View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Honda Civic EK9 converting to left hand
- help me i think im getting scammed for my eg8
- brake booster paint coming off due to leak
- 98civic engine swap.drop kit help!!!!!!!!!!!!!
- need an h22a4 tranny
- Mugen AGBS
- distributer problem please help on civic ex 96
- exhaust help on 96 civic ex ((PICS))
- 97 hx coupe, taillights will not come on
- Exhaust help
- Speedo and Cruise Control
- For Sale. DSM 450cc Injectors
- can some help me out tweeter pod
- OBD1 Distributor question
- Just joined the site, few pics of my 95 civic.
- D series cam and springs? Help!
- Slight oil leak from head
- 96 ek hatch for sale or trade for integra so-cal only
- How would you rate this car?
- motor not starting, video inside
- Oil change on 94 honda civic
- Skunk2 Intake Manifold acting funny????helllpppp... plzzz
- bracket
- DIY methods of getting the crank pulley nut tight
- b18 swap and sluggish off the line
- sunroof switch
- My 95 civic hatch
- Does MY car need a camber kit?
- do rear seats from a DA integra fit into a ek hatch???
- upgrades for my 99 civic si
- vtec question
- 93 hatch cooling system problems
- honda motor build
- Help - removing window tint
- window track issue
- sensor identification
- i need help civic 96
- pro or turner series parts?
- 98 SI Overheating/Heat not working
- Won't go into gear... need input
- EDIT: Solved my own problem, let me die.
- A/C and motor help!
- Screeching noise at high RPMs...
- help me please!!!!!
- Common Problems
- motor stalls help
- 2 step launch controll and ce shift light
- Transmission Jerking
- D16Z6 wont pass emissions test
- Quarter Panel Rust issue
- Sway Bar Qustion
- Removing glass from mirrors on CTR
- Hatch glass rattle need a fix...
- oil filter
- Noob clutch question
- b18c5 into EG hatch? mount question
- seafoming my car?
- need to kno if interchangable
- Old skool Riken wheels!
- Interior help
- eg hatch VS 90 CRX
- 93 civic block heater installing d16z6
- help with ek engine swap
- Moisty Headlights
- Transmission Questions about a b16a
- 1996 civic runs cold-poor mileage
- 92 civic got into an accident need input
- 26mm front sway bar
- Steering Wheel Wiring Help
- Cant find part number for this
- a/c removal under eg dash
- Trading my eg8 for a eg6
- msd improvements?
- Help with ECU codes
- civic with full nose mask
- Interior?
- What kind of gas mileage do you guys with d15y5's get?
- Did EG's come with front sway bars?
- fresh ek for sale TAKING OFFERS !!!
- Spring Rates
- FM radio doesn't work, but AM radio does??? Help!
- 97 dx civic trunk on a 97 ex!!!!!
- question regarding legalities of car sales
- dc2 stock shocks fit on 96-98 honda civic coupe ex?
- Does a complete 99-00 EX exhaust fit on a DX hatch?
- new suspention on the eg hatch...
- 96-00 Tranny in 92-95 Clutch Line/Bracket
- Will 99 coupe rear seats fit a 97 dx hatch???
- 1996 honda civi SI front end noise problem
- H22 HP Number I'm Confused
- Need Clutch Opinion
- HELP!!! JDM b16a tranny (STICKER VIN?)
- H22a replaced timing belt now the car dies
- Happy News Years Everyone, will my car lose value now since its new year?
- Re: h22 in my del sol?
- Arc intake em1
- D15 and D16 motmr mount/bracket comperisson ?
- Performence Clutch issue
- 95 honda civic drum to disc brakes
- rear disc conversion on my 97 civic HX?????
- Frontend/Steering Problems
- Solid cel, starts and idles fine.
- installing oil pressre guage...
- Just installed AEM intake...
- 88-91 sohc swapping into 92-95 ? HELP { REARD ON LINE}
- Ep3 wheel in a ek Diff question..
- CEL Help
- Fuel Burning Problem
- dsm turbo kit??
- Horn Relay Question '94 Civic...Horn not working!
- D15B7 Engine help
- Night pictures...last pics of the year!
- Clicking when turning?????
- 96 coupe tranny problem
- 93 EG6 B16 axle question
- difference between eg and ej bumper.
- check out this tsudo exhaust
- knocking
- Noob
- Temp gauge still doesn't work
- Stock fuel rail vs performance full rail
- Suspension?
- Bolt On Modified b16a2 need Opinions on Cam Upgrades
- opinions on carbon fiber hoods?
- Fuel Capacity in 95 EX civic sedan?
- fuel rail
- Rotor opinions
- H22a timing problem ~TDC~?
- tsudo exhaust system
- reverse lights
- My buddies 96 Del Sol won't start
- stick car with automatic ECU?
- Installed new o2 sensor still throwing code??
- How to unscrew torx screw from steering wheel?
- brakes leaking
- o2 sensor????
- Advice PLEASE
- (EM1) Question about the size of this bolt/screw.
- Sohc zc
- Huge swap problem !!! D16 help !!
- muffler silencer
- A bored out TB on a stock Intake Manifold???
- oem fuel pumps, civic sohc vs integra dohc? differences?
- 98 Civic DX Gauge Swap Info
- How to check for Fuel.....
- Mini swap help!
- ..where does the oil go into on the top of the transmission?!?!?!?!
- y7/y8 mini me problemss
- 00 Coupe ex rear seats in a hatch 97
- Replaced knock sensor
- All D series water pump the same?
- is there any difference in the eg models??
- Timing belt- head rebuild NEED HELP!!
- turbo 92 hatch problem! please try and help
- gas pedal question
- 96 honda civic getting a 91 integra
- Need Help On B Swap.
- Dash Removal Question-------
- Trouble Code 1298 +
- 95 EG sedan.. Need hep
- o2 sensor question?
- EG w/H22 won't rev! :(
- Brake Question
- ? How to ?
- any ideas???
- Replaced relay, still nothing
- 93 Civic High low Idle Problem FITV Question
- Debate on color car
- EM1 Parts
- $50 paint job attempt
- Question about fitment on the Yakima Racks
- shifter thread pitch
- i know, another heater problem...
- 02 sensor cel
- D16Y8 How much power?
- oil leak?
- tps?
- ok this is kinda weird
- Car won't start
- Help White Smoke!changed HD
- ignition switch question
- D16Z6 Worth much?
- 94 civic dx wont start
- Polishing Brake Lines
- auto trans problem
- eg depo foglight wiring harness.
- Swaping shift booth
- P0171 - System too lean.
- Questions with swapping B16/GSR into EG
- ctr 4 lug conversion
- Where to find stock EG Hatch Honda emblems?
- 1992 honda civic imput shaft problem
- How do i ADJUST MY CLUTCH ??
- Low compression = no spark?
- D16z6 boosting questions!!!!
- Few pics of my buddies 4 dr EG DD
- b16 a cel 20
- not starting and no codes
- need help installing skunk 2 cam gears
- Idle Surge/iacv/fitv
- Steering Wheel From CIVIC 95 EG to 97 EJ or EK or 97 Hatch?????
- Hello guys, my third Honda and I love it!! Please read!
- Eg cluster won't light up. Major help needed
- ls/ v tec???
- attitude check for all suby owners
- really confuesed help!
- Code 21
- xxr 513 's on Eg hatch
- Eg hatch nose bra??
- gsr full swap help
- Sticky This>>>> Ef-Eg-Ek Civic Service Manuals Stop Asking Me Now
- Strange electrical problem?
- low engine temp after rad install
- OBD2 SI Engine Harness...
- Helm Shop Manual vs. Service Manual
- TYPE R,SPOON,JASMA headers em1??
- Fuel Rail Help!!
- d16a6 with y8 head?
- delsol dash seats centerconsol, etc swap in to eg
- putting on a duckbill question on my ek..
- 94 hatchback stolen, need replacement parts
- d16z6 timing
- power steering with bseries
- how should I run my b20?
- skunk2 stage 2 cams.
- Please HELP!! ek window switch/regulator?? cant find any threads with my problem!!
- My resently stolen car
- Wire up side markers if youre bored !!!!
- can someone help me out ???
- what block to put on my car..??help please
- Loose clutch
- need help queston about injecters
- Fuel Pump Stays On
- spark
- Inflater for the Airbag??
- Radiator Buying Help!
- '93 Civic won't start
- ek4 front lips. civic type r lip or spoon?
- Interstate or Energizer battery??
- a/c bracket
- idle problem
- K swaping an EG
- wind shield help
- Helpp!!! Prop valve questions
- Pro-rata warranty??
- 92-00 hatch shells.
- Knocking noises
- Best place to purchase
- Civic help
- Head Gasket Replacement, in waaayy over my head.
