View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 98 Civic Coupe + 07 Crv
- D series swap
- 2000 civic dx hatch coolant leak?
- Honda JDM Blue Badge - VIN Number Help
- 1997 EK1 Issue on D16Y4 Engine
- Wheel Sizing and Offset?
- eBay “OEM Honda” map sensors?
- Passenger side shock tower 8pin Connector
- 1996 Civic No Spark troubleshooting details in post
- Ek civic H22 seap
- Lower Radiator hose stays cold
- Doesn’t shift right 1995 automatic civic sedan
- Unknown leak location
- Intake on 94 civic coupe swapped with D16Y8
- Looking for SS replacement for exhaust system
- 00 em1 d15b swap issues
- 98 civic LSVTEC b18b1 bottom b18c1 head bucking/cuts out
- B18C Chattering Noise Coming from Head
- EG6 Sunroof issue
- Weird Climate Control Issue EK Civic
- OK to drive without PS reservoir bracket?
- D-series engine questions
- 2000 civic ex d16y8 iac malfunction
- cel only after 2 hr driving
- GSR Swap Wont Start
- 1997 civic ex gets a few more horses
- D16y5 running extremely rich
- Am I reading this OBD1 engine code correctly? (1995 civic 4dr)
- Engine swap and manual swap
- 1994 Honda Civic DX D15B7: looking for timing cover replacement
- D16z6 60psi fuel pressure?
- ECU for OBDIIb swap
- What do i need to gsr swap
- Will a 93 civic coupe ex gauge cluster work on my 95 civic cx hatch?
- Shaking body b18
- Classic b series idle issues
- gsr swap from eg sedan to ek hatch
- Honda Civic EG 1993 Air Conditioning Upgrades/Fix
- OBD2a to OBD1 Conversion
- My 2000 Honda civic LX ignition fuse, keeps popping
- Injectors
- I have an EJ2 with a JDM D15B
- Built EK Civic Turbo – My Project Journey & Looking for Advice!”
- Unable to start my Honda Civic 93
- ECU service connector can't find
- Valex brake lines, Legal?
- car doesn't accelerate in 4th gear
- Heater Core Installation - Civic B16A
- Which ARP head stud use on D16A9??
- B18C1 GSR swap into 93 eg cx question
- 2000 Civic EJ8 underhood thermal pictures
- Tachometer issues EK swap.
- 95 civic passenger side water leak
- 1995 Honda Civic DX issue
- 1999 EX D16Y8 Rod knock or valve lash or?
- Radiator fans won’t come on
- d15z6 wastegate vacuum line help
- I have to smack my dash for car to turn on
- B20b swap
- Can We Make Civc Eg Sedan Hood Into Hatch Hood
- Performance Issues
- Jdm d15b non vtec help
- ABS problem
- Anyone know some affordable headers for a d16y8?
- OH COME ON, WTH
- 2000 HX, No power to some option plugs in fuse box
- 95 coupe EJ2 - To b20 swap
- 1992 Honda Civic CX EH2 D15B8 Idle problem
- Help i need a Diagram for ecu p08.. please help me
- Honda eg5 si distributor question
- Coolant temp sensor
- DIABOLICAL PARASITIC DRAW
- 2000 Honda civic dx mystery oil leak
- 1999 civic mb2 won't start anymore
- 1994 Del Sol S - Engine Temps too cold?
- Newly Rebuild B16A on Honda Civic EG 1993
- 2000 civic ex crank but no spark.
- Where can I get window run channel for my EK?
- Constant 7’s
- Engine tempatures
- IDLE SURGE
- 1994 Del Sol - SRS Light
- New EJ1 Owner questions
- Rebuild Kit For 1995 D16Z6
- Please help 2000 civic will crank no start
- Timing Pulley Key...why so small?
- Tachometer gauge goes crazy randomly
- Crank No Start 96 Civic D16y7
- 94 Civic D15B7 No Start
- 2000 Honda Civic Ex hose question??
- Lower ball joints are rubbing on rotor
- Switching Climate controls
- bad alternator?
- 94 del sol s rear bumper installation without rear bumper bracket?
- 5 lug swap axles
- Ek4 seat , outer slider question
- Axle won’t sit flush in trans? Any ideas?
- Looking for info on S40 Oil Plate guide C
- 2000 Civic SI EM1 complete engine overhaul at 300K
- B16 heads in general, compression ratios
- Help
- 98 civic stuttering
- D16Y7 4AT shifting late/hard
- differences between obd2a and obd1 harness help
- Im building a b20 vtec turbo build and i want some feedback
- help with diameter of my D15b7 pistons size
- Honda Del Sol Weatherstrip Seals Discussion
- D16y8 block with a y7 head?
- best tires for stretched fitment on 16x9?
- Del Sol dash loom in Civic EG4
- 2000 honda civic bogging bad under load and has a bad idle misfire
- 93 Del Sol crank no start
- fuel tech 550 to OBD2A b16a2 issue
- WTF is this? D17Y7
- Help with intermittent lights on my car's keyless system
- Coolant Temp Gauge Not Working
- D16Z6 Startup Idle Issue
- after market connecting rod length help
- Delsol Windshield rust Bottom cowl area.
- Help help help !
- B series small spline diff pin strength?
- Brake Booster Evaluation
- EG front subframe lost captured nut HELP
- 1999 honda civic si wont hold boost
- modding a d16, need help!
- Selecting a radiator for my 94 Sol
- Electronic Load Detector, need to find!
- Proportioning valve
- fuel line help please
- What’s this Harness?
- Ek canister delete
- EH9 EG Civic A/C Button not working after loop shorted plug. HELP!
- What is causing this sound??
- 1995 Honda Civic LX Sedan : ISSUES // HELP
- REBUILD ON B16a2 help with compression ratio
- Help finding side skirts
- Hitting Rpm Limiter Prematurely
- B18 Vtec no fuel pump prime
- Help with brake booster
- can really feel the road in my honda civic 1999 ej6 after shocks has been replaced
- Del Sol starting/stumbling issues.
- 1995 Honda Civic LX Sedan ( HELP )
- Distributor and won’t start
- Help with ecu
- Un equal suspension or is my car bent
- Problem with IACV
- I messed up
- P0301,P0302.P0303,P0304,P0300
- Honda civic 98 Vti from junk to glory
- Temp gauge problems
- b18b1 swap, p75 ecu no power to fuel pump
- 99 civic ex auto mods
- 92 civic speedo issue!!
- EK Subframe w/ EG Lower Arms Advice
- 92 civic speedo/ maybe trans issue???
- P30 VS P2T VS P2A SPARKPLUG CABLE FOR B16A2
- b18c1 Catch can
- B20B With GSR Head Questions
- 97 civic ex coupe D16y7 M/T & eng swapped from a 00 civic ex coupe A/T & engine
- IDLE ISSUE | EJ8 B18B1 SWAP FROM 98 INTEGRA
- Honda Civic SI Value?
- Rear Suspension Knocking - Skunk2 Coilovers
- Engine instantly revs to 5000rpm after starting
- No ignition or no start on ek4 sir
- Widest rims
- Transient speedometer failure and low-rpm power loss
- Error CEL 54 but only sometimes
- 1994 civic first start 6+ years
- Ignition distributor
- Need help figuring out a bucking/hesitating issue
- RPM gauge not working
- Broken spark plug
- Which parts can you take from other cars?
- 93 civic DX crank no fuel no spark help!
- Front tow hook on EJ8?
- Low performance / longer crank when cold
- My car has a small short i just want to know the description of these fuses
- Having trouble timing distributor
- Water pump
- Misfire after head gakset
- EK Civic door jamb boots
- 2000 Civic Auto shifter cable too long?
- 92 EG Suspension Build: Front Knuckle Upgrade?
- Front Camber
- 1993 civic hatch won’t start?
- CRANK NO START 2000 CIVIC LX SOHC
- idle surging
- Can I use any other Ecu for my B18C2 engine except P72 ecu?
- Motor swap
- 98 hatchback with sunroof??? headliner??
- 2000 Honda Civic - CEL and Shuts Off at Park
- Metallic Rattle when cold
- Mischievous oil leak
- Condenser fan not coming on
- Ek spitting fuel
- Misfire on cold start and new symptoms as of today
- Power steering
- Ecu p06
- 98 Civic LX High Idle
- civic 6 coupe. d16y7 Broken crankshaft
- Help needed ASAP
- Throttle body cable help
- D15b 3 stage, d15b jdm single stage
- Numbers on Cylinder head block
- 99 Civic intermittent crank/no start
- 99 Civic Ex, No power to relay
- Del sol ecu no fuel pump problem
- Gauge Cluster Indicator Film
- After market radio problems
- Auto to manual idle surge
- Supertech valves amd valve seals
- dark black fluid in oil filter housing
- EM1 Damaged from Attempted Theft
- Running Rich After High Flow Cat+Cat back Exhaust
- 98 hatchback surging idle cel p0505
- Ls swapped 93 ex coupe Gsr trans
- Wire from battery to taillight
- Making left armrest Civic 96-00
- 2000 Civic won’t start (d16y7)
- Eg hatch issues
- 98 Civic sedan Manifold Issues, Please Help.
- Knocking noise and lose shifter
- Interesting Coolant Issue
- Shifter Issue
- H22a1
- Steering issue after crash
- B18 Turbo circuit racing heating management
- Cluster lights issue
- 1992 Honda Civic Cx Ecu Question
- Random stuttering and no accelerate
- Failed Emission Test Help!
- Idle bounces at 1000-2500rpm
- Help!! Will 1996 ek civic sedan front bumper and bonnet fit 00 ek civic sedan
- Ignition, no start
- 500hp d16y8 build
- D16y8 turbo over heating issues
- No coolant system pressure/coolant loss with no leaks
- Honda Civic losing power
- OEM motor mounts in a kswap eg/ej
- 96 Civic EX Intermittent failed start
- replacing rear main seal
- 96-97 honda del sol Timing cover rubber gasket seal
- 1999 Civic CX manual parts
- D15b7 engine idle rpm very high after intake manifold install
- 96 Hatch to Sedan trunk difference?
- Headlight search
- No spark turbo civic
- auto intake to manual
- D16Y8 to D16Y7
- Interior instrument dimmer adjustment not working.
