View Full Version : Honda Civic / Del Sol (1992 - 2000)
- another b16 swap...HELP!!
- dark interior...
- need help on viper 791xv installation
- Speedo trouble on 94 Civic EX
- B18C3 for sale?
- 98 ex civic with 5 lug b20vtec motor
- CEL #43
- BDL fuel rail AN sizes
- home made exhaust systems.
- Low idle and cranks but doesn't start sometimes when car is warm
- shifter questions for my h22 sol
- ls trans won't go
- Paint list
- delso mud flap will it fit????? HELP!????
- Falken Ziex Ze 912?
- Should I Be Worried?
- Tein S-tech Question
- Del Sol / EG front bumper question
- Graddy EVO exhaust on EK coupe???
- Anyone see any problems with drilling my own rotor holes?
- jdm tailights 4 eg
- I just changed my cluster from a dx to an ex and everything works but the tach
- b20vtec in eg
- C-pillar Bar
- EG/EH itr header w/ cat + buddy club spec2?
- 2000 Civic LX need replace struts!
- no power, funny noises.. some help please
- integra brake
- Hard for passenger side window to roll up (PW)
- i have a wieard problem
- im lost need help
- dizzy
- finding your dumby plug
- I am looking for a stock 1999 civic Si coupe
- ek hatch code 16
- 94 DX hatch wont start when hott..
- vvs sencer or gage cluster problem
- want to put new seats in my car. 92 with matching rear seat will gsr or itr fit?
- clicking sound from front left
- 92-95 civic front end question
- 97 civic
- would this motor pass the smog?
- CEL on without ac/heat control connected
- anyone know?
- Check engine light, CSF Sensor code
- A/C in a H22 swapped Sol Anyone ?!?!?
- Will GSR sedan seats in my eg sedan?
- what does the code p1779 mean
- eg fender
- muteki lug tool is crap... need a replacement in eastern PA
- 92 eg6. exhaust help
- Timing covers NEED X Reference
- moldings or not
- B16A2 Engine hesitates at cold start
- What engine oil are you using?
- AEM H22 Hybrid intake 1992-1995
- new guy here
- so i change the clutch this $h17 happens!
- code 43 with stock ecu, no code with chipped ecu.
- jdm cluster not very bright
- Ac bracket Question
- Will a cell from my secondary 02 sensor throw off my air/fuel ratio?
- Can you purchase one replacement Tein coilver??
- ls vtec swap help
- NEED HELP with obdII codes
- Injector sizes
- please help..
- swapping roof panels?
- Manual Steering Q's
- swap help
- brake help
- ***WTB HX Center Caps***
- will this work??????
- Installing Cruise Control
- Why won't my car start???
- 91 integra B18C engine swap into 92 civic
- Question about new header fitment to exhaust (2.25"-2.5")
- AC went out on me after fixing bracket.
- Uneven ride height
- s200 question>??
- 1/4 mile
- civic question
- 92 hatch, LS Swap, few questions about vacuum hoses / locations of a few things.
- switching exhuasts
- Problem with my 1993 Honda Civic DX Automatic Transmission
- Electrical Prob
- Lsvtec oil leak
- em1--skunk2 dual bend
- Keyless entry
- shiftlight set at 7800 but comes on at 7000.
- what power to the wheels?
- Civic coupe seats
- code 20 electrical load detector??
- 99 si- im to tall
- Question on shop costs for modding exhaust setup (plz help!)
- 90 DA rear disc brakes into 98 civic ??
- S2K steering wheel in a EK HELP!!
- engine damper
- Integra springs on EK
- Knock Knock
- 92-95 civic hatch exhaust system to 96-00 civic??
- What my b20 EK to be QUIET!!! tired of noise!
- Important Notification of a Service Announcement *Urgent Attention Required*
- Motor Ecu Question...
- ecu looking for a pressure switch, and my solenoid is missing it.
- Any one tune there eg with apexi neo afc?
- z6 head on y7
- Just A Quick Question
- Air/fuel gauge ??????
- help !!! wiring f22b2 96-98 civic 4 door
- EM1 Wont start after theft! FUEL PROBLEM
- 92' Civic EX erratic idle
- Parking Lights
- transmission question
- spring rates
- 4 itr brake hlep
- Car not starting help!!!
- Ctr steering wheel question
- 2,25 inch catback for an VTi EK4 B16A2?
- LSD on JDM H22a?
- OBD2 CODE P0420
- Does JDM D15 (vtec) trans fit/work on the usa D16 (vtec) motor?
- D16 trans compatability
- 96 civic massive issue need help asap!!!!!!!
- ebay radiator?
- Help find a specific picture
- Del Sol 15" tires - how tall (profile) can we go ?
- Does anyone know where the starter relay is on a 94 civic.
- FUEL PUMP RELAY?
- kevlar sesries clutch kit
- JDMUnlimited.com
- 255 walbro fuel pump
- where to buy honda ultra gold oil?
- Alternator Adjustment Bolt
- i need to restore an expensive o2 sensor
- eg sedan front doors into eg coupe???
- CTR b16b head on a b18b block... question.
- Seafoam 'ed Car, running rich. . . searched.
- DA shift linkage, will it work on a ls/vtec eg?
- D15B swap preventive maintainance.
- k20 eg help
- CKF BYPASS TRICK HELP
- NRG products
- B16b pistons on a poormans type r? and otr questions
- b20 in 96 EK. which ECU should i use?
- smog help!
- Bumper Hole Plates
- EVAP Purge Solenoid Valve with GSR swap.
- is my vtec solenoid supposed to have only one plug. 95 gsr.
- Sportmax 002 Wheels problem fitting
- shop rebuilt oem d16y7. overheated and wont start..need advice.
- starter issues =(
- 96 civic...GSR swap. CEL 21 22 14?
- wiper problem
- what year teg mounts for a eg
- obd1 to obd2 accord distributor in my f2b swap help
- Might have hydrolocked need help tonight
- Is this a stock color civic?
- 1993 Civic AC Freon
- car dies after pressing the gas pedal
- PICS REQUEST OF 15x7+25 OFFSET
- What should you pay for an real EG6 cluster??
- Anyone have pix of 92 Hatch with Seibon side skirts?
- Can anyone tell me what this is worth
- 00 si serious problem. COmpression test not consitent plus shaking and loss of power (jisi)
- Fuel problems i think
- DEL SLOW!!!
- did a compression test on my gsr today and the results were low.
- EM1 Exhaust issue
- Aftermarket dizzy issue: No tach
- Swapped from automatic to manual Trans and the key will not come out of ignition.
- dropped shifter
- New Radiator fitment
- a sunroof visor...
- where can i buy the meal/rubber peice at the bottom of my window?
- 14 inch tires
- Block help.
- Brembo Drums Vs OEM Drums diff?
- Sarting Issues!
- Im looking for this one thread that shows you how to switch the speedometer on clusters
- i need help. does anyone no how 2 put a s2000 gauge cluster into a 92 hatch
- Is a B18c engine a direct replacement for a 99 Civic SI
- ITR sway bar question!
- ek axle back question
- thabj gid fir rear disk conversion
- SEARCHED: Removal of interior door panel in a 94 Civic Hatch
- how would i make hx wheels fit on my eg hatch with si front knuckles?
- Buddy Club Spec 3 Exhaust Diameter?
- recommanded clutch and flywheel for d16y8 daily drive?
- Please Help, No Start, Ignition Switch or Main Relay???
- Help with 2000 Honda Civic-Fuses
- HOw do i get to where the window is
- Extremely weird problem that came and went (civic hx)
- Repeatedly blown fuse ref: dash lights/cluster - why?
- jdm black housing headlights
- Replacing rear shoes on 98 hatch - trouble with top return spring.
- Car is leaking oal on the left and by the cams its leaking antifreeze
- HELP Broke fuel line
- ????NO SPARK AND NO STEREO VOLUME????
- Burnt Wiring?
- intake manifold for b18c5
- need help identifying a sensor
- Problem with Manual Window
- b16 tranny ID these parts
- Overheating Problems Resolved
- o2 sensor help, D16y8 please help
- OEM carnival yellow eg6 pic's needed
- rolled fenders
- JDMshit.com, do not buy from them.
- doing my swap small question
- My 96 Ek burning oil but has good compression
- exhaust problems!!!
- Which is the correct part number for an Apexi Exhaust for a 99-00 Civic Si?
- 97 civic lx sedan
- b 18 swap in a 96 civic hatch model dk
- Car suddenly Shut off while driving need help!!!!
- stupid lights
- HELP... my car is running wierd
- On a Civic VX/HX, would swapping in a K20A engine improve mileage?
- quick release (thin version)
- D15z4 spark plugs???
- manual windows to power windows?
- anyone Installed a CTR Intake camshaft on a JDm B18C SiR-G Motor ???? suggestions ?????anyone
- What mods are needed for a 2 door bumper to fit properly on a 4 door EG?
- d15b w y8 head gasket.help
- auto to 5 speed conversion.civic 94
- 5th Gear Making A Noise.HELP PLEASE
- Front LCA?
- 1997 SI Canada Newbie question
- Headgasket??? Please help
- car wont start!!!
- Wiring LED strip - 3rd Brake Light
- part identification d16z6 related
- what will happen if i put the radiator fan always on..
- Quick question, EG vs EK shocks/struts
- How much to get a bolt retapped
- weird noise under steering colum when starting
- when do you guys change timing belt?
- how to bleed the cooling system
- auto to manual swap rear mount help
- Coilover installation help plz.
- Car Timing. Is this the correct position? pls pls help
- who knows the answer
- kinda noob q's
- Rear tire pressure????
- Honda 98 Civic transmission control system malfuction
