View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Del sol coilovers fit on an ek?
- O2 Sensor problem? 95 Civic B16a swapped
- 97 Civic Clutch Pedal Assembly In A 95 Civic?
- Honda Civic ATF
- Quick cab disassembly ???
- Blox LCAs + Energy Suspension
- 95 ex coupe electrical/engine problems
- how do i change fuel line going to fuel rail?
- HELP ON COILOVERS!!!
- HELP!! New swap and radiator fan is not turning on and temp gauge does not work.
- Help, what is this black box...searched
- picture of evap purge solenoid?
- Mugen valve cover B16
- Fix disconnected door lock cylinder-latch-rod
- A/C won't turn on... at all
- How do I test my ECU?
- 1996 civic cluster swap, SRS light on HELP
- I NEED A P2J 003 ECU BADLY
- Where is the thread about swapping EM1 Si speedo and tach into EG cluster?
- rpm signal wire
- Broken Peice on Y8....Dont know what it is
- d15 tranny prop
- pixel car for signature
- mini me swap need help
- 99-00 fog light bulb type??
- Suspension Question
- Ek CTR Random Parts
- what seats fit in my 6th gen?
- 96-00 Ek Side Markers wiring problems!!!!
- B20z randomly stalling before warmup
- Ticking noise???
- Manual windows super hard to crank
- Trunk Springs
- Does a Black Hood look good on a color car?
- quick question (head gasket)
- question/something i did and can't figure out 5lug and 4 lug brake help
- HID Kits?
- copped an EG finally
- MPG Predictions: 97 Honda Civic 4dr
- newbie coupe owner
- Pic Request: Drag dr20 +10 offest and up on 96-00 civic coupes
- camber kit
- UNUSUAL NOISE IN INTAKE
- Need a transmission
- 93 civic rattle
- Z6 swap for a Y7...distributer question
- 97 civic wont start. spark gas timing all good
- getting ecu chipped redline ideas?
- em1 B16 engine harness in a 97 hatch
- Cat-Backss.. whats your picks?
- Wiring obd1 distributor to obd2b harness
- Alternator Pulley
- power windows quit working
- ek doors???
- 96-00 manual window regulator help
- how to repin ecu harness?
- Need help from the EG hatch folks regarding moon roof
- Help on 4x114 wheel bearing
- what cylinder head can be the replacement for a d17a2
- 94 civic wont rev over 3500rpms
- 97 ek hatch, worth it?
- Code 67 after replacing o2 sensor.
- D16Y8 To D16Z6 Swap Problems
- eg owner how wide can we go on wheels?
- 2000 hatch shift linkage problem
- 99 harness to OBD1 distributor
- b20 wont stay on!!!
- Shifter mount bolts
- B-series Freeze plug
- Warning dirty towing company
- h-swapped ek short shifter
- how to check for continuity
- vitara built z6 gasket help!
- blew my 80a battery fuse
- What to charge for an auto-to-manual swap
- oil pump gear removal help
- civic/ballade sr4
- Brake pedal qustion on an EG
- AEM intake bypass valve
- CKF work on a 99 SI
- Clean EG Pics
- Back On HT
- EM1 overheating
- Car falls flat on its face at 4K rpm
- Code 45 help!!!!!
- Shutting off when don't press the brake hard enough
- 92 sedan passenger door
- need help wit my b series swap
- New Del Sol member
- have ?'s about boosting my hatch(HELP)
- CEL and Speedo problem
- b16a in 92 vx
- Is 95 D15B dizzy from 92-95 D16z6 TD42U ?
- did a swap engine ticking
- How much quarts of oil do I need to put into my b16b ctr engine???
- Is this a fair trade? Bone stock 94 LX for modded 95 ex?
- Aftermarket Intake Q. (ebay)
- Brake Master Cylinder
- turbo or swap??
- car bogs when i accel. then when i flr it pwr comes back
- Springs for sale (move thread to marketplace please)
- I HATE GLOW GAUGE Covers. Would appreciate help with removing.
- ELD (Electronic Load Detector) discussion | 96-00 chassis
- help on b16a to Ek
- Ac bracket for a b18b1 in a ej1
- Map sensor wiring gsr
- CEL was throwing me code 3, 8, and 10 where do i start to fix this?
- Removing middle layer from Y8 head gasket
- Legend Hood Dampers in an ej8?
- Lookin for paint suggestion on eg hatch
- stock radio does not unlock with the code?
- Where can i get this mirror?
- thinking about doing these in the future, any thoughts?
- auto starter in a manual trans?
- squeeking water pump...
- 99 Civic - bad a/c compressor - how do i remove it?
- d16z6 swap wont start
- Dual Build: Del Sol Turbo, MR2 Turbo.
- DELETE WRong Area
- fuel pressure regulator - d series del Sol
- ATF Fliud for 94 civic?
- price for mugen wing for ek
- EM1 idling weird
- Question about swap
- Ordered a Greddy SP2 for my EM1, fitment question
- Rebuilding my engine
- swap??
- Electrical Issue
- HELP! CAR IS BOGGING!
- Noob question-transmission
- help with oil pressure gauge
- EK hatch B20 help
- Tranny Rebuild Where is the link?
- is this a good deal or a rip?
- HELP! MY CAR BOGS AT LOW RPM
- vtec does not come on
- sorry wrong spot
- question on slamming ej8
- b16 ticking??knock?? help
- I need help with axle and halfshaft pics inside
- HELP: knocking noise when i turn right...
- Engine Digital Diagnosis fraud?
- H22A in EJ1 shifter cables problem
- I think i made the right decision
- 4 point harness set up. need some help
- Back up fuse problem. HELP
- Del Sol SiR One Piece Headlight: Which way do they point?
- wheel size help
- Will an Integra B-Pipe fit on Hatch?
- ABS and check engine light on after hard shifts
- widest oem steelies
- brake conversion
- Help with del sol windows
- Domokuns
- post pics of your 92-00 interior,DIY tips etc.
- Front end noise
- 2000 Civic Si hesitating after 4000rpms
- Tailights and Amber lights both out?
- Question on LCA'S (lower control arm)
- HELP PLEASE!!!!
- Plugs and wires
- Weird Clutch Noise
- K24 in an 94 hatch??
- GSR brake swap Help!!!!
- How Do You Install Rear Sway Bar and Rear Lower Tie Bar To My EK Hatchback
- fog lights arent working 94 civic hatch
- Fresh body kit
- Hawk Front Brake Pads Not Fitting.
- d16z6 or b18 non vtec
- Camshaft Cap Has Small Crack!!!
- whats th weight difference??
- B18 swap
- 96-98 Climate Control Lights
- Calling all Tuners!
- vibrations
- 1998 Civic DX Hatchback - 125k miles ...
- Noise coming from motor
- What size air compressor do I need?
- 1997 civic coupe gas tank leak ? how to you remove this gas tank ??
- Is my tach off?
- 97 del sol front bumper bottom foglight
- PLEASE HELP WITH MY IGNITION!
- P30 or Chipped P28 In B16a 93 EJ1
- B-Series Auto questions
- y8 dizzy on z6 head HELP!!!
- bseries or dseries a/c parts
- Need HELP noise coming from front end
- Will tires fit my 95 civic ex?
- 93 ej1 brake master cylinder
- Pistons above the deck?? :( pics!!
- car spits water out.
- Interchangeable Interior?
- automatic transmission lock up solenoid ?
- EM1 black box ? I'm sorry
- Rear disc brake conversion help.
- Can You Make A Coupe Fast?
- front-end is jacked up..
- 94 civic ex with d16z6
- Door Lock?
- noise when i break
- blown head gasket? HELP
- Please help me wire vtec on my D15B
- BYS front lip where to get??
- 93 ej1 wheel question...
- 94 b20b with gsr tranny no start
- fuel wont prime?? w/new pump..updated
- Charging A/C Problems
- HELP: car wont start
- Anyone ever have a problem with their oil cap before?
- gsr leathers in ek
- My ej1 is leaking...
- Half-shaft trouble
- removing side molding
- whats wrong with my car? bent vavles?
- Is there an exhaust that sounds like a WRX's SPT?
- 92 VX - Fuel tank / Fuel line problem -- fuel everywhere, what a mess
- gsr in del sol, axles aren't long enough
- check engine light....
- 95 civic idle problem d16z6
- 08 Rear Si Seats Into EM1! (*WITH PICS*)
- b16a (SiR II) into eg cx questions
- 95 Del Sol tranny coolant
- New to HT,heres my EG
- Smells like gas & CEL on
- Better than ARC and $400 cheaper
- no brakes...brake upgrade...no braking power! any suggestions...
- Removing shift linkage from transmission on a B16
- indash tv
- Brake lines, any reccomendation?
- 99 si keeps chewing alternator belts
- power throttlebody doesnt close completely
- d15b y8 head
- Tach and Cruise Control not working
- Brian Crower stage 2 (BC0013) questions
- Newbie here h22a civic plans.
- 99-00 DOME LIGHT HELP! 550WHP boosted SI! HELP ME PLEASE!!!
- b16 head : milled, got questions
- question about an exhaust
- On the side of the road with my iPhone! Help. Car won't start
- Help with a Civic build
- Delete plugs for wire tuck
- stage 3 clutch installed, dont feel like its engaging.
- transaxel question
- wire tuck questions
- 1999 civic ex turn signals
- Need Help Installing Bike Rack On My 95 Hatchback.
- What tranny do i have?
- **Carbon Fiber Doors**
- EDITED: dash plugs inquiry, help
- 1995 civic 4 door
