View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Fuel level sender
- Car has been thrown together before me
- D16Y7/Y8 MiniMe Running Rich and Poorly
- No spark no ground to distributor
- Good mature exhaust for 2000 Civic Si
- 99 coupe bad cat reason?
- Engine harness removal
- D16y7 high idle low idle iacv issues
- 98 Civic EX Skunk2 Idle Issues
- Weird headlight problem , one comes on one goes off ?
- EM1 J's Racing Fenders +15MM
- 97 Honda Civic LX Crank No Start
- 98 1.5 vtec standard swapped into a 99 1.6 hatch cx
- Time to tune
- 93 civic shuts off after turning over
- 99 coupe auto trans issues
- b18c1 break up in vtec
- Overheating temp rising and going down
- 96 Civic EX: Sudden 'bumpy" ride.
- D16y8 auto jerking and loosing all power but still running
- 98 civic hatchback charging problem
- EG - whirring noise - A/C
- B20VTEC Swap high idle
- EJ8 Vitara build
- High idle after headgasket replacement.
- Fuel pump sounds but no fuel
- EX Cluster in DX CEL stays on, Why?
- del sol iccv wiring help
- B20VTEC Crank pully question
- Looking for this part
- engine won’t stay running.
- D to B swap no crank
- Crank sort of no start?
- (HELP) Which cats for 98 Honda civic EX b20b swap
- 1994 Honda Civic HB - Part Identification
- What model/yr/body style do these seats go to?
- EM/FI 15A Fuse keeps blowing?
- B16 no spark, no engine light on
- B16 - Rotating Crank while CAMS at TDC
- b16a Ticking Sound
- OB2A d16y7 stock wire harness to OB2A Vtec Engine & manifold
- B20VTEC Injector Question
- P0505 Code on Y8 intake swapped D16Y7
- 95 Civic DX Coupe, Horn not working
- problems after replacing clutch
- Coilovers
- S40 gearbox won't turn
- 1995 Honda Civic Doesn't Start
- Car sounds like its cammed when stock
- Del sol Cat
- Main wiring harness AT to MT conversion.
- Pls help identify these skunk2 cams on a b16a vtec
- I have a civic with a gsr swap I am trying to get it runn it is boosted aswell
- LS/VTEC dowel pin question
- 92 civic stumble
- D16y7 Misfire on all 4 cylinders
- 2000 honda civic wont idle in drive and shuts off when hot
- Issue with wiring 1993 del sol S no bulb check circuit no beeper
- 95 Civic LX trunk won't pop open automatically
- Thermostat Issue - Weird
- 98 Civic Hx 02 / Misfire codes
- Skunk 2 Intake Manifold and TB swap
- Overheating/ Fans not cutting on need help!
- HELP 1993 Civic Lx Auto Sedan
- K24 Swap - Harness and Throttle body
- 1997 Civic No Start
- Black box under rear deck of 2000 LX?
- B series - Size of water outlet in head?
- Is Torque converters of EG and EK are interchangeable
- Engine harness swap (From obd2a to obd1) mini me swap
- 96 Civic No Start / Intermittent Stalling
- No clue what to do. Need help pls
- '01 b18c1 in to '98 Civic LX
- Fuel pump won't prime
- Transmission torque mount
- 1995 Honda Civic LX won't start after rain
- Car door speaker replacement for 1995 Honda Civic LX
- Check engine light
- Coolant overfill tank stays maxed out, surging idle when warmed up.
- d15b7 Valve Cover Stud Torque Spec
- B18C1 cam cap rail question
- Ek civic cluster needle came out with pin
- Engine sputters
- 1997 Civic daily build.
- 00 civic EX advice after mechanic installed LKQ engine, lotta mistakes
- 1997 civic
- K24z3 into a ek
- Motor mount broken in the block
- Replacing Rear Break Lines '98 Honda Civic LX
- 94 civic lx d15b7 crank issue.
- D16y7 driver side motor mount click
- Iacv help
- Need help with ECU!
- 1998 civic tailgate lift handle
- 1998 civic rear lower control arm bushing help
- 1992 Honda Civic stutters after about 15 minutes
- Identifying B16 Head
- 00 Civic Interlock Solenoid Issues continued...
- Power door Issue
- cv joints
- Mishimoto cooling hose fitment
- Vehicle stalled, cranks, no spark.
- Fuel pump grinding noise, occasional CEL, car jerks from 1k - 2k rpm
- B18C4 EJ9 No spark
- POOR ACCELERATION / BOG DOWN EG 94’
- 00 Civic Ex wiring questions
- Ep3 steering wheel on del sol
- Timing belt slack
- 1999 abandoned civic being resurrected after 10 years. Issue with bogging
- My EM1 is not running 100% - Any ideas?
- Do you add any dielectric grease to the ignition coil spring?
- EK9 replica wheels. 4 lug and 5 lug
- Overcharging issues
- 2nd to 3rd High Rpm Shift Hesitation?
- Delsol ECU identification
- Mechanic apprentice w/ questions ‘97 civic ex
- Del Sol 1994 Tachometer Capacitor Specs
- 99 si coupe front subrframe assembly compatibility
- Single Click From LHS when braking hard
- EG civic bumper reinstall help
- Obd1 gsr into 98 ek hatch wiring question
- running lights won't work ?
- NEED HELP ASAP
- 98 civic lx knocking?
- 98 Honda civic lx
- 1992 Civic EG Hatch - Can you add A/C?
- Eg8 sedan battery shorted new battery negative lead sparks bad when trying to connect
- 93 EJ1 cutting off driving
- Need Help with ECU
- small idle surge after b20 swap
- Green wire Z6 ECU harness?
- Civic Si/Integra exhaust question…
- D16y8 p0141 code car won't stay running
- Wacky Vent Selector Nob Behavior & Not Working 99 Civic LX
- Eg civic drivers side plugs help
- situation: D16A swap into 99 civic
- Possible Interlock Shifter Solenoid issues 00 Civic EX
- Please help
- 97 civic
- Low Pitch Humming under Acceleration/Deceleration
- B20vtec problem
- Will removing Black Box & PCV valve on Naturally Aspirated car cause RMS to leak?
- 1993 Honda Del Sol Si Thread
- '93 civic eg automatic climate control turns off
- Help with turn indicator problem
- Wheel Sizes
- Civic Ek B16A2 Temperature gauge issue help
- 300k mile abuse
- Honda Civic 1999 Sedan (D15b Non-Vtec P2C ECU), Power Steering issue!!!
- D16y8 Swap into 92 EG hatch / OBD1 or OBD2?
- B20vtec/lsvtec pcv?catchcan?
- B20vtec high idle problem
- help choosing an ej2 turbo
- Bogging at low rpms and wont go past 5500rpm at full throttle
- Can you fit D16Y7 oil pump on D15B VTEC engine?
- Ek OBD1 SWAP VSS 6V CONSTANT
- poor heat
- Civic identity problems
- Delsol JDM Distributor Question
- Are 92-95 hub assemblies all the same in the front?
- Help with build planning
- car jerks when its in operating temp
- J Swap in The Del Sol
- b20 timing belt slack issue
- Rad fan not turning on
- EG K Swap Question
- B20B(block)/B16 (head)/B16 Trans (EM1) Swap into a 1994 Honda Civic Ex Coupe (D16Z6)
- Need help for Civic EJ2 Plug!
- B16a Turbo build
- Shaking and Vibrations, Bad Mounts?? (D15B7 w/Automatic Transmission)
- B20vtec iacv problem
- 98 civic no crank no start
- Latch closing mechanism
- TOO much fuel 96 Del Sol H23A swap
- P0505 pending after replacing IACV.
- K20C1 engine swap for Honda CRX del Sol
- Where can I get a harness bar for my 94’ del sol?
- Main Relay Short circuit
- Engne harness plugs
- Heater issue 97 civic EX
- Transmission question
- 2000 Civic Coupe rear splash guards won’t align
- Ek coupe OBD1 SWAP NO RPM NO SPEED NO VTEC
- honda del sol steering rack 3 ports
- idle learn
- What is this engine? & your opinion
- EG4 LSI B16A2 SWAP
- HELP Leaking coolant threw my headers!!
- OBD2A with OBD2B mess
- AC request/ Fuel Pump relay wires in EJ8
- **Update** 93 on fuel pump not priming
- Ek coupe obd1 swap no fuel pump prime
- Valve Adjustment Caused Very Loud Ticking Noise
- Construction of my D16y8 block
- Smoking
- Fully seating cv axles
- canadian civic SI??
- 93 honda civic no fuel but has spark
- Fuel pump not priming
- 2000 Civic EX dash light Woes
- D16y5 Question!
- Misfiring
- bottom of my EG all dented, Will it effect chassis strength?
- Civic speedometer pinning at 180 / alternator problem
- compression test help
- 2000 Honda Civic DX
- Tuner options D16y7 2000 civic LX
- D16y8 idle
- 2.25 or 2.5 test pipe?
- 94 Del Sol dohc Starting Problems...
- d16y8 Surging Idle issue/ Bogging issue.
- Speedometer, high rpm’s and fluctuation, temp gauge and gas guage
- 94 ex coupe d16z6 auto trans issues
- K24 speed sensor wiring
- Stock 93 D15b7 fuel pump won’t turn kick on right away///////////////////////////////
- front sway bar
- How to make right? Driveshaft?
- Is it a problem? Very slight oil leak on block.
- VIN decoder ABS, VTEC, clarification
- 1999 civic LX: Crank, No Spark, No Fuel Prime, No relay clicks
- Ecu turns off randomly and after moving abs wires
- Ignition time table
- 99/00 Civc Tach Wiring Questions
- Engine having rough idle with a sleight knock.
- Replace the IACV Now Engine Smoke and Shacking
- Problem with my Civic 1.6L VTI 1998
- Sohc ZC into a 98 Auto
- problems with ECU honda civic 95 injectors not pulse
- Major water leak
- Del sol Vtec alternator
- OBD1 EG B20V SWAP IN EK COUPE
- 1997 Civic DX (hatch) with B18B1 Cold Air Intake
- DEL SOL jerking
- OVERHEATING- Solved
- 1992-1995 Civic EG - Climate Control relocation?
- js racing exhaust
- Power window Assy Grease points
- Need help asap pls !
- 1999 Honda civic steering wheel connectors.
- 3.5" tach guage reading 5k rpm at idle
- Help with stereo
- Mounting Brake and Fuel Lines to rear tank and wheels.
- EK / EG A/C interchangeable parts ?
- Guide to Converting Manual windows and locks to all Auto
- ebay turbo install on SiR
- WINDOWS!!
- GSR transmission build
- Air Box & Air Tube For Swap - Ideas Needed
- Problems with trans 97 civic auto trans
- Swap will crank but no start
