View Full Version : Honda Civic / Del Sol (1992 - 2000)
- sri tube with stock airbox
- MOMO steering wheel? Will airbag work if i install a SRS wheel back on
- Dtc p1298 what can be wrong
- gears starting to grind
- how to install coilovers?
- Weird Problem
- EG Driver Side Speaker Question
- first car
- need help
- 94 eg coupe (Car wont go into gear!) help not sure what it is
- HELP 96 civic si d16y8 KNOCKING AFTER crankshaft pulley failed
- rpm gague does not work
- 'high end tri-Y headers' by LogicMotorsports.com problems
- EM1 restoration project
- water leaking
- ek sedan question
- EG Hatch Design flaw?
- how much motor oil should i put in.
- Bad starter??
- ckp sensor help!!!!
- 1993 civic starts sometimes and not others
- z6 into ek - running with problems
- Clutch Problems from 2nd to 3rd...
- Radio COdE??
- c-pillar bar
- need help desperately overheating problem!
- Car intermintely shuts off while driving...
- New Here, new(ish) car with swap problems (suprised?)
- B20 into Del sol
- USDM CKF to JDM B16a Help! (pictures)
- d15b waterpump
- NEED HELP WIT MY B16A2
- Question about Factory Seats and Aftermarket Rails
- 99-00 civic rear lip urethane or abs?
- how to read your vin.
- Window Problems in the EM1
- SOHC V-tec for sale
- Auto to Manual HELP!!!!Need input...
- Check this out
- why my care steers left
- Del sol e brake woes
- Why is my '92 eating up so much gas?
- 93 Del Sol. Right turn signal has a mind of its own with headlights on
- a/c question
- Quick Response. Will D16 trans fit D15?
- CIV4 door H22 questions
- EG CIVIC Shift knob Q.
- ITR DC2 rear seats in a gutted EG HB
- Hi, and a project question.
- Quick Simple question??
- b20v timing help
- jdm b16a block oil cooler...
- Just bought a Del sol...weird issue, would appreciate help
- Opinions Please..SOHC vs. DOHC
- Speedometer needle wobbles at certain speeds...
- EOI: what axles would i have to used on a f20b civic swap?
- D16Y7 T0 D16Y8 WIRRING CONVERSION
- 99 civic keyless entry/power door lock issue
- B18C4 (B18C1) Swap Problems, Wont Start but have Fuel and Spark
- d series performance axle question?????
- cam gear question
- fuel gauge + radio issues
- Help what is this called? h22a piece
- What is this called?
- Mounting bracket for mounting JDM SiR long arm rest?
- b20 swap in my sol..
- HELP!!! Swapped distributors, now it won't start.
- 92 EG LS/VTEC wont start
- How do I determine what EG I have??
- 93 Del Sol Aux Lights
- need swap engine for my eg6
- Rear Calipers seized?
- Full GSR Swap $2000 good deal?
- skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
- Coilovers ride hard
- Mods
- magnaflow muffler as resonator. Clearance issues?
- swapping vin tags on dash
- clutch master cylinder question
- painting alloy wheels help
- Intermittent Starting Problem
- b20 turbo
- Tein H.Tech or S.Tech??
- Where should I look???
- Rear seat delete kit
- What am I looking at?
- issue starting up after a 25 minute drive
- Removing windows for 1999 Civic coupe
- Wierd electrical Issue
- rear disc parts help
- 95 Del Sol -- need help with "sport mode" wiring
- 97 Honda Civic Ex Condenser fan and A/C compressor not working
- shift knob and shift boot question
- exhaust fitment help
- Removing EK Sideskirts
- 5zigen fireball Civic hatchback pictures
- parking brake replacement
- h22 del sol si
- fit on 4dr?
- GSR vs ITR? yes no why
- New engine for EG and $1500 to spend
- new to ht well kinda
- LS with a S4C tranny, I think someone swapped gearing???
- Uh....rust on the INSIDE of the unibody?
- question about ek9 front grille.
- Second gear hard to shift at high RPMs
- Turbo or Swap?
- Will 15" rims clear an 11" rear rotor?
- How To Adjust Headlights?
- Strut/Sway Bars
- tryin to make it faster
- Acceleration after engine braking not smooth
- Crank Position Sensor CEL
- Blower control knob...
- wiring harness
- dohc vtec swap in a 98 DX???
- tps removal?
- Idling problems with b18b1
- Exhaust swap question
- why is this happening?
- ac and power steering in my civic.
- Silicone Intake?
- Weight Difference between EG models *for the guru's
- Killswitch to 1998 civic
- Lowered with pictures
- eg with gsr ?
- Is it the rear main or oil pan that's leaking?
- Hubcaps
- need help finishing my swap !!!!!!!!!!!!!!
- Completely FrankenCivic
- Pulled over because of exhaust!! HELPP plzzz
- 96 auto to manual conversion
- plz help weired nasty rattle under car??
- Head gasket choice question
- skunk2 b series TB? no fast idle thermo valve?
- Good cams for a ls motor ?
- brake line leak
- 96 hatch need help
- 2000 SI w crAzy low mi
- CEL 20 Electrical Load Detector: 1993 Del Sol Si MT
- Need cruise control gone.
- Clutch still hitting floor after replacing master and slave
- vibration in clutch pedal and motor
- got a cel, jumped it doesnt blink code.
- Help! Extremely low idle and Low Compression?!
- will a gsr head bolt-on a b21a1 block
- how to disable TCS?
- 97 Ex With B16 SIRII swap
- wiring harness for O2 sensor after cat, location
- heat shield on a resonator ?
- 2000 Civic DX AC Issues
- non vtec to vtec..
- D16 axles
- Need to decide on a suspenson..
- Adding power steering to my civic dx?
- Making a decision about a motor setup.
- Help please! Lock cylinder is jammed...
- Better to rebuild or do mini me.
- 99-00 Honda Civic EX or SI
- Alignment after drop?
- Rim Width and offset question
- Reverse lights dont work!!! (94 eg coupe)
- CODE 14 IACV...Searched and done tests...need help
- Mad Steering Knuckle trouble
- swap out clutch fluid
- jdm b18c wiring harnesses? help
- eg blockoff's or delete plates ..piczz
- CLutch problem
- Replace EG Hatch Rear Window Grommet/Nut
- D16y8 Head Bent values and bad cam What should i do ?????
- What do you guys do for a living?
- Swapping out dashboard-wtd with vin plate?
- Power Window/Lock Conversion Question **Those who have done it**
- D15B8 to D15B
- recaro SR-3 classic harrier
- How do you get rid of the black rubber?
- Issues with buying a civic w/o catalytic converter?
- How to tell a z6 tranny from the rest?
- Autopower Roll Bar Question
- Mugen Twin Loop Muffler Replica exhaust
- 96 civic dx braking question
- linkage bolt size?
- need help installing cold air intake
- best height for better cornering and more travel
- Fastest Swap For Under $2500
- ARMREST fitment
- Who else hates........
- Rear Disc Brakes for 98 Civic EX
- where to find these?
- B18b...add oil sprayers? sleeve the block? add girdle?? wtf
- Burning 10 Quarts of Oil Between Changes
- Price tag on power lock/window conversion on 96-00
- Newbie - Civic EK4, UK
- new guy with rhd eg2
- How to Make A Skunk2 Pro Series+ Camber Kit (Pictures)
- Civic eg6 a/c question
- what kind of gauges to get for my car?
- automatic interior to 5spd interior
- question about CTR cams
- Power Steering / ABS?!?
- My Civic 2000 lx
- fog lights
- suspension question.
- for a B-series swap what parts do i need?
- control arm problem
- Question bout EK B-series mount bolts
- Code 21, wont rev past 7k
- Ls turbo QUESTIONS??
- coilovers..
- Power Steering pump.
- wiring a speedo direct?
- Question about steering gear ratios
- Where can I get eg hatch carpet?
- need brake help quick!!
- Spider Gears In ITR LSD
- fron lip wont fit any thoughts
- Little problem i've seen with recent threads...
- Double din in a 96 ex
- Gauge Cluster Problem
- vtec not working!!
- beaten topic, but still need help trying to find the horn wire
- 95 civic stereo harness stolen/all cut off need help!
- stiff pedals. is there anything i can do?
- EK INTERIOR FIT INTO EG COUPE?
- what engine harness to use in 94 civic b18b
- 98 civic hard brake lines
- D16 Turbo Running Rough
- need help with 95 civic fog light and power mirror instal
- Car will not start 1992 honda civic dx any advice?
- OEM steering wheels that fit
- newbie here with hondas
- were can i look for local honda meets?
- Rust on rims
- shifter troubles h22 swapped
- Car losing coolant!! Overheated help!
- EK coupe modding questions
- extended top hat?
- please tell me how to wire vtec with pics
- Normal to get some backfire?
- Am I able to mix green/orange coolants?
- what's going on with this motor???
- what kind of exhaust do you have??
- rear view mirror and sun visors loose
- Auto gauge cluster in a manual?
- rollcage question...
- BLOX, Skunk2, BUddy CLub..Short Shifter which is better
- Lips Help?
- Steering linkage?? Help...
- New Shell + Motor
- Anything else to do while changing timingbelt/waterpump?
