View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 GSR Short Block on Ebay NO Reserve
- Magnaflow
- What does everyone think of this car?
- import xpression
- KYB GR2 Or Bilstein's?
- r these real spoon bars...in this egg?
- 92 HATCH SI... (questions)
- Engine Swap & A/C in an EG... Possible or not?
- I FINALLY killed my Auto tranny, I am a happy camper.
- EG hatch owners?
- MSD Blaster Coil Resistance check, help evaluate.
- well bearing or caliper
- girl in need
- overheating at the track.....help!
- putting lowering springs on before getting aftermarket shocks on 02 civic ex.
- Anyone else find the stock 99-00 si clutch weak?
- How much is my car worth????
- Attn! 94 Civic EX needs help! What kind of exhaust?
- springs question
- can anybody tell me what could it be
- Need help with mount, we're stuck at this point
- ? DC JDM Header Vs. JDM ITR Header ?
- Apex I N1!! Custom piping or Catback?!?!
- Sucky luck...
- Help complete my 1st mod!
- Nice hatch
- rhd sir2
- mini me swap ecu?
- Mod Chips on Ebay
- New Pics Of VSM EJ6.....
- 92-95 Side mirror question?
- putting air bags back into 94 cx civic hatchback?
- Want a Y2K R ?
- 2002 Si Stereo Install
- Cool air intake
- sohc to sohc vtec HELP!!!!
- Timing advance DIYer's
- What can I do with my 2001 Civic EX??
- First ever mod...help
- Sac. peeps I need your help....
- can you put a better ecu in a dx hatch?
- TB install help, TPS related
- Help!! Fuel problem maybe.....
- My next wave of mods.
- JUN cams w/ stock valvetrain?
- type-r cams, stock valvetrain???
- how much to change EG axles with new ones?
- Drivetrain problems.. need help ASAP
- Whats the best injecters for civic si?
- spark plug stripped by shop?
- Type R camshafts
- Who makes a gas tank cover? Not from a cbr...but perhaps carbon fiber? Any pics or info is appreci
- will a 4dr front lip fit a 2dr or 3dr?
- Body prepping for paint...
- Car is back into the shop!
- When Do You Replace.....?
- I finally hit 12's with my SOHC!!!
- Sold my car...!!! Yay!!!
- best coilovers/springs for kyb agx
- Skyline front bumper...
- D15B vs B16A EF vs B18C5(ITR)
- Car not starting!!!Need Help!!!
- sohc timing question
- Valve adjustment questoins....
- Check Engine light comes on . . . car dies.
- 3 Quick questions...
- 92-95 hatch
- 99 Si Suspension question..
- GSR fuel pump in a 99 Civic?
- Anyone with a B18B swap?
- 95 head on a 00 sohc
- cpu swap??? obd!
- all u vx guys...front top sturt bar question
- DX trans on a D16Y8 any benefits?
- Tanabe Super Down Precedeo ?
- Engine Code Check
- 92 cx w/ B18c5?
- stiffer higher springs?
- anyone got an ecu lying around that they don't need?
- Need answer for p28 ecu Throwing codes
- Who makes these foglight inserts for the 92-95 civic? where can i get em'?
- 95 ex tranny in a 93 hatch dx, is it worth it?
- 3rd time at the track and a personal best time. Pics inside.
- Is there a way to make my 02 civic quick?
- hondamotorsonline.com
- cant find D16zg swap so...
- import...
- The Blue 4 door integra on TV.
- any probs with integra suspension parts on hatch?????
- what other bodys will have parts that will fit a 92 hatch???
- replacement parts for my project hatch: body
- Vtec Controller???
- act or clutch masters?
- Help. 240sx question but its general...
- Will 14"s fit on a 99 SI?
- CTR cams?
- will a 99 d16y8 tranny fit a 92 d15b7?????
- exhaust and header question?? answer soon!!!
- What's wrong with my side mirror?
- Which Swap?
- B&M shift stabilizer.....worth it?
- new HELP BADLY,,, my Funking car wont start
- Black smoke
- Low ass HP at the wheels: Why?
- Timing
- head gasket question
- Shaking Steering Wheel
- ram or c.a.i??
- pros and cons of landspeedracing's high flow cat converters
- ITR vs skunk2 valve springs and retainers
- obd2 b18c1
- Speedchannel email notifications, never miss Touring/GT races again.
- FS: JDM Integra Type R
- Smoke
- Were the 96-00 Coupes wired for ABS?
- need technical understanding
- looking for pics of h22 in civic 92-95
- anyone in South Florida know?
- 95 ecu diagram (s-afc)
- a general motor question...
- is this the evap purge valve?
- I just installed s afc controller
- kakimoto R exhaust Q's
- rsx type-s swap into a 02 civic.
- i got a problem with my tires rubbing ...need help
- Questions about milling my head...
- Wow ! ! !
- Would a 96+ EX iceman intake fit a 93 Si?
- white smoke
- Gonna sell it....
- dx hatch owners: do you really need the rear wiper?
- darton sleeve's
- Sway bar kit question? ( Suspension Techniques )
- HIN in atl
- Brake upgrade...
- FL.f/s 98 vtec d16y8 head $150.00
- Options for usdm B16 block....
- fuel additive s
- How do i make my car look like this? mugen kit for coupe?
- DING KING?? i know this is sort of old...
- Any Central Florida Honda-Tech guys up for a little meat ?
- Correct ECU
- stripped my car: fuel saver?
- somthin wrong with my chipped p28
- will a gsr shifter fit my 99 civic si linkage?
- predicted 1/4 times..
- HID's in stock eg light housing
- What is ur Compression Test Result??
- Del solrim weight
- $20,000 On a hatch ?
- What's your B16A header + b-pipe + exhaust setup?
- 2002 civic
- 95 civic injector's
- hey! i saw an Si lip from a 99' civic on an EG!
- :atten: Ek owners i got a question for you guys
- How do I put my "H" on my hood?
- Can somebody send me a stock drivers side washer nozzle??
- Opinions on skunk2 sway bar
- Stolen spoon EK recovered
- hood questions (stock hood)
- sunroof jerks?
- y8 t/b
- Axles: b20 in EK
- Radio turns on out of nowhere!
- ? difference between the ls brakes and gsr brakes
- 96 ex lip?
- replaced pads but braking sucks?
- what did you think about MTV street racing tonight?
- what headlight bulbs for 2002 civic?
- Anyone in AZ here that hates scammers/thieves?
- Good deal or not?
- NSX seats to trade.
- Where's a good place to get B16B's or JDM A's in cali?????
- 95 Civc lowering limit before camber plates
- 99 h22 :D
- Will a 1992 sohc non vtec cx motor fit into a 97 cx?
- Erattic Idle :(
- Anyone have an ES Oval on a 96-00 Civic coupe??
- whats the difference between a 99 DX Civic than an LX, the wiring from the car to the ECU.. Not the
- Brakes, suspension
- Guys, the JDM trend might be starting to fade
- How to install 3-piece mid wing ?!?! HELP...
- which cold air intake will fit?
- light weight wheel question
- Best header/exhaust setup for SiRII B16?
- OEM fog lights for 99/00 civic Si coupe
- got a ? on powder coating
- best head swap for a d15b7?
- Make my d16z6 faster
- NOT MY CAR!!!!! 92HatchW/JDM ITR headlight. So Dope Just So dope
- Interior Question 96-00
- 2000 Civic Si stolen and recovered... what should I check?
- where is the cheapest place I can get rear lower control arms for a eg?
- any from DFW area?
- ever carried a motor inside your civic>?
- calling all canadians...
- Tranny dilema?
- engine problems, tryin to get my eg runnin
- How do I protect my car?
- Bike rack on 00 hatch
- apexi s-afc
- D Series Transmission Quest. - DX - EX?
- Couple more Mini-Me Questions
- just received my KYB shocks and have a question
- Hatchback/Hybrid Meet?
- Gauge Cluster Install Q?
- What color rims for a white car???
- OEM gen5 Foglights... NOPE or yep?
- funny sound
- All B series blocks...........................
- Front bumper question!
- What can I expect from a ported and polished D15B7 head?
- Modifying stock seats
- need help with what motor to buy...?
- Locking lug nuts?
- ? ? ? What rims are these ? ? ?
- pic request
- can someone please run this vin for me? thanks
- New Pictures CTR ,ITR
- I need to find an early '90's Honda
- Coupon for Hot Import Nights in ATL
- who can get me a 2002 oem ctr body kit
- what should i be running with my b18c1 in my 98dxhtch?
- One Meelun Dollars OR a Suitable "LASER"
- Oil ?
- Are the power steering and altenator pulleys reverse thread?
- Who here has a 4 door civic?
- California Smog question
- HOw many people
- gsr rear brake conversion
- Dumb ? ...will ITR and GSR OEM strut bars fit 96+ EKs ?
- maaaaaaaaaaaaaaaaaaaaaaaaaan..........
- swap question (5th gen civic)
- Whats a 90 Civic Si with b16 w/ Jun cams, ported head..........worth??
- What will i need to fully built up a B16A2?
- my first ever mod ... finally ..
- This always boggled me...
- who makes 2.5" exhaust for 92 cx???
- aaaaaaaarrrrrrrrRRRRGGGGGHHHHHH
- what is the fastes u can go with a b16???
- okay....94+ Teg seats bolt in, yes?
- Check my ghetto window hahahaha
- Wheel Locks????
- dumb moment....DC2 seats bolt in, yes?
- JDM 4-2-1 header gains?
- Black wheels with Red polished lip??
- Sigh @ MTV
- What are u guys paying for insurance on a EG?
- Changed Fuel Filter...Now Car Won't Start
