View Full Version : Honda Civic / Del Sol (1992 - 2000)
- need link for GC/ koni setup
- Fluctuating temperature
- Del sol spoiler info?!
- What mirrors are these? Pulled off my 6th gen civic.
- Crank Pulley comes off at low RPM!!!?!!?!!?!
- 92 civic dx timing belt question
- JDM Type R Grill(?)
- good clutch for the daily
- d15b vtec - starter motor spins but does not engage flywheel
- B16a2 99 Si -- Crispy valves? or clean and move on
- 95 hatch, speedometer and odometer doesn't work
- B&M Short Shifter
- 93 Civic DX - Engine shut off while adjusting ignition timing. Now no spark. HELP!
- refrigerant leaked all out through service port
- Clutch Fluid leak problem
- Hydrocarbons and Carbon Monoxide section of EMISSIONS!
- 96-00 coupe trunk lid liner?
- D15
- Strange vibrations (not those kind)
- Problems with my body throttle after cleaning em1 2000((((
- need help on noises coming from the rear
- How to tighten 94 civic e-brake
- Safety ideas for civic?
- 93 Del Sol Si- Targa Top Rack Removal
- 94' Civic EX Overheating
- Need help identifying my d15b engine and ECU
- 97 Civic EX No Spark. Have Searched
- My new HX - need advice on misfire, EGR, and O2 sensor codes
- 2door front on 5 door civic
- My Build: 93 D-series Hatchback
- Car will not start!!!!
- JDM Honda OEM Center/Audio ACCESSORY Console for EG Civic installation instructions?
- Dashboard lights go dim when park light and headlights turn on (alternator replaced)
- Ferio side mirrors
- Manual Civic or CTR cluster swap into an auto Civic?
- Trouble with parking brake lever
- y5 mini-me in eg questions
- z6 block y7 head
- Going to buy headlights from craiglist..Are they OEM?
- d16z6 oil leak behind block
- 99-00 civic radio and climate control module in 96?
- Jdm d15b - What spark plugs? And looking for camshaft and valves
- 99 civic si not cranking
- D15 Advice
- Oil temp increasing!
- 1998 Civic coolant leak
- Honda civic/delsol Ecu Question?
- replacing y7 exhaust manifold with header?
- d15z1 improperly swapped into 92 Civic -- help please... read on
- 00 civic lx/jdm d15b vtec swap - need help installing a/c
- eg hatch carpet help
- 98 civic dx stock ride height in inches?
- A/C not cold when hot outside and engine is idling
- a/c works intermittently -- Tricks to removing climate control wire harness?
- Clarification on d vs. b shift linkages, one question
- 98 civic ex b18c swap spark problems
- engine stalls when clutch is pressed?
- what ac parts do i need for a d15b vtec
- d16y7 vs d16z6 Builds
- 97 civic DX overheating issue
- Brake line diagram for 1999 Honda Civic
- Help del sol lip
- 94 honda civic wont start
- 95 dx cant get timing past 10 btdc
- 97 lx cyl 3 misfire help please!!!
- d16z6 motor seized? :'(
- My 1994 Civic DX needs a new OEM exhaust
- air conditioning in 96-00 EK Civics good or not?
- 96 Civic DX: D16Y7 block, D16Z6 head mini-me questions
- Transmission leaking
- Real time help needed: Brake Hardware Torque Values
- Removing wire harness EK
- What do you guys think?
- 1997 honda civic hatchback gauge cluster problem
- help! 99-00 auto to manual park release wiring
- 93 civic ex transmission - grinds when i go from high 2 gear to 3 only
- civic ek b16 rebuilt or b20b v
- 94 Hatch Problems - Blown HG? Swap Time? (LOOONG)
- eg/eh civic rain/water leak guide
- turn signals stay on along with running lights???
- Overheatingggg.help
- aftermarket or oem alarm
- quick easy question
- Single cam Vtec Trans Weird sound!?
- some help with upgrading intake on D16y8 head
- Overheating
- D16Y7 to Y8 intake manifold swap misifre
- has my civic been lowered?
- d16y8 Knock sensor torque specs
- Multi question regarding engine/ tranny and upgrades....
- REALLY BAD Threading in my transmission HELP
- Del Sol leaking in another place
- 95 Eg Hatch - Running Warm
- Rotor "rubs" on back left only when turning.. wtf!!
- 95 Del Sol Vtec IACV
- help diagnosing no power to headunit
- 1994 EJ1
- Car Hesitation After New Engine?
- what to swap??????
- b18b1 mpg just not what it should be
- B20 Swapped Civic - CEL code 43 and dies at stops
- One headlight and tail lights not working
- D16Y8 aftermarket header - What gasket do I need?
- How to check engagement of shift selector
- Brake lights don't work - wiring and fuse issues
- Pop/clanking noise when I turn right at a slow speed
- 98 Civic GX/D16B5 engine - low idle problem (detailed ECU information also included)
- A disturbing sound from transmission?
- 00 civic dx starter issue?
- auto to manual swap woes...ECU, idle, bolt torque, and other problems
- Civic radiator question?
- My passenger brake light isnt working right!? Plz help!!
- 1998 Honda civic HX BRAKE PROBLEMS HELPPPP
- 94 del sol turbo axle
- 93 del sol - sometimes starts then dies immediantely, what's the problem?
- 98 civic/B18b1 swap - 3-wire to 2-wire IACV conversion and idling issue
- Spark & Fuel - No Start!!
- 93 Del Sol Interior Fuse Box Question
- Bolt in front bumper support?
- Honda civic fuel system won't prime.
- Problems with O2 sensor, P1169, P0141
- Em1Hero's wrecked Civic - Repair and Rebuild
- 97 Civic: Troubleshooting and solving high/fluctuating idle, pending CEL code P0505
- My Eg Hatch...kind of a slow build thread I guess
- will eg saloon rear seatbelts fit a hatch?
- Headgasket question, S&S related
- Need Help! :( Gsr and distributors now
- Rear License plate bolt Size?
- need loads of help!!!code 74 no injector pulse
- 99-00 civic si - CEL
- 1994 Civic CX Hatchback (clutch questions)
- BRAKES Lock Up - NEED HELP PLEASSEEEE
- 94 civic ex, D16Z6 overheating
- obd0 distributor to obd1 harness
- testing the d16y8 distributor. need help with a link.
- Starter Issue (maybe) 94 Civic EX EJ1
- 97 Civic EX - problem with passenger power door lock
- eg hatch b20b - overheating
- EPA says the 92-95 civic sedans with 5 speed get 29-35 mpg. True?
- Door Skin removal? DIY out there?
- CEL cam position TDC
- please help! y8 intake manifold y7 throttle cable bracket
- 95 civic dx - question about replacing and compatibility of the heater control panel
- Whats the diff in B16 head and gsr
- Odometer randomly stopped working, speedo works fine ?
- o2 Sensor Problems?
- Radio Pocket?
- So I think my speed sensor gave out on me, any ideas before I spent the $
- 93 CX Hatch Fuel Pump & Regulator Probs
- Hood is crooked due to lower crossmember being bent?
- 97 honda civic ex pops out of gear
- ECU Problem
- Where does this harness plug in?
- what motor mount and axle to use?
- my vx injector 3 isnt geting a signal from the ecu
- Cabin/ Engine Harness
- 92 Civic Si: stiff power steering
- HondaGuy8 EJ1 Build
- 90-97 accord koni yellows on 99 civic?
- 92 EH hot weather starting problems
- '00 Coupe - Hard Cold Starts
- D16Y5 missfire at highway speeds
- 94 hatch stalling issue,please help
- 94 Civic EX ej1 Water Outlet - gasket needed?
- d16y7 timing cover fit a d15b8 engine?
- CEL and idle problem?
- del sol rails/sliders for recaro?
- losing coolant
- o ring question
- Engine Harness Deadend Plug issue
- 99 Civic Won't Start Misfire code 74
- What is this thing hanging from two option ports of the dash fuse box? (pic)
- 93 Civic shifter display P & D4 at same time
- 94 hatch running light wiring problem
- 00 Auto EK: Replaced Transmission, now surging idle
- car stalls when putting in clutch?! please help
- !992 Honda Civic Air intake help
- o2 Sensor Plugs? Ek Hatch
- ABS Modulator wires degraded - is there a better one?
- oil leaks after oil change
- leaking hatch area
- tranny stamp?
- 1995 Del Sol VTEC brake pads
- 92 eg hatch/b18b1 swap - idle problems
- 97 civic ex is making a loud humming noise in the rear
- Sometimes AC works. Sometimes it doesn't. No one can figure out why...????
- 1995 Civic EX VTEC engine quits at highway speed.
- 98 civic lsv swap. Misfire above 3k rpm CEL code 8
- 93 civic sedan idle surging Cold idle assist?
- D16Y8 Cylinder head swap into a D16y7
- 99-00 A/T gauge question (fuel & temp)
- Ej1 build thread
- 1996 Honda Civic DX Hatch A/C clutch makes slight whirring metal like sound
- 97 civic ex - feels like something hits my car when i accelerate from a stop
- 94 D15b stalls with A/C on
- 93 Civic DX - Engine seems to be flooding after short trips (when engine is warm)
- 93 Del Sol/LS swap -- bogs at partial throttle
- 1994 EG coupe build
- swapping 92-95 JDM civic SI-R trans in my civic ex
- 93 Civic/2000 ls swap -- How connect aftermarket tach to ECU
- Engine overheats with A/C on
- 96 Civic Hatch - front driver side parking light doesnt turn on
- Estimated Horsepwoer gains D16y8
- About short ram intake...
- Engine Swap for school commuter
- 1994 del sol rear disc not working?
- Clutch pedal up almost all the way before it engages
- a/c clutch and fan dont engage
- Ek Mini Swap Problems! Crazy Speedometer, Limiter at 5k RPM, CEL! HELP!
- D16Z6 Studders under acceleration while cold.
- Does anyone know where to find this? Glovebox part
- 93 Del sol S Engine help
- i no theres been a lot of asking but 1 more!, will integra rear seats fit 96 civic?
- Need help wiring JDM Power Folding Mirrors
- Question about idea for relay/selonoid to control dual dummy kill switch/alarm
- Interior dash light problems (flickering, not staying on, dimming)
- P29 Pistons into D16Z6
- 97 Civic EX: Air Conditioner Up To Pressure, Parts Working, Still Blows Hot Air
- EK FAMILY !
- Coilovers??
- air/fuel turbo gsr
- skunk 2 pro2 or tuner 3 B16A??
- Adapter to install 72 super beetle steering wheel into 98 Civic?
- Check Engine and SRS lights come on. Won't start.EM1
- 99 civic si b16a semi built - won't start
- 97 Civic Acceleration & bogging problems
- broken motor mount in my eg
- hesitation when tryin to go WOT
- hood/engine clearance problem
- D16z6 Timing belt whine
- If I rev over 5K rpm, my speedo jumps all over the place
- 95' Climate Control Lights Dont Work. Please Help!!!
- mini me swap
- Connector C502 on 96 cx
- What is this difference between the 97 and 98 Civic wire harnesses (see Pic)
- 93 del sol, wont start/turnover PLEASE help!
- Weird Humming Noise Vid coming: Video inside
- Cat-back exhaust system + headers question
- d16y5 build questions
- no rpm reading. eg 4dr ex
- is there a total bolt kit to replace all the suspension hardware 94 civic hb cx
- recaro. seats -- real or fake?
- 97 HX swap, stock y5 to 99' y8
- 94 EG8 Build Thread
- Lower ball joint castle nut cotter pins
- 00 Civic A/C problem; works fine at idle, cycles while driving
- 99 Civic Si - Shifter gets hot while driving
- eg spoiler question
- Exhaust Bolts
- Grinding/Vibrating Noise After CV Axle Replacement Both in and Out of Gear (solved)
