over heating but did search
- Elusive Cold/Hot Start Problem
- jdm d15b vtec solenoid ???
- A/C smells like wet dog :crook:
- Has anyone ever replaced the WHOLE brake lines to the rear?
- Idling purge b16
- Recomandations for civic 97?
- B16A2 camshafts vs B18C1 camshafts
- HELP!!!!!! 95 civic outer tie rod!!!!!!!!!!!!!
- getting the rear rotors off?
- Turn signals
- Alternator Belt To Short... - A6 motor, d15 alt. What size belt do I get?
- White Smoke ( coolant) please read, very odd!
- I NEED HELP ON MY ALARM
- EG hatch front-end conversion
- Misfire...Hesitation...CEL sometimes
- Washer Fluid Light will not turn off 98 civic
- Civic Del Sol safety information
- will a '94 Integra GSR alternator fit in/work with a '96 Civic?
- obd2 alt with obd1 harness
- clutch lacks pressure
- told motor work was done by Jerry ? how do I contact him?
- D15B7 Crank Angle Sensor...Help...
- A/C compressor not turning on?
- Help: Do you have 96-97 civic projector headlights? Earn $5!!!
- please help
- finally a new project
- Spray paint that matches VSM "Info Here"
- Name this steering wheel: pics inside
- Fuel pump
- HELP ME IDENTIFY MY HEAD
- Need a/c charged
- motor swap?
- Headache...
- P28 ECU problem... fried?
- Honda VTeC
- The dealership tried to bend me over....
- A new header...again
- My EJ1 Project (Self documentation, tech + appearance) Feedback appreciated
- Header for D16Y8 work on Y7?
- jdm d15b
- Cat swap.............will it work
- VTi cluster in mph but speedo off by about 10mph tach???
- quick question do i need this mount?
- Will a SiR A/C bracket work for a b series swap?
- What options are available to me?
- How much do b16a2 heads cost now?
- Clutch not engaging..
- NA z6
- Dipstick Problem
- Sir part numbers?
- Attention honda experts a puzzle lerks here.
- Is it the same??
- fake Js intake + b16swap
- eg4 power folding mirror ?'s
- Will my stock clutch hold up?
- how to test locks
- FUSE problem please help!!
- Built b16a3, now headgasket is leakin oil on the block, PLZ help.
- dc2 mugen intake in Ek civic
- help me fix my car
- ??How do you know what to change on a transmission??
- How to tell the difference between turbo and non turbo dsm injectors
- Cruise control, mecanical vs électronic
- Intake Difference Question
- EG spoon lip
- spoon n1 question!
- question on pistons
- 3 quick questions about my new ej8
- I need help H-T
- Manual to Automatic Conversion?
- 00 Civic quick story about how this "autozone part sucks"
- honda database?
- power loss with a/c way more than usual????
- clutch problem
- bumper pole
- shift knob help
- Help: Toda cams set up questions!
- wtf f22
- Major Electrical problem please help
- 2000 b18c5 swap in a 2000 Civic EX
- D16Z6
- EP3 steering wheel into EK
- where can i buy stainless steel fuel lines?
- How to take this off? Part of wiring harness
- 2000 civic fuel tank capacity?
- cant figure it out... *cel 16*
- Which ac belt? b-series in 93 hatch
- rear integra seat question....
- Buddy club spec II
- WANTED 94 2 door civic hood and bumper
- window track question
- Oil pressure sensor thread size?
- overheating problem in my civic... PLEASE HELP=\
- are these plugs good or not?
- Projectors for a 95 EX
- lugnuts and wheel stud help
- Cuise control - Electronic vs mecanical versions
- delsol/ ek catback exhaust
- EXHAUST HELP
- Cleaning cylinders out...
- high squeel when turning the steering wheel
- B16a2 IM weight?
- Beeping sounds when turning off engine
- motor mount question
- Looking for instruction for 96-99 Honda Civic DX - Check Engine Light codes (CEL) ECU
- about to swap motor.. question???
- wont stay in gear?
- "Maintinence Required" light
- 96-98 hatch owners which fog lights?
- 93 integra seats into a 96 coupe?
- wtb obd2b 99-2000 civic si distributor
- RC Injector ?????
- the things needed for to add p/s and a/c into a 1999 honda civic hatch
- that infamous 3rd gear grind............WTF
- official name for 00 si coupe?
- my 92 civic ex problem
- Q on exhuast..
- Exhaust question
- need help with code 41
- SMOG CHECK
- Radiator
- quick mount ???
- evo 8 caliper upgrade?can it be done?
- motor wont start
- ek front wheel hub, are there any compatible hubs?
- Weird misfire
- Loud squak from suspension and turning
- want to try this but..
- Should i expect faster?
- SWAP papers ?
- b16 question.
- Map Sensor
- anybody know, please let me know!!
- ?light weight battery?
- What rotor to use on civic with the ITR calipers???
- Help: Oil Check lighting up... but there's oil
- power mirrors not working help!
- Help With Lowered Car/ New Rims
- getting rotors off?
- '93 EH3 Stolen in Toronto...
- apexi vtec
- eg front to ek front
- 95 civic hatch
- Can someone post EJ seat removal again? Topic was deleted
- Need D Tranny Hydr. 92-00 and dx wiring harness 5spd.
- h22 in a 99 civic coupe
- jdm hood pop?
- Extreme weight reduction
- ok so i got my shocks
- civic wont start? what do you think?
- 99 civic center hub size????
- High Octane Pump Gas in the Bay Area
- b16/18 swap and still keep ac in eg?
- fog lights blowing fuse
- 22mm type r sway bar on an eg
- V-tec does not work!!
- Help on a mini me
- Considering Purchasing a 94' Si Coupe
- Rear Camber Fix (bolt/washer) Bolt Size Question
- Need help fast! Ecu related... like within the half hour
- b18b into 93DX
- Question on 93 hatch CX
- lsd question
- Steering Wheel Shaft size?
- can someone get me a picture???
- what part would the d15b motor come from!
- interesting iab question
- Removing the sound deadening tar?
- Ideas on this crazy sound?
- HOW in the hell do you get it off?
- replacing fuel filter
- shift linkage?
- Where to get OBX twin loop muffler?
- Prostreet flywheel?
- 90,000 mile maintenance?
- VSS Question
- poor poor d15, Lost hp
- D15B Skipping
- NEW CAR/ wierd clutch / ideas...
- Muffler - If yours was loud what would you do?
- how do you remove the trim around the windows?
- removing rotors on civic integra???
- i ordered a new motor for my 93 civic dx
- rhd conversions????
- delsol weight reduction?
- Big problem here are the symptoms...
- LMA question
- Brakes are squealing
- Low Temp Thermostat
- DSM 450cc? Blue or Black top? OBD1 or 2 injector clip?
- Axle question..size?
- auto-to-manual AND D-to-B at same time using integra parts??
- Need help with a tranny issue
- Axle popped out a little!! ??
- How to install BLOX RPM gauge in del sol?
- Couple questions about a 94 Civic
