View Full Version : Honda Civic / Del Sol (1992 - 2000)
- my car is cutting off and dont know why
- DIY: How to intall Front Benen Tow Hook
- is 93 cx pre wired for vtec..??
- is it worth it to get a CTR head and get rid of my si head ?
- ek to gsr wiring harness question
- vtec bogging
- how to vtec..?
- Just ordered injector harness for my ek hatch need help on resistor box!
- gsr full brake swap
- civic vs supra
- compression???
- DOT tires for the street
- Del sol auto conversion with a b-series Need help
- Caught Between NA and Boost Need Your Opinion
- wiring subharness
- how to... change color of dash light buttons
- 96 nsx brake conversion(eg6)
- itr front brake line.
- Question..
- Whats the difference between Honda power steering fluid and others?
- vtec no worky..
- B-series wiring question
- D16Z6....Head "pins"?
- del sol Carbon Fiber Fenders ?
- b-seriesno spark problem please read n help
- Fog Lights Pwnd my cluster
- lots of smoke!
- How to tell if HeaD is Bad.. When Off Block
- 97 sol with GSR swap
- Replacing EM1 front endlinks
- help with electrical?
- Fuel Pump Power Wire Location 1994 Del Sol VTEC (for Kill switch)????
- Skunk2 IM help im lost!!!! (DOING IT NOW) B16A2
- A little bit of Help,Well searched but confused.
- question about iacv??????
- Fidanza flywheel friction disc, can you flip it?
- scary brake problem on del sol
- New member looking to do a Z1 vx transplant
- 92-95 Front lca's the same as 96-00?
- yet another idle problem
- what engine comes in civic DX
- clutch need help.
- Eletrical problem ! NEED HELP!!
- Car wants to shut off.
- need help with swaping seat rails
- gsr or turbo
- 94 civic automatic now manual
- Please help! 1993 civic with H22 doesnt run right
- ob2 and 92 octane
- car loses power when warmed up
- Water Pump change during swapping?
- ITR muffler on Eg hatch?
- crank pully bolt came out!
- car wont move and its in gear
- Code 16-Fuel Injector System Need Help!
- amber city lights on a 96-98 or 99-00
- Speedo, Heat and Gas gauge all stopped working. Help please
- timing belt... what? i'm freaking paranoid
- Help with a swap?
- help!!
- suspension ?
- Going to a B20b from a D16z..question..
- dimmer switch
- I think my head gasket blew. LONG
- car wont start 92 civic si w/obd1 gsr swap!
- Alternator not charging
- Help with Innovative Motor Mounts - 92-95 civic b/d replacement mounts
- shocks?
- Lowering Car
- Stereo helpppp
- SOUNDPROOFING & TAIL GATE - 1995 LSi Coupe
- sunroof help..
- 95mm stroker kit
- Questions - how do you tell which engine after swap?
- EK3 (D15Z6) Engine died ! B18C Time ??
- please please help starting problems??????????????
- Anyone have pics of Mugen EK hatch rear wing on car
- need internal help z6
- My car wont start, please help.
- 92civic hatch ls questions
- oem honda parts websites
- 96 civic airbag module location?
- Power Locks... Option???
- high idle and check engine light.
- Dumb question regarding OEM fuel injectors.............
- HF manifold?
- Good tip for exhaust installation.
- LsVtec assistance?? knock while cold/?
- ENGINE/TRANS PROBLEMS???
- How do you remove Tilt Steering Column?
- 99-00 civic sedan ???
- Good deal or no?
- steering by its self...
- civic dash swap
- 99 Civic primary O2 sensor wiring
- My s200 Keeps saying its "OFFLINE" Everything is connected and ready to go...what could this be? Im
- Honda-Tech
- catalytic converter
- ECU not powering up, fuel pump not coming on!
- fog light question on a 92 eg ?
- What options to I have, replacing a liquid filled EK drivers side mount
- are civics pre-wired for accessories?
- Blower Motor Stopped Working
- 2000 cx hb won't pass inspection
- sedan and coupe fender
- Integra Discs On My 92' Civic DX
- My Horn goes off when I hit the break... PLEASE HELP!!
- Newbie question about dumping my car
- D15Z1 post swap running into trouble
- timing belt problem? b16 motor
- exhuast question
- whats the problem??
- OEM Type R Clutch
- Help with my JDM d15b vtec
- kevlar spoon style lips
- i have a question about dash lighting
- Engine Swap Vs Turbo Build Suggestions For Rookie
- I think I may have the solution to stuck rear LCA to shock bolts
- Amazing electrical problems
- head gasket f***up-at least i think!
- swap b20 automatic really need help eg 93 civic tcm
- Help/ dx motor, auto tran, dx ecu, Swap question.......
- need some help....
- gsr swap help
- Does anybody have HONDA EMBLEMS for sale ??????????
- 2 Quick Questions
- weird...no power..
- Water pump help!
- What do you guys think of DROP ZONE coilover and SHOCK COMBO??
- Have anyone ordered from this website??
- del sol questions...
- my car is tilted to my driver side.
- ECU problem !!!
- whats better??
- I have some ? about this swap
- shock noise
- motor mounts for GSR swap.
- Clicking/rattling problem.. help
- clutch master cylinder questioN!!
- ECU settings?
- b16a1 swap using stock d-series radiator, running hotter than normal
- d16y7/y8 engine leaking
- New Member - Some Questions
- ITR swaybars on EG... couple questions
- mixing different brands of coolant
- clutch question
- lowell meet!!!! tommorow
- Looking to buy B Series Trans
- Charing System failure
- Distributor & TDC... question
- ecu problem !!!!!! URGENT
- A.C.T. 6 puck queston
- My CEL just came one .... P0171 (Fuel system too lean??)
- ics of the d15b VTEC engine and vacume lines
- what interior fits into my eg coupe?
- Pic request Pls....
- ***swapping rails, recaro srd question***
- Quick Mini-Me Question: D16Z6 Head On a D16Y7 Block, Torque Specs? Alread Searched!
- i need a good auto body shop in LA Area. Help me!!!
- 97 civic need help determining if it has v-tec or not
- Engine tilting!!! need help!!! causing leaks!!!
- Spoon Style Wing 92-95
- wing/spoiler for 92-95 civic coupe
- p2p with d16y7
- car just shuts off.
- jumper harness
- Need Wiring Help, Diagram. Civic.
- Does a after market cd changer work with a oem si cd player?
- electrical Question
- water leak z6
- how do i put the resistor on my IAT SENSOR ?
- OBX itbs
- 2 Questions. keyes locked & how do i tell i f a muffler is a ES oval tuning?
- my steering wheel feels kinda loose when the car is still (youtube vid)
- 98 civic hatchback cx Cat question
- Will a 4 door trunk fit on a 2 door coupe?
- how high can you rev a
- harness obd version, need opinion
- D15 into D16
- ek body question
- Update!! Hissing from b18 engin compartment
- change wheel parts
- need help trying to find info....
- b16 leaking cam seal
- amber clock
- b16 problem at high rpm
- How much does it cost you for lower ball joint pressed.
- ECU OBD2a Pin Outs VTPS.
- fpr making loud noise
- misfire/backfire
- thinking about putting cams???
- Head lights pluse
- B16a2 misfires and sometimes won't turn on,help.
- Clutch Pilot Bearing : size and/or reference?
- S4C transmission grinding? 1st and 3rd!
- oil leak :(
- check engine light!!! o2 sensor? codes?
- Car died on drive home
- to trust
- soon to buy 1994 vx eg *needs help, noob*
- will an exhaust manifold from a 1995 LX fit my 1996 DX coupe?
- seat belts
- car stalls unless i give it gas
- HELP!!! smoke coming from near my guage cluster
- should i TRADE please help.....
- integra leather seats
- need help with my 1991 civic dx im going to swap a jdm d15b vtec
- 2000 civic trunk lid stays open about 1/4 inch. need to fix asap
- need help asap
- obd2 gsr swap in 95 civic ex problems
- Car is dead please help.
- Carbon fiber Del Sol EBAY lip
- 2k idle. Hear me out!
- TOKICO SHOcks and GC's
- car doesnt want to start
- need help my dad is going to kill me
- 96-00 Civic Mileage Roll Back Question (searched)
- i need alot of help badly
- suspension help
- head gasket?
- would this ecu work???
- Getting New Engine....What are some things i can do myself prior to putting it in
- help with suspension setup for my eg
- oil in exhaust port, help!!!
- Swaping 96-00 steering column into a 92-95
- My battery died.... :( (radio code)
- low / rough idle when slowing down and at stops?
- 95 civic wtih gsr swap running like busted sohc non v
- Where to find this carbon fiber piece(pic)
- back right squeeks
- Any washington Machine shops
- Quick headlight Q
- 97 hatch with rear disks = no ebrake
- HELP !!! Need to know what power steering bracket to use on my b16
- 1995 Honda Civic DX
- Tire Sizing on EG?
- Rear brake piston problems.... Help!
- Brakelines....
- Replica Sir bumper question Please help
- Help!!! my 93 delsol has a missfire in idle
- password jdm 99-00 civic si replica front lip.
- Help: Horrible gas mileage
- fog lights not workin right
- D15B bore...
- B Series Clutch question
- 98 civic lx 4dr where is pcv valve
- Grinding 2 to 3 gear
- Not the typical A/C problem!!
- Suspension/Trackion Opinions
- What is the lifespan of a 1997 Honda Civic?
