View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Does a 5th gen pedal set fit in a 6th gen?
- Need a pic of the stock rear wiper on a 92-95 Civic hatch.
- 98 EX Ecu.........HELP
- 5th gen si/ex swaybar?
- civic type R, how much?
- insurance
- Stupid but serious question
- Phantom Gray Civic
- Would a 1.4 gearbox fit 1.6 D16??
- TEIN S.Tech Install (finished) review soon to come (PICS W/LINK to others) 56K Can Try
- Making Injector wires longer
- Civic Suspension.Help
- Clutch pedal creaking noise - Help please!
- some new rollers... hope you like it.
- where did JHP go ?
- Spoon cam gears
- eg foglight help...again
- where can i find a cheap place to buy......
- Deck Height
- b16a2+95 civic?
- Broken Caliper Bolt - Help needed'
- oxygen sensor question????
- car is handling better today (warm day=less rattles)...
- how to replace clutch pedal bracket?
- Where to find Long Wheel Studs...besides Skunks
- I cant search archives.....so i need your help
- How do I get my headlights apart?
- 00 supercharged SI for sale...cheap..cheap..cheap.....
- pic request - Koni Yellows and H&R (sports if ya got em)
- torque convertor
- Why do my hoses keep breaking!?!?!
- 95-'00 Si Headlight conversion?
- My EG6 SiR
- Gsr or B20/vtech motor?
- (i searched) best sounding and lookin exhuast for a hatch
- car starts then dies...HELP!
- EK Shop Manual...anyone have this in PDF format or to download
- Fast Brakes over priced??
- Lug Nut size?
- RC stars???
- archive search wasnt working...TIMING ??
- gsr vtec wiring problem in eg
- Great deals on 17's????
- Skunk2 lugnuts????
- SHocks/Struts???
- 5 lug help
- whistling noise from a stock d16y7 ('92 Si) motor??
- new motor?
- what size wrench do i need to remove axleback exh (stupid ?)
- I hope im right, but this manifold looks different...:(
- Best low end HP gains
- Civic w/ Nitrous: VIDEO Anyone from Central FL recongize this car?
- EG arm rest console
- Power mirrors in a CX?
- Looking to buy a 98 & Up Type R (C5 Preferably J-Spec) Swap!
- cleaning tint
- Samco Hoses. Where to get in the US???
- Please help me out
- D16z6 vs. D16y8: What is better for Hp and torque?
- anybody know how to switch auto to standard on 96 hatchh22 swap
- Okay: 93 Honda Civic SI, 2001 ITR motor, Del Sol Radiator: What Rad hoses do I use??
- zc and a6
- failing inspection
- Ordered some new toys off ebay . . . !
- Clicking sound durring hard acceleration around 3000 rpm and beyond HELP!!
- loss of power
- can anyone tell me wht lip this is
- eg exhaust fit on ek?
- Water nozzle on 5th gen duckbill install
- Changing out tranny and waterpump, easier to just take whole engine out??
- a couple of ??
- HOW do you bend brake lines...
- Good Deal Or No Sorry If Wrong Forum...
- check engine light for nock senser
- Which is Best?
- what about the progress springs?
- quick suspension question
- skunk2 rear swaybar help
- Clear blinkers
- Jackson Racing Cam Gears
- How To: Cam Gears
- Please need help with ITR sway bar install
- installing eg foglights was easy ans sneezing
- *ATTN:Canadian residents*
- Installing Eclipse Foglight Q's
- Was ABS standard on all 93+ EX coupes?
- Oil pump..what do I need to replace?
- fees buying a used car?
- car wont move....
- skunk 2 stage 3 cams?
- HELP! bumpstop question!!!
- Why is the J-spec H22A less expensive than most of the b-series motors?
- GSR engine information needed
- optinal audio console
- Water pump... its the little differences.
- Gridle???
- can you guys lend me a hand?
- 96 Civic Common Swaps?
- D16Z6 ECU - JDM D15B
- Whinning from the clutch?
- type r suspension\ ek civic???
- Third brake light in CF duckbill
- dunlop fm901?
- Skunk2 IM Install tips??
- Fastbrakes Thumbs Up!
- Stock exhaust size? 5G
- how much brake fluid for a rear brake swap
- lowering ?
- Intake air temperature(IAT) sensor placement?
- SOHC VTEC.. Can't tell if its working
- Whats the deal with chipped p28 ecu's?
- q-forms kick panel pods..... clutch???
- I fought the tree and the tree won!
- The 5Zigen Fighter wheels, they look good... are they good?
- Coilovers?
- how much performance will i lose using a cx tranny?
- Need pics of 96-00 hatches with headers . . .
- d16y8??? 1.6 sohc vtec.... when does it kick in?
- Finally My Header Has Arrived(Board At Work)
- h22 full swap
- squeak squeel sound
- Does anyone has one of those exhaust silencers laying around?
- humming sound?
- Removing back seats in 99 Si?
- 95 Civic tranny
- Axel problem???
- pr3-1
- How Do You Identify the Different B-Series Honda Cams?
- Need Help! Im a n00b
- Clutch Problem with 95 DX need some advice
- Mini me Y7
- Short shifter for my SI???
- Anyone know where to get a SoHC vtec head?
- will this work?
- A'pexi axle-back interchagibility?
- Everyone check this out.....
- Trouble code 65??
- 90-93 Integra tranny, Can I change it to hydraulic
- ODB2 Scan Tool
- lowering springs: integra spring rates are lower than civic spring rates???
- integra sway bar install
- Summit Racing: (new products) Got CO2? and Built B20-B18 Blocks by Dart
- Its so simple, yet can't get it.
- Paint Help Please
- 98 dx coupe changes
- Sway bar question
- stupid timing belt.... i hate it. This doesnt make sense
- Tanabe Under Brace?
- aftermarket steering wheel and horn problem
- EK Hatch: Sedan Door Handle Swap
- What to look for in new car? EG vs. EK
- 98 Civic DX 'n stuff.
- Front Left/Right shock/strut question... (in middle of install)
- Tranny Tech Question
- Tein type flex- testing water
- Crappy fuel economy...help!
- Exaust question
- ex coupe doors on si
- Seats
- What pistons for my b18c1????
- P28 for a B16?
- what to trade my power steering for manual
- Wat Tire Size For My Blade Rims
- Got a simple question...
- bolt size
- lowering springs
- ok
- anyone know where i can find this bumper?
- Installed Cam Gear and Ignition Timing is off??
- 6 1/2 speakers in doors of 92-95 hb? is it a easy fit?
- ceramic or stainless
- Fuel Rail
- D16Z6 Zex Cam
- Air bag tray....anyone have one???
- who can get me a good deal on OEM replacement parts?
- Planning to buy EG9, what is interchangable ?
- Turn signals.....?
- Is this right?
- question on exhaust fittings
- SUS Help???
- type r or gsr cat?
- For all of you dial-up suckas interested in the EG Helms manual pdf on CD.
- CTR side skirts
- 90k replacements on 98 civic ex
- Interesting differential discussion.
- Brakes for 00Civic . .
- VAFC Question
- D16 blocks all created equal?
- Removing Side Moldings
- have you seen me?
- I just bought a 95 CX hatch white with clean title for 500 bucks.
- hi peeps need some seat help in a sol
- Wgich brace is this
- ACT Flywheel question ?
- Difference between distributors ?
- Project for school, can anyone give me some pics?
- Invidia Exhaust.. Any Pics on Eg- HB or any experience with it.
- VAFC or Not?
- Need pics of Civics with 15" and 16" Rota Slip rim
- LS dyno #'s?
- screwed up cat and/or header
- Ball joint spinning???
- Collector size...
- Red EK hatch with what color wheels?
- halo projestor's questions
- people with jdm EG6 sir cluster... SRS warning light
- Which power window kits works on 92 EG hatch non power window?
- DIY EK Maplights!
- need the pocket bracket that comes with the optional audio console for 92-95 civics
- big gap on my duckbill - bad?
- Timeline of my hatch..
- lowering springs
- who owns this EG?
- *Weird Electrical Problems - Please Help*
- what exactly does the hondata do?
- Guys, i am new, and i will need all the input i can get!
- Magnetic Drain Plugs - Any problems?
- which vafc?
- unstable idle
- Turbo AT?
- GSR Blade Rims What Color?
- new guy ... old EG ... Sup.
- 96 dx to ex swap.......
- coolant change on 97ex civic question
- Getting my windows tinted tommorrow on my EBP SI, need opinions....
- HELP!!! (with my horn)
- pics of my amber/red interior.56k dont even dare!!!
- Muffler For 92 Civic VX
- I just got my Hondata!
- Anyone swapped a d16z6 for a d16y7??????
- 92' dx hb fuel pump fuse location
- USDM ITR front upper control arms in EK
- would you get this?
- GSR Parts For My 96 Civic DX
- b18a from a 92 - 93
- i finally ordered em!
- VAFC mounting help
- New Guy...Whats up?
- Need SI Springs?
- my SI hatch has only 81K and its startin to smoke a lil . can this be fixed?
- Throttle body spacers
- wiring harness
- Does anybody remember a thread about...
- Axel problems on 97 Civic...
- what rims are on my car (hopefully this one works)
- jumping throttle problems
- what kind of rims are on my car?
- Frankenstein motor
- just filled up.
- question
