View Full Version : Honda Civic / Del Sol (1992 - 2000)
- em1 radiator into automatic eg
- P28?
- Comptech exaust???
- Ran the civic out of gas and will not start
- HKS exhaust
- CROME help
- D16Z6 Drivers Side Motor Mount Bracket Compatibility
- 93 Eg6 h22 swap halfshaft problem
- Moving dizzy
- headlight question
- Tranny need help!!
- what is a hybrid???
- GAS LEAK!??
- motor ranny help!!!
- shift linkage ? help ASAP
- Help With Tranny Problem Please
- Help with suspenion setup on em1
- Changing the chip on an ecu?
- EK swap inspection problem
- 1" brake M/C in my 93 hatch.
- hood doesn't close all the way...
- D Series Oil Pans, All the same?
- Valve Cover Fitment
- h22 98 hatch
- Tranny problem...Need help ASAP
- a/c help!!!!!
- how long can i ride after installing new suspension without getting a new alignment
- How big rear sway bar on an EJ6....is too big bad ?
- JDM B16a2 Half Shaft
- rear disk upgrade, now soft pedal...what do i need to fix?
- Bride Cloth
- d series s/c on a b series??
- Removing the rear door handles on a 92 lx 4 door.
- Need a wireing diagram for a d16 y7
- What kind of civic is this
- Are the Civic Si headlights the same as Ex lights?
- FAQs - Frequently Asked (Tech) Questions
- d15 sensor question
- Help with KYB AGX adjustable shock settings
- idle problems
- IS MY HEADGASKET BLOWN!?!!?!? **I HAVE NO MONEY FOR NEW MOTOR**
- Radiator Problems
- help please!!!!!!
- RHD Clip
- License plate bolts
- new muffler help
- D16Z6 Distributor bolt size
- IAT sensor code 10 - Which wires goto where?
- VSS wires
- how much harm can i do on an NA basemap?
- internal build suggestions
- help with these??
- I want to install cruise on my 99 civic HX anyone know a good writeup on this or. . .
- 92 Hatch with B16 Swap Axle Question
- ? on the code of my civic
- Will WRX seats fit in 95 Civic?
- B20b with B16 tranny
- Any ways to clear Spoon Calipers on Rota Slipstream?
- 98 civic brake drums question.
- Searched..car still won't start
- the "JDM Slant"
- GSR Front or Rear Sway Bar Fit EK Hatch?
- Jacking onto Axle Stands???
- How to make a b16 faster?
- Crower vs Skunk 2
- Will an EG sedan's axle back bolt straight to a hatch?
- Are All 3 Bolts On LCA The Same Size??
- Did i buy the wrong engine mounts??? HELP!!!
- Cleaning Power Window Contacts?
- R18A Swap.. anyone done it?
- Tein springs for 92-95 civic on a 96-00 civic?
- GSR Cluster in EG
- me again. the throtle link does not fit..
- T braket prob. with b20 into EG. the braket doesn't reach
- D16 camshafts in d15 head
- LS swap into 93 de sol -Double checking things!- Which mounts?
- pics of 99-00 coupes
- 99 Civic Fog Light Bulb ?
- bumper question
- How-To: 3-Point Strut Tower Bar (PW:JDM, Carbing, Etc.) On 96-00 Civic
- GSR swap Ek, what upper radiator hose?
- Can you add a sub to an OEM CD Deck?
- thing on my battery???
- Where to get Clear and Red tail lights for EX?
- 2001 type r head
- 00 ej8
- manual folding manual adjustable ek 96-00 civic mirrors
- Type R intake retrofit to SiR
- Cut wires-JDM Headlights EG6
- my 92 hatchback dx
- Need info on header that I have and I can not identify. Picture!
- Idle???very noob question
- Front Tow Hooks...
- i'm confused.. d15b engine
- TRANNY
- vtec vs non vtec
- which tranny top mount?
- d16 piston fit for d15
- 2001 suspension to 97 civic???
- vtec ?
- ek w/ h22 euro r?
- ECU Swap Question?
- they say im gunna get beat my a 8,000lbs truck haha
- need help connecting horn
- NOT TECHl; but simple quick question for paypal newb.
- starter interchangability
- si cluster problem please help!!!
- 92 Civic Stalling
- How to?
- Break peddle going to ground Help pls.
- 98 Civic Dx Exhaust- "give me some pointers"
- battery wont keep charge?????
- how do i remove the climate control
- Searched and cant find
- d series, to b series hydraulic clutch pump.
- whats on my civic
- aem fuel rail+guage
- Timing belt / Water pump will d16 fit d15?
- Re: Burning Oil.......... (Searched for three hours)
- NEED HELP Car DIED on me (b16a2)
- Need input with Paint Molding Project
- oil pressure 99 civic ex
- ZEX dry nitrous kit on b18b1 75 shot
- brake probelms 94 civic
- what are the first mods to get?
- Integra mid pipe on ej1. Will it fit?
- b16 A/C
- help: install deck problem with fuse 96 honda civic
- turbo kit fit?
- 96-00 hatches how many swap in front LCA/Sways
- annoying beep
- turbo Gauges
- Fuel line kink w/pics...Problem?>
- adjust clutch on '00 civic ex
- Poor Idle (surging)
- are 92-95 jdm civic radiator support same as usdm ones?
- failed smog, need a good website to buy a cat converter?
- does anyone know how to do a wire tuck on a 2000 si?
- wanting to know how much this would cost
- will i pass emmisions ?
- Just finished my swap, now i have tranny problems, please help
- How-To: Easy headlight clean
- would a 96-00 civic hatchback apexi catback fit a 92-95 coupe??
- IAC problem
- I cant open my trunk pt2
- Spoon twin blocks on EG6
- weight difference?
- Rear power lock won't work anymore
- Relocating Fuse Box from Engine Bay
- LS Vs B20
- Removing Fuse Box From Engine Bay
- Rear Disc Brake Conversion
- WIRING HELP!!!!!
- 99-00 Civic Radiator Fan Switch
- APEXi World Sport Coilover
- how do I open my trunk.
- Anyone know which wire the rpm signal is for a 96-00 civic .. on the cluster
- how do you....
- Using apexi power fc with forced induction
- Car won't start
- help!! wiring problem smoke coming out!!
- which 02 sensor? and evap sys
- Power Windows Question!
- new disk trailing arms for my 93 del sol s from a 95 sol si !!
- Question
- will it fit?
- what did i do?
- QUick Brakes question???
- quick question
- My Project: D15b Swap in my 94 ex coupe.
- sorry another noobie please help i have a wiring question
- New valve Cover gasket and it's leaking
- Mini-me swap done ( time for dumb questions)
- knock sensor question.
- Trust Me I Searched!! VX Engine Harness B18C Questions
- 00 Civic Fog light help?
- URGENT O2 sensor wiring
- HELP.... Years for matching Body Parts . What is the breakdown for late 90's
- anyone know any websites for this exhaust?
- City light bulb?
- car wont start???
- Putting a B18C1 Engine Into An EG And Dont Know How To Put In The P/S
- ej1 emblem
- OVERHEATING PLEASE HELP
- Choosing color to paint car... where can I see samples?
- Ahh car is stalling all the time... need some suggestions!
- is it possible to change an engines ODB?
- Need Help.........Vehicle Speed Sensor Code
- 95 civic ex clutch issues
- will a 95 si tranny benifet a d15b7 engine
- cam gear question
- EG and DC parts
- GSR Front Brake on DX EK Hatchback, Will GSR Knuckles work?
- oil filter
- possible to run a P2E ecu on a gsr?
- ebrake cable lengths
- NEW TO HONDA!!!
- Check Engine Lights On
- does anyone know?
- Omni Power Design?
- Help Swap Engine: Lose Speed
- vtec wiring problem
- Wheel bearing question.
- coilover recommendation
- I think I did more harm than good
- Yonaka Seat Install
- b18c1 valve cover modification
- Integra Sway Bar
- obd1 b16 into 99 civic si
- transmission seal?
- Gas average on 1999 civic ex
- Fog Lights
- RE: Transmission code help
- coming into 8k spending 3k what is the best choice?
- B18C into a 95 Civic
- d16y8 burning oil; compression test results inside
- PCV from hell
- Vtec engage(GSR)
- Vtec engage
- my car is burning oil (searched)
- (gsr-ef)__Twin EG & EF Build Up: Project Coffee N Cream__(turbo-ITBS-ef)
- (gsr_eg)__Twin EG & EF Build Up: Project Coffee N Cream___(turbo-ITBS-ef)
- B18B valve cover???
- repalcing gauge cluster for an eg
- eg rear brakes to ek
- pivot tach reading wrong :(
- OBD1 or OBD2?
- Ls swap
- d15b vtec cylinoid
- PGMFI.ORG wtf happened?
- D16 Block B16 head?
- help please
- Skunk2 Mega Power Exhaust
- 1993 del sol problems
- should i get a JDM D15 or a D16z6... i've searched
- Does anyone know the easiest way to the get dash of of a 96 DX....
- #####99-00 Civic Si Coupe interior question
- what do you need to put a si cluster on a cx hatch ?
- Powee Window/Power Lock Conversion
- Can't find forum---
- Fuel System upgrades
- will ek dash swap in eg?
- timing D16Z6 issue
- Axle Woes
- VTEC HITS?
- VAFC Question for EG/B16
- Problems with Tein Basic Suspension
- Steering Wheel problem
- 1 more question about d15z6 tranny to my new d15b(flywheel bolt pattern)
- My cd player won't work..... and i'm missing some fuses does anyone have a fuse diagram picture? so
