View Full Version : Honda Civic / Del Sol (1992 - 2000)
- B16 with ITR internals - How much WHP ?
- using a d16y8 intake man on a d15b head????
- what hoses to buy?
- help with ek power window conversion
- what turbo to choose? b18c mid range-full range powerband street/track/autox scca
- need help clearing codes
- need info on a swap b16
- 2000 civic smoked fogs
- need some information please
- Wattage for 99-00 OEM Fog Light Bulbs?
- OBD1 O2 Sensors
- ek civics w/dr20 wheels
- what exhuast is on my car?
- need help fast
- HELP!!!! I NEED A RADIATOR!!!
- Problem with Brake Upgrade
- Upgrading 93 civic coupe
- automatic locks - HELLPPPPP :(
- Need Help knock sensor wiring
- Removing Woodruff key
- Wetsanding??????
- indiglo gauges.
- jdm lowering springs
- Civic dx tach?
- Post up your VSM or any 99-00 Civic coupes!
- Enkei J10 16" wheel
- just got out of smog.. with a stock cx computer
- Help me fit my EVO VIII Recaro's in my EG hatchback .
- Will these LCA's by Omni fit on a 99-00 civic si (coupe)?
- 97 civic w/b16 axle help
- will civic airbags work in a del sol?
- interchangeable parts - 96-98 sedan and coupe?
- K swap into EG question?
- What U Get For What U Pay For!!!
- EG: Keyless Door Handle Swap
- what interior fits
- Torque mounts cut?
- q31 for EVAP or IAT?
- 96 Civic Tire Question
- % Clutch adjustment 2000 Si?
- swap help
- oil capacity?
- will the aem pulleys from a b18 fit my b16???
- another civic gone missing
- What would it take to have front sway bar on a Non-Si EK?
- blox intake manifold installation
- clean iacv?
- 2000 Civic Si P2T Ecu Question
- anyone swap a CTR rpm gauge to Si cluster?
- anyone have a data sheet on stock injector sizes and Saturated / Peak?Hold Injectors
- size rims
- what mounts to use
- Exhaust fitment Q
- p06 ecu question
- Will my AEM cold from 94 EX fit my 2000 Si?
- Welding 2000 Civic HB Radiator Support
- OIL / FLUID LEAK SPRAYING ALL OVER FIREWALL BEHIND GEARBOX
- power steering whine
- Valve Lash Lashing h22 h22a h22a4
- i got 2 questions need help on ( check engine light)
- I Had a GSR Swap on my EG coupe.. !!! Can i Use those Spindal for D15B SWAP?
- removal of oem sound deadening material
- pic request: ecu mounting..
- Anyone have pictures of what a 94 up Gsr Center Console Will look like in an Eg hatch?
- CEL 21, No Speedo or Odometer - 1995 Civic EX
- Cluster Question
- chassis code
- b16a2 Overheating Please HELP!!!
- clock.
- Which HID kit do i need for 99 civic??
- Swap Questions.
- Adjusting My Headlights...
- p/s pulley reverse thread?
- Auto Start question
- Fender Paint Estimate
- Door Panel Question
- another idle issue...d16z6
- Speedo / Odometer Accuracy
- headlamps again.
- Civic Automatic Gear Help..
- aftermath of a fire...
- Code 41 appears after Primary Oxygen Sensor Heater replacement
- H22 Vs B18b which one will i choose.....hmmm.
- I.D. HELP !!
- 95 tegra gage cluster in 94 civic
- sohc zc issue from a honda newbie
- not going into gear
- swap
- I was told to go on here?....
- Where Can i find the RIGHT CLUTCH FOR MY SOHC ..
- Secondary O2 Sensor wiring
- Dashboard (Searched)
- JRC 6" on civic....pic request for how it's mounted.
- wtb-94 civic hb stock front seats
- 99-00 em1 rear lip?
- HOW the F*** do you get a pedal assembly out?! 5spd swap questions
- error code 14 & 15...IAC & Ignition output.??
- Taillight swap question
- HIDs and JDM head lights
- ksport 10k/6k... input
- brake drum shoe install, can't remove snap ring
- wavering idle
- Tech Question...
- Need Help! Can loose intake manifold cause car not to start?
- ECU help
- b20vtec all motor
- Main Relay location
- Turbo my 94 LX??
- best upgrade for the lowest price
- S2K AP1 wheels fitment on an EK
- torque damper
- i have some jdm coupe tail lights but they dont fit on my hatch?>
- 2000 civic power folding mirror diagram needed
- Some Crazy stuff that has me confused as no other. Map sensor
- Another civic got jack'ed. :(
- overheating
- Anti-rice/APC altezza/vtec thread, ricers GTFO -engine swaps
- Del Sol with a mini me swap TN
- Rear LCA backwards?
- neuspeed racing springs ?
- My Car Won't Start.
- integra da seats problem
- SiR Lip oem or not.
- vtec oil pressure switch help
- Nut on catalytic converter
- Transmission question, wheres Bense at?
- spring rates... somebody help
- Volts, no current?
- Speed Sensor?
- h22a problem
- How tall are you?
- quick wiring question... need a quick answer!!! HELP!
- TPS
- where to buy tires online?
- dashboard insulator, can you see it?
- Shift linkage rattle???
- turbo
- need help with z6 into a 00 ek
- Starting Problem
- id toAvid torque mounts, EXTREME vibration Help!!!!
- **GOOD OR BAD HEAd B16A2 Help***
- (195 x 60 x 15) on OEM 15's si rims?
- Car shutting off
- EK hatch rear seat removal help please
- new dizzy and still no spark
- Need help my VIS hood is a fake or VIS sucks!!
- bad map sensor caused by bolt ons?
- B16 A JDM ECU codes
- Manual to Auto motor tranny mount for EG? passenger side
- Problems with my z6
- Name that lip
- Brake Indicator Comes on Between 4k-5k
- hood latch wont latch
- MY D16y7 w/ y8 intake manifold needs help
- Street Racing Death Polls Compared to other death polls
- Crank pulley tool
- odb-2 DOHC ZC (D16A)
- New build... need ideas.. D SERIES fans! Help?
- civic takes forever to heat up, why??
- cylinder head id
- Rear wheel not spinning
- weird noise? axles?
- front or back?
- B16a2 Gearbox - possible problem?
- DC Suspension in EK
- auto to manual ignition key park release
- HELP!! 95 DX - Over heating! NEED HELP ASAP
- difference? jdm zc (sohc vtec) and d16z6?
- Need help tucking the wire harness on my 94 Eg Si
- Question on eg9 front bumper?
- Is this what a distributor should feel like?
- rear bumper license plate
- new rims/tires, do i need an alignment?
- california tint...
- Timing of on my 93 D15b7.
- need some assistances and advices
- eg b'pillar harness bar, del sol?
- tranny conversion??
- 95 civic sohc with 99 ex tranny?
- check engine light
- NEED usdm b16a2 200 CIVIC SI vacuum and emissions diagram.
- does the ecu record the mileage?
- 99-00 Power window instructions please
- beaks kit with omni power lca's - install tips
- Shed some light on me
- Installation of Skunk2 Coilover kit for 1997 honda civic ex coupe
- ebay hid's
- is this possible?
- couldnt break 80mph tonight.
- 90 ls integra rotors on 93 eg srs
- steering wheel shakes/steering is off/rims shakes bad when hit small bumps HELP !!
- Test pipe for swapped cars???
- **********Stolen Cars*********
- DEL SOL B-series Shift linkage
- Random Ecu Codes,throwing codes 3,7,10
- eg seats in my ek??
- Toe at -7.00º WTF!! help
- What integra center console, do I always see in civic hatches
- New, and need help
- What throttle cable and bracket for 95 civic/b16 swap
- eg brake master cylinder help
- Best engine/Exhaust mods for a 99 civic cxi
- Does anyone know where to get the Helm Electronic Troubleshooting Manual in PDF!!!
- my cruise control is acting weirdly (2000 Si)
- del sol motor mounts?
- ep3 seats in a eg6...
- MSD spark plug wires not fitting MSD Cap
- Brake Problem!!!!
- OBD swap alternator wiring- need a little help.
- some basic questions need answered thanks
- B16a motor mounts for eg!!!
- Timing Belt Snapped, Fixed. Now VTEC and Idle is erratic.
- IS Buying an CX-DX is Better then a EX
- Si cluster in DX
- another problem !
- D15B p28, Cel about 80-100 MPH only,no vtec
- want to know how to convert obd1 to obd2???
- 95 SI hatch 4 sale
- rotor bolt pattern
- Just installed coilovers
- D16Z6 piston rings = D16A1 rings?
- 96-00 honda civic HX CVT transmission reliability
- Which Wiring Harness?
- Walboro fuel pump...
- PCV valve. use oem? or aftermarket?
- VTEC not engaging??
- d16z6 rebuild
- horn wires
- What kinda came transmission in 95 dx hatch?
- Automatic Transmission Problem
- poorman's type r questions
- CV boot ripped...Can I drive to work? Need answer...
- anyone use these head lights on your car?
- Reverse lights don't work/what's this wire (with pictures)
- Suspension setup for a 95 civic ex with disc brakes
- Rear wheel drive del sol?
- Conversions
- Waterpump and Timing belt 2
- civic ek1997 civic with b16 swap
- For those all motor d-series junkies check it out!!
- Help car won't start!!
- i need major help
- need pinouts or a jumper need obd2a(female) to obd2b (male)!!
- h-t memebers around the binghamton johnson city vestal area looking for tuner
- sohc trannys.
- Looking for another 3rd gear ratio - D16Y8 tranny
- ebay catback exhaust systems
- VTEC OPS
- 1320 Custom Fab
- 92 civic w/ a 94 integra rear disc conversion
