View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 99 B16A2 into 2000 Si (Canada D16Y8) Question
- Speedometer issues
- 97 Civic-LX: 4 Cyl;5-spd manny - NoCrankNoStart!
- Why do my two d16y7 hatchbacks get different gas mileage - 25 versus 40 mpg?
- more power
- 98 ek dx with check engine light. HELP
- Wrapping door panels, how much material?
- turning on ac shakes the sh1tt out of my civic?
- 99 Civic DX, a tale of two CELs
- New member, need A/C info '92 Civic VX
- D15b8 mini me swap
- Over Heating Issue!
- fixing a front bumper/fender bolt loop thing
- 96 ex b16 questions
- Can I put a catalytic converter from an 01 Civic lx in my 00 Civic?
- 94 del Sol Vtec, buy or pass
- $1400 Build Thread EG Hatchback
- Bushing for front lower motor mount?
- 92' civic, rack and pinion repair, or replace?
- jdm EK4 SIR steering wheel
- MAF sensor on a D16z6 intake
- bump stops, koni warranty
- fast blink signal
- d16 aftermarket cam gears
- 1996 Electric Issues-Dash/Windows/AC
- Frame advice please
- Loose windshield wiper switch
- D16y8 swap gone wrong!!! Advice anyone??
- Wheel Lug Nut Q:
- 96 Civic with knock sensor code P0325
- Overheating problem!
- Front Camber
- 96-00: Is the 3dr license plate trim moulding interchangable with the 2dr trunk?
- Brake light dont work
- Another A/C blowing warm
- 92 Civic - fuel pump won't run
- Questions about Head Gaskets
- 92 Civic Shifting Issues
- Baby on the way ! Big problem !
- 95 civic dx staying on problem?
- D16y8 with a z6 gasket set
- turbo d16y8 bogging issue
- 95 honda civic d15b7 vtec engine
- timing at 30'?? mpg
- header bolt size??
- main relay buzzing noise
- eg front end alignment issues.
- Please Help with exhaust rattle
- My civic jerks me
- RHD Options?
- 98 honda civic window help
- Jaydec11 build thread h2b content
- Knock sensor or bad barring
- d16y7/sohc MPG Let's discuss
- 95 Civic D16Y8; Starter gets stuck when hot.
- 1993 honda civic EG6 Tail Lights
- 94 Del Sol Si Won't Shift
- suspension troubleshooting
- American and Canadian Clusters can I swap?
- Bad A/C
- Need 99 civic dx engine wiring harness diagram/wire colors for plugs.
- 2000 civic HB high idle after putting back on manifold
- A/C works unless it is really hot outside
- eg help!
- 2000 Civic EX: Turns over but won't start after head gasket and timing belt replaced
- Suspension problems
- Mystery: Car sputters and stalls on hwy, but - later - drives just fine
- Need your help with wiring Hazard switch from 96 EDM to 99 USDM
- Will a b16 motor mount fit for a b20
- Civic DX 1995 not starting
- d16z6 gas mileage..
- '96 Civic EX - engine swapped - miss, code and trans
- On the hunt for OEM genuine honda fuel pump for '95 del sol
- Overheating Mystery???
- rear hatch stiffen (loud cabin noise)
- Distinguish OBD1 & 2
- Slipping clutch *Brand New*
- Camshaft Identification?
- 99 Civic EX Starter Not Engaging
- exhaust fitment help
- nonvtec mini me swap issue
- Quick question on squeaky brakes.
- Oil Pan Gasket Issue
- 1998 Honda Civic Vent Control Question
- 94 civic sputtering Help!
- smell of fuel in my garage
- Tapping noise under load driving me crazy
- Fujitsubo Exhaust
- Wheel bearing question
- hard to start when warm, main reply replace
- 93 eg with b16 axle clicking?
- (HELP) B16a block and head with 82mm pctx pistons.
- Map sensor questions!!
- 1999 Honda Civic Lx Horn Issues
- SLIM FAN QUESTION
- jdm b16 swap question
- Blue Recaro Srd
- Gauge interchangeable questions
- intake manifold problems
- AC pressure help
- Possible Addons?
- 97 Civic Ex - CEL Codes P1339 and P0301
- 99 b16 in 95 civic into 97 civic
- switched auto trans to standard?
- Is my headgasket blown?
- d16z6 tensioner question
- clutch slip issue
- 96 civic master cylinder question
- Heavy smell inside of EG cabin
- 94 Civic - Need radiator replacement
- Questions on rear motor mount for an EK
- Questions
- 99-00 civic fog lights fit on 94 civic bumper?
- My 96 D16Y8 non-vtech manual making strange noises at idle
- Reviews/Opinions on Tiger Japanese Auto Parts LTD
- 96 D16Y8 Hesitation On Acceleration, help.
- del sol lexan rear window legal?
- 92' civic d15b7 hard starting.
- Steering wheel practically pulled out of my hands when letting off the gas
- Swap and ecu questions
- 92 civic hatch obd0 d15 swap
- D16Y8 Fuel Injectors
- Eg vs integra steering wheel?
- neutral safety or interlock switch MISSING!?
- awd setup on civic???? need help
- 96-00 Civic cluster options?
- 00 civic si CHECK ENGINE LIGHT(HELP!!!)
- Clutch Dragging
- Wonder about this oil Leak
- Need help 93' dx hatch
- Assistance/input on cam selection
- Erratic Idle / Need help ASAP!!!
- vtec CEL wont clear.
- Radiator cap PSI?
- Multiple map sensors?
- ek b16 post mount on eg b series motor ?
- 94 Del Sol not starting sometimes after a short drive
- Rear Control Arms
- NO reading failed E-check
- explain 3 wire IAC valve
- Del Sol Acceleration Problem
- Honda OEM providers?
- Engine Mounts
- 1998 Honda Civic and strange waxy fluid?
- CEL code 9 and now a no start condition
- D16Z6 - got an oil leak
- AUTO VS MANUAL D16Y8's
- What to do with a z6 head?
- Where can I buy an OEM radiator support for a civic ek?
- is the pm9-2 91 head b7 or a6?
- P0302 and P1399 With Compression Loss
- 92-95 ex coupe Exhaust Question
- Windshield Q Hatch,Coupe,Sedan
- What does this plug go to??
- Lil' Blue
- won't engage v Tec
- Noise from blower motor (solved)
- gas gauge drops to empty when I start delsol
- D15B HEAD SWAP HELP
- Can't charge my A/C
- 99 ek radiator support
- 3 Alarm Key Fobs and only 1 works. 98 Civic
- integra subframe swap broken bolt help
- O2 sensor disconnect!
- Coolant Spraying Out Of Overflow Tank
- Rear Caliper question
- Which EK side skirts fit on a del Sol?
- Compression test 210-215-180-180
- IAT HELP!!!!!!
- engine harness main connector diagram?
- Overheat
- "Rattling" noise from drivers side rear brake.
- Skunk 2 pro series on D15B
- Car shudders and makes noises, dies, then won't start
- 2000 civic lx Catalytic Converter Swap
- o2 Sensor Mounting Depth
- AC problems
- Ctr red carpet cleaning
- D16y7 Manuel trans swap to d16y8???
- D16Y8 Rough running/start
- 2000 civic si, dies randomly, won't start for random amount of time
- faulty ignition coil??
- d16b2 distributor
- D16Y7/8 dizzy?
- question about identifying what cams are in my car
- 98 DX Cooling Issues
- Loud grinding noise when turning over to start car
- 99 GSR tranny/clutch issue?
- OEM o2 sensor doesnt fit cat
- D16Z6 mismatched cam gear
- Hatch is stuck... Need help
- 94 EX OBD1 CEL Issue
- D15B7 rough idle, smokes when warm
- EX vs DX engine harness (DX car)
- Re-pin 96-98 civic power door locks to 99-00
- DIY. How to install LED radiator fan indicator light on EG. (For Diagnostic purpose)
- Please Help :( 98 civic d16y8 distributor issues $5 paypal reward
- d16 block with b7 head
- New VSS Help!
- Y8 vs Y7 throttle body diameter
- 95 civic brain twister
- 95 Civic w/ D16Y8 & GSR TB. FITV adjustment needed?
- Lowering Springs?
- d15b/z6 mini me swap - Intake manifold and Emanage questions
- Clacking
- All dash lights out?
- b16a2 swap question about Intake Manifold
- b16a2 wiring and GSR cluster on a 96 ek
- main relay
- 99 Si Overheating issue- New WP, tstat, hoses, etc...
- D16Y8 has issues
- B16 block with nippon 82mm PCT pistons
- B16A2 VS D16Z6
- del sol - starts briefly and then turns off
- Correct Part#???
- advance timing?
- wheel question
- 95 Civic DX radiator leak. Is it possible to fix it w/o buying new?
- Gauge cluster bulb change to color.
- Help with b18b1 ac compressor
- Electrical problems !!
- Test drove civic, reverse was hard to find
- My smoke screen button works too good ! - My build thread.
- Fog light switch help
- Trans Cooler?
- Did a tune up on 98 Civic EX now it wont start
- Ceramic coat the muffler?
- Rough engine running and poor acceleration.
- Engine difference???
- A/C question....
- Gsr swap into ek help
- allways i hit boost the p/s belt gone
- AC Bog issues
- Subframe Rust Rot - need advice - 00 Civic 4dr
- A/C doesn't blow cold - high side gauge needle flutters
- Correct VSS replacement.
- FAQ: Is my head gasket blown? Overheating
- still over heating after head gasket instal
- 99 civic ex - constant brake noise when braking unless....
- lukes 2000 ex shave and tuck build
- What is damaged when AC compressor blows
- D16z6 parts question
- B16A Upgrades
- radiator hoses?
- Would a stock ecu and dsm 450's cause 3000+ idle when cold
- Car dies randomly when I stop
- car wont start
- Starter problems
- DOHC ZC Swap.. obd1-odb0? converstion??
